查看: 2176|回复: 1
Virtuoso 安装GPDK后的仿真问题
发表于 2021-3-3 16:37:20 | 显示全部楼层 |阅读模式
小白刚刚安装好GPDK45,主要是用里面的NMOS管。
当时GPDK45是解压以后,通过library path editor安装的。
仿真失败,原因是:
Error found by spectre during circuit read-in.
    ERROR (SFE-23): "input.scs" 21: The instance `NM0' is referencing an undefined model or subcircuit, `gpdk045_nmos1v_lvt'. Either include the file containing the definition of `gpdk045_nmos1v_lvt', or define `gpdk045_nmos1v_lvt' before running the simulation.
请问各位是啥原因呀?
 楼主| 发表于 2021-3-3 16:58:23 | 显示全部楼层
在model library添加了路径以后,依然报错,回复是:Error found by spectre during circuit read-in.     ERROR (SFE-675): "/home/IC/Modellib/gpdk045_v_2_0/models/spectre/gpdk045.scs" 7: Illegal library definition found in netlist
GMT+8, 2025-12-26 20:27 , Processed in 0.011992 second(s), 3 queries , Gzip On, Redis On.
