楼主: FFFYY
求助cadence xcelium的license破解问题
发表于 2024-5-9 11:40:14 | 显示全部楼层
liruii 发表于 2024-5-8 15:10
大佬求问怎么解决的呀~我也是报错invalid license key
我是报错我评论的那个噢,你这个看着就是license用的不对
发表于 2024-5-9 14:36:10 | 显示全部楼层
换了好几个license  格式和内容看着也没有什么问题
发表于 2024-5-9 14:42:47 | 显示全部楼层
一部分license和报错信息如下  求懂的大佬帮忙看看不胜感激!
SERVER sanjose d4f5ef428974 27000
DAEMON cdslmd /homes/software/Liberate/bin/cdslmd
USE_SERVER
FEATURE 100 cdslmd 2100.000 permanent uncounted 7D741D9C17262421213F \
        VENDOR_STRING=UHDERM HOSTID=ANY vendor_info=31-dec-2015 \
        ISSUER=CDNS216dfa12b695947d596a697549785772 ISSUED=31-dec-2015 \
        SN=2015-12-31T08:18:28:248 SIGN2="1D84 3BBE D2A1 BDD6 E7A8 \
        3E13 2D98 42B8 003F 4B50 C1E3 8903 8FBE 3FB1 08BE 1067 749F \
        32B8 FEF9 F72B 33E6 C12F E4D4 9D11 7ECA 191F A9B5 4201 19DD \
        FD2C" V7.1_LK=5D54DD3C1B227D5A9A02
报错:
14:23:40 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
14:23:40 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
14:23:40 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /homes/software/Liberate/bin/license.dat
14:23:40 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /homes/software/Liberate/bin/license.dat
14:23:40 (lmgrd) (@lmgrd-SLOG@) ===============================================
14:23:40 (lmgrd) Starting vendor daemons ...
14:23:40 (lmgrd) Started cdslmd (internet tcp_port 35427 pid 35173)
14:23:40 (cdslmd) FlexNet Licensing version v11.15.1.0 build 225974 i86_lsb
CADENCE_INFO_MSG:         Cadence kit version: 12.11-p001
14:23:47 (cdslmd) SLOG: Summary LOG statistics is enabled.
14:23:47 (cdslmd) SLOG: FNPLS-INTERNAL-CKPT1
14:23:47 (cdslmd) SLOG: VM Status: 0
14:23:47 (cdslmd) SLOG: FNPLS-INTERNAL-CKPT5
14:23:47 (cdslmd) SLOG: TPM Status: 0
14:23:47 (cdslmd) SLOG: FNPLS-INTERNAL-CKPT6
14:23:47 (cdslmd) Invalid license key (inconsistent authentication code)
14:23:47 (cdslmd)         ==>FEATURE 100 cdslmd 2100.000 permanent uncounted 7D741D9C17262421213F \
14:23:47 (cdslmd)         ==>FEATURE 111 cdslmd 2100.000 permanent uncounted 6D14ADDCF29E1C6A3367 \
        SN=2015-12-31T08:18:28:248 SIGN2="098F 1D4B A45E 8A36 8B30 \
        48EC C7BE 85BA DEB5 00AF 1E35 E2FA 5D50 4DA2 B9C0 100D 7946 \
        B582 408E 3245 3442 6C1C 440B C12C D093 A56E 9211 7603 BEC1 \
        DAD1" V7.1_LK=3DB4ADFC9A921D6F04BE
14:23:48 (cdslmd) Invalid license key (inconsistent authentication code)
14:23:48 (cdslmd)         ==>FEATURE Innovus_PI_Opt cdslmd 2100.000 permanent uncounted \
        9D845DCC61457431BA31 VENDOR_STRING=UHD:PERM HOSTID=ANY \
        SN=2015-12-31T08:18:28:248 SIGN2="1E8C FA80 8C5C 06C5 838C \
        8C8A 0BD4 23C3 9069 6F0B 74E7 BAB6 F91E 40A9 EDEC 177D 327E \
        C21B 2DF2 58D8 C105 D649 9A97 3ED6 EFC2 0BC7 18A9 110F 3A44 \
        9482" V7.1_LK=CD24BD8CA4A51231E149
14:23:48 (cdslmd) License server system started on sanjose
14:23:48 (cdslmd) No features to serve, exiting
14:23:48 (cdslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
14:23:48 (lmgrd) cdslmd exited with status 36 (No features to serve)
14:23:48 (lmgrd) cdslmd daemon found no features.  Please correct
14:23:48 (lmgrd) license file and re-start daemons.
14:23:48 (lmgrd)
14:23:48 (lmgrd) This may be due to the fact that you are using
14:23:48 (lmgrd) a different license file from the one you expect.
发表于 2024-5-9 19:17:26 | 显示全部楼层
可能是破解的问题  你用这个pubkey重新破解一下试试
https://pan.baidu.com/s/1tsHPkt7TqJdnKHVAQc_A6A?pwd=2024
发表于 2024-5-9 21:10:31 | 显示全部楼层
https://pan.baidu.com/s/1tsHPkt7TqJdnKHVAQc_A6A? ...
求问下用这个要怎么破解呀  还有下载文件的时候浏览器提示恶意软件
发表于 2024-5-10 11:19:41 | 显示全部楼层
把pubkey_verify移动到你的安装目录下面,然后运行./pubkey_verify -y
发表于 2024-10-8 16:01:52 来自手机 | 显示全部楼层
请问一下,有大佬有jedai和versiumdebug的license 吗?
发表于 2025-1-10 17:38:26 | 显示全部楼层
有原始安装包的话,我这里可以patch
发表于 2025-1-10 18:35:27 | 显示全部楼层
eda工具安装流程
1.安装工具
2.eetop找最新的patch 方法。
2.2 猜测:所有eda-vendor都是用flexlm管理license,有一家可以patch,应该可以通杀所有eda-vendor(但是尽量少用patch)。
3.找到对应的license管理工具,在安装目录find,找到最新版本。
3.2.patch
3.3. https://alllicenseparser.com/engineering-db/flexlm/ 添加工具feature。
3.4.生成license。
4.启动测试。
发表于 2025-5-12 22:22:40 | 显示全部楼层
SOLEDADLXW 发表于 2022-4-20 18:42
Loading snapshot worklib.tb:v .................... Done
xmsim: *F,INTERR: INTERNAL EXCEPTION
Observe ...
兄弟,解决了吗,我也遇到了这个问题
GMT+8, 2025-12-22 05:31 , Processed in 0.017533 second(s), 3 queries , Gzip On, Redis On.
