查看: 2271|回复: 1
[求助] encounter: routeDesign有时出现警告Some nets are not global routed
发表于 2018-10-10 06:41:53 | 显示全部楼层 |阅读模式
求教各位高人,encounter在做routeDesign -viaOpt时,有时会出现WARNING:
#Using multithreading with 4 threads.
#WARNING (NRDR-13) Some nets are not global routed. Detail routing cannot be run.
#WARNING (NRDR-14) Net paddr_i2c_2 is not global routed.
#WARNING (NRDR-16) 1 nets out of 54201 nets are not global routed. Please run globalRoute or globalDetailRoute on these nets before detailRoute.
#WARNING (NRIF-19) Failed to complete detailRoute on Mon Oct  8 16:40:57 2018
请问怎样才能解决这个问题,还是可以忽略?(globalDetailRoute前一步已经做过了)
命令如下:
setNanoRouteMode -droutePostRouteSwapVia multiCut
setNanoRouteMode -drouteUseMultiCutViaEffort medium
setNanoRouteMode -routeReserveSpaceForMultiCut true
routeDesign -viaOpt
 楼主| 发表于 2018-10-11 00:55:30 | 显示全部楼层
没有人碰到过吗?
GMT+8, 2025-12-21 01:31 , Processed in 0.011808 second(s), 3 queries , Gzip On, Redis On.
