查看: 2757|回复: 6
[求助] vcs与verdian安装有问题,求大神
发表于 2020-4-25 10:44:00 | 显示全部楼层 |阅读模式
安装VCS与Verdi到最后激活的时候报错如下:[root@localhost bin]# lmg_vcs
12:59:08 (lmgrd) -----------------------------------------------
12:59:08 (lmgrd)   Please Note:
12:59:08 (lmgrd)
12:59:08 (lmgrd)   This log is intended for debug purposes only.
12:59:08 (lmgrd)   In order to capture accurate license
12:59:08 (lmgrd)   usage data into an organized repository,
12:59:08 (lmgrd)   please enable report logging. Use Flexera Software LLC's
12:59:08 (lmgrd)   software license administration  solution,
12:59:08 (lmgrd)   FlexNet Manager, to  readily gain visibility
12:59:08 (lmgrd)   into license usage data and to create
12:59:08 (lmgrd)   insightful reports on critical information like
12:59:08 (lmgrd)   license availability and usage. FlexNet Manager
12:59:08 (lmgrd)   can be fully automated to run these reports on
12:59:08 (lmgrd)   schedule and can be used to track license
12:59:08 (lmgrd)   servers and usage across a heterogeneous
12:59:08 (lmgrd)   network of servers including Windows NT, Linux
12:59:08 (lmgrd)   and UNIX. Contact Flexera Software LLC at
12:59:08 (lmgrd)   www.flexerasoftware.com for more details on how to
12:59:08 (lmgrd)   obtain an evaluation copy of FlexNet Manager
12:59:08 (lmgrd)   for your enterprise.
12:59:08 (lmgrd)
12:59:08 (lmgrd)
12:59:08 (lmgrd)
12:59:08 (lmgrd) Server's System Date and Time: Sat Apr 25 2020 12:59:08 CST
12:59:08 (lmgrd) SLOG: Summary LOG statistics is enabled.
12:59:08 (lmgrd) The license server manager (lmgrd) running as root:
12:59:08 (lmgrd)         This is a potential security problem
12:59:08 (lmgrd)         and is not recommended.
12:59:08 (lmgrd) license manager: can't initialize:Invalid license file syntax.
12:59:08 (lmgrd) License Path: "/home/wming_hao/Eda/synopsys/vcs_2016.06/license/Synopsys.dat"
12:59:08 (lmgrd) FlexNet Licensing error:-2,40027
12:59:08 (lmgrd) For further information, refer to the FlexNet Licensing documentation,available at "www.flexerasoftware.com".
鼓捣了好久也没解决
求大神帮帮忙,这个怎么解决
发表于 2020-4-25 12:45:32 | 显示全部楼层
alias lmg_vcs=“/home/wming_hao/Eda/synopsys/scl_11.9/linux/bin/lmgrd -c /home/wming_hao/Eda/synopsys/vcs_2016.06/license/Synopsys.dat”
应该是这个有问题吧。没放在一行?你可以先注释掉试下
 楼主| 发表于 2020-4-25 13:04:16 | 显示全部楼层
puxiancheng 发表于 2020-4-25 12:45
alias lmg_vcs=“/home/wming_hao/Eda/synopsys/scl_11.9/linux/bin/lmgrd -c /home/wming_hao/Eda/synopsy ...
这个问题貌似已经解决了,然后最后激活又出问题了
 楼主| 发表于 2020-4-25 13:05:48 | 显示全部楼层
上面写着不能初始化liences,有问题
 楼主| 发表于 2020-5-3 15:22:09 | 显示全部楼层
有没有大神帮帮忙吧
发表于 2022-12-19 17:20:24 | 显示全部楼层
最后怎么解决的
发表于 2022-12-21 22:10:46 | 显示全部楼层
kkkkkkkkkkkkkkkk
GMT+8, 2025-12-30 08:05 , Processed in 0.016732 second(s), 5 queries , Gzip On, Redis On.
