查看: 9194|回复: 15
[原创] 在CentOS8.0上安装IC618,安装installscape时出错,诸位帮帮
发表于 2020-3-29 12:00:24 | 显示全部楼层 |阅读模式
Do you have InstallScape for lnx86 platform installed[y/n]?n
You are on lnx86 platform
InstallScape version 04.23.s12
for platform lnx86
is available on this media.
Do you want to install InstallScape for lnx86 [y/n]?y
It is recommended that you install InstallScape
outside the Cadence installation hierarchy
and include the ~iscape/bin in your PATH environment variable.
Type the path to InstallScape installation directory [ (q to quit)]: /opt/eda/cadence/iscape
InstallScape installation directory: /opt/eda/cadence/iscape
Extracting InstallScape version 04.23.s12
for platform lnx86 in /opt/eda/cadence/iscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0
If you do not see the InstallScape console
window or it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/opt/eda/cadence/iscape/iscape/bin/iscape.sh /opt/eda/cadence/IC06.18.000_lnx86.Base/CDROM1:::/opt/eda/cadence/IC618
Initializing InstallScape using JVM at /opt/eda/cadence/iscape/iscape.04.23-s012/runtime/LNX86/bin/java. This might take some time...
Error occurred during initialization of VM
Unable to load native library: libnsl.so.1: cannot open shared object file: No such file or directory
Failed with InstallScape JVM.
Now loading System JVM...
No protocol specified
Exception in thread "main" java.awt.AWTError: Can't connect to X11 window server using ':0' as the value of the DISPLAY variable.
        at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
        at sun.awt.X11GraphicsEnvironment.access$200(X11GraphicsEnvironment.java:65)
        at sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:115)
        at java.security.AccessController.doPrivileged(Native Method)
        at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:74)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:264)
        at java.awt.GraphicsEnvironment.createGE(GraphicsEnvironment.java:103)
        at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:82)
        at sun.awt.X11.XToolkit.<clinit>(XToolkit.java:126)
        at java.awt.Toolkit$2.run(Toolkit.java:860)
        at java.awt.Toolkit$2.run(Toolkit.java:855)
        at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:854)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:107)
Error:
/usr/bin/java/jdk-8u171-linux-x64/jdk1.8.0_171/bin/java
Could not use JVM packaged with Installcape. The Java in your path did not work or could not find Java in your path.  Ensure that Java 1.6 or later is in your PATH environment variable and restart InstallScape.
发表于 2020-3-29 13:30:03 | 显示全部楼层
yum install libnsl.i686 libnsl.x86_64
发表于 2020-3-29 20:40:35 来自手机 | 显示全部楼层
解决了这个问题估计以后还会有其他的问题,Centos 8系统太新了,cadence现在估计还不支持
发表于 2020-3-29 20:50:22 | 显示全部楼层
cadence not suppot centos8/rhel8 platform at present
发表于 2020-3-29 22:41:24 | 显示全部楼层
some still don't support 7
 楼主| 发表于 2020-3-29 23:05:29 | 显示全部楼层
是的是的,,亲测在Centos7上可以运行installscape,rhel8.0/centos8.0不行
发表于 2020-3-30 00:00:58 | 显示全部楼层
亲测IC618可以在rhel8.1上运行
 楼主| 发表于 2020-3-30 00:32:36 | 显示全部楼层
我试了怎么不行?同样出现这段话
 楼主| 发表于 2020-3-30 00:34:25 | 显示全部楼层
you are right,but this may because the centos8.0 could not run the iscape
 楼主| 发表于 2020-3-30 00:35:37 | 显示全部楼层
寂寞的歌 发表于 2020-3-29 20:40
解决了这个问题估计以后还会有其他的问题,Centos 8系统太新了,cadence现在估计还不支持 ...
是的,尝试了RHEL8.0有同样的问题
GMT+8, 2025-12-22 08:47 , Processed in 0.018433 second(s), 4 queries , Gzip On, Redis On.
