楼主: majpliush
[求助] 只有仿真结果,能发好期刊吗
发表于 2020-4-23 21:17:41 | 显示全部楼层
zouliang1127 发表于 2020-4-23 12:56
“A General Theory of Phase Noise in Electrical Oscillators“ Ali Hajimiri, Student Member, IEEE , ...
    你在扯啥呢?都有测试结果的,而且都是顶级大咖。
    你举这些例子不是来高校的。
    你给我找个最近十年没测试结果的JSSC?
    没测试结果,你往JSSC 上投,你不嫌丢人么,读者都觉得丢人。
点评
Hajimiri这种物理奥赛金牌得主来玩ic设计,完全就是吊打了,他导师也牛。我不是搞pll的,外行也就是能看看简历了  发表于 2020-4-24 03:07
发表于 2020-4-23 21:19:42 | 显示全部楼层
所以,搜狗输入法你电脑没有?
回复 支持 0 反对 2
发表于 2020-4-23 21:24:49 | 显示全部楼层
JoyShockley 发表于 2020-4-23 21:19
所以,搜狗输入法你电脑没有?
你的主观,已经让楼歪了!
Btw, were those people famous when they published those famous papers?
发表于 2020-4-23 23:21:01 | 显示全部楼层
你到底有没有读过,你举的这三篇JSSC 的理论文章,究竟哪一篇没有测试结果?
第一篇测试结果:A General Theory of Phase Noise in Electrical Oscillators“ Ali Hajimiri, Student Member, IEEE , and Thomas H. Lee, Member, IEEE
第二篇芯片照片:
”The Quadrature LC Oscillator: A Complete Portrait Based on Injection Locking“ Ahmad Mirzaei, Mohammad E. Heidari, Rahim Bagheri, Saeed Chehrazi, and Asad A. Abidi, Fellow, IEEE
第三篇芯片照片:
“Multi-Phase Injection Widens Lock Range of Ring-Oscillator-Based Frequency Dividers” Ahmad Mirzaei, Mohammad E. Heidari, Rahim Bagheri, Student Member, IEEE, and Asad A. Abidi, Fellow, IEEE
发表于 2020-4-24 00:27:40 | 显示全部楼层
One more related paper: Oscillator Phase Noise: A Tutorial  Thomas H. Lee, Member, IEEE, and Ali Hajimiri, Member, IEEE
First of all, the owner of this post is trying to ask the possibilities on publishing articles on good journals without real tape out results.  My answer is trying to provide examples for the possibility, of course, out of the scope of the common sense, that is, CAS related papers apparently should include a detailed fabricated circuit result.
Secondly, it is obvious that the intentions of those authors were to publish their general theories instead of describing some kind of particular circuit architectures, I believe you also agree if they grab your chip, they can still write those masterpieces. If you looked into their backgrounds before they became famous, you would find their situations and methods when writing these papers. For example, Mirzaei had been with Broadcom for almost a decade before he joined PSU as a faculty, I believe you understand his injection locking theories have been in succession, quite apparently, his thoughts and hand writings came out first, those dies were just at the corner in some company lab, but just could serve as his verification tool.
Last, as a member in the CAS community, especially, in China, we should make every effort to make things easy and possible and lower any unnecessary high threshold for more interested parties to join and make contributions in this CAS society in China. Our arguments should be objective, positive, instead of rather stiff.
发表于 2020-4-24 03:21:14 | 显示全部楼层
只能这么说,jssc和isscc都会有越来越多同胞中的
另外平台很重要,一般人离了好平台也难得灌顶刊
找个中等资质的扔到imec去试试,不想发都难
发表于 2021-9-26 12:45:54 | 显示全部楼层
学习了
GMT+8, 2025-9-14 09:43 , Processed in 0.017769 second(s), 5 queries , Gzip On, Redis On.
