查看: 7353|回复: 2
[求助] (已解决)跑uvm仿真提示rsp_export Connection Error和BUILDERR
发表于 2018-5-16 23:58:13 | 显示全部楼层 |阅读模式
*Verdi3* : End of traversing.
UVM_ERROR @ 0.0ns: uvm_test_top.env.master_agent.seqr.rsp_export [Connection Error] connection count of 0 does not meet required minimum of 1
UVM_FATAL @ 0.0ns: reporter [BUILDERR] stopping due to build errors
--- UVM Report Summary ---
** Report counts by severity
UVM_INFO :    1
UVM_WARNING :    0
UVM_ERROR :    1
UVM_FATAL :    1
** Report counts by id
[BUILDERR]     1
[Connection Error]     1
[RNTST]     1
$finish called from file "/eda/synopsys/vcs/etc/uvm/base/uvm_report_object.svh", line 277.
$finish at simulation time        0.0ns
以上是log报告,试了把driver的rsp_port连到agt的rsp_export,还是会同样的报错,有大神遇到过这个问题吗?怎么解决?谢谢
发表于 2018-5-17 15:36:18 | 显示全部楼层
在哪个phase你做的connection?
 楼主| 发表于 2018-5-19 22:34:09 | 显示全部楼层
问题解决了,是因为我在seqr的connect_phase函数里漏掉了super.connect_phase(phase)语句
GMT+8, 2025-12-28 09:45 , Processed in 0.013579 second(s), 3 queries , Gzip On, Redis On.
