查看: 2548|回复: 1
[求助] monte carlo trimmed simulation in adexl (cadence 6)
发表于 2020-1-10 14:25:52 | 显示全部楼层 |阅读模式
Trevor1981over 7 years ago
Hi,
Does anyone know how to setup monte carlo simulation under adexl in such way that:
- 1st test bench uses tran smulation to find a trimming code for a particular instance (DUT)
- 2nd test bench uses dc temp sweep to run a monte carlo trimmed simulation
Problem: In both test benches DUT should contain devices with the same mismatch spread on their model parameters. It seems that my DUT has different monte carlo spread in both test benches and the trimming doesn't really have any effect.
Thanks for your help.
那位仁兄可以下载这篇Applicaiton note, 谢谢
http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:doc;src=wp;q=ApplicationNotes/Custom_IC_Design/appNote_Calibrated_Verification.pdf
或者有更好的办法解决类似问题,谢谢!
发表于 2021-2-25 16:06:00 | 显示全部楼层
这个文档您可以上传一下吗?
GMT+8, 2025-12-29 14:03 , Processed in 0.012793 second(s), 3 queries , Gzip On, Redis On.
