楼主: haibianxia
(东南大学)PWM_PFM自动切换降压DC_DC转换器的分析与设计
发表于 2009-3-25 10:35:39 | 显示全部楼层
dingdingding
发表于 2009-3-25 11:37:50 | 显示全部楼层
下来看看,先感谢
发表于 2009-3-26 07:59:29 | 显示全部楼层
Refugee's modification  is completely wrong.  He does not understand the operation of this cicruit.
Acutally, if 改成虚线所示, the current sensor no longer monitors or detects Ids of Mp power transistor and of course fails. Originally schematic is correct although it is quite simple and not that much accurate. However, for PWM/PFM transition, the threshold varition +/-20% is acceptable.  If used in Current Mode DC-DC, this circuit is not good enough.
发表于 2009-4-17 01:13:48 | 显示全部楼层
看看有没有用
发表于 2009-4-17 03:07:43 | 显示全部楼层
pwm 應該很難吧, 推推推
发表于 2009-4-22 12:40:23 | 显示全部楼层
顶一下
顶一下
发表于 2009-4-22 12:44:08 | 显示全部楼层
看看再说
看看再说
发表于 2009-8-19 22:09:07 | 显示全部楼层
h嘿 下了
发表于 2009-8-21 23:28:41 | 显示全部楼层
顶一下
发表于 2009-8-22 18:10:26 | 显示全部楼层
现下一个  有时间慢慢学习了
GMT+8, 2025-12-22 07:04 , Processed in 0.020908 second(s), 4 queries , Gzip On, Redis On.
