查看: 3145|回复: 1
[求助] qsys创建pcie出现错误,求救
发表于 2018-5-29 15:54:18 | 显示全部楼层 |阅读模式
根据网上的博客文章《[size=1em]Qsys创建ALTERA PCIe》,一步一步设计的PCIE,到后面还有这些错误,请问大家有谁能帮我看下是什么问题。
Error: System.pcie_hard_ip_0.: set ALTERA_HW_TCL_KEEP_TEMP_FILES=1 to retain temp files
Error: System.pcie_hard_ip_0.: Command: C:/altera/13.1/quartus\bin/quartus_map.exe not_a_project --generate_hdl_interface=C:/altera/13.1/ip/altera/altera_pcie/altera_pcie_avmm/altpcie_hip_pipen1b_qsys.v --source=C:/altera/13.1/ip/altera/altera_pcie/altera_pcie_avmm/altpcie_hip_pipen1b_qsys.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/joe/AppData/Local/Temp/alt7680_8742741961398406373.dir/0001_sopcqmap/ --ini=disable_check_quartus_compatibility_qsys_only=on
Error: System.pcie_hard_ip_0.: Command took 0.972s
Error: System.pcie_hard_ip_0.: Analyser output file not present: altpcie_hip_pipen1b_qsys.v.xml
Error: System.pcie_hard_ip_0.: No definition of altpcie_hip_pipen1b_qsys in
Warning: System.pcie_hard_ip_0.pcie_hard_ip_0: Module dependency loop involving: "pcie_internal_hip" (altera_pcie_internal_hard_ip_qsys 13.1)
Warning: System.pcie_hard_ip_0.pcie_hard_ip_0: Module dependency loop involving: "avalon_clk" (altera_clock_bridge 13.1), "pcie_internal_hip" (altera_pcie_internal_hard_ip_qsys 13.1)
Warning: System.pcie_hard_ip_0.pcie_internal_hip.app_msi_ack: Interface has no signals
Warning: System.pcie_hard_ip_0.pcie_internal_hip.app_msi_num: Interface has no signals
Warning: System.pcie_hard_ip_0.pcie_internal_hip.app_msi_req: Interface has no signals
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.pcie_core_clk cannot be both connected and exported
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.app_msi_ack must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.rc_rx_analogreset must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.rc_rx_digitalreset must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.app_msi_num must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.app_msi_req must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.msi_interface_export must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.tx_deemph_0 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pcie_internal_hip: pcie_internal_hip.tx_margin_0 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pipe_interface_internal: pipe_interface_internal.pll_powerdown_pcs must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pipe_interface_internal: pipe_interface_internal.rateswitch_pcs must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.pipe_interface_internal: pipe_interface_internal.rateswitchbaseclock_pcs must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_2 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_3 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_4 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_5 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_6 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_7 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_8 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.refclk_conduit: refclk_conduit.conduit_out_9 must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0.reset_controller_internal: reset_controller_internal.reset_n_out cannot be both connected and exported
Warning: System.pcie_hard_ip_0: pcie_hard_ip_0.powerdown must be exported, or connected to a matching conduit.
Warning: System.pcie_hard_ip_0: Interrupt sender pcie_hard_ip_0.cra_irq is not connected to an interrupt receiver
Info: System.pcie_hard_ip_0:  Rx Master BAR 1_0 mapped to 26 -bit Avalon-MM address
Info: System.pcie_hard_ip_0:  Rx Master BAR 2 mapped to 15 -bit Avalon-MM address
Info: System.pcie_hard_ip_0.pcie_internal_hip:  Txs Address width is 25
Info: System.pcie_hard_ip_0.pcie_internal_hip: Application clock frequency is 125 Mhz
Info: System.pcie_hard_ip_0.altgx_internal: Family: Cyclone IV GX
Info: System.pcie_hard_ip_0.altgx_internal: Lanes: 1
 楼主| 发表于 2018-5-30 10:50:01 | 显示全部楼层
已解决。软件安装的问题。
GMT+8, 2025-12-16 03:43 , Processed in 0.011249 second(s), 3 queries , Gzip On, Redis On.
