查看: 7571|回复: 8
Fractional Rate Phase Detectors for CDR
发表于 2007-11-9 09:07:51 | 显示全部楼层 |阅读模式
IEEE paper
Abstract—Some recent PLL designs utilize a half-rate phase
detector so that the VCO operates at a frequency that is one-half
of the input data rate. In this paper, a technique is proposed to
extend the half-rate phase detector structure to a rate of  ,
for integer
         . The concept is explained using a rate 1/8
implementation and simulation results are presented to verify the
scheme. These rate    phase detectors can be used to raise the
maximum operating frequency of clock and data recovery circuits
in a given CMOS process technology.
FractionalRatePhaseDetectorForCDR.pdf
256.29 KB, 下载次数: 91 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-12-2 09:48:26 | 显示全部楼层
要传paper就多准备一些啊,打个包哦
发表于 2009-4-25 23:27:08 | 显示全部楼层
98
发表于 2010-9-8 10:36:07 | 显示全部楼层
thanks
发表于 2011-5-16 21:18:20 | 显示全部楼层
楼主无私分享!!!楼主无私分享!!!
发表于 2014-8-27 14:36:43 | 显示全部楼层
以前下过了
发表于 2016-5-14 16:55:59 | 显示全部楼层
thanks!
发表于 2016-6-26 15:46:13 | 显示全部楼层
THANK YOU
发表于 2019-3-25 16:02:01 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-25 14:14 , Processed in 0.025219 second(s), 6 queries , Gzip On, Redis On.
