查看: 4693|回复: 3
一篇vco论文
发表于 2007-10-17 00:23:40 | 显示全部楼层 |阅读模式
如题
A critical building block of almost any wireless or wireline transceiver is the local oscillator
(LO). When used with a mixer, the LO allows frequency translation and channel selection
of radio frequency (RF) signals. The LO is typically implemented as a phase-locked
loop (PLL), wherein a voltage-controlled oscillator (VCO) is phase-locked to a high-stability
crystal oscillator. A VCO is basically comprised of a gain element and a resonator.
The resonator determines the oscillation frequency, and when it is composed of energystoring
inductors and capacitors, it is often referred to as an LC tank. A voltage-controlled
varactor diode allows the oscillation frequency of the VCO to be varied.
The most critical performance specification for an oscillator is phase noise. In a
receiver, the phase noise of the LO limits the ability to detect a weak signal in the presence
of a strong signal in an adjacent channel. In a transmitter, phase noise results in energy
being transmitted outside of the desired band. To help minimize phase noise, we need
high-Q (low-loss) inductors and capacitors.
发表于 2007-10-30 16:22:56 | 显示全部楼层
谢谢谢谢!
发表于 2008-4-3 18:08:35 | 显示全部楼层
XIEXIE
XIEXIE
发表于 2008-4-3 19:46:02 | 显示全部楼层
xiexiexie
GMT+8, 2025-12-18 16:42 , Processed in 0.020219 second(s), 5 queries , Gzip On, Redis On.
