查看: 4168|回复: 4
[求助] VCS2018安装问题
发表于 2020-10-26 12:53:44 | 显示全部楼层 |阅读模式
系统:centos6.10
gcc版本inux version 2.6.32-754.33.1.el6.x86_64 (mockbuild@x86-02.bsys.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-23) (GCC) ) #1 SMP Tue Aug 25 15:29:40 UTC 2020
环境变量设置:
#vcs
export VCS_HOME=/tools/synopsys/vcs_mk
#dve
export DVE_HOME=/tools/synopsys/vcs_mk/gui/dve
export PATH=$PATHDVE_HOME/binVCS_HOME/bin
#scl
export PATH=$PATH:/tools/synopsys/scl/linux64/bin
#license
export SNOSLMD_LICENSE_FILE="/tools/synopsys/license/Synopsys.dat"
export LM_LICENSE_FILE="/tools/synopsys/license/Synopsys.dat"
export VCS_ARCH_OVERRIDE=linux
export VCS_TARGET_ARCH=amd64
问题:dve命令能够正常启动。用vcs编译.v文件出现问题,如下:
$ vcs add4.v add8.v addertb.v fa.v
/tools/synopsys/vcs_mk/bin/vcs: line 3312: dc: command not found
                         Chronologic VCS (TM)
       Version O-2018.09-SP2_Full64 -- Mon Oct 26 13:03:30 2020
               Copyright (c) 1991-2018 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Parsing design file 'add4.v'
Parsing design file 'add8.v'
Parsing design file 'addertb.v'
Parsing design file 'fa.v'
Top Level Modules:
       addertb
No TimeScale specified
Starting vcs inline pass...
1 module and 0 UDP read.
recompiling module addertb
rm -f _csrc*.so pre_vcsobj_*.so share_vcsobj_*.so
if [ -x ../simv ]; then chmod -x ../simv; fi
g++  -o ../simv    -Wl,-rpath-link=./ -Wl,-rpath='$ORIGIN'/simv.daidir/ -Wl,-rpath=./simv.daidir/ -Wl,-rpath='$ORIGIN'/simv.daidir//scsim.db.dir  -rdynamic  -Wl,-rpath=/tools/synopsys/vcs_mk/linux64/lib -L/tools/synopsys/vcs_mk/linux64/lib   objs/amcQw_d.o   _13314_archive_1.so  SIM_l.o       rmapats_mop.o rmapats.o rmar.o rmar_nd.o  rmar_llvm_0_1.o rmar_llvm_0_0.o          -lzerosoft_rt_stubs -lvirsim -lerrorinf -lsnpsmalloc -lvfs    -lvcsnew -lsimprofile -luclinative /tools/synopsys/vcs_mk/linux64/lib/vcs_tls.o   -Wl,-whole-archive -lvcsucli -Wl,-no-whole-archive          /tools/synopsys/vcs_mk/linux64/lib/vcs_save_restore_new.o -ldl  -lc -lm -lpthread -ldl
../simv up to date
然后./simv就出问题了。
为什么会出现我标红的地方,网上搜了很多一直解决不了,希望论坛大佬帮小弟看看,怎么解决?
 楼主| 发表于 2020-10-26 17:09:08 | 显示全部楼层
问题已解决,license问题
发表于 2020-10-30 09:25:23 | 显示全部楼层
请问有软件安装包吗?方便交流下安装心得吗?
发表于 2021-12-8 09:31:07 | 显示全部楼层
哥哥你用的哪个crack。发个链接可以
发表于 2021-12-8 09:57:16 | 显示全部楼层
相同的问题,哥给个crack的链接吧,找了很久没找到对的
GMT+8, 2025-12-22 03:41 , Processed in 0.014930 second(s), 3 queries , Gzip On, Redis On.
