查看: 4598|回复: 6
安装cadence ic618的奇怪问题,装上nvidia闭源显卡驱动之后启动报错
发表于 2020-11-11 20:27:17 | 显示全部楼层 |阅读模式
系统是ubuntu20 ,因为电脑是ryzen4800+2060所以只能装比较新版本的linux发行版,尝试过fedora和ubuntu。安装fedora32 33 和ubuntu20都遇到一个问题,装上显卡驱动之后ic618启动报错,但是不装nvidia显卡闭源驱动的话(ic618启动正常),外界屏幕又不能用,所以现在就是没法用外接显示器打开cadence。
终端报错如下
bao@bao:~/桌面$ virtuoso
sh: 1: ��k: not found
Segmentation fault (core dumped)
bao@bao:~/桌面$
checkSysConf报错如下:
[Copyright 2002-2018] Cadence Design Systems, Inc. All rights reserved.
This  program and online  documentation  may not be copied, modified,
re-published, uploaded,  executed, or  distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf:  Version 3.36 ====================
Operating System release details:
Red Hat Enterprise Linux release 6.12
Date information gathered: Wed Nov 11 07:10:58 EST 2020
Host Name ..............:  bao
Hostid .................:  7c787dcd
Operating System .......:  Linux / x86_64
OS Version .............:  Red Hat Enterprise Linux release 6.12
Kernel Version .........:  5.8.0-26-generic
Hardware Type ..........:  x86_64
Memory .................:  15480 Megabyte
CPU model ..............:  AMD Ryzen 7 4800H with Radeon Graphics
No. of CPUs ............:  16
Total Swap Space........:  2047 Megabyte
X Server ...............:
Patch Data file ........:  /home/bao/eda/cadence/IC618/share/patchData/Linux/x86_64/redhat/6.0WS/IC6.1.8
****************   Now verifying configuration     ****************
Validating Kernel requirements...
            Minimum             Installed                   Status    Info
            2.6.32-431.11.2     5.8.0-26-generic            PASS
Validating MEMORY requirements MegaByte ...
            2048MB    15480MB   PASS
Validating SWAP requirements in MegaByte ...
            4096MB    2047MB    FAIL
Validating DISPLAY requirements...
          8 planes          --- planes                  UNKNOWN Run script from console
          PseudoColor
Validating PACKAGE requirements.....31 to check
#   PACKAGE                Release    Build          Installed               Arch        Status  Info
1   glibc                  2.12       1.132          -                       i686        FAIL    Package not installed.
->  'GlibC-32bit'
2   glibc                  2.12       1.132          -                       x86_64      FAIL    Package not installed.
->  'GlibC'
3   elfutils-libelf        0.152      1              -                       i686        FAIL    Package not installed.
->  'Libelf-32bit'
4   elfutils-libelf        0.152      1              -                       x86_64      FAIL    Package not installed.
->  'Libelf Library'
5   ksh                    20120801   10             -                       x86_64      FAIL    Package not installed.
->  'ksh'
6   mesa-libGL             9.2        0.5            -                       i686        FAIL    Package not installed.
->  'Mesa libGL 32bit'
7   mesa-libGL             9.2        0.5            -                       x86_64      FAIL    Package not installed.
->  'Mesa libGL Library'
crashReport报错如下:
startdate:Wed Nov 11 07:10:36 2020
crashdate:Wed Nov 11 07:10:37 2020
appname:virtuoso
version(#)$CDS: virtuoso version 6.1.8-64b 10/01/2018 20:02 (ip-172-18-22-57) $
subversion:IC6.1.8-64b.83
mem:253353984 (total 16232296448)
memavail:16185404k (total 17949000k)
signal:SegFault(11)
user:bao
host:bao (x86_64)
osinux
osversion: 5.8.0-26-generic #27-Ubuntu SMP Wed Oct 21 22:29:16 UTC 2020 x86_64
xserver:The X.Org Foundation
xversion:11.0 (vendor release 12009000)
display::1
qtversion:5.9.1
signal_by:system
stack:libpthread.so.0:__restore_rt+0()
stack:libnvidia-glcore.so.455.38:+140512581821416()
stack:0x0x7fcba3d376c2:0x0x7fcba3d376c20x0x7fcba3d376c2
userenv:A__z="*SHLVL
userenv:CADENCE_DIR=/home/bao/eda/cadence/IC618
userenv:CADHOME=/home/bao/eda/cadence
userenv:CALIBRE_HOME=/opt/mentor/calibre2019/aoj_cal_2019.3_15.11
userenv:CDNS_QT5DIR=/home/bao/eda/cadence/IC618/tools/Qt/v5/64bit
userenv:CDS=/home/bao/eda/cadence/IC618
userenv:CDSDIR=/home/bao/eda/cadence/IC618
userenv:CDSHOME=/home/bao/eda/cadence/IC618
userenv:CDSROOT=/home/bao/eda/cadence/IC618
userenv:CDS_ARCH=lnx86
userenv:CDS_AUTO_64BIT=ALL
userenv:CDS_ENABLE_VMS=1
userenv:CDS_INST_DIR=/home/bao/eda/cadence/IC618
userenv:CDS_LANG=C
userenv:CDS_LC_MONETARY=en_US.UTF-8
userenv:CDS_LC_NUMERIC=en_US.UTF-8
userenv:CDS_LC_TIME=en_US.UTF-8
userenv:CDS_LIC_FILE=/home/bao/eda/cadence/license/license.dat
userenv:CDS_LIC_ONLY=1
userenv:CDS_LOAD_ENV=CWD
userenv:CDS_MPS_SESSION=virtuoso2693
userenv:CDS_Netlisting_Mode=Analog
userenv:CDS_ROOT=/home/bao/eda/cadence/IC618
userenv:CDS_SET_LOCALE=C
userenv:CDS_W3264_LIBPATH=/home/bao/eda/cadence/IC618/share/oa/lib/linux_rhel60_64/opt::/home/bao/eda/cadence/IC618/tools/dfII/lib/64bit:/home/bao/eda/cadence/IC618/tools/sev/lib/64bit:/home/bao/eda/cadence/IC618/tools/lib/64bit:/home/bao/eda/cadence/IC618/tools/lib:/home/bao/eda/cadence/IC618/tools/hdf5/lib/64bit::/home/bao/eda/cadence/IC618/tools/lz4/lib/64bit:/home/bao/eda/cadence/IC618/tools/inca/lib/64bit:/home/bao/eda/cadence/IC618/tools/Qt/v5/64bit/lib
userenv:COLORTERM=truecolor
userenvBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
userenvESKTOP_SESSION=ubuntu
userenvISPLAY=:1
userenv:GDMSESSION=ubuntu
userenv:GJS_DEBUG_OUTPUT=stderr
userenv:GJS_DEBUG_TOPICS=JS ERROR;JS LOG
userenv:GNOME_DESKTOP_SESSION_ID=this-is-deprecated
userenv:GNOME_SHELL_SESSION_MODE=ubuntu
userenv:GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/fd188c7b_4f89_4ac9_bde8_0c00d25900ae
userenv:GNOME_TERMINAL_SERVICE=:1.90
userenv:GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
userenv:GTK_IM_MODULE=fcitx
userenv:GTK_MODULES=gail:atk-bridge
userenv:HOME=/home/bao
userenv:IM_CONFIG_PHASE=1
userenvANG=C
userenvANGUAGE=zh_CN:en
userenv:LC_ADDRESS=en_US.UTF-8
userenv:LC_ALL=C
userenv:LC_IDENTIFICATION=en_US.UTF-8
userenv:LC_MEASUREMENT=en_US.UTF-8
userenv:LC_NAME=en_US.UTF-8
userenv:LC_PAPER=en_US.UTF-8
userenv:LC_TELEPHONE=en_US.UTF-8
userenv:LD_LIBRARY_PATH=/home/bao/eda/cadence/IC618/share/oa/lib/linux_rhel60_64/opt::/home/bao/eda/cadence/IC618/tools/dfII/lib/64bit:/home/bao/eda/cadence/IC618/tools/sev/lib/64bit:/home/bao/eda/cadence/IC618/tools/lib/64bit:/home/bao/eda/cadence/IC618/tools/lib:/home/bao/eda/cadence/IC618/tools/hdf5/lib/64bit::/home/bao/eda/cadence/IC618/tools/lz4/lib/64bit:/home/bao/eda/cadence/IC618/tools/inca/lib/64bit:/home/bao/eda/cadence/IC618/tools/Qt/v5/64bit/lib:/lib64:/home/bao/eda/cadence/IC618/tools/lib/64bit/Ubuntu
userenv:LESSCLOSE=/usr/bin/lesspipe %s %s
userenv:LESSOPEN=| /usr/bin/lesspipe %s
userenv:LOGNAME=bao
userenv:MGC_CALIBRE_LAYOUT_SERVER=bao:9189
userenv:MGC_CALIBRE_SAVE_ALL_RUNSET_VALUES=1
userenv:MGC_CALIBRE_SCHEMATIC_SERVER=bao:9199
userenv:MGC_HOME=/opt/mentor
userenv:MGC_LIB_PATH=/opt/mentor/calibre2019/aoj_cal_2019.3_15.11/lib
userenv:MGC_PDF_READER=evince
userenv:MGLS_LICENSE_FILE=/opt/mentor/license/license.dat
userenv:MMSIMHOME=/home/bao/eda/cadence/SPECTRE181
userenv:OA_BIT=64
userenv:OA_UNSUPPORTED_PLAT=linux_rhel60_64
userenvAPERSIZE=letter
userenvATH=/home/bao/eda/cadence/IC618/bin:/home/bao/eda/cadence/IC618/tools/bin/64bit:/home/bao/eda/cadence/IC618/tools/bin:/home/bao/eda/cadence/IC618/share/oa/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/bao/eda/cadence/IC618/tools/dfII/bin:/home/bao/eda/cadence/IC618/tools/plot/bin:/home/bao/eda/cadence/SPECTRE181/bin:/home/bao/eda/cadence/SPECTRE181/tools/relxpert/bin:/home/bao/eda/cadence/EXT151/bin:/opt/mentor/calibre2019/aoj_cal_2019.3_15.11/bin
userenvWD=/home/bao/
userenvRC_HOME=/home/bao/eda/cadence/EXT151
userenvRC_MOS_LW_PRECISION=Y
userenvT_ACCESSIBILITY=1
userenv:QT_IM_MODULE=ibus
userenv:QT_XCB_NO_XI2_MOUSE=1
userenv:SHELL=/bin/bash
userenv:SHLVL=3
userenv:SSH_AGENT_PID=2206
userenv:SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
userenv:TERM=xterm-256color
userenv:TSMC_CAL_DFM_PATH=/opt/PDKs/tsmc/CRNxxG/Calibre/lvs/DFM
userenv:USER=bao
userenv:USERNAME=bao
userenv:VTE_VERSION=6200
userenv:W3264_ENV=/home/bao/.kshrc
userenv:W3264_NO_HOST_CHECK=1
userenv:WINDOWPATH=2
userenv:XAUTHORITY=/run/user/1000/gdm/Xauthority
userenv:XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg
userenv:XDG_CURRENT_DESKTOP=ubuntu:GNOME
userenv:XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
userenv:XDG_MENU_PREFIX=gnome-
userenv:XDG_RUNTIME_DIR=/run/user/1000
userenv:XDG_SESSION_CLASS=user
userenv:XDG_SESSION_DESKTOP=ubuntu
userenv:XDG_SESSION_TYPE=x11
userenv:XMODIFIERS=@im=fcitx
userenv:_=*2671*/home/bao/eda/cadence/IC618/tools/dfII/bin/64bit/virtuoso
userenv:__DFII_INTEG_NC_PATH__=/home/bao/eda/cadence/IC618/tools/inca/bin/64bit
userenv:_dfII_bin_bit=/64bit
userenv:df2BaseVhdlin=/home/bao/eda/cadence/IC618
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdsDefTechLib':
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdsDefTechLib/cdsinfo.tag
cdslibinfo:    defines 'DMTYPE none'.
cdslibinfo:Info (cdsinfo): Library checking is off, CDSLIBRARY entries will not be used.
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdsDefTechLib/cdsinfo.tag
cdslibinfo:has a CDSLIBRARY entry defined.
cdslibinfo:    defines 'NAMESPACE libraryUnix'.
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/basic':
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/basic/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/basic/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths':
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/analogLib':
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/analogLib/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/analogLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/functional':
cdslibinfo:Info (cdsinfo): could not locate an entry for 'DMTYPE' in any cdsinfo.tag file.
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/functional/cdsinfo.tag
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/functional/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfLib':
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfLib/cdsinfo.tag
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfExamples':
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfExamples/cdsinfo.tag
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfExamples/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/ahdlLib':
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/ahdlLib/cdsinfo.tag
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/ahdlLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfTlineLib':
cdslibinfo:The cdsinfo.tag file at: /home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfTlineLib/cdsinfo.tag
cdslibinfo:/home/bao/eda/cadence/IC618/tools.lnx86/dfII/samples/artist/rfTlineLib/cdsinfo.tag
xdpyinfo:name of display:    :1
xdpyinfo:version number:    11.0
xdpyinfo:vendor string:    The X.Org Foundation
xdpyinfo:vendor release number:    12009000
xdpyinfo:X.Org version: 1.20.9
xdpyinfo:maximum request size:  16777212 bytes
xdpyinfo:motion buffer size:  256
xdpyinfo:bitmap unit, bit order, padding:    32, LSBFirst, 32
xdpyinfo:image byte order:    LSBFirst
xdpyinfo:number of supported pixmap formats:    7
xdpyinfo:supported pixmap formats:
xdpyinfo:    depth 1, bits_per_pixel 1, scanline_pad 32
xdpyinfo:    depth 4, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 8, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 15, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 16, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 24, bits_per_pixel 32, scanline_pad 32
xdpyinfo:    depth 32, bits_per_pixel 32, scanline_pad 32
xdpyinfo:keycode range:    minimum 8, maximum 255
xdpyinfo:focus:  window 0x380000b, revert to Parent
xdpyinfo:number of extensions:    30
xdpyinfo:    BIG-REQUESTS
xdpyinfo:    Composite
xdpyinfo:    DAMAGE
xdpyinfo:    DOUBLE-BUFFER
xdpyinfo:    DPMS
xdpyinfo:    DRI2
xdpyinfo:    GLX
xdpyinfo:    Generic Event Extension
xdpyinfo:    MIT-SCREEN-SAVER
xdpyinfo:    MIT-SHM
xdpyinfo:    NV-CONTROL
xdpyinfo:    NV-GLX
xdpyinfo:    Present
xdpyinfo:    RANDR
xdpyinfo:    RECORD
xdpyinfo:    RENDER
xdpyinfo:    SECURITY
xdpyinfo:    SHAPE
xdpyinfo:    SYNC
xdpyinfo:    X-Resource
xdpyinfo:    XC-MISC
xdpyinfo:    XFIXES
xdpyinfo:    XFree86-DGA
xdpyinfo:    XFree86-VidModeExtension
xdpyinfo:    XINERAMA
xdpyinfo:    XINERAMA
xdpyinfo:    XInputExtension
xdpyinfo:    XKEYBOARD
xdpyinfo:    XTEST
xdpyinfo:    XVideo
xdpyinfo:default screen number:    0
xdpyinfo:number of screens:    1
xdpyinfo:screen #0:
xdpyinfo:  dimensions:    3840x2160 pixels (602x331 millimeters)
xdpyinfo:  resolution:    162x166 dots per inch
xdpyinfo:  depths (7):    24, 1, 4, 8, 15, 16, 32
xdpyinfo:  root window id:    0x20d
xdpyinfo:  depth of root window:    24 planes
xdpyinfo:  number of colormaps:    minimum 1, maximum 1
xdpyinfo:  default colormap:    0x20
xdpyinfo:  default number of colormap cells:    256
xdpyinfo:  preallocated pixels:    black 0, white 16777215
xdpyinfo:  options:    backing-store WHEN MAPPED, save-unders NO
xdpyinfo:  largest cursor:    256x256
xdpyinfo:  current input event mask:    0xda0033
xdpyinfo:    KeyPressMask             KeyReleaseMask           EnterWindowMask
xdpyinfo:    LeaveWindowMask          StructureNotifyMask      SubstructureNotifyMask
xdpyinfo:    SubstructureRedirectMask PropertyChangeMask       ColormapChangeMask
xdpyinfo:  number of visuals:    132
xdpyinfo:  default visual id:  0x21
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x21
xdpyinfo:    class:    TrueColor
xdpyinfo:    depth:    24 planes
xdpyinfo:    available colormap entries:    256 per subfield
xdpyinfo:    red, green, blue masks:    0xff0000, 0xff00, 0xff
xdpyinfo:    significant bits in color specification:    11 bits
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x22
xdpyinfo:    class:    DirectColor
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x24
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x25
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x26
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x27
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x28
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x29
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x30
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x31
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x32
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x33
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x34
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x35
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x36
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x37
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x38
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x39
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x3a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x3b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x3c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x3d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x3e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x3f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x40
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x41
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x42
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x43
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x44
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x45
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x46
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x47
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x48
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x49
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x4a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x4b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x4c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x4d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x4e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x4f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x50
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x51
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x52
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x53
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x54
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x55
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x56
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x57
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x58
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x59
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x5a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x5b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x5c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x5d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x5e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x5f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x60
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x61
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x62
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x63
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x64
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x65
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x66
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x67
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x68
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x69
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x6a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x6b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x6c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x6d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x6e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x6f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x70
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x71
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x72
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x73
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x74
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x75
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x76
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x77
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x78
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x79
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x23
xdpyinfo:    depth:    32 planes
xdpyinfo:    significant bits in color specification:    8 bits
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x7a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x7b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x7c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x7d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x7e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x7f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x80
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x81
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x82
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x83
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x84
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x85
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x86
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x87
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x88
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x89
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x8a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x8b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x8c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x8d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x8e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x8f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x90
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x91
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x92
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x93
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x94
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x95
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x96
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x97
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x98
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x99
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x9a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x9b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x9c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x9d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x9e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x9f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa0
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa1
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa2
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa3
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa4
发表于 2020-11-12 10:06:05 | 显示全部楼层
N家的显卡和AMD的CPU? 为啥不用A家的显卡? 自己家的人吵架的概率要小很多.
这应该是主要原因
发表于 2020-11-12 10:07:08 | 显示全部楼层
N和A冤家路窄, 不给你下点套那就奇了怪了
 楼主| 发表于 2020-11-14 17:11:35 | 显示全部楼层
这应该是主要原因 ...
我感觉也是,给这个本子装cadence搞得心力交瘁
 楼主| 发表于 2021-1-20 21:44:43 | 显示全部楼层
NVIDIA显卡驱动问题,一路更新下来用最新的没报错了
发表于 2021-5-12 17:35:15 | 显示全部楼层
为了装Cadence,在下用的RHEL,,yum仓库配置,手动安装显卡驱动,真的崩溃了
F**k
 楼主| 发表于 2021-5-26 11:04:27 | 显示全部楼层
F**k ...
老黄这个没办法,我的装了nvidia显卡驱动外接显示器卡卡的
GMT+8, 2025-12-18 22:20 , Processed in 0.028350 second(s), 4 queries , Gzip On, Redis On.
