请教各位达人,本人新手,对linux 的许多命令也不懂,这几天查过以往的帖子,没有遇到同样的问题,第一段报的错误和很多人都一样,第二段ahdlcmi.out则不一样,看到别人的都是no such file or directory,而我的是file not recognized。我这报错的部分是verilogA DAC,目前verilogXL部分和模拟部分SpectreVerilog混仿能够出来波形,但verilogA DAC这块一直不能通过,verilogA DAC本身可以生成symbol,尝试仿真了不同的verilogA DAC,也都是遇到同样的问题,报错如下:
Error found by spectre during AHDL read-in.
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//3052_SA18219047_anaCMOS18_dac_8bit_veriloga_veriloga.va.dac_8bit.ahdlcmi/Linux/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
ERROR (SFE-91): Error when elaborating the instance dac_8bit. Simulation should be terminated.
ahdlcmi.out文件报错如下:
/soft1/cadence/MMSIM121/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc -shared -O3 -fPIC -o obj/optimize/5.0/dac_8bit_libahdlcmi.so ./obj/optimize/5.0/dac_8bit_func.o ./obj/optimize/5.0/dac_8bit_DcFuncDerLoad.o ./obj/optimize/5.0/dac_8bit_DcFuncLoad.o ./obj/optimize/5.0/dac_8bit_TranFuncDerLoad.o ./obj/optimize/5.0/dac_8bit_TranFuncLoad.o ./obj/optimize/5.0/dac_8bit_cmi_c.o -m32 -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
/lib/../lib/libgcc.so: file not recognized: File truncated
collect2: ld returned 1 exit status
gnumake: *** [obj/optimize/5.0/dac_8bit_libahdlcmi.so] Error 1
另外,用的linux系统是RedHat 5.7,virtuoso &之前环境设置如下:
$ setdt ic616
$ setdt mmsim
$ setdt ldv
$ setenv CDS_AUTO_64BITS NONE (Spectreverilog仿真报错不支持64位)
$ setenv CDS_VHDLCMI_ENABLE NO
不知道有没有人遇到过同样的问题,麻烦各位达人帮忙看看,谢谢!
