在对时序单元D触发器进行特征化时,出现了问题:
- ERROR (LIB-52): The constraint search failed to find a solution within the search range for arc of cell:'DFM1RA_st', r_pin:'CK', r_pin dir:'r', pin:'D', pin dir:'r', type:'hold_rising rise_constraint', vector:'RRxx'. This cell will be marked as failed and the constraint data will be set to: 1.0 (see constraint_failed_value). To debug, review the saved simulation results for deck: hold_5. Possible causes include: 'constraint_delay_degrade' too large; 'constraint_delay_degrade_abstol' too large; 'constraint_check_final_state_threshold' too large;
复制代码
请问有人知道这是为什么吗?
在liberate的template里面,针对时序单元的define_template中的 -constraint应该怎么确定合适呐? |
