查看: 1199|回复: 6
[资料] [Springer.2015]Compact Models and Performance Investigations for Subthreshold Interconnects
发表于 2019-4-23 07:45:13 | 显示全部楼层 |阅读模式
Rohit Dhiman• Rajeevan Chandel
Modern very-large-scale integration (VLSI) chips contain millions of transistors. It
is envisaged that VLSI chips will contain more than three billion transistors in the
coming decade. VLSI chips find wide applications in all modern electronic circuits
and systems. In highly-scaled VLSI technology nodes, more and more function-
alities are being housed on a chip. Various functional blocks of the chip are con-
nected to each other with interconnects. Interconnects distribute clock, supply
voltage, and signals in a VLSI chip. Chip sizes are also decreasing due to tech-
nological advances. High chip complexity requires dense interconnections to
communicate information between devices and circuit blocks. As a result, long
interconnects have become common on-chip features. However, long interconnects
cause various deleterious effects, viz., high propagation delay, degradation of signal
waveforms, excess power dissipation, and crosstalk. Consequently, the increased
number of interconnects in present-day VLSI chips has made the interconnection
design problem complex and challenging.
In recent years, power dissipation is given comparable weightage to the area and
speed considerations. The primary driving factor is increasing prominence and fast
growth of battery operated applications such as micro-sensor networks, pacemak-
ers, hearing aids, and many other portable devices, which require stringent energy
constraints for longer battery lifetime. Subthreshold operation of devices presents
an opportunity for energy-constrained applications with its ultra-low-power con-
sumption. Subsequently, the benefits from ultra-low-power operation have carved
out a significant niche for subthreshold circuits. Though the subthreshold operation
shows huge potential toward satisfying the ultra-low-power requirements of por-
table systems, it holds design issues both for interconnects and circuit design. These
issues lead to significant increase in the design complexity of integrated circuits.
There are not many works that address these challenges for subthreshold circuit
design in an integrated and comprehensive manner. This book provides a detailed
analysis of concerns related to subthreshold interconnect performance from the
perspective of analytical approach and design techniques. It also presents a quali-
tative summary of the work reported in the literature by various researchers in the
design of digital subthreshold circuits. Particular emphasis is laid on the
performance analysis of coupling noise and variability issues in subthreshold
domain to develop efficient compact models. The different tasks accomplished in
this book are mentioned below.
A new parameter called subthreshold drain conductance is defined. Two new sub-
regions of MOS operation are identified. Compact analytical expressions governing
output voltage, propagation delays, and coupling noise are developed. The impact of
coupling on aggressor delay is analyzed. The proposed analytical approach gives
physical insight into the parameters affecting the transient behavior. This is essential
for avoidance of dynamic crosstalk and circuit malfunctioning. Remedial design
techniques are suggested to mitigate the effect of coupling noise caused by the
interconnect coupling capacitance. The effects of wire width, spacing between the
wires and wire length are thoroughly investigated. In addition, the effect of
parameters like driver strength on peak coupling noise has also been analyzed.
Process, voltage, and temperature variations are prominent factors affecting
subthreshold design and have also been investigated. Analytical expressions char-
acterizing variability based on the parametric analysis are developed. The process
variability analysis has been carried out using parametric analysis, process corner
analysis, and Monte Carlo technique. The impact of temperature on subthreshold
interconnect performance is also investigated.
To summarize, this book will serve as a platform for researchers and graduate
students with deeper insights into subthreshold interconnect models in particular
and designing complex logic gates in general. This book will best fit as a textbook
and/or a reference book for students who are initiated in the area of research and
advanced courses in nanotechnology, ultra-low-power interconnect design, and
modeling.
Compact Models and Performance Investigations for Subthreshold Interconnects.[Ro.pdf
4.13 MB, 下载次数: 42 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2019-4-23 12:41:28 | 显示全部楼层
thanks for share ~
发表于 2019-4-23 21:15:05 | 显示全部楼层
thanks
发表于 2019-4-24 10:12:59 | 显示全部楼层
下载看看
发表于 2019-4-24 14:34:50 | 显示全部楼层
谢谢分享,下载学习
发表于 2019-4-26 11:03:25 | 显示全部楼层
Thanks for sharing
发表于 2019-6-13 09:40:04 | 显示全部楼层
goooooooooooooooooooood
GMT+8, 2025-12-4 08:22 , Processed in 0.018555 second(s), 4 queries , Gzip On, Redis On.
