查看: 3074|回复: 2
sentaurus license 确认问题,如何破解license?
发表于 2021-1-19 16:03:16 | 显示全部楼层 |阅读模式
[root@peacefulslt license]# sssverify license.dat
Integrity check report for license file "license.dat".
Report generated on 19-Jan-2021 (SCL_11.6)
Checking the integrity of the license file...
The SSS features are garbled.
All revenue keys ("SN=RK:..." on feature line) have been excluded.
Siteid: <No Site Id>, Server Hostid: 000c29ff6441, Issued on: N/A
License file integrity check FAILED!
This is an INVALID license file. You SHOULD NOT use this license file.
Please use the license file as received from Synopsys, Inc.
弄了好长时间,参照网络上的做法结果问题还是这一块儿,纠结。。。是license过期了吗,又该如何破解?寻求各位大神帮助....
发表于 2022-2-3 05:16:12 | 显示全部楼层
Have you solved this problem? I have the same
发表于 2023-8-3 18:55:02 | 显示全部楼层
解决了吗
GMT+8, 2025-12-20 07:17 , Processed in 0.012520 second(s), 3 queries , Gzip On, Redis On.
