查看: 6718|回复: 9
cadence spectre仿真遇到的问题,求助
发表于 2019-4-30 10:47:52 | 显示全部楼层 |阅读模式
*WARNING* The Virtuoso Analog Design Environment (ADE) creates a user interface (UI) to match the features of the particular
version of MMSIM you are using. The software could not find the 'feature file' in the MMSIM hierarchy that lists the features
available in this version of MMSIM. You might be using a wrapper script around spectre such that 'which spectre' returns
your wrapper script and not spectre in the MMSIM hierarchy. For now, ADE will create a UI to match the latest version
of spectre. If you are using an older version and do not want to see the UI for features that are not available in
that version, you can set the following variable according to spectre version you are using:
setenv  SPECTRE_FEATURE_FILE /home/pathForMMSIM/tools/spectre/etc/files/spectre.dat
Loading msgHandler.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
ERROR (ADE-3023): Unable to locate spectre executable in the specified path. Ensure that
        the executable is present in the path or to set the correct path, use
        the setShellEnvVar() in Command Interpreter Window (CIW).
发表于 2019-4-30 21:18:28 | 显示全部楼层
写的很清楚啊,你的SPECTRE路径定义的不对。检查一下shell resource文件中的PATH定义
发表于 2019-12-9 13:57:35 | 显示全部楼层
hspice 发表于 2019-4-30 21:18
写的很清楚啊,你的SPECTRE路径定义的不对。检查一下shell resource文件中的PATH定义 ...
SPECTRE_FEATURE_FILE 我得路径我能打开但就是一直报错,spectre是否需要设置lic在cshrc中?
发表于 2022-1-27 17:49:42 | 显示全部楼层
问题解决了么,我也遇到这种了
发表于 2022-5-7 22:06:04 | 显示全部楼层
我也遇到这种了
发表于 2022-5-7 22:39:47 | 显示全部楼层
发表于 2022-7-25 16:12:22 | 显示全部楼层
wutong56tg 发表于 2022-5-7 22:06
我也遇到这种了
你好,请问你解决这个问题了吗,能不能帮忙解答下
发表于 2022-8-11 15:16:05 | 显示全部楼层
看上一楼我附的链接哦
发表于 2024-10-17 15:30:00 | 显示全部楼层
我也遇到了:'(
发表于 2025-5-21 16:22:19 | 显示全部楼层
也有可能你的home路径下有多个.cshrc文件,(比如home路径一个,它的下一级也有一个,这样读文件的时候会产生冲突)
GMT+8, 2025-12-26 04:57 , Processed in 0.019180 second(s), 6 queries , Gzip On, Redis On.
