查看: 2034|回复: 1
[求助] 两个class类型转换的结果是什么,怎么理解
发表于 2018-6-5 11:24:18 | 显示全部楼层 |阅读模式
class apb_monitor extends uvm_monitor;
   virtual apb_if.passive sigs;
   uvm_analysis_port#(apb_rw) ap;
   apb_config cfg;
   `uvm_component_utils(apb_monitor)
   function new(string name, uvm_component parent = null);
      super.new(name, parent);
      ap = new("ap", this);
   endfunction: new
   virtual function void build_phase(uvm_phase phase);
      apb_agent agent;
      if ($cast(agent, get_parent()) && agent != null) begin
         sigs = agent.vif;
      end
      else begin
         virtual apb_if tmp;
         if (!uvm_config_db#(apb_vif)::get(this, "", "vif", tmp)) begin
            `uvm_fatal("APB/MON/NOVIF", "No virtual interface specified for this monitor instance")
         end
         sigs = tmp;
      end
   endfunction
   virtual protected task run_phase(uvm_phase phase);
      super.run_phase(phase);
      forever begin
         apb_rw tr;
         // Wait for a SETUP cycle
         do begin
            @ (this.sigs.pck);
         end
         while (this.sigs.pck.psel !== 1'b1 ||
                this.sigs.pck.penable !== 1'b0);
         tr = apb_rw::type_id::create("tr", this);
endclass: apb_monitor
         sigs = agent.vif;
get_parent()得到的还是agent,为什么还要转换一下
发表于 2018-6-5 15:20:13 | 显示全部楼层
haohaohao
GMT+8, 2025-12-17 14:45 , Processed in 0.012763 second(s), 3 queries , Gzip On, Redis On.
