*WARNING* defmethod: invalid template string ("gtl") for the method 'SetLayerMap'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetLayerMapTable'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gtt") for the method 'FilterRuleFile'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetRuleTable'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetMapTable'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gtgg") for the method 'GetDR'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetMetalStack'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gst") for the method 'GetLayerData'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gl") for the method 'GetGDS'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetLPP'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gl") for the method 'GetLPAttr'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetDeviceList'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetDeviceOptionData'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetBEOL'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'GetDevice'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
GLOBALFOUNDRIES INFO: Loading Library.ils...
GLOBALFOUNDRIES INFO: Loading Device.ils...
GLOBALFOUNDRIES INFO: Loading TechFile.ils...
GLOBALFOUNDRIES INFO: Loading CapProp.ils...
GLOBALFOUNDRIES INFO: Loading ResProp.ils...
GLOBALFOUNDRIES INFO: Loading MinMax.ils...
GLOBALFOUNDRIES INFO: Loading AbsGenStreamMap.ils...
GLOBALFOUNDRIES INFO: Loading Rules1.ils...
GLOBALFOUNDRIES INFO: Loading Rules2.ils...
GLOBALFOUNDRIES INFO: Loading Rules3.ils...
GLOBALFOUNDRIES INFO: Loading DM290_Layers.ils...
Loading oasis.cxt
GLOBALFOUNDRIES INFO: Loading 018ULL_30V_ISO_modelFile.cfg
Loading analog.cxt
Loading asimenv.cxt
Loading spectrei.cxt
Loading devCheck.cxt
Loading relXpert.cxt
Loading hspiceD.cxt
Loading spectreinl.cxt
Loading msgHandler.cxt
Loading UltraSim.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
Loading esd.cxt
*WARNING* envSetVal: Can't set the value of variable 'pinTextSamePurpose',
in tool[.partition] 'layoutXL' - it has not been registered.
打开原理图,就会提示上边的警告,不知道怎么解决
