 发表于 2021-3-4 14:44:18
显示全部楼层
| There is one case. I think you have this problem in your simualtion setup, so you may use some power source from analog library, like "vpluse" or "vpwl".
 In property, you need to specify "number of pairs of points" . You can change the number to bigger. If you set it before at higher number, but you lower the number now, you won't be able to see it. If you set it bigger, you can see it.
 When you copy the variables from schematic, Virtuoso will still copy those parameters.
