查看: 5311|回复: 17
[资料] New Fractional Charge pump idea (Research paper 2020)
发表于 2020-8-24 15:06:45 | 显示全部楼层 |阅读模式
A Fully-Integrated Efficient Power Management System for Micro-Scale Biomedical Applications
A new fractional charge pump that can be used for energy harvesting applications
Abstract This paper presents a fully integrated power management system suited for biomedical implanted devices. The proposed system employs a reconfigurable capacitor-based step-up DC-DC converter. The proposed DC-DC converter can provide fractional voltage conversion ratio (VCR) in a step of 0.25 to support wide input range from 0.4-1.2 V providing a constant output voltage of 1.6 V. The system efficiency is optimized using a real-time monitoring for the input current supplied to the DC-DC converter. This allows the system, using a control sequence, to adaptively optimize the number of stages and switching frequency that will provide the required constant output voltage while maintaining optimum efficiency. The proposed system is designed using a 180nm CMOS technology. Simulation results show that the proposed system provides peak efficiency of 78.1%.
Researchgate link
https://www.researchgate.net/publication/343339049_A_Fully-Integrated_Efficient_Power_Management_System_for_Micro-Scale_Biomedical_Applications
IEEE Link
https://ieeexplore.ieee.org/document/9152496
发表于 2020-8-24 21:29:35 | 显示全部楼层
sesesesese
A Fully-Integrated Efficient Power Management System for Micro-Scale Biomedical .pdf
2.63 MB, 下载次数: 91 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2020-8-25 06:26:17 | 显示全部楼层
kankan
发表于 2020-8-25 07:47:45 | 显示全部楼层
感谢
发表于 2020-8-25 20:16:39 | 显示全部楼层
谢谢分享
发表于 2020-9-13 12:49:25 | 显示全部楼层
发表于 2020-9-13 12:53:14 | 显示全部楼层
 楼主| 发表于 2021-1-8 19:02:02 | 显示全部楼层
Thank you
发表于 2021-1-9 10:22:53 | 显示全部楼层
感谢
发表于 2021-1-15 13:47:30 | 显示全部楼层
kankan ennn
GMT+8, 2025-12-13 23:10 , Processed in 0.027789 second(s), 4 queries , Gzip On, Redis On.
