查看: 2756|回复: 3
[求助] Can't locate a C/C++ compiler for compilation of DPI
发表于 2020-8-13 16:01:03 | 显示全部楼层 |阅读模式
questasim64_10.6c
# vsim -c -sv_lib D:/questasim64_10.6c/uvm-1.2/win64/uvm_dpi work.top -novopt
# Start time: 16:00:18 on Aug 13,2020
# ** Warning: (vsim-8891) All optimizations are turned off because the -novopt switch is in effect. This will cause your simulation to run very slowly. If you are using this switch to preserve visibility for Debug or PLI features please see the User's Manual section on Preserving Object Visibility with vopt.
# Refreshing D:/uvm/uvm_game/0813/work.top
# Loading sv_std.std
# Loading mtiUvm.uvm_pkg
# Loading work.top
# Refreshing D:/uvm/uvm_game/0813/work.dut_if
# Loading work.dut_if
# Loading work.dut
# Loading mtiUvm.questa_uvm_pkg
# ** Fatal: (vsim-7019) Can't locate a C/C++ compiler for 'Exportwrapper Compilation'.
# FATAL ERROR while loading design
# Error loading design
求助 怎么解决
发表于 2025-2-2 18:58:38 | 显示全部楼层
可能是因为缺少编译器支持C的编译,下载编译器解压后直接放在Questasim的安装目录即可。
发表于 2025-2-2 19:09:36 | 显示全部楼层
安装gcc可以看这篇帖子求助,求好心人上传questasim_gcc - EDA资源使用讨论 - EETOP 创芯网论坛 (原名:电子顶级开发网) -
发表于 2025-2-2 19:21:48 | 显示全部楼层
不想下载的这边也有直接下好了的
gcc-4.5.0-mingw64vc12.7z
20.03 MB, 下载次数: 15 , 下载积分: 资产 -7 信元, 下载支出 7 信元
GMT+8, 2025-12-24 02:56 , Processed in 0.017195 second(s), 5 queries , Gzip On, Redis On.
