楼主: renzhangqiang3
PLL的matlab建模源代码
发表于 2009-1-6 17:27:15 | 显示全部楼层
xia le jiu yao ding
发表于 2009-1-24 13:09:54 | 显示全部楼层
Very good
发表于 2009-1-28 12:26:45 | 显示全部楼层
Thank you
发表于 2009-2-11 03:50:54 | 显示全部楼层
ddddddddddddddddd
发表于 2009-3-9 23:15:26 | 显示全部楼层
xiexie
发表于 2009-3-10 01:46:10 | 显示全部楼层
kan kan..
发表于 2009-3-10 08:28:44 | 显示全部楼层
关于附件的说明:
   Release R2006A - R2007A Compliant Analog and Mixed Signal Examples
   To install this collection of Analog and Mixed Signal examples, please do the following:
   1) Create a directory at the top level of a disk partition and name it AMS eg d:\ams  (it must be named AMS!)
   2) Unzip the AMS_R2006a-2007a.zip file into this directory.  As a result of this, seven subdirectories should be created.
   3) Open MATLAB and ADD the AMS directory top the TOP of your MATLAB path. You only need to add this one directory.
   4) Type AMS at the MATLAB command prompt and the Example Navigator will open.
   To run all of these examples, the following Release 14 products are required:
  MATLAB
      Signal Processing Toolbox
      RF Toolbox
      Communication Toolbox
  Simulink
      Signal Processing Blockset
      SimPower Systems
      RF Blockset
  NOTE: If you want to install this package in a directory other than "ams",  you will need to edit
  both the ams.m file and the AMS_sel.txt file.
  Dick Benson
  May 2007
发表于 2009-3-11 14:13:25 | 显示全部楼层
knakanknak
发表于 2009-3-13 14:53:43 | 显示全部楼层
博主,别老传错
发表于 2009-3-13 23:32:37 | 显示全部楼层
ding
GMT+8, 2025-12-21 02:49 , Processed in 0.018803 second(s), 4 queries , Gzip On, Redis On.
