查看: 6897|回复: 13
柯明道-Design of mixedvoltage IO buffer by using NMOSblocking technique
发表于 2007-9-6 16:53:54 | 显示全部楼层 |阅读模式
論文名稱Design of mixed-voltage I/O buffer by using NMOS-blocking technique
期刊Ming-Dou Ker and S.-L. Chen, “Design of mixed-voltage I/O buffer by using NMOS-blocking technique,”IEEE Journal of Solid-State Circuits, vol. 41, no. 10, pp. 2324-2333, Oct. 2006.
摘要        An nMOS-blocking technique for mixed-voltage I/O buffer realized with only 1 VDD devices can receive 2XVDD, 3XVDD, and even 4XVDD input signal without the gate-oxide reliability issue is proposed. In this paper, the 2 VDD input tolerant mixed-voltage I/O buffer by using the nMOS-blocking technique has been verified in a 0.25-um 2.5-V CMOS process to serve 2.5/5-V mixed-voltage interface. The 3 VDD input tolerant mixed-voltage I/O buffer by using the nMOS-blocking technique has been verified in a 0.13-um 1-V CMOS process to serve 1/3-V mixed-voltage interface. The proposed nMOS-blocking technique can be extended to design the 4XVDD, 5XVDD, and even 6XVDD input tolerant mixed-voltage I/O buffers. The limitation of the nMOS-blocking technique is the breakdown voltage of the pn-junction in the given CMOS process
關鍵字Gate-oxide reliability, hot-carrier degradation,
interface, junction breakdown, mixed-voltage I/O buffer
918_Ker_SLChen_JSSC_Oct_2006.pdf
1.75 MB, 下载次数: 156 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-9-7 00:33:25 | 显示全部楼层
xiexie  louzhu!!!
发表于 2007-9-7 02:43:33 | 显示全部楼层
thanks!
发表于 2008-6-18 09:22:52 | 显示全部楼层
Thanks!
 楼主| 发表于 2008-7-30 18:46:14 | 显示全部楼层
发表于 2009-6-9 22:43:34 | 显示全部楼层
偶来取经啦
发表于 2011-7-19 23:06:00 | 显示全部楼层
Thanks!
发表于 2019-9-7 23:28:54 | 显示全部楼层
论文中没有提及如何设计4xVdd的动态偏置电路?有没有人设计过这种电路,或者类似的资料参考一下?谢谢
发表于 2020-5-23 21:32:39 | 显示全部楼层
thanks!
发表于 2022-2-22 13:26:34 | 显示全部楼层
学习
GMT+8, 2025-12-30 12:39 , Processed in 0.026748 second(s), 8 queries , Gzip On, Redis On.
