楼主: 闲人过客
[原创] CDB转OA
 楼主| 发表于 2020-12-3 11:06:27 | 显示全部楼层
浩然 发表于 2020-10-26 09:26
楼主有自己建立的51库转61的方法吗
什么叫自己建立的库?不大懂
发表于 2020-12-4 21:14:09 | 显示全部楼层
闲人过客 发表于 2020-12-3 11:06
什么叫自己建立的库?不大懂
就比如自己在51或者61里新建了个库,然后在库里画电路原理图一类的,哪个库里就没有cds.lib文件
 楼主| 发表于 2020-12-7 16:01:55 | 显示全部楼层
这个在你新建库的时候有cds.lib文件,提醒你去保存的,应该另存为你的work目录下。可能你直接x掉了
发表于 2021-2-2 19:02:25 | 显示全部楼层
kanka nnnnnnn
发表于 2021-3-4 23:02:19 | 显示全部楼层
你好,同IC617,转换不成功,为什么报这个warning呢?
Message Summary:
WARNING (CDBOA-406): Directory <path>/<name> is in a cellview. The directory
                     and its contents will be copied to the destination database
                     but will not be translated.
                      Generated 2 times. Neither CDBA nor OpenAccess supports
                     directories in cellviews. The directory and its contents
                     are copied to the destination library but are not
                     translated. This could mean that you end up with CDBA data
                     in the OpenAccess version of your library. Check the
                     directory in question. If it contains data that needs to be
                     translated, correct the source data so that it conforms to
                     legal directory structure conventions and then run the
                     translator again.
发表于 2021-3-5 12:47:03 | 显示全部楼层
Thank you!!!
发表于 2021-5-23 15:44:01 | 显示全部楼层
111111
发表于 2021-7-31 18:02:30 | 显示全部楼层
感谢分享
发表于 2021-12-16 10:26:13 | 显示全部楼层
CDB转OA后,库里器件没有预览图片了,楼猪这个怎么处理的哦
发表于 2025-8-1 10:28:04 | 显示全部楼层
thanks
GMT+8, 2025-12-2 13:02 , Processed in 0.018033 second(s), 3 queries , Gzip On, Redis On.
