查看: 2431|回复: 0
[求助] spartan-6下载一个spi slave的程序后,mosi管脚一直为低,导致无法master无法发送数据
发表于 2019-12-12 17:57:23 | 显示全部楼层 |阅读模式
本人从网上抄了一个spi slave的fpga代码,综合后下载到spartan-6中,上电后fpga的mosi口一直为低,无法通讯,请高手指点!
代码如下:
module spislave(nrst, clk, ncs, mosi,  sck);
// PORT declarations
   input clk, nrst;
   input ncs, mosi, sck;
//INTERNALS signal
   wire sck_riseedge, sck_falledge;
   reg[7:0] byte_received;
   reg[3:0] bit_received_cnt;
   reg rec_flag;
   reg[1:0] rec_status;
   reg[7:0] rec_data;
   reg[2:0] rec_flag_width;
   reg[2:0] sck_edge;
always @ (posedge clk or negedge nrst)
begin
  if(~nrst)
  begin
   sck_edge <= 3'b000;
  end
  else
  begin
   sck_edge <= {sck_edge[1:0], sck};
  end
end
assign sck_riseedge = (sck_edge[2:1] == 2'b01);
assign sck_falledge = (sck_edge[2:1] == 2'b10);
begin
  if(~nrst)
  begin
   byte_received <= 8'h00;
   bit_received_cnt <= 4'h0;
   rec_flag <= 1'b0;
   rec_status <= 2'b00;
   rec_flag_width <= 3'b000;
  end
  else
  begin
   if(~ncs)
   begin
    case (rec_status)
    2'b00: begin
     if(sck_riseedge)
     begin
      byte_received <= {byte_received[6:0], mosi};
      if(bit_received_cnt == 4'h7)
      begin
       bit_received_cnt <= 4'b0000;
       rec_status <= 2'b01;
      end
      else
      begin
       bit_received_cnt <= bit_received_cnt+1;
      end
     end
    end
    2'b01: begin
     rec_data <= byte_received;
     rec_flag <= 1'b1;
     if(rec_flag_width==3'b100) begin
      rec_status <= 2'b11;
     end
     else begin
      rec_flag_width <= rec_flag_width+1;
     end
    end
    2'b11: begin
     rec_flag <= 1'b0;
    end
    endcase
   end
  end
end
endmodule
我的ucf文件:
NET clk LOC = R7 | TNM_NET = sys_clk_pin | IOSTANDARD = "LVCMOS33";
TIMESPEC TS_sys_clk_pin = PERIOD sys_clk_pin 24576 kHz;
NET nrst                                LOC = N8 | IOSTANDARD = "LVCMOS33";
NET mosi                                 LOC = D16  | IOSTANDARD = "LVCMOS33";  //数据接收端,一直为低,导致mcu无法发数据过来
NET mosi PULLUP;
NET "sck" CLOCK_DEDICATED_ROUTE = FALSE;
NET sck                                  LOC = E16  | IOSTANDARD = "LVCMOS33";
NET ncs                                   LOC = G16  | IOSTANDARD = "LVCMOS33";
#NET "spi_data" PULLUP;        //配置中加了上拉也没有用
GMT+8, 2025-12-26 03:04 , Processed in 0.011199 second(s), 3 queries , Gzip On, Redis On.
