查看: 2282|回复: 2
[原创] modelsim win7 运行 UVM
发表于 2019-6-12 22:03:17 | 显示全部楼层 |阅读模式
1) 创建一个文件run.tcl 内容如下
#UVM verilog source HOME
set UVM_HOME     D:/modelsim/verilog_src/uvm-1.1d
#UVM DPI Home
set UVM_DPI_HOME D:/modelsim/uvm-1.1d/win64
vlib     work
vlog -sv +incdir+$UVM_HOME/src -L mtiAvm -L mtiOvm -L mtiUvm -L mtiUPF  hello.v
vsim -c -sv_lib $UVM_DPI_HOME/uvm_dpi work.hello
run 100
2)创建一个hello.v 文件, 内容如下:
`include "uvm_pkg.sv"
module hello (/*AUTOARG*/);
   import uvm_pkg::*;
   `include "uvm_macros.svh"
   initial begin
      `uvm_info("inf1","UVM Hello",UVM_LOW);
   end
endmodule: hello
3) 创建run.bat 内容如下:
echo
modelsim -do run.tcl
4 ) 双击run.bat
# Loading D:/modelsim/uvm-1.1d/win64/uvm_dpi.dll
# UVM-1.1d
# (C) 2007-2013 Mentor Graphics Corporation
# (C) 2007-2013 Cadence Design Systems, Inc.
# (C) 2006-2013 Synopsys, Inc.
# (C) 2011-2013 Cypress Semiconductor Corp.
#   ***********       IMPORTANT RELEASE NOTES         ************
#   You are using a version of the UVM library that has been compiled
#   with `UVM_NO_DEPRECATED undefined.
#   See http://www.eda.org/svdb/view.php?id=3313 for more details.
#   with `UVM_OBJECT_MUST_HAVE_CONSTRUCTOR undefined.
#   See http://www.eda.org/svdb/view.php?id=3770 for more details.
#       (Specify +UVM_NO_RELNOTES to turn off this notice)
# UVM_INFO hello.v(15) @ 0: reporter [inf1] UVM Hello
第一个UVM 程序就运行完毕了~~~
发表于 2019-6-14 14:41:09 | 显示全部楼层
半点UVM特性没用到呀
发表于 2019-6-17 17:34:39 | 显示全部楼层
等待楼主后续帖子。。。。。。。。。
GMT+8, 2025-12-29 13:08 , Processed in 0.013130 second(s), 4 queries , Gzip On, Redis On.
