楼主: niuyin
ADC-oversample专题---包括Understanding,top-down等6本
 楼主| 发表于 2007-12-3 10:49:46 | 显示全部楼层
Design of Low-Voltage Low-Power Delta-Sigma ADC part3
Design of LV LP Delta-Sigma ADC.part3.rar
4.77 MB, 下载次数: 578 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2007-12-3 10:51:31 | 显示全部楼层
ZHENSHI TAI HAO
 楼主| 发表于 2007-12-3 10:51:38 | 显示全部楼层
Design of Low-Voltage Low-Power Delta-Sigma ADC part4
Design of LV LP Delta-Sigma ADC.part4.rar
2.85 MB, 下载次数: 499 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-12-3 10:52:56 | 显示全部楼层
Design of Low-Voltage Low-Power CMOS Delta-Sigma A/D Converters investigates the feasibility of designing Delta-Sigma Analog to Digital Converters for very low supply voltage (lower than 1.5V) and low power operation in standard CMOS processes. The chosen technique of implementation is the Switched Opamp Technique which provides Switched Capacitor operation at low supply voltage without the need to apply voltage multipliers or low VtMOST devices.
A method of implementing the classic single loop and cascaded Delta-Sigma modulator topologies with half delay integrators is presented. Those topologies are studied in order to find the parameters that maximise the performance in terms of peak SNR. Based on a linear model, the performance degradations of higher order single loop and cascaded modulators, compared to a hypothetical ideal modulator, are quantified.
An overview of low voltage Switched Capacitor design techniques, such as the use of voltage multipliers, low VtMOST devices and the Switched Opamp Technique, is given. An in-depth discussion of the present status of the Switched Opamp Technique covers the single-ended Original Switched Opamp Technique, the Modified Switched Opamp Technique, which allows lower supply voltage operation, and differential implementation including common mode control techniques.
The restrictions imposed on the analog circuits by low supply voltage operation are investigated. Several low voltage circuit building blocks, some of which are new, are discussed. A new low voltage class AB OTA, especially suited for differential Switched Opamp applications, together with a common mode feedback amplifier and a comparator are presented and analyzed.
As part of a systematic top-down design approach, the non-ideal charge transfer of the Switched Opamp integrator cell is modeled, based upon several models of the main opamp non-ideal characteristics. Behavioral simulations carried out with these models yield the required opamp specifications that ensure that the intended performance is met in an implementation.
A power consumption analysis is performed. The influence of all design parameters, especially the low power supply voltage, is highlighted. Design guidelines towards low power operation are distilled.
Two implementations are presented together with measurement results. The first one is a single-ended implementation of a Delta-Sigma ADC operating with 1.5V supply voltage and consuming 100 &mgr;W for a 74 dB dynamic range in a 3.4 kHz bandwidth. The second implementation is differential and operates with 900 mV. It achieves 77 dB dynamic range in 16 kHz bandwidth and consumes 40 &mgr;W.
Design of Low-Voltage Low-Power CMOS Delta-Sigma A/D Converters is essential reading for analog design engineers and researchers.
发表于 2007-12-3 10:53:00 | 显示全部楼层
ADFASFADSF
 楼主| 发表于 2007-12-3 10:54:47 | 显示全部楼层
大家觉得可以的帮顶起来啊
有新的资料我会陆续更新在这边的
发表于 2007-12-3 12:14:37 | 显示全部楼层
谢谢楼主了.
发表于 2007-12-3 13:22:14 | 显示全部楼层
好事扫描版的吧?看起来有些费劲,不过还是感谢楼主分享!!
发表于 2007-12-3 13:27:15 | 显示全部楼层
太感谢了啊哈
发表于 2007-12-3 13:38:48 | 显示全部楼层
真是太好了
GMT+8, 2025-12-29 06:16 , Processed in 0.023987 second(s), 6 queries , Gzip On, Redis On.
