查看: 3836|回复: 3
[求助] tie—off cell
发表于 2020-7-24 19:29:40 | 显示全部楼层 |阅读模式
请问大佬们,tie-off cell 具体是个什么东西,后端小白只了解 tie-high和tie-low
发表于 2020-7-24 22:46:50 | 显示全部楼层
https://www.edaboard.com/threads/whats-the-logical-tie-off-cells-in-soc-encounte.108904/
Tie-off cells provide ESD protected logic levels '1' and '0' to be used for connecting transistor gates.
the transistor gates in a design may be required to connect logic '1' and logic '0' permanently, ie VDD and VSS logic levels, It is usually tapped from near by Power lines.
But to ensure the Transistor gate recieves only ESD protected signal, the Tie-off cells are placed between these gates and power line.
These cells are part of standard cell library.soc encounter has the option for connecting Tie-off cells to the design.
 楼主| 发表于 2020-7-25 09:17:24 | 显示全部楼层
Tie-off cel ...
thanks very much,best wish
发表于 2021-12-24 14:36:09 | 显示全部楼层
thanks
GMT+8, 2025-12-15 12:32 , Processed in 0.014663 second(s), 3 queries , Gzip On, Redis On.
