查看: 6214|回复: 20
[资料] 非常好的coverage 入门书籍
发表于 2018-9-4 10:15:48 | 显示全部楼层 |阅读模式
以下是目录
适合个阶段的验证工程师们.当然了资深工程师早就看过了
Coverage - This overview page
Introduction - Introduction to the Coverage Cookbook
Coverage Metrics and process (Theory)
What is coverage? - What coverage is about and why you should use it
Kinds of coverage - An explanation of the different types of coverage available
Code Coverage - An explanation of the different types of code coverage
Functional Coverage - Describes the various alternative forms of functional coverage
Specification to testplan - Outlines different approaches for creating a testplan based on specifications
Executable Testplan Format - Describes the format of an executable testplan spreadsheet
Testplan to functional coverage - Explains how to go from a testplan to a coverage model
Coding for analysis - How to ensure that your functional coverage code gives results that are easy to
interpret
Coverage Examples (Practice)
Bus protocol coverage - Illustrates how to use assertions to check a bus protocol and yield functional coverage data
APB3 Protocol test plan - A test plan for the APB3 protocol
APB3 Protocol Monitor - A set of code fragments from the implemented APB3 Protocol monitor
Block Level coverage - A block level UART design, where functional coverage is is based mainly on register
based configuration
UART test plan - The test plan for the UART
UART example covergroups - A set of code fragments illustrating how to implement the block level
covergroups
Datapath Coverage - Illustrates how coverage is collected on the settings of a datapath block
Coverage 2
UVM/OVM Documentation - Copyright (c) 2012 Mentor Graphics Corporation - http://verificationacademy.com/uvm-ovm
BiQuad IIR Filter test plan - A test plan for the BiQuad IIRFilter
BiQuad IIR Filter example covergroups - Code fragments to illustrate the implementation of the BiQuad IIR
functional coverage model
SoC coverage example - Explains the process for creating a SoC functional coverage model based on use cases
Appendices
Requirements Writing Guidelines - Guidelines for thinking about and writing requirements
Please note that it may not always be possible or appropriate to supply source code for all of the examples in the
Coverage Cookbook
coverage-cookbook-complete-verification-academy.rar
1.71 MB, 下载次数: 254 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2018-9-5 09:27:43 | 显示全部楼层
thanks
发表于 2018-9-5 13:55:25 | 显示全部楼层
thanks for your sharing!
发表于 2018-9-5 18:33:21 | 显示全部楼层
thanks
发表于 2018-9-5 22:47:55 | 显示全部楼层
多谢分享
发表于 2018-9-8 10:57:48 | 显示全部楼层
感谢 分享
发表于 2018-9-11 19:24:42 | 显示全部楼层
发表于 2018-9-30 23:30:44 | 显示全部楼层
thank you a lot
发表于 2018-10-23 19:53:56 | 显示全部楼层
Thanks for sharing.
发表于 2019-2-26 15:49:35 | 显示全部楼层
thanks
点评
yes  发表于 2019-9-25 22:02
GMT+8, 2025-12-28 01:05 , Processed in 0.026620 second(s), 9 queries , Gzip On, Redis On.
