查看: 3550|回复: 2
[求助] 仿真报错,求助!!!
发表于 2020-1-8 17:43:06 | 显示全部楼层 |阅读模式
Simulation Error:
Simulator failed to complete the simulation.
The simulator process returned a non-zero exit code 134, indicating failure.
The simulator could have crashed or intentionally returned to indicate an error.
Check the simulator log file for more information.  Common causes:
1. Simulator may have crashed during exit even after reporting success in log file.
2. Abrupt automatic simulator termination (e.g., SIGKILL) because the simulator process has
   exceeded resource limits, which can be specified in the distribution system or
   by the kernel itself (e.g., the Linux OOMKiller).
3. Manual termination of the simulator process.
./runSimulation can be manually run in this directory to check the issue.
仿真过程中报出这种错误,有没有哪位大神帮忙看看
发表于 2023-8-15 09:53:20 | 显示全部楼层
请问楼主解决了吗
 楼主| 发表于 2023-8-15 10:57:01 | 显示全部楼层
jx2016 发表于 2023-8-15 09:53
请问楼主解决了吗
太久了,忘了怎么解决的了
GMT+8, 2025-12-29 11:18 , Processed in 0.180078 second(s), 3 queries , Gzip On, Redis On.
