楼主: 龚_利90
[资料] New Fractional Charge pump idea (Research paper 2020)
发表于 2021-1-15 14:29:57 | 显示全部楼层
谢谢分享
发表于 2021-3-2 15:12:51 | 显示全部楼层
beauty
发表于 2021-3-2 21:01:38 | 显示全部楼层
Thanks for sharing
 楼主| 发表于 2021-8-16 12:37:19 | 显示全部楼层
A Fully-Integrated Efficient Power Management System for Micro-Scale Biomedical Applications
A new fractional charge pump that can be used for energy harvesting applications
Abstract This paper presents a fully integrated power management system suited for biomedical implanted devices. The proposed system employs a reconfigurable capacitor-based step-up DC-DC converter. The proposed DC-DC converter can provide fractional voltage conversion ratio (VCR) in a step of 0.25 to support wide input range from 0.4-1.2 V providing a constant output voltage of 1.6 V. The system efficiency is optimized using a real-time monitoring for the input current supplied to the DC-DC converter. This allows the system, using a control sequence, to adaptively optimize the number of stages and switching frequency that will provide the required constant output voltage while mAIntaining optimum efficiency. The proposed system is designed using a 180nm CMOS technology. Simulation results show that the proposed system provides peak efficiency of 78.1%.
发表于 2021-8-16 17:55:40 | 显示全部楼层
Interesting
发表于 2022-1-26 16:07:07 | 显示全部楼层
新颖的论文,多谢楼主
发表于 2022-1-26 22:15:40 | 显示全部楼层
:victory:
发表于 2025-6-24 10:29:11 | 显示全部楼层
谢谢分享
GMT+8, 2025-11-1 11:39 , Processed in 0.020195 second(s), 3 queries , Gzip On, Redis On.
