楼主: smartchen
VCS 安装在ubuntu18.04下面的问题【已解决】
发表于 2018-10-10 15:11:28 | 显示全部楼层
understand
发表于 2018-10-12 17:33:48 | 显示全部楼层
Thanks for your information!
Tips for usage (under ubuntu 18.04)
1. install gcc-4.8
sudo apt install gcc-4.8 g++-4.8
2. start vcs
vcs -full64 -cpp g++-4.8 -cc gcc-4.8 -LDFLAGS -Wl,-no-as-needed ....
If startup goes slowly, I think maybe it's caused by license system.
I usually modify the ethernet device name to something like "eth0" ...
the startup procedure seems no any problem,  from my side.
发表于 2018-10-27 00:12:38 | 显示全部楼层
回复 12# mipsgreen
  楼主完全安装好可以用了吗?如果是那就太好了,我正要安装
 楼主| 发表于 2018-10-29 16:28:28 | 显示全部楼层
回复 13# jackwei1987
   你回复的是别人。。。。
已经安装成功了,用了很久了。
12楼解决gcc的方法可以与其他要更高版本gcc的软件共存,更好。
发表于 2018-10-29 20:17:53 | 显示全部楼层
回复 14# smartchen
   哦哦,我还是报错。在超级用户模式下:
root@wei:/home/wei/questasim10.4c/questasim/bin# ./vsim
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license.  Vsim is closing.
** Fatal: Invalid license environment. Application closing.
在普通用户模式下:
wei@wei:~/questasim10.4c/questasim/bin$ ./vsim
Error in startup script:
Initialization problem, exiting.
    while executing
"InitializeINIFile quietly"
    invoked from within
"ncFyP12 -+"
    (file "/mtitcl/vsim/vsim" line 1)
** Fatal: Read failure in vlm process (0,0)
发表于 2018-10-29 20:24:13 | 显示全部楼层
回复 14# smartchen
    看来我搞混了,主要是仿真FPGA的代码,改用questasim了
发表于 2018-10-30 09:30:38 | 显示全部楼层
谢谢分享经验
发表于 2018-10-31 16:12:47 | 显示全部楼层
ubuntu16.04能装吗?
发表于 2018-11-2 21:05:24 | 显示全部楼层
回复 18# 记忆冬天
   Of course!
发表于 2018-11-8 11:33:32 | 显示全部楼层
回复 12# mipsgreen
楼主你好,为什么我的按照你的方式编译以后,运行simv还是显示Command line: ./simv
--- Stack trace follows:
Dumping VCS Annotated Stack:
No context available
GMT+8, 2025-12-19 05:46 , Processed in 0.019152 second(s), 4 queries , Gzip On, Redis On.
