查看: 4654|回复: 3
[原创] iscape.sh 命令行方式安装软件
发表于 2019-12-16 16:23:32 | 显示全部楼层 |阅读模式
iscape.sh -batch  majorAction=InstallFromArchive archiveDirectory=/home/chaos/eda/cadence/innovus/invs1810/CDROM1 installDirectory=/home/chaos/eda/cadence/innovus1810
Initializing InstallScape using JVM at /home/chaos/eda/cadence/iscape/iscape.04.23-s012/runtime/LNX86/bin/java. This might take some time...
WARNING: The DISPLAY environment variable has not been set.
InstallScape might not initialize.
InstallScape Installer (Batch Mode) - 04.23.s12
The following products will be installed:
    3003:Virtuoso Digital Implementation XL
    3004:VDI-XL Block Capacity Option
    EDS210:Encounter Clock Concurrent Optimization
    FE100GPS:First Encounter - XL (aka Cadence (R) First Encounter - GPS)
    INVS07:Innovus 7nm Option
    INVS100:Innovus Implementation System
    INVS10:Innovus 10nm Option
    INVS20:Innovus 20/16/14nm Option
    INVS30:Innovus Mixed Signal Option
    INVS35:Innovus High Frequency Route Option
    INVS40:Innovus Hierarchical Design Option
    INVS60:Innovus 3D-IC Option
    INVS80:Innovus CPU Accelerator Option
    INVSI10:Innovus I10nm Option
    INVSI20:Innovus I20nm Option
Installing: slfiles_lnx86 INNOVUS_18.10.000_lnx86
Installing: ski64b_lnx86 16.10-s440lnx86
Installing: uiCore_lnx86 35.15-s005lnx86
Installing: msSrr64b_lnx86 06.17-e176lnx86
Installing: NanoRouteIndep 18.10-p002
Installing: syntechIndep 11.10-p001
Installing: gdm64b_lnx86 35.15-s005lnx86
Installing: AnlsCommon64b_lnx86 18.10-a011lnx86
Installing: voltuscuicmdhlp 18.10-p002
Installing: lapack_lnx86 12.00-d008lnx86
Installing: ddBaseIndep 35.15-s005
Installing: IEEE1801wDoc 18.10-p002
Installing: InnovusTCRDoc 18.10-p001
Installing: InnovusWNDoc 18.10-p001
Installing: gccLib_lnx86 04.83-p004lnx86
Installing: commonuiDoc 18.10-p002
Installing: InnovusUGDoc 18.10-p001
Installing: itk64b_lnx86 06.17-d050lnx86
Installing: virtuos_lnx86 35.15-s023lnx86
Installing: voltusDoc 18.10-p007
Installing: uiReplay64b_lnx86 35.15-s005lnx86
Installing: voltuscommonuiMigDoc 18.10-p003
Installing: libBasic_lnx86 06.17-d050lnx86
Installing: mmsimMKL_1111__lnx86 14.10-s001lnx86
Installing: cadencehelpSupport 03.00-s001
Installing: NanoRouteEMS 18.10-p002
Installing: ckSysConf_lnx86 02.09-p153lnx86
Installing: mmsimTclTk_8420__lnx86 15.10-p002lnx86
Installing: Install from CDROM(s) Successful
Done.
发表于 2019-12-17 11:05:47 | 显示全部楼层
InstallScape can also run in GUI mode.  It's a bit more intuitive.  Also, it can show what's been installed, what features are installed.
 楼主| 发表于 2019-12-20 20:38:33 | 显示全部楼层
jake 发表于 2019-12-17 11:05
InstallScape can also run in GUI mode.  It's a bit more intuitive.  Also, it can show what's been in ...
it's for install automation
发表于 2023-5-30 14:39:30 | 显示全部楼层
则会个你需要,非常感谢
GMT+8, 2025-12-17 01:12 , Processed in 0.015415 second(s), 3 queries , Gzip On, Redis On.
