查看: 2372|回复: 0
[转贴] glibc 里面rand函数的实现
发表于 2020-3-24 13:34:32 | 显示全部楼层 |阅读模式
  1. #include <stdlib.h>
  2. /* This algorithm is mentioned in the ISO C standard, here extended
  3.    for 32 bits.  */
  4. int
  5. rand_r (unsigned int *seed)
  6. {
  7.   unsigned int next = *seed;
  8.   int result;
  9.   next *= 1103515245;
  10.   next += 12345;
  11.   result = (unsigned int) (next / 65536) % 2048;
  12.   next *= 1103515245;
  13.   next += 12345;
  14.   result <<= 10;
  15.   result ^= (unsigned int) (next / 65536) % 1024;
  16.   next *= 1103515245;
  17.   next += 12345;
  18.   result <<= 10;
  19.   result ^= (unsigned int) (next / 65536) % 1024;
  20.   *seed = next;
  21.   return result;
  22. }
    复制代码
As you can see, it's simply multiply with an addition and a shift. The values are carefully chosen to make sure that you get no repeat of the output for RAND_MAX iterations.
Note that this is an old implementation which has been replaced by a more complex algorithm: [color=var(--blue-700)]https://sourceware.org/git/?p=glibc.git;a=blob_plain;f=stdlib/random_r.c;hb=HEAD
If the link if broken, Google for "glibc rand_r"
https://stackoverflow.com/questions/1026327/what-common-algorithms-are-used-for-cs-rand
GMT+8, 2025-12-24 02:09 , Processed in 0.011199 second(s), 4 queries , Gzip On, Redis On.
