查看: 2219|回复: 0
[求助] formality验证问题
发表于 2019-5-31 19:05:23 | 显示全部楼层 |阅读模式
做verify时出现下面情况,该怎么解决啊
********************************* Verification Results *********************************
Verification FAILED
Reference design: r:/WORK/calendar
Implementation design: i:/WORK/calendar
88 Passing compare points
6 Failing compare points
0 Aborted compare points
0 Unverified compare points
Matched Compare Points     BBPin    Loop   BBNet     Cut    Port     DFF     LAT   TOTAL
Passing (equivalent)           0       0       0       0      46      40       2      88
Failing (not equivalent)       0       0       0       0       0       6       0       6
Info:  Try the analyze_points command to see if Formality can determine potential
causes, or suggest next steps for a FAILED or INCONCLUSIVE verification.
See the man page for analyze_points usage and options.
Info:  Formality Guide Files (SVF) can improve verification success by automating setup.
0
GMT+8, 2025-12-30 07:27 , Processed in 0.015359 second(s), 4 queries , Gzip On, Redis On.
