查看: 19843|回复: 34
XCELIUMMAIN_18.03.001 + LICENSE TOOL
发表于 2019-2-15 11:07:51 | 显示全部楼层 |阅读模式
Hi everybody,Supporter, manager
I've already had package to install xceliummain 18.03.001 , but i don't have license to install.
Could you help me give solution to have license ??
Thank you very much
发表于 2019-2-15 11:18:06 | 显示全部楼层
你是有病么? 求资源还要买
 楼主| 发表于 2019-2-15 11:29:38 | 显示全部楼层
please support by other method, not buy license
发表于 2019-3-16 09:40:10 | 显示全部楼层
还以为你有…………
发表于 2019-3-23 10:30:19 | 显示全部楼层
哈哈 我的是最新版的 lic可以破
xrun: 18.09-s010: (c) Copyright 1995-2019 Cadence Design Systems, Inc.
file: dut_dummy.v
        module worklib.dut_dummy:v
                errors: 0, warnings: 0
                Caching library 'worklib' ....... Done
        Elaborating the design hierarchy (primary partition):
xmelab: *N,MEVCON: In multi-run MSIE mode, explicit connectivity access from command-line would be required for tran gate pins, if '$dumpports' is used in the design.
        Top level design units:
                dut_dummy
xmelab: *W,DSEMEL: This SystemVerilog design will be simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.
        Building instance overlay tables: .................... Done
        Generating native compiled code:
                worklib.dut_dummy:v <0x0ca9ca81>
                        streams:  17, words:  9380
        Building instance specific data structures.
        Loading native compiled code:     .................... Done
        Design hierarchy summary:
                         Instances  Unique
                Modules:         1       1
                Registers:       6       6
                Scalar wires:   71       -
                Always blocks:   3       3
        Writing primary snapshot: worklib.dut_dummy:v
Compiling UVM packages (uvm_pkg.sv cdns_uvm_pkg.sv) using uvmhome location /tools/cadence/XCELIUM1809/tools/methodology/UVM/CDNS-1.1d
file: ubus_tb_top.sv
        package worklib.ubus_pkg:sv
        interface worklib.ubus_if:sv
        module worklib.ubus_tb_top:sv
Loading primary snapshot worklib.dut_dummy:v .................... Done
        Elaborating the design hierarchy (incremental partition):
        [MSIE] Instance ubus_tb_top.dut is bound to module worklib.dut_dummy:v in primary snapshot worklib.dut_dummy:v
        Top level design units (incremental partition):
                uvm_pkg
                cdns_uvmapi
发表于 2019-3-27 14:44:00 | 显示全部楼层
zw1035961900 发表于 2019-3-23 10:30
哈哈 我的是最新版的 lic可以破
xrun: 18.09-s010: (c) Copyright 1995-2019 Cadence Design Systems, Inc. ...
支持 可以分享么
发表于 2019-4-13 13:28:35 | 显示全部楼层
哈哈 我的是最新版的 lic可以破
share是一种精神
发表于 2019-4-14 07:03:29 | 显示全部楼层
lu guo
发表于 2019-4-18 11:26:28 | 显示全部楼层
哈哈 我的是最新版的 lic可以破
Hey, youhave the license, upload it or at least the public key to get the sfk working, please
发表于 2019-4-19 12:13:06 | 显示全部楼层
共享是一种美德
GMT+8, 2025-12-18 14:48 , Processed in 0.234354 second(s), 3 queries , Gzip On, Redis On.
