查看: 1913|回复: 0
龜 兔 賽 跑 另 一 章[推荐]
发表于 2003-12-9 15:54:59 | 显示全部楼层 |阅读模式
龜 兔 賽 跑 另 一 章[推荐]
作者:龜毛的烏龜
校稿:有三棟房子的兔子
排版:有孫子的母雞
  Once upon a time a tortoise and a hare had an argument about who was faster. They decided to settle the argument with a race. They agreed on a route and started off the race.
從前,有一隻烏龜和一隻兔子在互相爭辯誰跑得快。他們決定來一場比賽分高下,選定了路線,就此起跑。
  The hare shot ahead and ran briskly for some time. Then seeing that he was far ahead of the tortoise, he thought he'd sit under a tree for some time and relax before continuing the race.
兔子帶頭衝出,奔馳了一陣子,眼看它已遙遙領先烏龜,心想,它可以在樹下坐一會兒,放鬆一下,然後再繼續比賽。
  He sat under the tree and soon fell asleep. The tortoise plodding on overtook him and soon finished the race, emerging as the undisputed champ.
兔子很快地在樹下就睡著了,而一路上笨手笨腳走來的烏龜則超越過它,不一會兒完成比賽
,成為貨真價實的冠軍。
  The hare woke up and realised that he'd lost the race. The moral of the story is that slow and steady wins the race.
等兔子一覺醒來,才發覺它輸了。這個故事給我們的啟示是:緩慢且持續的人會贏得比賽。
  This is the version of the story that we've all grown up with.
這是從小伴隨我們長大的龜兔賽跑故事的版本。
   But then recently, someone told me a more interesting version of this story. It continues.
但最近有人告訴了我一個更有趣的版本。故事這麼連續下去。
  The hare was disappointed at losing the race and he did some Defect Prevention (Root Cause Analysis). He realised that he'd lost the race only because he had been overconfident, careless and lax.
兔子當然因輸了比賽而倍感失望,為此他做了些缺失預防工作(根本原因解析)。它很清楚,失敗是因它太有信心,大意,以及散漫。
  If he had not taken things for granted, there's no way the tortoise could have beaten him. So he challenged the tortoise to another race. The tortoise agreed.
如果它不要自認一切都是理所當然的,烏龜是不可能打敗它的。因此,它單挑烏龜再來另一場比賽,而烏龜也同意。
  This time, the hare went all out and ran without stopping from start to finish. He won by several miles.
這次,兔子全力以赴,從頭到尾,一口氣跑完,領先烏龜好幾公里。
  The moral of the story? Fast and consistent will always beat the slow and steady.
這故事的有什麼啟示?動作快且前後一致的人將可勝過緩慢且持續的人。
  If you have two people in your organisation, one slow, methodical and reliable, and the other fast and still reliable at what he does, the fast and reliable chap will consistently climb the organisational ladder faster than the slow, methodical chap.
如果在你的工作單位有兩個人,一個緩慢,按部就班,且可靠,另一個則是動作快,且辦事還算牢靠,那麼動作快且牢靠的人會在組織中一直往上爬,陞遷的速度比那緩慢且按部就班辦事的人快。
  It's good to be slow and steady; but it's better to be fast and reliable.
緩慢且持續固然很好,但動作快且牢靠則更勝一籌。
  But the story doesn't end here. The tortoise did some thinking this time, and realised that there's no way he can beat the hare in a race the way it was currently formatted.
這故事還沒完沒了。這下輪到烏龜要好好檢討,它很清楚,照目前的比賽方法,它不可能擊敗兔子。
  He thought for a while, and then challenged the hare to another race, but on a slightly different route.
它想了一會兒,然後單挑兔子再來另一場比賽,但是是在另一條稍許不同的路線上。
  The hare agreed. They started off. In keeping with his self-made commitment to be consistently fast, the hare took off and ran at top speed until he came to a broad river.
兔子同意,然後兩者同時出發。為了確保自己立下的承諾-從頭到尾要一直快速前進,兔子飛馳而出,極速奔跑,直到碰到一條寬闊的河流。
  The finishing line was a couple of kilometers on the other side of the river.
而比賽的終點就在幾公里外的河對面。
  The hare sat there wondering what to do. In the meantime the tortoise trundled along, got into the river, swam to the opposite bank, continued walking and finished the race.
兔子呆坐在那裡,一時不知怎麼辦。這時候,烏龜卻一路跚跚而來,撩入河裡,游到對岸,繼續爬行,完成比賽。
  The moral of the story? First identify your core competency and then change the playing field to suit your core competency.
這故事的有什麼啟示?首先,辨識出你的核心競爭力,然後改變遊戲場所以適應(發揮)你的核心競爭力。
  In an organisation, if you are a good speaker, make sure you create opportunities to give presentations that enable the senior management to notice you.
在你的工作單位,如果你是一個能言善道的人,一定要想法創造機會,好好表現自己,以便讓層峰注意到你。
  If your strength is analysis, make sure you do some sort of research, make a report and send it upstairs. Working to your strengths will not only get you noticed but will also create opportunities for growth and advancement.
如果你的優勢是從事分析工作,那麼你一定要做一些研究,寫一個報告,然後呈送上樓。依著自己的優勢(專長)來工作,不僅會讓上頭的人注意到你,也會創造成長和進步的機會。
  The story still hasn't ended.
故事還沒結束。
  The hare and the tortoise, by this time, had become pretty good friends and they did some thinking together. Both realised that the last race could have been run much better.
這下子,兔子和烏龜成了惺惺相惜的好朋友。它們一起檢討,兩個都很清楚,在上一次的比賽中,它們可以表現得更好。
  So they decided to do the last race again, but to run as a team this time.
所以,他們決定再賽一場,但這次是同隊合作。
  They started off, and this time the hare carried the tortoise till the riverbank. There, the tortoise took over and swam across with the hare on his back.
它們一起出發,這次可是兔子扛著烏龜,直到河邊。在那裡,烏龜接手,背著兔子過河。。
  On the opposite bank, the hare again carried the tortoise and they reached the finishing line together. They both felt a greater sense of satisfaction than they'd felt earlier.
到了河對岸,兔子再次扛著烏龜,兩個一起抵達終點。比起前次,它們都感受到一種更大的成就感。
  The moral of the story? It's good to be individually brilliant and to have strong core competencies; but unless you're able to work in a team and harness each other's core competencies, you'll always perform below par because there will always be situations at which you'll do poorly and someone else does well.
這故事的有什麼啟示?個人表現優異與擁有堅強的核心競爭力固然不錯,但除非你能在一個團隊內(與別人)同心協力,並掌控彼此間的核心競爭力,否則你的表現將永遠在標準之下,因為總有一些狀況下,你是技不如人,而別人卻幹得蠻好的。
Teamwork is mainly about situational leadership, letting the person with the relevant core competency for a situation take leadership.
團隊合作主要就是有關情境(權變)領導這檔事,讓具備處理某一情境能力(核心競爭力)的人當家做主。
There are more lessons to be learnt from this story.
從這故事,我們可以學到更多
Note that neither the hare nor the tortoise gave up after failures. The hare decided to work harder and put in more effort after his failure.
我們了解,在遭逢失敗後,兔子和烏龜都沒有就此放棄。兔子決定更拼,並且投入更多的努力。
The tortoise changed his strategy because he was already working as hard as he could. In life, when faced with failure, sometimes it is appropriate to work harder and put in more effort.
在盡了全力之後,烏龜則選擇改變策略。在人的一生中,當失敗臨頭時,有時我們需更加努力。
  Sometimes it is appropriate to change strategy and try something different. And sometimes it is appropriate to do both.
有時則需改變策略,嘗試不同的抉擇。有時候,兩者都要一起來。
  The hare and the tortoise also learnt another vital lesson. When we stop competing against a rival and instead start competing against the situation, we perform far better.
兔子和烏龜也學到了最關鍵的一課。當我們不再與競爭對手較力,而開始逐鹿某一情境時,我們會表現得更好。
  To sum up, the story of the hare and tortoise teaches us many things.
Chief among them are that fast and consistent will always beat slow and steady; work to your competencies; pooling resources and working as a team will always beat individual performers; never give up when faced with failure; and finally, compete against the situation. Not against a rival.
結論:龜兔賽跑的故事啟發我們良多。
最重要的是:動作快且前後一致的人總是勝過緩慢且持續的人;依著自己的優勢(專長)來工作;結合所有的資源且團隊合作的人,總是打敗單打獨鬥者;面對失敗時,絕不輕言放棄;最後,與某一情境競爭,而不是限定某對手。
GMT+8, 2025-12-17 20:30 , Processed in 0.030409 second(s), 7 queries , Gzip On, Redis On.
