查看: 8734|回复: 3
[need help] Synopsys license problem
发表于 2020-6-17 19:20:56 | 显示全部楼层 |阅读模式
我在使用synopsys许可证时遇到问题。
如果执行finesim,sx等,则会执行它们。 但是它运行得很晚。
18:56:21 (lmgrd) -----------------------------------------------
18:56:21 (lmgrd)   Please Note:
18:56:21 (lmgrd)
18:56:21 (lmgrd)   This log is intended for debug purposes only.
18:56:21 (lmgrd)   In order to capture accurate license
18:56:21 (lmgrd)   usage data into an organized repository,
18:56:21 (lmgrd)   please enable report logging. Use Flexera's
18:56:21 (lmgrd)   software license administration  solution,
18:56:21 (lmgrd)   FlexNet Manager, to  readily gain visibility
18:56:21 (lmgrd)   into license usage data and to create
18:56:21 (lmgrd)   insightful reports on critical information like
18:56:21 (lmgrd)   license availability and usage. FlexNet Manager
18:56:21 (lmgrd)   can be fully automated to run these reports on
18:56:21 (lmgrd)   schedule and can be used to track license
18:56:21 (lmgrd)   servers and usage across a heterogeneous
18:56:21 (lmgrd)   network of servers including Windows NT, Linux
18:56:21 (lmgrd)   and UNIX.
18:56:21 (lmgrd)
18:56:21 (lmgrd)
18:56:21 (lmgrd)
18:56:21 (lmgrd) Server's System Date and Time: Wed Jun 17 2020 18:56:21 CST
18:56:21 (lmgrd) SLOG: Summary LOG statistics is enabled.
18:56:21 (lmgrd) FlexNet Licensing (v11.16.6.0 build 260203 x64_lsb) started on svr1 (linux) (6/17/2020)
18:56:21 (lmgrd) Copyright (c) 1988-2019 Flexera. All Rights Reserved.
18:56:21 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
18:56:21 (lmgrd) License file(s): /user/eda/license/synopsys/svr1.dat
18:56:21 (lmgrd) lmgrd tcp-port 27000
18:56:21 (lmgrd) (@lmgrd-SLOG@) ===============================================
18:56:21 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
18:56:21 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Jun 17 2020 18:56:21 CST
18:56:21 (lmgrd) (@lmgrd-SLOG@) PID: 2711
18:56:21 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.16.6.0 build 260203 x64_lsb ( build 260203 (ipv6))
18:56:21 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
18:56:21 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
18:56:21 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
18:56:21 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
18:56:21 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /user/eda/license/synopsys/svr1.dat -l /tmp/s.log
18:56:21 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /user/eda/license/synopsys/svr1.dat
18:56:21 (lmgrd) Starting vendor daemons ...
18:56:21 (lmgrd) Started snpslmd (internet tcp_port 51842 pid 2717)
18:56:21 (snpslmd) FlexNet Licensing version v11.16.6.0 build 260203 x64_lsb
06/17/2020 18:56:22 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
06/17/2020 18:56:22 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2020.06
06/17/2020 18:56:22 (snpslmd) INFO: Server health report data collection is enabled.
06/17/2020 18:56:22 (snpslmd) INFO: License sanity check enabled (3600)
06/17/2020 18:56:22 (snpslmd) INFO: File descriptor limit (soft, hard) for snpslmd: 1024, 4096
06/17/2020 18:56:22 (snpslmd) INFO: TCP - tcp_keepalive_time - 7200 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 60
06/17/2020 18:56:22 (snpslmd) INFO: Cloud detection enabled. 1
18:56:22 (snpslmd) SLOG: Summary LOG statistics is enabled.
18:56:22 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
18:56:22 (snpslmd) SLOG: VM Status: 0
18:56:22 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT5
18:56:22 (snpslmd) SLOG: TPM Status: 0
18:56:22 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT6
18:56:25 (snpslmd) Server started on svr1 for:        SSS
18:56:25 (snpslmd) timemill/csx        timemill/internal_use timemill/msx
18:56:25 (snpslmd) timemill/nsaddon turboSchema        turboState
18:56:25 (snpslmd) Licenses are case sensitive for TE_CATS
18:56:25 (snpslmd)
18:56:25 (snpslmd) EXTERNAL FILTERS are OFF
18:56:25 (lmgrd) snpslmd using TCP-port 51842
18:56:25 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  extremed  hscd  innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  SIINT  simple  snpsOEM1  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd  wlld
06/17/2020 18:56:25 (snpslmd) ------------------------------------------------------------------
06/17/2020 18:56:25 (snpslmd) Checking the integrity of the license file....
06/17/2020 18:56:25 (snpslmd) Valid SSS feature found.
06/17/2020 18:56:25 (snpslmd) The feature is needed to enable the other keys in your license file.
06/17/2020 18:56:25 (snpslmd) Licensed to mammoth//ZWT 2006
06/17/2020 18:56:25 (snpslmd) Siteid: 1238, Server Hostid: xxxxxxxxxxxx, Issued on: 12/12/2012
大约7分钟后,出现以下日志。
如果在生成以下日志之前执行了以下命令,则会生成以下消息。
$> /user/eda/license/synopsys/scl/lmutil lmstat -c /user/eda/license/synopsys/svr1.dat
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
Flexible License Manager status on Wed 6/17/2020 18:57
License server status: 27000@svr1
    License file(s) on svr1: /user/eda/license/synopsys/svr1.dat:
      svr1: license server UP (MASTER) v11.16.6
Vendor daemon status (on svr1):
   snpslmd: Cannot read data from license server system. (-16,287)
<<< synopsys log (7分钟后记录消息) >>>
06/17/2020 19:02:54 (snpslmd) INFO: Server WAN NC data enabled
19:02:55 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
19:02:55 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
19:02:55 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
19:02:55 (snpslmd) (@snpslmd-SLOG@) ===============================================
19:02:55 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
19:02:55 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
19:02:55 (snpslmd) (@snpslmd-SLOG@) Start-Date: Wed Jun 17 2020 19:02:55 CST
19:02:55 (snpslmd) (@snpslmd-SLOG@) PID: 2717
19:02:55 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.16.6.0 build 260203 x64_lsb ( build 260203 (ipv6))
19:02:55 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
19:02:55 (snpslmd) (@snpslmd-SLOG@) Options file used: None
19:02:55 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
19:02:55 (snpslmd) (@snpslmd-SLOG@) Is FlexNet Licensing Service installed and compatible: No
19:02:55 (snpslmd) (@snpslmd-SLOG@) FlexNet Licensing Service Version: -NA-
19:02:55 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
19:02:55 (snpslmd) (@snpslmd-SLOG@) TS access time: -NA-
19:02:55 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
19:02:55 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
19:02:55 (snpslmd) (@snpslmd-SLOG@) Listening port: 51842
19:02:55 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
19:02:55 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
19:02:55 (snpslmd) (@snpslmd-SLOG@) Host used in license file: svr1
19:02:55 (snpslmd) (@snpslmd-SLOG@) HostID node-locked in license file: xxxxxxxxxxxx
19:02:55 (snpslmd) (@snpslmd-SLOG@) HostID of the License Server: xxxxxxxxxxxx
19:02:55 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
19:02:55 (snpslmd) TCP_NODELAY NOT enabled
19:02:55 (snpslmd) Listener Thread: running
如果在此消息后执行以下命令,将得到以下结果。
Flexible License Manager status on Wed 6/17/2020 19:06
   snpslmd: UP v11.16.6
输入命令(例如sx,finesim)后,将显示以下结果,但是该程序大约需要5~10分钟才能显示在屏幕上。
立即检查许可证。
<<< Command Terminal >>>
$> sx
Checkout succeeded: spice_explorer/5F30EBA0E2B043D148C3
        License file: 27000@svr1
        License Server: 27000@svr1
<<< Synopsys Log Message >>>
19:11:03 (snpslmd) OUT: "spice_explorer" testman@svr1
Sx在19:17显示在屏幕上。 Finesim也很耗时。
也就是说,它在输入命令后大约运行5-10分钟。
如果您知道为什么,请您教我,我将不胜感激。
请理解,作为外国人,写作是否奇怪。
谢谢。
发表于 2020-6-18 09:20:00 | 显示全部楼层
do not connect the internet ,  try it again
发表于 2020-9-8 03:30:09 | 显示全部楼层
Could you share the license file or licgen?
发表于 2023-6-19 15:15:33 | 显示全部楼层
thanks
GMT+8, 2025-12-16 21:03 , Processed in 0.014113 second(s), 3 queries , Gzip On, Redis On.
