查看: 18026|回复: 58
ANALOG DEVICES的HIGH SPEED DESIGN TECHNIQUES教程
发表于 2007-10-6 14:19:40 | 显示全部楼层 |阅读模式
ANALOG DEVICES关于高速设计方面的教程,非常不错,下面是它的目录
PREFACE
SECTION 1
HIGH SPEED OP AMPS
Voltage Feedback Op Amps
Current Feedback Op Amps
Effects of Feedback Capacitance
High-Speed Current-to-Voltage Converters, and the Effects of Inverting Input Capacitance
Noise Comparisons between Voltage Feedback Op Amps and Current Feedback Op Amps
DC Characteristics of High Speed Op Amps
SECTION 2
HIGH SPEED OP AMP APPLICATIONS
Optimizing the Feedback Network for Maximum
Bandwidth Flatness in Wideband CFB Op Amps
Driving Capacitive Loads
Cable Drivers and Receivers
A High Performance Video Line Driver
Differential Line Drivers/Receivers
High Speed Clamping Amplifiers
Single-Supply/Rail-to-Rail Considerations
High Speed Video Multiplexing with Op Amps Using Disable Function
Video Programmable Gain Amplifier
Video Multiplexers and Crosspoint Switches
High Power Line Drivers and ADSL
High Speed Photodiode Preamps
SECTION 3
RF/IF SUBSYSTEMS
n Dynamic Range Compression
n Linear VCAs
n Log/Limiting Amplifiers
n Receiver Overview
n Multipliers, Modulators, and Mixers
n Modulation / Demodulation
n Receiver Subsystems
SECTION 4
HIGH SPEED SAMPLING AND HIGH SPEED ADCs
n Fundamentals of High Speed Sampling
n Baseband Antialiasing Filters
n Undersampling
n Antialiasing Filters in Undersampling Applications
n Distortion and Noise in an Ideal N-bit ADC
n Distortion and Noise in Practical ADCs
n High Speed ADC Architectures
SECTION 5
HIGH SPEED ADC APPLICATIONS
n Driving ADC Inputs for Low Distortion and Wide
Dynamic Range
n Applications of High Speed ADCs in CCD Imaging
n High Speed ADC Applications in Digital Receivers
SECTION 6
HIGH SPEED DACs AND DDS SYSTEMS
n Introduction to DDS
n Aliasing in DDS Systems
n 125MSPS DDS System (AD9850)
n DDS Systems as ADC Clock Drivers
n Amplitude Modulation in a DDS System
n The AD9831/AD9832 Complete DDS System
n Spurious Free Dynamic Range Considerations in
DDS Systems
n High Speed Low Distortion DAC Architectures
n Improving SFDR Using Sample-and-Hold Deglitchers
n High Speed Interpolating DACs
n QPSK Signal Generation Using DDS (AD9853)
SECTION 7
HIGH SPEED HARDWARE DESIGN TECHNIQUES
n Analog Circuit Simulation
n Prototyping Analog Circuits
n Evaluation Boards
n Grounding in High Speed Systems
n Power Supply Noise Reduction and Filtering
n Power Supply Regulation/Conditioning
n Thermal Management
n EMI/RFI Considerations
n Shielding Concepts
B009-High Speed Design Techniques.part1.rar
2.44 MB, 下载次数: 225 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-6 14:24:44 | 显示全部楼层
同上
第二部分:
B009-High Speed Design Techniques.part2.rar
2.44 MB, 下载次数: 185 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-6 14:26:54 | 显示全部楼层
同上
继续来吧:
B009-High Speed Design Techniques.part3.rar
2.27 MB, 下载次数: 187 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-10-11 08:45:10 | 显示全部楼层
xia look
发表于 2007-10-12 10:56:23 | 显示全部楼层
正在下载,谢谢
发表于 2007-10-12 10:58:42 | 显示全部楼层
这个还是不错的,支持啊
大家可以看看
发表于 2007-12-12 19:03:17 | 显示全部楼层
thanks good boy
发表于 2007-12-17 15:03:49 | 显示全部楼层
ADI 的好东东啊~~
发表于 2007-12-19 10:18:17 | 显示全部楼层
ADI的教程是一定要看看的.谢谢.
发表于 2007-12-19 18:41:13 | 显示全部楼层
内容很实用,谢谢分享
GMT+8, 2025-12-23 04:40 , Processed in 0.025022 second(s), 7 queries , Gzip On, Redis On.
