楼主: cham
[求助] AMS仿真时提示找不到Connect rules? 求助!!
发表于 2020-3-29 19:36:27 | 显示全部楼层
The AMS install directories include Connect Modules and Rules that can be copied
or referenced, but you can write their own and include them in the project. The path
for the built-in set is:
<IUS_path>/tools/affirma_ams/etc/connect_lib
Connect Rules and Modules must be pre-compiled for use in AMS Designer. The
built-in set can be pre-compiled by a system administrator by executing the script:
<IUS_path>/tools/affirma_ams/etc/install/amsConnectLibCompile
Include the Connect Rule and Modules library path in the cds.lib file. The built-in
set, once it is pre-compiled, can be included by adding the following to the cds.lib
file:
SOFTINCLUDE <IUS_path>/tools/inca/files/cds.lib
eetop.cn_AMSDesigner_5_7.OH notes.rar
1.57 MB, 下载次数: 298 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2020-10-6 16:28:44 | 显示全部楼层
谢谢
发表于 2021-2-13 22:50:05 | 显示全部楼层
cham 发表于 2020-2-7 06:17
到tool上一级地址里去运行 ./tools/affirma_ams/etc/install/amsConnectLibCompile
大神请问,为什么我的 ./tools/affirma_ams路径下只有一个lib文件夹,没有etc,请问是怎么回事啊。
发表于 2021-2-14 01:22:59 | 显示全部楼层
可以执行/tools/affirma_ams/etc/install/amsConnectLibCompile来生成connect_lib;注意原始的amsConnectLibCompile有错!!主要是其中的libNames、ncvlog、genConnRulesFile的路径不完整!!,执行会报错;当修改好后,执行./amsConnectLibCompile,便可以在Terminal中观察到有变化。执行完了后将在/tools/affirma_ams/etc/connect_lib中生成cds.lib文件,如果没有编译成功,是不会生成它的。方法参考https://m.newsmth.net/article/METech/126110?p=1
发表于 2021-5-26 14:55:37 | 显示全部楼层
你好,我也只是在你描述的同样位置找到lib文件夹,没有etc。后面你是怎么解决的呢,还望指教。
发表于 2021-10-30 12:58:54 | 显示全部楼层
我也遇到了相同问题,但是我发现我的/tools/affirma_ams路径下面没有etc/install...这些东西
和10楼一样,在tools/dfII/bin里面倒是找到了这个文件:genConnRulesFile.perl
请问各位遇到过这种情况吗
发表于 2021-12-2 21:22:18 | 显示全部楼层
完全按照楼主的说法做,确实变异了成功了,也出现了connectlib但是还是会找不到connectrule
回复 支持 2 反对 0
发表于 2022-5-15 19:48:01 | 显示全部楼层
感谢,标记一下
发表于 2023-1-12 14:55:11 | 显示全部楼层
tool在哪啊  大佬
发表于 2023-1-31 18:24:33 | 显示全部楼层
or referenced, but  ...
Thanks
GMT+8, 2025-12-17 01:11 , Processed in 0.019902 second(s), 5 queries , Gzip On, Redis On.
