查看: 5429|回复: 10
AWR Design Environment with Analyst v15.01 x64
发表于 2020-9-12 10:42:42 | 显示全部楼层 |阅读模式
NI AWR Design Environment v15 introduces numerous innovations in design flow management and simulation, supporting monolithic microwave integrated circuit (MMIC), RFIC, multi-chip module and printed circuit board (PCB) technologies. Simulation capabilities have been expanded within the Microwave Office APLAC harmonic balance (HB) and Visual System Simulator (VSS) system-level simulation engines and speed improvements have been made to both its AXIEM planar 3D and Analyst arbitrary 3D electromagnetic (EM) solvers.
Design automation and simulation have been enhanced for multi-chip modules, with greater support for multi-technology process design kits (PDKs) within a single project, new support for OpenAccess (schematic) databases and APLAC co-simulation support for Spectre RFIC netlists, as well as simplified EM layout and port creation. For PCB design, a new import wizard supports ODB++ and IPC2851 databases to provide interoperability with mainstream third-party PCB layout tools. New layout editing capabilities have also been added, along with simplified multi-technology management. Furthermore, the new EM Socket II architecture within V13 offers improved third-party EM simulation flows for AWR Connected partner solutions from ANSYS, CST and Sonnet, giving designers access to alternate EM simulators within NI AWR Design Environment.
V15 addresses specific system requirements with highly accurate simulated RF front-end component measurements provided through new communication libraries for 5G candidate modulation waveforms and phased-array behavioral model enhancements. RF power amplifier designers can now use the system-level load-pull analysis in VSS to generate contours for communication performance metrics such as adjacent channel power ratio (ACPR) and error vector magnitude (EVM). RF filter designers can take advantage of new capabilities in the iFilter synthesis tool to accelerate their product development and designers of passive and control components such as transformers, couplers and mixers can benefit from the new synthesis capabilities and powerful new optimization methods using proprietary genetic algorithms for more robust designs.
If you are interested in the full software AWR Design Environment and Analyst v15.01 then do well to contact  fast.forever24@gmail.com
发表于 2020-12-8 10:45:11 | 显示全部楼层
你有V15.03的license文件吗?
发表于 2020-12-8 13:57:21 | 显示全部楼层
看看吧。
发表于 2021-1-21 09:19:06 | 显示全部楼层
楼主不够意思
发表于 2021-1-23 00:24:00 | 显示全部楼层
我拿SONNET 17.52 和你换咋样?
发表于 2021-1-30 04:40:09 | 显示全部楼层
有lic吗
发表于 2021-4-16 15:05:00 | 显示全部楼层
资源上传呗,共享一下
发表于 2021-4-30 13:04:28 | 显示全部楼层
现在有v15的lic了吗
发表于 2021-8-1 14:20:20 | 显示全部楼层
我有15.04
发表于 2023-9-29 08:57:33 | 显示全部楼层
thanks
GMT+8, 2025-12-25 23:11 , Processed in 0.026887 second(s), 6 queries , Gzip On, Redis On.
