查看: 2893|回复: 7
[求助] SAR-ADC输入的问题
发表于 2019-7-26 22:29:15 | 显示全部楼层 |阅读模式
全差分和伪差分(正端接信号,负端接VDD/2)性能差的多吗?
发表于 2019-7-26 22:45:18 | 显示全部楼层
Your common mode will shift a lot for pseudo differential input. This can change your comparator behavior
 楼主| 发表于 2019-7-26 22:53:07 | 显示全部楼层
yuechuan 发表于 2019-7-26 22:45
Your common mode will shift a lot for pseudo differential input. This can change your comparator beh ...
两种情况要是ADC输入共模相同呢?
发表于 2019-7-26 23:04:59 | 显示全部楼层
For pseudo differential input:
V+ connected to Vsignal (Assuming varies from 0 - VDD)
V - connected to VDD/2
Your common mode will be changing from VDD/4 to VDD*3/4.
For fully differential input
V+ connected to  Vcom +Vsignal
V- connected to Vcom - Vsignal
Your common mode voltage will always be Vcom
They will not have the same common mode voltage if you vary the input.
发表于 2019-7-26 23:06:43 | 显示全部楼层
They cannot be the same.
V+ (0 to VDD)
V- (VDD/2)
V_common (VDD/4 to VDD*3/4)
发表于 2019-7-27 10:40:03 | 显示全部楼层
对于商用芯片,应该有改变共模的input  buffer,这样只要信号源和PCB做好,性能应该不受影响。
 楼主| 发表于 2019-7-27 15:04:26 | 显示全部楼层
V+ (0 to VDD)
直接相连确实是您说的这样,但是ADC前面有个buffer,buffer的两个输出共模是固定/一样的。
 楼主| 发表于 2019-7-27 15:08:33 | 显示全部楼层
谢谢,再请教一下buffer前面的滤波器是不是对ADC的SNR影响很大。
GMT+8, 2025-12-14 00:13 , Processed in 0.020098 second(s), 4 queries , Gzip On, Redis On.
