查看: 3534|回复: 2
System Design with System C
发表于 2007-12-1 00:59:07 | 显示全部楼层 |阅读模式
Book Title: System Design with System C
by Thorsten Gr?tker, Stan Liao (Snopsys, Inc)
and Grant Martin, Stuart Swan (Cadence Design Systems, Inc)
Published by Kluwer Academic 2002
Book Description:
The emergence of the system-on-chip (SoC) era is creating many new challenges at all stages of the design process. Engineers are reconsidering how designs are specified, partitioned and verified. With systems and software engineers programming in C/C++ and their hardware counterparts working in hardware description languages such as VHDL and Verilog, problems arise from the use of different design languages, incompatible tools and fragmented tool flows. Momentum is building behind the SystemC language and modeling platform as the best solution for representing functionality, communication, and software and hardware implementations at various levels of abstraction. The reason is clear: increasing design complexity demands very fast executable specifications to validate system concepts, and only C/C++ delivers adequate levels of abstraction, hardware-software integration, and performance. System design today also demands a single common language and modeling foundation in order to make interoperable system--level design tools, services and intellectual property a reality. SystemC is entirely based on C/C++ and the complete source code for the SystemC reference simulator can be freely downloaded from www.systemc.org and executed on both PCs and workstations. System Design and SystemC provides a comprehensive introduction to the powerful modeling capabilities of the SystemC language, and also provides a large and valuable set of system level modeling examples and techniques. Written by experts from Cadence Design Systems, Inc. and Synopsys, Inc. who were deeply involved in the definition and implementation of the SystemC language and reference simulator, this book will provide you with the key concepts you need to be successful with SystemC. System Design with SystemC thoroughly covers the new system level modeling capabilities available in SystemC 2.0 as well as the hardware modeling capabilities available in earlier versions of SystemC. designed and implemented the SystemC language and reference simulator, this book will provide you with the key concepts you need to be successful with SystemC. System Design with SystemC will be of interest to designers in industry working on complex system designs, as well as students and researchers within academia. All of the examples and techniques described within this book can be used with freely available compilers and debuggers &endash; no commercial software is needed. Instructions for obtaining the free source code for the examples obtained within this book are included in the first chapter.
Book Info:
Provides a comprehensive introduction to the powerful modern capabilities of the System C language and also provides a large and valuable set of system modeling examples and techniques.
Please refer to :
http://www.amazon.com/System-Design-SystemC-Thorsten-Gr%F6tker/dp/1402070721
DownloadLink: http://rapidshare.com/files/73250754/System_Design_with_SystemC.pdf
发表于 2007-12-1 09:50:39 | 显示全部楼层
GOOD,RS就是好,如果有时间的话慢慢拖。
 楼主| 发表于 2007-12-5 19:07:31 | 显示全部楼层
免费下载,欲下从速
GMT+8, 2025-12-26 01:34 , Processed in 0.020143 second(s), 5 queries , Gzip On, Redis On.
