查看: 7690|回复: 8
[求助] CSMC 0.18um工艺 LVS不识别cmim电容
发表于 2018-5-12 22:09:24 | 显示全部楼层 |阅读模式
mimlvs.GIF CMSC 0.18um工艺 LVS总是不能识别MIM电容器,LVS报3个错误,如图1,mim电容的结构如图2,下底板通过m3连接出来,上极板通过M4接出。问题出在哪里? mimstruct.GIF cmimlayout.GIF
Deleting PHDB cmim_test.phdb
Deleting XDB cmim_test.xdb
MGC_HOME = /apps/aoi_cal_2014.4_18.13
$MGC_HOME/bin/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
//  Calibre v2014.4_18.13    Wed Nov 5 16:04:06 PST 2014
//  Calibre Utility Library   v0-7_7-2014-2    Tue Jul 8 18:35:09 PDT 2014
//  Litho Libraries v2014.4_18.13  Wed Nov 5 16:04:06 PST 2014
//        Copyright Mentor Graphics Corporation 1996-2014
//                       All Rights Reserved.
//   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Mentor Graphics software executing under x86-64 Linux
//  Running on Linux eda 2.6.32-71.el6.x86_64 #1 SMP Wed Sep 1 01:33:01 EDT 2010 x86_64 glibc 2.12/NPTL 2.12
//  Entries in /proc/meminfo:
//  MemTotal:        2054708 kB
//  MemFree:          412224 kB
//  Buffers:          243272 kB
//  Cached:           714684 kB
//  SwapCached:            0 kB
//  Active:           674908 kB
//  Inactive:         635472 kB
//  Active(anon):     352636 kB
//  Inactive(anon):     5280 kB
//  Active(file):     322272 kB
//  Inactive(file):   630192 kB
//  Unevictable:           0 kB
//  Mlocked:               0 kB
//  SwapTotal:       4128760 kB
//  SwapFree:        4128760 kB
//  Dirty:               152 kB
//  Writeback:             0 kB
//  AnonPages:        348352 kB
//  Mapped:           128060 kB
//  Shmem:              5492 kB
//  Slab:             279656 kB
//  SReclaimable:     176012 kB
//  SUnreclaim:       103644 kB
//  KernelStack:        2064 kB
//  PageTables:        29628 kB
//  NFS_Unstable:          0 kB
//  Bounce:                0 kB
//  WritebackTmp:          0 kB
//  CommitLimit:     5156112 kB
//  Committed_AS:     829520 kB
//  VmallocTotal:   34359738367 kB
//  VmallocUsed:      274608 kB
//  VmallocChunk:   34359442720 kB
//  HardwareCorrupted:     0 kB
//  AnonHugePages:     88064 kB
//  HugePages_Total:       0
//  HugePages_Free:        0
//  HugePages_Rsvd:        0
//  HugePages_Surp:        0
//  Hugepagesize:       2048 kB
//  DirectMap4k:       10240 kB
//  DirectMap2M:     2086912 kB
//  CPU Info: Cores = 1
//  Max file descriptors: 1024
//  64 bit virtual addressing enabled
//  Running aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
//  Process ID: 25223
//  Starting time: Sun May 13 10:05:33 2018
//  Running on 1 CPU (pending licensing)
-----          STANDARD VERIFICATION RULE FILE COMPILATION MODULE          -----
--- RULE FILE = /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
WARNING: The PEX NETLIST keyword 'LOOP' is obsolete and will be ignored. Please remove from your ruledeck.
//  Rule file generated on Sun May 13 10:05:33 CST 2018
//     by Calibre Interactive - LVS (v2014.4_18.13)
//      *** PLEASE DO NOT MODIFY THIS FILE ***
LAYOUT PATH  "cmim_test.calibre.db"
LAYOUT PRIMARY "cmim_test"
LAYOUT SYSTEM GDSII
SOURCE PATH "/home/jshi/csmc18/lvs/cmim_test.src.net"
SOURCE PRIMARY "cmim_test"
SOURCE SYSTEM SPICE
MASK SVDB DIRECTORY "svdb" QUERY
LVS REPORT "cmim_test.lvs.report"
LVS REPORT OPTION NONE
LVS FILTER UNUSED OPTION NONE SOURCE
LVS FILTER UNUSED OPTION NONE LAYOUT
LVS REPORT MAXIMUM 50
LVS POWER NAME
"VDD4"
LVS GROUND NAME
"GND"
LVS RECOGNIZE GATES ALL
LVS ABORT ON SOFTCHK NO
LVS ABORT ON SUPPLY ERROR YES
LVS IGNORE PORTS NO
LVS SHOW SEED PROMOTIONS NO
LVS SHOW SEED PROMOTIONS MAXIMUM 50
LVS ISOLATE SHORTS NO
VIRTUAL CONNECT COLON NO
VIRTUAL CONNECT REPORT NO
LVS EXECUTE ERC YES
ERC RESULTS DATABASE "cmim_test.erc.results"
ERC SUMMARY REPORT "cmim_test.erc.summary" REPLACE HIER
ERC CELL NAME YES CELL SPACE XFORM
ERC MAXIMUM RESULTS 1000
ERC MAXIMUM VERTEX 4096
DRC ICSTATION YES
INCLUDE "/home/jshi/csmc18/lvs/CSMC018_mixRF_sali_calLVS.rul"
--- STANDARD VERIFICATION RULE FILE COMPILATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 1/3/4
--- CALIBRE_* ENVIRONMENT VARIABLES:
CALIBRE_CMD_LINE='/apps/aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre  -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_'
CALIBRE_ECHO_RULE_FILE=
CALIBRE_HOME=/apps/aoi_cal_2014.4_18.13
CALIBRE_INITIAL_CMD_LINE='/apps/aoi_cal_2014.4_18.13/bin/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_'
CALIBRE_READDB_LD_LIBRARY_PATH=/apps/aoi_cal_2014.4_18.13/pkgs/icv_lib/lib64:/apps/aoi_cal_2014.4_18.13/pkgs/icv_qt_comp/plugins:/apps/aoi_cal_2014.4_18.13/pkgs/umc_libs/lib/lnx32:/apps/aoi_cal_2014.4_18.13/shared/pkgs/icv_oa/22.41.004/lib/linux_rhel40_gcc44x_64/opt:/apps/Cadence/IC5141/tools/lib:/apps/Cadence/IC5141/tools/lib:/apps/Cadence/IC5141/tools/dfII/lib:/lib:/lib64:/usr/lib:/usr/lib64
CALIBRE_SKIP_OS_CHECKS=
CALIBRE_SSE3_SUPPORTED=1
--- CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR - Sun May 13 10:05:33 2018
//  Applying licensing policy...
//  mgc_s license acquired (calibrehlvs requested).
//  mgc_s license acquired (calibrelvs requested).
//  Licensed Products
//  Base products running on 1 core:
//  - LVS (Hierarchical)
//  - LVS Extraction
-----                   CALIBRE LAYOUT DATA INPUT MODULE                   -----
--- LAYOUT SYSTEM = GDS
--- LAYOUT MAGNIFICATION = 1
-----                     GDS FILE SUMMARY INFORMATION                     -----
GDS FILENAME:        cmim_test.calibre.db
GDS VERSION:         5
LIBRARY NAME:        MLX.DB
LAST MODIFIED:       ON 2018/5/12 AT 21:40:29
LAST ACCESSED:       ON 2018/5/13 AT 10:5:30
DATABASE PRECISION:  0.001 user units per database unit
PHYSICAL PRECISION:  1e-09 meters per database unit
MAGNIFICATION:       1
-----                 GDS INPUT DATA FOR INDIVIDUAL CELLS                  -----
     CELL NAME                  PLACEMENTS   ARRAYS   POLYGONS    PATHS    TEXTS
OSC_C_1_cell                             0        0         39        0        0
cmim_test                                1        0          4        0        9
NOTE: UNUSED geometric data is present on the following layer/datatype pairs:
    LAYER = 94 DATATYPE = 0
    LAYER = 153 DATATYPE = 1
NOTE: The following required simple layers are EMPTY:
    1002
    1003
    1004
    1005
    1007
    1008
    1009
    1012
    1013
    1014
    1017
    1018
    1019
    1020
    1022
    1023
    1024
    1030
    1032
    1033
    1034
    1035
    1036
    1037
    1039
    1040
    1041
    1042
    1043
    1045
    1046
    1047
    1048
    1049
    1050
    1051
    1052
    1053
    1055
    1056
    1057
    1058
    1059
    1060
    1061
    1062
    1063
    1064
    1065
    1066
    1067
    1068
    1069
    1071
    1072
    1073
    1074
    1075
    1076
    1077
    1080
    1081
    1082
    1083
    1084
    1085
    1086
    1087
--- LAYOUT DATABASE CONSTRUCTOR COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/4/67
CONSTRUCTING HIERARCHICAL DATABASE
    COPYING LAYOUT DATABASE
    FLATTENING SELECTED LAYERS
    PROCESSING TEXT
    ELIMINATING DUPLICATE TEXT
    ELIMINATING EMPTY CELLS
    COMPUTING RECTANGULAR EXTENTS
    ELIMINATING DUPLICATE PLACEMENTS
    IDENTIFYING TOP LAYER CELLS
    IDENTIFYING ADDITIONAL TOP LAYER CELLS
    IDENTIFYING VERY SMALL CELLS
    CHECKING ACUTE/SKEW/ANGLED/OFFGRID
    FLATTENING SELECTED VERY SMALL CELL PLACEMENTS
    FLATTENING SELECTED TOP LAYER CELL PLACEMENTS
    EXPANDING UNIQUE VERY SMALL CELL PLACEMENTS
    EXPANDING UNIQUE TOP LAYER CELL PLACEMENTS
    EXPANDING UNIQUE MONO-GEOMETRIC CELL PLACEMENTS
    EXPANDING LARGE TOP LAYER CELL PLACEMENTS
    COMPUTING RECTILINEAR EXTENTS
    SORTING PLACEMENTS
    EXPANDING UNIQUE TRANSPARENT CELL PLACEMENTS
        OSC_C_1_cell in cmim_test at (1.978,30.175)
    EXPANDING UNIQUE LIGHT-WEIGHT CELL PLACEMENTS
    EXPANDING UNIQUE ROW CELL PLACEMENTS
    EXPANDING TRIVIAL CELL PLACEMENTS
    EXPANDING VERY SPARSE ARRAY PLACEMENTS
    EXPANDING LARGE CELL ARRAY PLACEMENTS
    EXPANDING VERY SPARSE CELL PLACEMENTS
    ELIMINATING DUPLICATE SUPER-HIERARCHICAL PLACEMENTS
    PROCESSING LAYOUT BLOAT LAYERS (auto-detected)
    PROCESSING LARGE CELL EXTENT-BLOATING LAYERS
    EXPANDING DENSE OVERLAPS
    EXPANDING UNIQUE META-CELL PLACEMENTS
    INJECTING HIERARCHY
    FLATTENING REMAINING VERY SMALL CELL PLACEMENTS
    SORTING PLACEMENTS
    PUSHING VERY SMALL CELL PLACEMENTS
    PUSHING TOP LAYER CELL PLACEMENTS
    COMPUTING CELL-TO-WORLD TRANSFORMS
    SORTING PLACEMENTS
    PACKING HIERARCHY
    COMPUTING PLACEMENT OVERLAP RECORDS
    COMPUTING CELL OVERLAP AREAS
    INTERSECTING PLACEMENTS AND OVERLAP AREAS
HIERARCHICAL DATABASE CONSTRUCTOR COMPLETE.
CPU TIME = 0  REAL TIME = 0  LVHEAP = 2/5/67
-----               TEXT OBJECTS FOR CONNECTIVITY EXTRACTION               -----
plus (-4.14,34.939) 1016 cmim_test      vdd (9.062,22.875) 1001 cmim_test
gnd! (28.739,35.463) 1011 cmim_test
-----                TEXT OBJECTS FOR WITH TEXT OPERATIONS                 -----
-----               TEXT OBJECTS FOR EXPAND TEXT OPERATIONS                -----
-----                  TEXT OBJECTS FOR CAPI OPERATIONS                    -----
-----                                PORTS                                 -----
-----             LAYER READ SUMMARY (SIMPLE LAYER GEOMETRIES)             -----
  1000                   1
  1002                   0
  1003                   0
  1004                   0
  1005                   0
  1007                   0
  1008                   0
  1009                   0
  1010                   2
  1012                   0
  1013                   0
  1014                   0
  1015                   1
  1017                   0
  1018                   0
  1019                   0
  1020                   0
  1022                   0
  1023                   0
  1024                   0
  1030                   0
  1032                   0
  1033                   0
  1034                   0
  1035                   0
  1036                   0
  1037                   0
  1038                  35
  1039                   0
  1040                   0
  1041                   0
  1042                   0
  1043                   0
  1045                   0
  1046                   0
  1047                   0
  1048                   0
  1049                   0
  1050                   0
  1051                   0
  1052                   0
  1053                   0
  1054                   2
  1055                   0
  1056                   0
  1057                   0
  1058                   0
  1059                   0
  1060                   0
  1061                   0
  1062                   0
  1063                   0
  1064                   0
  1065                   0
  1066                   0
  1067                   0
  1068                   0
  1069                   0
  1071                   0
  1072                   0
  1073                   0
  1074                   0
  1075                   0
  1076                   0
  1077                   0
  1080                   0
  1081                   0
  1082                   0
  1083                   0
  1084                   0
  1085                   0
  1086                   0
  1087                   0
-----            LAYER READ SUMMARY (ORIGINAL LAYER GEOMETRIES)            -----
ORIGINAL LAYER       INITIAL GEOMETRIES                 FINAL GEOMETRIES
  DCTY_mark                0 (0)                            0 (0)
  A1SLOT_slot              0 (0)                            0 (0)
  A2SLOT_slot              0 (0)                            0 (0)
  A3SLOT_slot              0 (0)                            0 (0)
  A4SLOT_slot              0 (0)                            0 (0)
  A5SLOT_slot              0 (0)                            0 (0)
  MTTSLOT_slot             0 (0)                            0 (0)
  TB                       0 (0)                            0 (0)
  RES_NW_mark              0 (0)                            0 (0)
  TO                       0 (0)                            0 (0)
  SN                       0 (0)                            0 (0)
  SP                       0 (0)                            0 (0)
  GT                       0 (0)                            0 (0)
  HV                       0 (0)                            0 (0)
  SE                       0 (0)                            0 (0)
  SI                       0 (0)                            0 (0)
  W1                       0 (0)                            0 (0)
  W2                       0 (0)                            0 (0)
  W3                       0 (0)                            0 (0)
  W4                       0 (0)                            0 (0)
  W5                       0 (0)                            0 (0)
  WT                      35 (35)                          35 (35)
  MTT                      0 (0)                            0 (0)
  DN                       0 (0)                            0 (0)
  PWB                      0 (0)                            0 (0)
  MN                       0 (0)                            0 (0)
  MP                       0 (0)                            0 (0)
  PD                       0 (0)                            0 (0)
  HR                       0 (0)                            0 (0)
  MCT                      2 (2)                            2 (2)
  A1_net                   0 (0)                            0 (0)
  A1                       1 (1)                            1 (1)
  A1_pin                   0 (0)                            0 (0)
  RES_M1                   0 (0)                            0 (0)
  A2_net                   0 (0)                            0 (0)
  A2                       0 (0)                            0 (0)
  A2_pin                   0 (0)                            0 (0)
  RES_M2                   0 (0)                            0 (0)
  A3_net                   0 (0)                            0 (0)
  A3                       2 (2)                            2 (2)
  A3_pin                   0 (0)                            0 (0)
  A4_net                   0 (0)                            0 (0)
  A4                       1 (1)                            1 (1)
  A4_pin                   0 (0)                            0 (0)
  A5_net                   0 (0)                            0 (0)
  A5                       0 (0)                            0 (0)
  A5_pin                   0 (0)                            0 (0)
  MCTM5                    0 (0)                            0 (0)
  RFDUM_mark               0 (0)                            0 (0)
  RES_M3                   0 (0)                            0 (0)
  RES_M4                   0 (0)                            0 (0)
  RES_M5                   0 (0)                            0 (0)
  RES_MT                   0 (0)                            0 (0)
  RES_PY_mark              0 (0)                            0 (0)
  BJT_mark                 0 (0)                            0 (0)
  RES_TO_mark              0 (0)                            0 (0)
  VARMOS_mark              0 (0)                            0 (0)
  RES_HR_mark              0 (0)                            0 (0)
  ESD_mark                 0 (0)                            0 (0)
  VTSRAM_mark              0 (0)                            0 (0)
  VTSRAM_gc2               0 (0)                            0 (0)
  VTSRAM_gc3               0 (0)                            0 (0)
  VTSRAM_l                 0 (0)                            0 (0)
  VTSRAM_lc                0 (0)                            0 (0)
  DIODE_mark               0 (0)                            0 (0)
  PSUB2                    0 (0)                            0 (0)
  RNDMY                    0 (0)                            0 (0)
  RES_3T_mark              0 (0)                            0 (0)
  RPDMY                    0 (0)                            0 (0)
  RFDUM_g2                 0 (0)                            0 (0)
  VARJUN_mark              0 (0)                            0 (0)
  INDUM_mark               0 (0)                            0 (0)
  EXCLU                    0 (0)                            0 (0)
-----         LAYER READ SUMMARY (TEXT FOR CONNECTIVITY EXTRACTION)        -----
SIMPLE LAYER              TEXTS
  1001                     1 (1)
  1011                     1 (1)
  1016                     1 (1)
-----          LAYER READ SUMMARY (TEXT FOR WITH TEXT OPERATIONS)          -----
SIMPLE LAYER              TEXTS
-----         LAYER READ SUMMARY (TEXT FOR EXPAND TEXT OPERATIONS)         -----
SIMPLE LAYER              TEXTS
-----            LAYER READ SUMMARY (TEXT FOR CAPI OPERATIONS)             -----
SIMPLE LAYER              TEXTS
-----                      LAYER READ SUMMARY (PORTS)                      -----
SIMPLE LAYER              TEXTS
  1001                     1 (1)
  1011                     1 (1)
  1016                     1 (1)
-----                      CELL AND PLACEMENT SUMMARY                      -----
CELL TYPE                 CELLS           PLACEMENTS       FLAT PLACEMENTS
USER                          1                    0                     0
VERY SMALL                   0                    0                     0
TOP LAYER                    0                    0                     0
  VERY SMALL                  0                    0                     0
PSEUDO                        0                    0                     0
TOTAL                         1                    0                     0
-----                   LAYOUT DATA INPUT MODULE SUMMARY                   -----
--- TOTAL GEOMETRIES READ FROM SIMPLE LAYERS = 41
--- TOTAL GEOMETRIES READ FROM ORIGINAL LAYERS = 41 (41)
--- TOTAL GEOMETRIES WRITTEN TO ORIGINAL LAYERS = 41 (41)
--- LVHEAP = 2/5/67
--- DATABASE EXTENT = [ -5.2 , 18.855 ] -> [ 31.622 , 41.475 ]
--- GEOMETRIC DEPTH = ALL
--- TEXT DEPTH FOR CONNECTIVITY EXTRACTION = PRIMARY
--- TOTAL TEXT OBJECTS FOR CONNECTIVITY EXTRACTION = 3 (3)
--- TOTAL TEXT OBJECTS FOR WITH TEXT OPERATIONS = 0 (0)
--- TOTAL TEXT OBJECTS FOR EXPAND TEXT OPERATIONS = 0 (0)
--- TOTAL TEXT OBJECTS FOR CAPI OPERATIONS = 0 (0)
--- TOTAL PORT OBJECTS = 3 (3)
--- GEOMETRY FLAGGING = ACUTE (NO)  SKEW (NO)  ANGLED (NO)  OFFGRID (NO)
                        NONSIMPLE POLYGON (NO)  NONSIMPLE PATH (NO)
--- PRIMARY CELL = cmim_test
--- EXCLUDED CELLS =
--- LAYOUT BASE LAYER = (NOT SPECIFIED)
--- LAYOUT TOP LAYER = (NOT SPECIFIED)
--- CALIBRE LAYOUT DATA INPUT MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0
-----      CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR - EXECUTIVE MODULE      -----
SN = OR SN
SN (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 1 OF 455  ELAPSED TIME = 0
Original Layer SN DELETED -- LVHEAP = 3/5/67
DCTY_mark = OR DCTY_mark
DCTY_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 2 OF 455  ELAPSED TIME = 0
Original Layer DCTY_mark DELETED -- LVHEAP = 3/5/67
SN_drc = SN NOT DCTY_mark
SN_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 3 OF 455  ELAPSED TIME = 0
TO = OR TO
TO (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 4 OF 455  ELAPSED TIME = 0
Original Layer TO DELETED -- LVHEAP = 3/5/67
TO_drc = TO NOT DCTY_mark
TO_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 5 OF 455  ELAPSED TIME = 0
ndiff = SN_drc AND TO_drc
ndiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 6 OF 455  ELAPSED TIME = 0
GT = OR GT
GT (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 7 OF 455  ELAPSED TIME = 0
Original Layer GT DELETED -- LVHEAP = 3/5/67
GT_drc = GT NOT DCTY_mark
GT_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 8 OF 455  ELAPSED TIME = 0
nsd1 = ndiff NOT GT_drc
nsd1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 9 OF 455  ELAPSED TIME = 0
RES_TO_mark = OR RES_TO_mark
RES_TO_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 10 OF 455  ELAPSED TIME = 0
Original Layer RES_TO_mark DELETED -- LVHEAP = 3/5/67
nsd = nsd1 NOT RES_TO_mark
nsd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 11 OF 455  ELAPSED TIME = 0
Layer nsd1 DELETED -- LVHEAP = 3/5/67
SP = OR SP
SP (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 12 OF 455  ELAPSED TIME = 0
Original Layer SP DELETED -- LVHEAP = 3/5/67
TMP<38> = TO AND SP
TMP<38> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 13 OF 455  ELAPSED TIME = 0
TB = OR TB
TB (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 14 OF 455  ELAPSED TIME = 0
Original Layer TB DELETED -- LVHEAP = 3/5/67
TMP<37> = TMP<38> NOT TB
TMP<37> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 15 OF 455  ELAPSED TIME = 0
Layer TMP<38> DELETED -- LVHEAP = 3/5/67
TMP<36> = TMP<37> NOT GT
TMP<36> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 16 OF 455  ELAPSED TIME = 0
Layer TMP<37> DELETED -- LVHEAP = 3/5/67
W1 = OR W1
W1 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 17 OF 455  ELAPSED TIME = 0
Original Layer W1 DELETED -- LVHEAP = 3/5/67
TMP<35> = TMP<36> INTERACT W1
TMP<35> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 18 OF 455  ELAPSED TIME = 0
Layer TMP<36> DELETED -- LVHEAP = 3/5/67
EXCLU = OR EXCLU
EXCLU (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 19 OF 455  ELAPSED TIME = 0
Original Layer EXCLU DELETED -- LVHEAP = 3/5/67
lvpsb = TMP<35> AND EXCLU
lvpsb (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 20 OF 455  ELAPSED TIME = 0
Layer TMP<35> DELETED -- LVHEAP = 3/5/67
SP_drc = SP NOT DCTY_mark
SP_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 21 OF 455  ELAPSED TIME = 0
pdiff = SP_drc AND TO_drc
pdiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 22 OF 455  ELAPSED TIME = 0
psd1 = pdiff NOT GT_drc
psd1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 23 OF 455  ELAPSED TIME = 0
psd = psd1 NOT RES_TO_mark
psd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 24 OF 455  ELAPSED TIME = 0
Layer psd1 DELETED -- LVHEAP = 3/5/67
TMP<41> = TO AND SN
TMP<41> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 25 OF 455  ELAPSED TIME = 0
TMP<40> = TMP<41> AND TB
TMP<40> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 26 OF 455  ELAPSED TIME = 0
Layer TMP<41> DELETED -- LVHEAP = 3/5/67
TMP<39> = TMP<40> NOT GT
TMP<39> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 27 OF 455  ELAPSED TIME = 0
Layer TMP<40> DELETED -- LVHEAP = 3/5/67
lvnsb = TMP<39> AND EXCLU
lvnsb (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 28 OF 455  ELAPSED TIME = 0
Layer TMP<39> DELETED -- LVHEAP = 3/5/67
A1_pin = OR A1_pin
A1_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 29 OF 455  ELAPSED TIME = 0
Original Layer A1_pin DELETED -- LVHEAP = 3/5/67
A1 = OR A1
A1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 30 OF 455  ELAPSED TIME = 0
Original Layer A1 DELETED -- LVHEAP = 3/5/67
A1_net = OR A1_net
A1_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 31 OF 455  ELAPSED TIME = 0
Original Layer A1_net DELETED -- LVHEAP = 3/5/67
a1net = A1 OR A1_net
a1net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 32 OF 455  ELAPSED TIME = 0
a1_net_pin = A1_pin OR a1net
a1_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 33 OF 455  ELAPSED TIME = 0
Layer a1net DELETED -- LVHEAP = 3/5/67
A1_drc = a1_net_pin NOT DCTY_mark
A1_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 34 OF 455  ELAPSED TIME = 0
Layer a1_net_pin DELETED -- LVHEAP = 3/5/67
A1SLOT_slot = OR A1SLOT_slot
A1SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 35 OF 455  ELAPSED TIME = 0
Original Layer A1SLOT_slot DELETED -- LVHEAP = 3/5/67
A1SLOT_slot_drc = A1SLOT_slot NOT DCTY_mark
A1SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 36 OF 455  ELAPSED TIME = 0
a1_conn1 = A1_drc NOT A1SLOT_slot_drc
a1_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 37 OF 455  ELAPSED TIME = 0
Layer A1SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M1 = OR RES_M1
RES_M1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 38 OF 455  ELAPSED TIME = 0
Original Layer RES_M1 DELETED -- LVHEAP = 3/5/67
a1_conn = a1_conn1 NOT RES_M1
a1_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 39 OF 455  ELAPSED TIME = 0
Layer a1_conn1 DELETED -- LVHEAP = 3/5/67
W2 = OR W2
W2 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 40 OF 455  ELAPSED TIME = 0
Original Layer W2 DELETED -- LVHEAP = 3/5/67
A2_pin = OR A2_pin
A2_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 41 OF 455  ELAPSED TIME = 0
Original Layer A2_pin DELETED -- LVHEAP = 3/5/67
A2 = OR A2
A2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 42 OF 455  ELAPSED TIME = 0
Original Layer A2 DELETED -- LVHEAP = 3/5/67
A2_net = OR A2_net
A2_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 43 OF 455  ELAPSED TIME = 0
Original Layer A2_net DELETED -- LVHEAP = 3/5/67
a2net = A2 OR A2_net
a2net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 44 OF 455  ELAPSED TIME = 0
a2_net_pin = A2_pin OR a2net
a2_net_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 45 OF 455  ELAPSED TIME = 0
Layer a2net DELETED -- LVHEAP = 3/5/67
A2_drc = a2_net_pin NOT DCTY_mark
A2_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 46 OF 455  ELAPSED TIME = 0
Layer a2_net_pin DELETED -- LVHEAP = 3/5/67
A2SLOT_slot = OR A2SLOT_slot
A2SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 47 OF 455  ELAPSED TIME = 0
Original Layer A2SLOT_slot DELETED -- LVHEAP = 3/5/67
A2SLOT_slot_drc = A2SLOT_slot NOT DCTY_mark
A2SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 48 OF 455  ELAPSED TIME = 0
a2_conn1 = A2_drc NOT A2SLOT_slot_drc
a2_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 49 OF 455  ELAPSED TIME = 0
Layer A2SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M2 = OR RES_M2
RES_M2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 50 OF 455  ELAPSED TIME = 0
Original Layer RES_M2 DELETED -- LVHEAP = 3/5/67
a2_conn = a2_conn1 NOT RES_M2
a2_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 51 OF 455  ELAPSED TIME = 0
Layer a2_conn1 DELETED -- LVHEAP = 3/5/67
W3 = OR W3
W3 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 52 OF 455  ELAPSED TIME = 0
Original Layer W3 DELETED -- LVHEAP = 3/5/67
A3_pin = OR A3_pin
A3_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 53 OF 455  ELAPSED TIME = 0
Original Layer A3_pin DELETED -- LVHEAP = 3/5/67
A3 = OR A3
A3 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 54 OF 455  ELAPSED TIME = 0
Original Layer A3 DELETED -- LVHEAP = 3/5/67
A3_net = OR A3_net
A3_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 55 OF 455  ELAPSED TIME = 0
Original Layer A3_net DELETED -- LVHEAP = 3/5/67
a3net = A3 OR A3_net
a3net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 56 OF 455  ELAPSED TIME = 0
a3_net_pin = A3_pin OR a3net
a3_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 57 OF 455  ELAPSED TIME = 0
Layer a3net DELETED -- LVHEAP = 3/5/67
A3_drc = a3_net_pin NOT DCTY_mark
A3_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 58 OF 455  ELAPSED TIME = 0
Layer a3_net_pin DELETED -- LVHEAP = 3/5/67
A3SLOT_slot = OR A3SLOT_slot
A3SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 59 OF 455  ELAPSED TIME = 0
Original Layer A3SLOT_slot DELETED -- LVHEAP = 3/5/67
A3SLOT_slot_drc = A3SLOT_slot NOT DCTY_mark
A3SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 60 OF 455  ELAPSED TIME = 0
a3_conn1 = A3_drc NOT A3SLOT_slot_drc
a3_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 61 OF 455  ELAPSED TIME = 0
Layer A3SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M3 = OR RES_M3
RES_M3 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 62 OF 455  ELAPSED TIME = 0
Original Layer RES_M3 DELETED -- LVHEAP = 3/5/67
a3_conn2 = a3_conn1 NOT RES_M3
a3_conn2 (HIER TYP=1 CFG=1 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 63 OF 455  ELAPSED TIME = 0
Layer a3_conn1 DELETED -- LVHEAP = 3/5/67
a3_conn = COPY a3_conn2
a3_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 64 OF 455  ELAPSED TIME = 0
Layer a3_conn2 DELETED -- LVHEAP = 3/5/67
WT = OR WT
WT (HIER TYP=1 CFG=1 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 65 OF 455  ELAPSED TIME = 0
Original Layer WT DELETED -- LVHEAP = 3/5/67
WT_drc = WT NOT DCTY_mark
WT_drc (HIER TYP=1 CFG=1 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 66 OF 455  ELAPSED TIME = 0
MCT = OR MCT
MCT (HIER TYP=1 CFG=1 HGC=2 FGC=2 HEC=8 FEC=8 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 67 OF 455  ELAPSED TIME = 0
Original Layer MCT DELETED -- LVHEAP = 3/5/67
MCT_drc = MCT NOT DCTY_mark
MCT_drc (HIER TYP=1 CFG=1 HGC=2 FGC=2 HEC=8 FEC=8 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 68 OF 455  ELAPSED TIME = 0
mctcap = MCT_drc INTERACT WT_drc
mctcap (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 69 OF 455  ELAPSED TIME = 0
Layer MCT_drc DELETED -- LVHEAP = 3/5/67
wtmct = WT_drc AND mctcap
wtmct (HIER TYP=1 CFG=3 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 70 OF 455  ELAPSED TIME = 0
MTT = OR MTT
MTT (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 71 OF 455  ELAPSED TIME = 0
Original Layer MTT DELETED -- LVHEAP = 3/5/67
MTT_drc = MTT NOT DCTY_mark
MTT_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 72 OF 455  ELAPSED TIME = 0
MTTSLOT_slot = OR MTTSLOT_slot
MTTSLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 73 OF 455  ELAPSED TIME = 0
Original Layer MTTSLOT_slot DELETED -- LVHEAP = 3/5/67
MTTSLOT_slot_drc = MTTSLOT_slot NOT DCTY_mark
MTTSLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 74 OF 455  ELAPSED TIME = 0
tt_conn1 = MTT_drc NOT MTTSLOT_slot_drc
tt_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 75 OF 455  ELAPSED TIME = 0
Layer MTTSLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_MT = OR RES_MT
RES_MT (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 76 OF 455  ELAPSED TIME = 0
Original Layer RES_MT DELETED -- LVHEAP = 3/5/67
tt_conn2 = tt_conn1 NOT RES_MT
tt_conn2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 77 OF 455  ELAPSED TIME = 0
Layer tt_conn1 DELETED -- LVHEAP = 3/5/67
INDUM_mark = OR INDUM_mark
INDUM_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 78 OF 455  ELAPSED TIME = 0
Original Layer INDUM_mark DELETED -- LVHEAP = 3/5/67
tt_ind = tt_conn2 AND INDUM_mark
tt_ind (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 79 OF 455  ELAPSED TIME = 0
tt_conn = tt_conn2 NOT tt_ind
tt_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 80 OF 455  ELAPSED TIME = 0
Layer tt_conn2 DELETED -- LVHEAP = 3/5/67
wtcon = WT_drc OUTSIDE mctcap
wtcon (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 81 OF 455  ELAPSED TIME = 0
Layer WT_drc DELETED -- LVHEAP = 3/5/67
A5_pin = OR A5_pin
A5_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 82 OF 455  ELAPSED TIME = 0
Original Layer A5_pin DELETED -- LVHEAP = 3/5/67
A5 = OR A5
A5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 83 OF 455  ELAPSED TIME = 0
Original Layer A5 DELETED -- LVHEAP = 3/5/67
A5_net = OR A5_net
A5_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 84 OF 455  ELAPSED TIME = 0
Original Layer A5_net DELETED -- LVHEAP = 3/5/67
a5net = A5 OR A5_net
a5net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 85 OF 455  ELAPSED TIME = 0
a5_net_pin = A5_pin OR a5net
a5_net_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 86 OF 455  ELAPSED TIME = 0
Layer a5net DELETED -- LVHEAP = 3/5/67
A5_drc = a5_net_pin NOT DCTY_mark
A5_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 87 OF 455  ELAPSED TIME = 0
Layer a5_net_pin DELETED -- LVHEAP = 3/5/67
A5SLOT_slot = OR A5SLOT_slot
A5SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 88 OF 455  ELAPSED TIME = 0
Original Layer A5SLOT_slot DELETED -- LVHEAP = 3/5/67
A5SLOT_slot_drc = A5SLOT_slot NOT DCTY_mark
A5SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 89 OF 455  ELAPSED TIME = 0
a5_conn1 = A5_drc NOT A5SLOT_slot_drc
a5_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 90 OF 455  ELAPSED TIME = 0
Layer A5SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M5 = OR RES_M5
RES_M5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 91 OF 455  ELAPSED TIME = 0
Original Layer RES_M5 DELETED -- LVHEAP = 3/5/67
a5_conn2 = a5_conn1 NOT RES_M5
a5_conn2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 92 OF 455  ELAPSED TIME = 0
Layer a5_conn1 DELETED -- LVHEAP = 3/5/67
am_ind = a5_conn2 AND INDUM_mark
am_ind (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 93 OF 455  ELAPSED TIME = 0
a5_conn = a5_conn2 NOT am_ind
a5_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 94 OF 455  ELAPSED TIME = 0
Layer a5_conn2 DELETED -- LVHEAP = 3/5/67
W5 = OR W5
W5 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 95 OF 455  ELAPSED TIME = 0
Original Layer W5 DELETED -- LVHEAP = 3/5/67
A4_pin = OR A4_pin
A4_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 96 OF 455  ELAPSED TIME = 0
Original Layer A4_pin DELETED -- LVHEAP = 3/5/67
A4 = OR A4
A4 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 97 OF 455  ELAPSED TIME = 0
Original Layer A4 DELETED -- LVHEAP = 3/5/67
A4_net = OR A4_net
A4_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 98 OF 455  ELAPSED TIME = 0
Original Layer A4_net DELETED -- LVHEAP = 3/5/67
a4net = A4 OR A4_net
a4net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 99 OF 455  ELAPSED TIME = 0
a4_net_pin = A4_pin OR a4net
a4_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 100 OF 455  ELAPSED TIME = 0
Layer a4net DELETED -- LVHEAP = 3/5/67
A4_drc = a4_net_pin NOT DCTY_mark
A4_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 101 OF 455  ELAPSED TIME = 0
Layer a4_net_pin DELETED -- LVHEAP = 3/5/67
A4SLOT_slot = OR A4SLOT_slot
A4SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 102 OF 455  ELAPSED TIME = 0
Original Layer A4SLOT_slot DELETED -- LVHEAP = 3/5/67
A4SLOT_slot_drc = A4SLOT_slot NOT DCTY_mark
A4SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 103 OF 455  ELAPSED TIME = 0
a4_conn1 = A4_drc NOT A4SLOT_slot_drc
a4_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 104 OF 455  ELAPSED TIME = 0
Layer A4SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M4 = OR RES_M4
RES_M4 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 105 OF 455  ELAPSED TIME = 0
Original Layer RES_M4 DELETED -- LVHEAP = 3/5/67
a4_conn2 = a4_conn1 NOT RES_M4
a4_conn2 (HIER TYP=1 CFG=1 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 106 OF 455  ELAPSED TIME = 0
Layer a4_conn1 DELETED -- LVHEAP = 3/5/67
a4_conn = COPY a4_conn2
a4_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 107 OF 455  ELAPSED TIME = 0
Layer a4_conn2 DELETED -- LVHEAP = 3/5/67
W4 = OR W4
W4 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 108 OF 455  ELAPSED TIME = 0
Original Layer W4 DELETED -- LVHEAP = 3/5/67
W1_drc = W1 NOT DCTY_mark
W1_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 109 OF 455  ELAPSED TIME = 0
TB_drc = TB NOT DCTY_mark
TB_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 110 OF 455  ELAPSED TIME = 0
RFDUM_mark = OR RFDUM_mark
RFDUM_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 111 OF 455  ELAPSED TIME = 0
Original Layer RFDUM_mark DELETED -- LVHEAP = 3/5/67
TMP<29> = TB_drc INTERACT RFDUM_mark
TMP<29> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 112 OF 455  ELAPSED TIME = 0
ndiff_tb = ndiff INSIDE TB_drc
ndiff_tb (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 113 OF 455  ELAPSED TIME = 0
VARMOS_mark = OR VARMOS_mark
VARMOS_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 114 OF 455  ELAPSED TIME = 0
Original Layer VARMOS_mark DELETED -- LVHEAP = 3/5/67
var_ndiff = ndiff_tb INTERACT VARMOS_mark
var_ndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 115 OF 455  ELAPSED TIME = 0
Layer ndiff_tb DELETED -- LVHEAP = 3/5/67
vargate = var_ndiff AND GT_drc
vargate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 116 OF 455  ELAPSED TIME = 0
Layer var_ndiff DELETED -- LVHEAP = 3/5/67
HV = OR HV
HV (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 117 OF 455  ELAPSED TIME = 0
Original Layer HV DELETED -- LVHEAP = 3/5/67
HV_drc = HV NOT DCTY_mark
HV_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 118 OF 455  ELAPSED TIME = 0
var18 = vargate NOT HV_drc
var18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 119 OF 455  ELAPSED TIME = 0
var18_rf_rec = TMP<29> ENCLOSE var18
var18_rf_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 120 OF 455  ELAPSED TIME = 0
var18_rf_to = TO_drc INSIDE var18_rf_rec
var18_rf_to (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 121 OF 455  ELAPSED TIME = 0
var18_rf_gt = GT_drc NOT OUTSIDE var18_rf_to
var18_rf_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 122 OF 455  ELAPSED TIME = 0
var18_rf_gt_con = W1_drc AND var18_rf_gt
var18_rf_gt_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 123 OF 455  ELAPSED TIME = 0
var33 = vargate AND HV_drc
var33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 124 OF 455  ELAPSED TIME = 0
Layer vargate DELETED -- LVHEAP = 3/5/67
var33_rf_rec = TMP<29> ENCLOSE var33
var33_rf_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 125 OF 455  ELAPSED TIME = 0
Layer TMP<29> DELETED -- LVHEAP = 3/5/67
var33_rf_to = TO_drc INSIDE var33_rf_rec
var33_rf_to (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 126 OF 455  ELAPSED TIME = 0
var33_rf_gt = GT_drc NOT OUTSIDE var33_rf_to
var33_rf_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 127 OF 455  ELAPSED TIME = 0
var33_rf_gt_con = W1_drc AND var33_rf_gt
var33_rf_gt_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 128 OF 455  ELAPSED TIME = 0
w1_and_gt = GT_drc AND W1_drc
w1_and_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 129 OF 455  ELAPSED TIME = 0
RES_PY_mark = OR RES_PY_mark
RES_PY_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 130 OF 455  ELAPSED TIME = 0
Original Layer RES_PY_mark DELETED -- LVHEAP = 3/5/67
gt_conn1 = GT_drc NOT RES_PY_mark
gt_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 131 OF 455  ELAPSED TIME = 0
RES_HR_mark = OR RES_HR_mark
RES_HR_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 132 OF 455  ELAPSED TIME = 0
Original Layer RES_HR_mark DELETED -- LVHEAP = 3/5/67
TMP<1> = gt_conn1 NOT RES_HR_mark
TMP<1> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 133 OF 455  ELAPSED TIME = 0
Layer gt_conn1 DELETED -- LVHEAP = 3/5/67
TMP<2> = var18_rf_gt OR var33_rf_gt
TMP<2> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 134 OF 455  ELAPSED TIME = 0
gt_conn = TMP<1> NOT TMP<2>
gt_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 135 OF 455  ELAPSED TIME = 0
Layer TMP<1> DELETED -- LVHEAP = 3/5/67
Layer TMP<2> DELETED -- LVHEAP = 3/5/67
w1_and_nsd = W1_drc AND nsd
w1_and_nsd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 136 OF 455  ELAPSED TIME = 0
w1_and_psd = W1_drc AND psd
w1_and_psd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 137 OF 455  ELAPSED TIME = 0
Layer W1_drc DELETED -- LVHEAP = 3/5/67
ntap = TB_drc AND nsd
ntap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 138 OF 455  ELAPSED TIME = 0
RES_NW_mark = OR RES_NW_mark
RES_NW_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 139 OF 455  ELAPSED TIME = 0
Original Layer RES_NW_mark DELETED -- LVHEAP = 3/5/67
nwelcon = TB_drc NOT RES_NW_mark
nwelcon (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 140 OF 455  ELAPSED TIME = 0
RFDUM_g2 = OR RFDUM_g2
RFDUM_g2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 141 OF 455  ELAPSED TIME = 0
Original Layer RFDUM_g2 DELETED -- LVHEAP = 3/5/67
nmos_rf_s = nsd AND RFDUM_g2
nmos_rf_s (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 142 OF 455  ELAPSED TIME = 0
nmos_rf_s_con = nmos_rf_s AND nsd
nmos_rf_s_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 143 OF 455  ELAPSED TIME = 0
nmos_rf_d = nsd NOT RFDUM_g2
nmos_rf_d (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 144 OF 455  ELAPSED TIME = 0
nmos_rf_d_con = nmos_rf_d AND nsd
nmos_rf_d_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 145 OF 455  ELAPSED TIME = 0
pmos_rf_s = psd AND RFDUM_g2
pmos_rf_s (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 146 OF 455  ELAPSED TIME = 0
pmos_rf_s_con = psd AND pmos_rf_s
pmos_rf_s_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 147 OF 455  ELAPSED TIME = 0
pmos_rf_d = psd NOT RFDUM_g2
pmos_rf_d (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 148 OF 455  ELAPSED TIME = 0
pmos_rf_d_con = psd AND pmos_rf_d
pmos_rf_d_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 149 OF 455  ELAPSED TIME = 0
TMP<10> = pdiff NOT TB_drc
TMP<10> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 150 OF 455  ELAPSED TIME = 0
DN = OR DN
DN (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 151 OF 455  ELAPSED TIME = 0
Original Layer DN DELETED -- LVHEAP = 3/5/67
DN_drc = DN NOT DCTY_mark
DN_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 152 OF 455  ELAPSED TIME = 0
dn_hole = HOLES DN_drc
dn_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 153 OF 455  ELAPSED TIME = 0
dn_no_touch_hole = DN_drc NOT TOUCH dn_hole
dn_no_touch_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 154 OF 455  ELAPSED TIME = 0
Layer dn_hole DELETED -- LVHEAP = 3/5/67
dnwel_size01 = SIZE dn_no_touch_hole BY -0.005
dnwel_size01 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 155 OF 455  ELAPSED TIME = 0
TMP<19> = dn_no_touch_hole NOT dnwel_size01
TMP<19> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 156 OF 455  ELAPSED TIME = 0
Layer dn_no_touch_hole DELETED -- LVHEAP = 3/5/67
Layer dnwel_size01 DELETED -- LVHEAP = 3/5/67
DIODE_mark = OR DIODE_mark
DIODE_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 157 OF 455  ELAPSED TIME = 0
Original Layer DIODE_mark DELETED -- LVHEAP = 3/5/67
dnwel_ring = TMP<19> NOT INSIDE DIODE_mark
dnwel_ring (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 158 OF 455  ELAPSED TIME = 0
Layer TMP<19> DELETED -- LVHEAP = 3/5/67
dnwel_ptap = DN_drc NOT INTERACT dnwel_ring
dnwel_ptap (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 159 OF 455  ELAPSED TIME = 0
ptap = TMP<10> NOT dnwel_ptap
ptap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 160 OF 455  ELAPSED TIME = 0
Layer TMP<10> DELETED -- LVHEAP = 3/5/67
Layer dnwel_ptap DELETED -- LVHEAP = 3/5/67
bulk = EXTENT
bulk (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 161 OF 455  ELAPSED TIME = 0
psub_1 = bulk NOT dnwel_ring
psub_1 (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 162 OF 455  ELAPSED TIME = 0
Layer bulk DELETED -- LVHEAP = 3/5/67
Layer dnwel_ring DELETED -- LVHEAP = 3/5/67
PSUB2 = OR PSUB2
PSUB2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 163 OF 455  ELAPSED TIME = 1
Original Layer PSUB2 DELETED -- LVHEAP = 3/5/67
psub_size01 = SIZE PSUB2 BY 0.005
psub_size01 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 164 OF 455  ELAPSED TIME = 1
psub_cut = psub_size01 NOT PSUB2
psub_cut (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 165 OF 455  ELAPSED TIME = 1
Layer psub_size01 DELETED -- LVHEAP = 3/5/67
psub_2 = psub_1 NOT psub_cut
psub_2 (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 166 OF 455  ELAPSED TIME = 1
Layer psub_1 DELETED -- LVHEAP = 3/5/67
Layer psub_cut DELETED -- LVHEAP = 3/5/67
BJT_mark = OR BJT_mark
BJT_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 167 OF 455  ELAPSED TIME = 1
Original Layer BJT_mark DELETED -- LVHEAP = 3/5/67
pdiff_bjt = BJT_mark AND pdiff
pdiff_bjt (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 168 OF 455  ELAPSED TIME = 1
nw_bjt = BJT_mark AND TB_drc
nw_bjt (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 169 OF 455  ELAPSED TIME = 1
qvp_e = pdiff_bjt INSIDE nw_bjt
qvp_e (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 170 OF 455  ELAPSED TIME = 1
psub = psub_2 NOT qvp_e
psub (HIER-LSL TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 171 OF 455  ELAPSED TIME = 1
Layer psub_2 DELETED -- LVHEAP = 3/5/67
dn_nw = DN_drc INTERACT TB_drc
dn_nw (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 172 OF 455  ELAPSED TIME = 1
dn_tbtap = TB_drc AND dn_nw
dn_tbtap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 173 OF 455  ELAPSED TIME = 1
qvp33_e = qvp_e AND HV_drc
qvp33_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 174 OF 455  ELAPSED TIME = 1
qvp33_b = nw_bjt ENCLOSE qvp33_e
qvp33_b (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 175 OF 455  ELAPSED TIME = 1
qvp33B_con = qvp33_b AND ntap
qvp33B_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 176 OF 455  ELAPSED TIME = 1
qvp18_e = qvp_e NOT HV_drc
qvp18_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 177 OF 455  ELAPSED TIME = 1
Layer qvp_e DELETED -- LVHEAP = 3/5/67
qvp18_b = nw_bjt ENCLOSE qvp18_e
qvp18_b (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 178 OF 455  ELAPSED TIME = 1
Layer nw_bjt DELETED -- LVHEAP = 3/5/67
qvp18B_con = qvp18_b AND ntap
qvp18B_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 179 OF 455  ELAPSED TIME = 1
qvp33E_con = pdiff_bjt AND qvp33_e
qvp33E_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 180 OF 455  ELAPSED TIME = 1
qvp18E_con = pdiff_bjt AND qvp18_e
qvp18E_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 181 OF 455  ELAPSED TIME = 1
Layer pdiff_bjt DELETED -- LVHEAP = 3/5/67
ndiff_bjt = BJT_mark AND ndiff
ndiff_bjt (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 182 OF 455  ELAPSED TIME = 1
nw_Hole = HOLES TB_drc INNER
nw_Hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 183 OF 455  ELAPSED TIME = 1
dn_enc_nwHole = DN_drc ENCLOSE nw_Hole
dn_enc_nwHole (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 184 OF 455  ELAPSED TIME = 1
nwHole_dn = dn_enc_nwHole AND nw_Hole
nwHole_dn (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 185 OF 455  ELAPSED TIME = 1
Layer dn_enc_nwHole DELETED -- LVHEAP = 3/5/67
Layer nw_Hole DELETED -- LVHEAP = 3/5/67
vnpn_e = ndiff_bjt AND nwHole_dn
vnpn_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 186 OF 455  ELAPSED TIME = 1
Layer nwHole_dn DELETED -- LVHEAP = 3/5/67
vnpnE_con = ndiff_bjt AND vnpn_e
vnpnE_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 187 OF 455  ELAPSED TIME = 1
Layer ndiff_bjt DELETED -- LVHEAP = 3/5/67
resnw = TB_drc AND RES_NW_mark
resnw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 188 OF 455  ELAPSED TIME = 1
SI = OR SI
SI (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 189 OF 455  ELAPSED TIME = 1
Original Layer SI DELETED -- LVHEAP = 3/5/67
SI_drc = SI NOT DCTY_mark
SI_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 190 OF 455  ELAPSED TIME = 1
resnw_nosab = resnw OUTSIDE SI_drc
resnw_nosab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 191 OF 455  ELAPSED TIME = 1
Layer resnw DELETED -- LVHEAP = 3/5/67
RNDMY = OR RNDMY
RNDMY (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 192 OF 455  ELAPSED TIME = 1
Original Layer RNDMY DELETED -- LVHEAP = 3/5/67
rnw_rec = resnw_nosab NOT RNDMY
rnw_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 193 OF 455  ELAPSED TIME = 1
Layer resnw_nosab DELETED -- LVHEAP = 3/5/67
nwellRes_term = nwelcon TOUCH rnw_rec
nwellRes_term (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 194 OF 455  ELAPSED TIME = 1
nwResTerm_con = nwelcon AND nwellRes_term
nwResTerm_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 195 OF 455  ELAPSED TIME = 1
tb_in_to = TB_drc INSIDE TO_drc
tb_in_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 196 OF 455  ELAPSED TIME = 1
tb_to_res = tb_in_to AND RES_NW_mark
tb_to_res (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 197 OF 455  ELAPSED TIME = 1
Layer tb_in_to DELETED -- LVHEAP = 3/5/67
tb_to_sab_res = tb_to_res AND SI_drc
tb_to_sab_res (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 198 OF 455  ELAPSED TIME = 1
Layer tb_to_res DELETED -- LVHEAP = 3/5/67
rnw_sab = tb_to_sab_res AND RNDMY
rnw_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 199 OF 455  ELAPSED TIME = 1
Layer tb_to_sab_res DELETED -- LVHEAP = 3/5/67
rnw_sab_term = nwelcon TOUCH rnw_sab
rnw_sab_term (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 200 OF 455  ELAPSED TIME = 1
rnwsabTerm_con = nwelcon AND rnw_sab_term
rnwsabTerm_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 201 OF 455  ELAPSED TIME = 1
CONNECTIVITY EXTRACTION TOTAL LAYER PREPARATION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
NC = Net Count  IPC = Internal Pin Count
CEC = Cell Edge Count  PEC = Promoted Edge Count
LVHEAP = Geometry heap memory allocation.
MALLOC = Total heap memory allocation.
CELL cmim_test
     cmim_test (NC=40 IPC=0 CEC=80 PEC=0 CFGC=40)
     cmim_test  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
TOTAL CEC=80 PEC=0
POST-PROCESSING CONNECTIVITY DATA STRUCTURE...
    MARKING TRUE NETS AND EXTERNAL PINS...
    DISCARDING FALSE VIRTUAL NETS, RESOLVING DEEP SHORTS AND PERFORMING VIRTUAL CONNECTIONS...
    CREATING COMPACT PIN DATA STRUCTURE...
    FINALIZING NODE NUMBERS ON SCONNECT LAYERS...
    RESOLVING SHORT CIRCUIT TEXT...
    PROCESSING HIGH SHORTS...
    COMPUTING FINAL NET NAMES AND REPORTING TEXT WARNINGS...
    PROCESSING LINK OPTIONS OF SCONNECT STATEMENTS...
POST-PROCESSING completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34
CONNECTIVITY EXTRACTION completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
WRITING CELL INFORMATION to PHDB svdb
PHDB CELL DATA WRITE completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  ELAPSED TIME = 1
WRITING CONNECT INFORMATION to PHDB svdb
PHDB CONNECT INFORMATION written. CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 35/35/35  ELAPSED TIME = 1
Layer lvpsb DELETED -- LVHEAP = 3/5/67
Layer lvnsb DELETED -- LVHEAP = 3/5/67
Layer wtmct DELETED -- LVHEAP = 3/5/67
Layer wtcon DELETED -- LVHEAP = 3/5/67
Layer var18_rf_gt_con DELETED -- LVHEAP = 3/5/67
Layer var33_rf_gt_con DELETED -- LVHEAP = 3/5/67
Layer w1_and_gt DELETED -- LVHEAP = 3/5/67
Layer w1_and_nsd DELETED -- LVHEAP = 3/5/67
Layer w1_and_psd DELETED -- LVHEAP = 3/5/67
DEVICE RECOGNITION
LVS PUSH DEVICES enabled.
MCTM5 = OR MCTM5
MCTM5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 202 OF 455  ELAPSED TIME = 1
Original Layer MCTM5 DELETED -- LVHEAP = 4/5/67
mct5 = mctcap AND MCTM5
mct5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 203 OF 455  ELAPSED TIME = 1
mimcap5x = mct5 AND A5_drc
mimcap5x (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 204 OF 455  ELAPSED TIME = 1
Layer mct5 DELETED -- LVHEAP = 4/5/67
mimcap5 = mimcap5x NOT RFDUM_mark
mimcap5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 205 OF 455  ELAPSED TIME = 1
var33a = var33 NOT RFDUM_mark
var33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 206 OF 455  ELAPSED TIME = 1
var33_mix = VARMOS_mark ENCLOSE var33a
var33_mix (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 207 OF 455  ELAPSED TIME = 1
var18a = var18 NOT RFDUM_mark
var18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 208 OF 455  ELAPSED TIME = 1
var18_mix = VARMOS_mark ENCLOSE var18a
var18_mix (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 209 OF 455  ELAPSED TIME = 1
Layer VARMOS_mark DELETED -- LVHEAP = 4/5/67
ngate = GT_drc AND ndiff
ngate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 210 OF 455  ELAPSED TIME = 1
mosngate = ngate OUTSIDE TB_drc
mosngate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 211 OF 455  ELAPSED TIME = 1
Layer ngate DELETED -- LVHEAP = 4/5/67
ngate33 = mosngate AND HV_drc
ngate33 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 212 OF 455  ELAPSED TIME = 1
ngate18 = mosngate NOT ngate33
ngate18 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 213 OF 455  ELAPSED TIME = 1
PWB = OR PWB
PWB (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 214 OF 455  ELAPSED TIME = 1
Original Layer PWB DELETED -- LVHEAP = 4/5/67
PWB_drc = PWB NOT DCTY_mark
PWB_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 215 OF 455  ELAPSED TIME = 1
nngate18 = ngate18 AND PWB_drc
nngate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 216 OF 455  ELAPSED TIME = 1
nngate33 = ngate33 AND PWB_drc
nngate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 217 OF 455  ELAPSED TIME = 1
MN = OR MN
MN (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 218 OF 455  ELAPSED TIME = 1
Original Layer MN DELETED -- LVHEAP = 4/5/67
MN_drc = MN NOT DCTY_mark
MN_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 219 OF 455  ELAPSED TIME = 1
nmgate18 = ngate18 AND MN_drc
nmgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 220 OF 455  ELAPSED TIME = 1
nmgate33 = ngate33 AND MN_drc
nmgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 221 OF 455  ELAPSED TIME = 1
pgate = GT_drc AND pdiff
pgate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 222 OF 455  ELAPSED TIME = 1
mospgate = pgate INSIDE TB_drc
mospgate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 223 OF 455  ELAPSED TIME = 1
pgate33 = mospgate AND HV_drc
pgate33 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 224 OF 455  ELAPSED TIME = 1
pgate18 = mospgate NOT pgate33
pgate18 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 225 OF 455  ELAPSED TIME = 1
MP = OR MP
MP (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 226 OF 455  ELAPSED TIME = 1
Original Layer MP DELETED -- LVHEAP = 4/5/67
MP_drc = MP NOT DCTY_mark
MP_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 227 OF 455  ELAPSED TIME = 1
pmgate18 = pgate18 AND MP_drc
pmgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 228 OF 455  ELAPSED TIME = 1
pmgate33 = pgate33 AND MP_drc
pmgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 229 OF 455  ELAPSED TIME = 1
PD = OR PD
PD (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 230 OF 455  ELAPSED TIME = 1
Original Layer PD DELETED -- LVHEAP = 4/5/67
PD_drc = PD NOT DCTY_mark
PD_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 231 OF 455  ELAPSED TIME = 1
pdgate = pgate AND PD_drc
pdgate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 232 OF 455  ELAPSED TIME = 1
Layer pgate DELETED -- LVHEAP = 4/5/67
ESD_mark = OR ESD_mark
ESD_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 233 OF 455  ELAPSED TIME = 1
Original Layer ESD_mark DELETED -- LVHEAP = 4/5/67
esd_to = TO_drc AND ESD_mark
esd_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 234 OF 455  ELAPSED TIME = 1
Layer TO_drc DELETED -- LVHEAP = 4/5/67
SE = OR SE
SE (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 235 OF 455  ELAPSED TIME = 1
Original Layer SE DELETED -- LVHEAP = 4/5/67
SE_drc = SE NOT DCTY_mark
SE_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 236 OF 455  ELAPSED TIME = 1
nesd_to = esd_to AND SE_drc
nesd_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 237 OF 455  ELAPSED TIME = 1
esdnmos = ngate33 AND nesd_to
esdnmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 238 OF 455  ELAPSED TIME = 1
esdlvnmos = ngate18 AND nesd_to
esdlvnmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 239 OF 455  ELAPSED TIME = 1
Layer nesd_to DELETED -- LVHEAP = 4/5/67
esdpmos = pgate33 AND esd_to
esdpmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 240 OF 455  ELAPSED TIME = 1
Layer esd_to DELETED -- LVHEAP = 4/5/67
VTSRAM_mark = OR VTSRAM_mark
VTSRAM_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 241 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_mark DELETED -- LVHEAP = 4/5/67
nsram = mosngate AND VTSRAM_mark
nsram (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 242 OF 455  ELAPSED TIME = 1
mn_acess = AREA nsram > 0.054 <= 0.056
mn_pudn = AREA nsram > 0.052 <= 0.053
mn_acess (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 244 OF 455  ELAPSED TIME = 1
Layer nsram DELETED -- LVHEAP = 4/5/67
VTSRAM_gc2 = OR VTSRAM_gc2
VTSRAM_gc2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 245 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_gc2 DELETED -- LVHEAP = 4/5/67
nsram_gc2 = mosngate AND VTSRAM_gc2
nsram_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 246 OF 455  ELAPSED TIME = 1
mn_acess_gc2 = AREA nsram_gc2 > 0.054 <= 0.056
mn_pudn_gc2 = AREA nsram_gc2 > 0.052 <= 0.053
mn_acess_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 248 OF 455  ELAPSED TIME = 1
Layer nsram_gc2 DELETED -- LVHEAP = 4/5/67
VTSRAM_gc3 = OR VTSRAM_gc3
VTSRAM_gc3 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 249 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_gc3 DELETED -- LVHEAP = 4/5/67
nsram_gc3 = mosngate AND VTSRAM_gc3
nsram_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 250 OF 455  ELAPSED TIME = 1
mn_acess_gc3 = AREA nsram_gc3 > 0.054 <= 0.056
mn_pudn_gc3 = AREA nsram_gc3 > 0.059 <= 0.06
mn_acess_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 252 OF 455  ELAPSED TIME = 1
Layer nsram_gc3 DELETED -- LVHEAP = 4/5/67
VTSRAM_l = OR VTSRAM_l
VTSRAM_l (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 253 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_l DELETED -- LVHEAP = 4/5/67
nsram_l = mosngate AND VTSRAM_l
nsram_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 254 OF 455  ELAPSED TIME = 1
mn_acess_l = AREA nsram_l > 0.0774 <= 0.0776
mn_pudn_l = AREA nsram_l > 0.0721 <= 0.0723
mn_acess_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 256 OF 455  ELAPSED TIME = 1
Layer nsram_l DELETED -- LVHEAP = 4/5/67
VTSRAM_lc = OR VTSRAM_lc
VTSRAM_lc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 257 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_lc DELETED -- LVHEAP = 4/5/67
nsram_lc = mosngate AND VTSRAM_lc
nsram_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 258 OF 455  ELAPSED TIME = 1
Layer mosngate DELETED -- LVHEAP = 4/5/67
mn_acess_lc = AREA nsram_lc > 0.0774 <= 0.0776
mn_pudn_lc = AREA nsram_lc > 0.0721 <= 0.0723
mn_acess_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 260 OF 455  ELAPSED TIME = 1
Layer nsram_lc DELETED -- LVHEAP = 4/5/67
mp_puup = mospgate AND VTSRAM_mark
mp_puup (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 261 OF 455  ELAPSED TIME = 1
mp_puup_gc2 = mospgate AND VTSRAM_gc2
mp_puup_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 262 OF 455  ELAPSED TIME = 1
mp_puup_gc3 = mospgate AND VTSRAM_gc3
mp_puup_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 263 OF 455  ELAPSED TIME = 1
mp_puup_l = mospgate AND VTSRAM_l
mp_puup_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 264 OF 455  ELAPSED TIME = 1
mp_puup_lc = mospgate AND VTSRAM_lc
mp_puup_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 265 OF 455  ELAPSED TIME = 1
Layer mospgate DELETED -- LVHEAP = 4/5/67
TMP<9> = PWB_drc OR MN_drc
TMP<9> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 266 OF 455  ELAPSED TIME = 1
Layer PWB_drc DELETED -- LVHEAP = 4/5/67
Layer MN_drc DELETED -- LVHEAP = 4/5/67
TMP<8> = TMP<9> OR MP_drc
TMP<8> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 267 OF 455  ELAPSED TIME = 1
Layer TMP<9> DELETED -- LVHEAP = 4/5/67
Layer MP_drc DELETED -- LVHEAP = 4/5/67
TMP<7> = TMP<8> OR PD_drc
TMP<7> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 268 OF 455  ELAPSED TIME = 1
Layer TMP<8> DELETED -- LVHEAP = 4/5/67
Layer PD_drc DELETED -- LVHEAP = 4/5/67
TMP<6> = TMP<7> OR VTSRAM_mark
TMP<6> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 269 OF 455  ELAPSED TIME = 1
Layer TMP<7> DELETED -- LVHEAP = 4/5/67
TMP<5> = TMP<6> OR VTSRAM_gc2
TMP<5> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 270 OF 455  ELAPSED TIME = 1
Layer TMP<6> DELETED -- LVHEAP = 4/5/67
TMP<4> = TMP<5> OR VTSRAM_gc3
TMP<4> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 271 OF 455  ELAPSED TIME = 1
Layer TMP<5> DELETED -- LVHEAP = 4/5/67
TMP<3> = TMP<4> OR VTSRAM_l
TMP<3> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 272 OF 455  ELAPSED TIME = 1
Layer TMP<4> DELETED -- LVHEAP = 4/5/67
nonom_5 = TMP<3> OR VTSRAM_lc
nonom_5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 273 OF 455  ELAPSED TIME = 1
Layer TMP<3> DELETED -- LVHEAP = 4/5/67
ngate18a = ngate18 NOT nonom_5
ngate18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 274 OF 455  ELAPSED TIME = 1
Layer ngate18 DELETED -- LVHEAP = 4/5/67
ntgate18 = ngate18a NOT RFDUM_mark
ntgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 275 OF 455  ELAPSED TIME = 1
nonom_6 = ESD_mark OR nonom_5
nonom_6 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 276 OF 455  ELAPSED TIME = 1
ngate33a = ngate33 NOT nonom_6
ngate33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 277 OF 455  ELAPSED TIME = 1
Layer ngate33 DELETED -- LVHEAP = 4/5/67
ntgate33 = ngate33a NOT RFDUM_mark
ntgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 278 OF 455  ELAPSED TIME = 1
pgate18a = pgate18 NOT nonom_5
pgate18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 279 OF 455  ELAPSED TIME = 1
Layer pgate18 DELETED -- LVHEAP = 4/5/67
Layer nonom_5 DELETED -- LVHEAP = 4/5/67
ptgate18 = pgate18a NOT RFDUM_mark
ptgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 280 OF 455  ELAPSED TIME = 1
pgate33a = pgate33 NOT nonom_6
pgate33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 281 OF 455  ELAPSED TIME = 1
Layer pgate33 DELETED -- LVHEAP = 4/5/67
Layer nonom_6 DELETED -- LVHEAP = 4/5/67
ptgate33 = pgate33a NOT RFDUM_mark
ptgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 282 OF 455  ELAPSED TIME = 1
v1Rec = RECTANGLE qvp33_e == 2 BY == 2
v2Rec = RECTANGLE qvp33_e == 5 BY == 5
v3Rec = RECTANGLE qvp33_e == 10 BY == 10
v1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
v2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
v3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 285 OF 455  ELAPSED TIME = 1
p1Rec = RECTANGLE qvp18_e == 2 BY == 2
p2Rec = RECTANGLE qvp18_e == 5 BY == 5
p3Rec = RECTANGLE qvp18_e == 10 BY == 10
p1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
p2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
p3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 288 OF 455  ELAPSED TIME = 1
TMP<14> = vnpn_e NOT HV_drc
TMP<14> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 289 OF 455  ELAPSED TIME = 1
n4Rec = RECTANGLE TMP<14> == 0.6 BY == 0.6
n1Rec = RECTANGLE TMP<14> == 2 BY == 2
n2Rec = RECTANGLE TMP<14> == 5 BY == 5
n3Rec = RECTANGLE TMP<14> == 10 BY == 10
n4Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 293 OF 455  ELAPSED TIME = 1
Layer TMP<14> DELETED -- LVHEAP = 4/5/67
TMP<18> = vnpn_e AND HV_drc
TMP<18> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 294 OF 455  ELAPSED TIME = 1
h4Rec = RECTANGLE TMP<18> == 0.6 BY == 0.6
h1Rec = RECTANGLE TMP<18> == 2 BY == 2
h2Rec = RECTANGLE TMP<18> == 5 BY == 5
h3Rec = RECTANGLE TMP<18> == 10 BY == 10
h4Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 298 OF 455  ELAPSED TIME = 1
Layer TMP<18> DELETED -- LVHEAP = 4/5/67
esdndiff = ndiff AND SE_drc
esdndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 299 OF 455  ELAPSED TIME = 1
dioesd = esdndiff AND DIODE_mark
dioesd (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 300 OF 455  ELAPSED TIME = 1
Layer esdndiff DELETED -- LVHEAP = 4/5/67
dnpwesd = dioesd NOT INTERACT nwelcon
dnpwesd (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 301 OF 455  ELAPSED TIME = 1
Layer dioesd DELETED -- LVHEAP = 4/5/67
ndiff_dio = ndiff AND DIODE_mark
ndiff_dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 302 OF 455  ELAPSED TIME = 1
ndiff_dio_no_esd = ndiff_dio NOT INTERACT SE_drc
ndiff_dio_no_esd (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 303 OF 455  ELAPSED TIME = 1
Layer SE_drc DELETED -- LVHEAP = 4/5/67
dnpw = ndiff_dio_no_esd NOT nwelcon
dnpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 304 OF 455  ELAPSED TIME = 1
Layer ndiff_dio_no_esd DELETED -- LVHEAP = 4/5/67
dnpw33 = dnpw AND HV_drc
dnpw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 305 OF 455  ELAPSED TIME = 1
dnpw18 = dnpw OUTSIDE HV_drc
dnpw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 306 OF 455  ELAPSED TIME = 1
Layer dnpw DELETED -- LVHEAP = 4/5/67
dnwdio = TB_drc ENCLOSE ndiff_dio
dnwdio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 307 OF 455  ELAPSED TIME = 1
Layer ndiff_dio DELETED -- LVHEAP = 4/5/67
dnwpw = dnwdio NOT INTERACT DN_drc
dnwpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 308 OF 455  ELAPSED TIME = 1
Layer dnwdio DELETED -- LVHEAP = 4/5/67
dnwpw33 = dnwpw AND HV_drc
dnwpw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 309 OF 455  ELAPSED TIME = 1
dnwpw18 = dnwpw OUTSIDE HV_drc
dnwpw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 310 OF 455  ELAPSED TIME = 1
Layer dnwpw DELETED -- LVHEAP = 4/5/67
pdiff_dio = pdiff AND DIODE_mark
pdiff_dio (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 311 OF 455  ELAPSED TIME = 1
dpnw = pdiff_dio AND nwelcon
dpnw (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 312 OF 455  ELAPSED TIME = 1
Layer pdiff_dio DELETED -- LVHEAP = 4/5/67
dpnw33 = dpnw AND HV_drc
dpnw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 313 OF 455  ELAPSED TIME = 1
dpnw18 = dpnw NOT HV_drc
dpnw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 314 OF 455  ELAPSED TIME = 1
Layer dpnw DELETED -- LVHEAP = 4/5/67
dnndiff = DN_drc ENCLOSE ndiff
dnndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 315 OF 455  ELAPSED TIME = 1
Layer DN_drc DELETED -- LVHEAP = 4/5/67
ddepdio = dnndiff AND DIODE_mark
ddepdio (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 316 OF 455  ELAPSED TIME = 1
Layer dnndiff DELETED -- LVHEAP = 4/5/67
Layer DIODE_mark DELETED -- LVHEAP = 4/5/67
ddnwpw = ddepdio AND TB_drc
ddnwpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 317 OF 455  ELAPSED TIME = 1
Layer ddepdio DELETED -- LVHEAP = 4/5/67
Layer TB_drc DELETED -- LVHEAP = 4/5/67
m1_res = A1_drc AND RES_M1
m1_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 318 OF 455  ELAPSED TIME = 1
Layer A1_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M1 DELETED -- LVHEAP = 4/5/67
m2_res = A2_drc AND RES_M2
m2_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 319 OF 455  ELAPSED TIME = 1
Layer A2_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M2 DELETED -- LVHEAP = 4/5/67
m3_res = A3_drc AND RES_M3
m3_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 320 OF 455  ELAPSED TIME = 1
Layer A3_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M3 DELETED -- LVHEAP = 4/5/67
m4_res = A4_drc AND RES_M4
m4_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 321 OF 455  ELAPSED TIME = 1
Layer A4_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M4 DELETED -- LVHEAP = 4/5/67
m5_res = A5_drc AND RES_M5
m5_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 322 OF 455  ELAPSED TIME = 1
Layer A5_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M5 DELETED -- LVHEAP = 4/5/67
tt_res = MTT_drc AND RES_MT
tt_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 323 OF 455  ELAPSED TIME = 1
Layer MTT_drc DELETED -- LVHEAP = 4/5/67
Layer RES_MT DELETED -- LVHEAP = 4/5/67
RES_3T_mark = OR RES_3T_mark
RES_3T_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 324 OF 455  ELAPSED TIME = 1
Original Layer RES_3T_mark DELETED -- LVHEAP = 4/5/67
rnw_rec_2t = rnw_rec OUTSIDE RES_3T_mark
rnw_rec_3t = rnw_rec NOT OUTSIDE RES_3T_mark
rnw_rec_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnw_rec_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 326 OF 455  ELAPSED TIME = 1
Layer rnw_rec DELETED -- LVHEAP = 4/5/67
rnw_sab_2t = rnw_sab OUTSIDE RES_3T_mark
rnw_sab_3t = rnw_sab NOT OUTSIDE RES_3T_mark
rnw_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnw_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 328 OF 455  ELAPSED TIME = 1
Layer rnw_sab DELETED -- LVHEAP = 4/5/67
rndiff = ndiff AND RES_TO_mark
rndiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 329 OF 455  ELAPSED TIME = 1
Layer ndiff DELETED -- LVHEAP = 4/5/67
rndiff_nsab1 = rndiff OUTSIDE SI_drc
rndiff_sab1 = rndiff NOT OUTSIDE SI_drc
rndiff_nsab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rndiff_sab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 331 OF 455  ELAPSED TIME = 1
Layer rndiff DELETED -- LVHEAP = 4/5/67
rndiff_sab2 = rndiff_sab1 AND RNDMY
rndiff_sab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 332 OF 455  ELAPSED TIME = 1
Layer rndiff_sab1 DELETED -- LVHEAP = 4/5/67
rndiff_sab3 = rndiff_sab2 OUTSIDE RES_3T_mark
rnimp_sab_3t = rndiff_sab2 NOT OUTSIDE RES_3T_mark
rndiff_sab3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnimp_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 334 OF 455  ELAPSED TIME = 1
rnimp_sab_2t = rndiff_sab3 OUTSIDE RFDUM_mark
rnimp_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 335 OF 455  ELAPSED TIME = 1
Layer rndiff_sab3 DELETED -- LVHEAP = 4/5/67
rndiff_nsab2 = rndiff_nsab1 NOT RNDMY
rndiff_nsab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 336 OF 455  ELAPSED TIME = 1
Layer rndiff_nsab1 DELETED -- LVHEAP = 4/5/67
rnimp_2t = rndiff_nsab2 OUTSIDE RES_3T_mark
rnimp_3t = rndiff_nsab2 NOT OUTSIDE RES_3T_mark
rnimp_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnimp_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 338 OF 455  ELAPSED TIME = 1
Layer rndiff_nsab2 DELETED -- LVHEAP = 4/5/67
rpdiff = pdiff AND RES_TO_mark
rpdiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 339 OF 455  ELAPSED TIME = 1
Layer pdiff DELETED -- LVHEAP = 4/5/67
Layer RES_TO_mark DELETED -- LVHEAP = 4/5/67
rpdiff_nsab1 = rpdiff OUTSIDE SI_drc
rpdiff_sab1 = rpdiff NOT OUTSIDE SI_drc
rpdiff_nsab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpdiff_sab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 341 OF 455  ELAPSED TIME = 1
Layer rpdiff DELETED -- LVHEAP = 4/5/67
RPDMY = OR RPDMY
RPDMY (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 342 OF 455  ELAPSED TIME = 1
Original Layer RPDMY DELETED -- LVHEAP = 4/5/67
rpdiff_sab2 = rpdiff_sab1 AND RPDMY
rpdiff_sab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 343 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab1 DELETED -- LVHEAP = 4/5/67
rpdiff_sab3 = rpdiff_sab2 OUTSIDE RES_3T_mark
rpimp_sab_3t = rpdiff_sab2 NOT OUTSIDE RES_3T_mark
rpdiff_sab3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpimp_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 345 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab2 DELETED -- LVHEAP = 4/5/67
rpimp_sab_2t = rpdiff_sab3 OUTSIDE RFDUM_mark
rpimp_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 346 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab3 DELETED -- LVHEAP = 4/5/67
rpdiff_nsab2 = rpdiff_nsab1 NOT RPDMY
rpdiff_nsab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 347 OF 455  ELAPSED TIME = 1
Layer rpdiff_nsab1 DELETED -- LVHEAP = 4/5/67
rpimp_2t = rpdiff_nsab2 OUTSIDE RES_3T_mark
rpimp_3t = rpdiff_nsab2 NOT OUTSIDE RES_3T_mark
rpimp_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpimp_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 349 OF 455  ELAPSED TIME = 1
Layer rpdiff_nsab2 DELETED -- LVHEAP = 4/5/67
ndifpoly = GT_drc INSIDE SN_drc
ndifpoly (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 350 OF 455  ELAPSED TIME = 1
Layer SN_drc DELETED -- LVHEAP = 4/5/67
rndifpoly = ndifpoly AND RES_PY_mark
rndifpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 351 OF 455  ELAPSED TIME = 1
Layer ndifpoly DELETED -- LVHEAP = 4/5/67
rndifpoly_sab_o = rndifpoly OUTSIDE SI_drc
rndifpoly_sab = rndifpoly NOT OUTSIDE SI_drc
rndifpoly_sab_o (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rndifpoly_sab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 353 OF 455  ELAPSED TIME = 1
Layer rndifpoly DELETED -- LVHEAP = 4/5/67
rnpoly_sab1 = rndifpoly_sab AND RNDMY
rnpoly_sab1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 354 OF 455  ELAPSED TIME = 1
Layer rndifpoly_sab DELETED -- LVHEAP = 4/5/67
TMP<22> = rnpoly_sab1 INTERACT RFDUM_mark
rnpoly_sab = rnpoly_sab1 NOT INTERACT RFDUM_mark
TMP<22> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnpoly_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 356 OF 455  ELAPSED TIME = 1
Layer rnpoly_sab1 DELETED -- LVHEAP = 4/5/67
rnpoly = rndifpoly_sab_o NOT RNDMY
rnpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 357 OF 455  ELAPSED TIME = 1
Layer rndifpoly_sab_o DELETED -- LVHEAP = 4/5/67
Layer RNDMY DELETED -- LVHEAP = 4/5/67
pdifpoly = GT_drc INSIDE SP_drc
sp2poly = GT_drc CUT SP_drc
pdifpoly (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
sp2poly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 359 OF 455  ELAPSED TIME = 1
Layer GT_drc DELETED -- LVHEAP = 4/5/67
Layer SP_drc DELETED -- LVHEAP = 4/5/67
rpdifpoly = pdifpoly AND RES_PY_mark
rpdifpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 360 OF 455  ELAPSED TIME = 1
Layer pdifpoly DELETED -- LVHEAP = 4/5/67
Layer RES_PY_mark DELETED -- LVHEAP = 4/5/67
rpdifpoly_sab_o = rpdifpoly OUTSIDE SI_drc
rpdifpoly_sab = rpdifpoly NOT OUTSIDE SI_drc
rpdifpoly_sab_o (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpdifpoly_sab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 362 OF 455  ELAPSED TIME = 1
Layer rpdifpoly DELETED -- LVHEAP = 4/5/67
rppoly_sab1 = rpdifpoly_sab AND RPDMY
rppoly_sab1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 363 OF 455  ELAPSED TIME = 1
Layer rpdifpoly_sab DELETED -- LVHEAP = 4/5/67
TMP<23> = rppoly_sab1 INTERACT RFDUM_mark
rppoly_sab = rppoly_sab1 NOT INTERACT RFDUM_mark
TMP<23> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rppoly_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 365 OF 455  ELAPSED TIME = 1
Layer rppoly_sab1 DELETED -- LVHEAP = 4/5/67
TMP<21> = rpdifpoly_sab_o NOT RPDMY
TMP<21> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 366 OF 455  ELAPSED TIME = 1
Layer rpdifpoly_sab_o DELETED -- LVHEAP = 4/5/67
rppoly_rf = TMP<21> INTERACT RFDUM_mark
rppoly = TMP<21> NOT INTERACT RFDUM_mark
rppoly_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rppoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 368 OF 455  ELAPSED TIME = 1
Layer TMP<21> DELETED -- LVHEAP = 4/5/67
sipoly = sp2poly INTERACT SI_drc
sipoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 369 OF 455  ELAPSED TIME = 1
Layer sp2poly DELETED -- LVHEAP = 4/5/67
Layer SI_drc DELETED -- LVHEAP = 4/5/67
HR = OR HR
HR (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 370 OF 455  ELAPSED TIME = 1
Original Layer HR DELETED -- LVHEAP = 4/5/67
HR_drc = HR NOT DCTY_mark
HR_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 371 OF 455  ELAPSED TIME = 1
Layer DCTY_mark DELETED -- LVHEAP = 4/5/67
hrpoly1 = sipoly NOT OUTSIDE HR_drc
hrpoly1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 372 OF 455  ELAPSED TIME = 1
Layer sipoly DELETED -- LVHEAP = 4/5/67
Layer HR_drc DELETED -- LVHEAP = 4/5/67
hrpoly2 = hrpoly1 AND RES_HR_mark
hrpoly2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 373 OF 455  ELAPSED TIME = 1
Layer hrpoly1 DELETED -- LVHEAP = 4/5/67
Layer RES_HR_mark DELETED -- LVHEAP = 4/5/67
hrpoly3 = hrpoly2 AND RPDMY
hrpoly3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 374 OF 455  ELAPSED TIME = 1
Layer hrpoly2 DELETED -- LVHEAP = 4/5/67
hrpoly_rf = hrpoly3 INTERACT RFDUM_mark
hrpoly = hrpoly3 NOT INTERACT RFDUM_mark
hrpoly_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
hrpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 376 OF 455  ELAPSED TIME = 1
Layer hrpoly3 DELETED -- LVHEAP = 4/5/67
ngate18_rf = RFDUM_mark ENCLOSE ngate18a
ngate18_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 377 OF 455  ELAPSED TIME = 1
ngate33_rf = RFDUM_mark ENCLOSE ngate33a
ngate33_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 378 OF 455  ELAPSED TIME = 1
pgate18_rf = RFDUM_mark ENCLOSE pgate18a
pgate18_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 379 OF 455  ELAPSED TIME = 1
pgate33_rf = RFDUM_mark ENCLOSE pgate33a
pgate33_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 380 OF 455  ELAPSED TIME = 1
rnpsab_rf = TMP<22> AND nwelcon
rnpsab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 381 OF 455  ELAPSED TIME = 1
Layer TMP<22> DELETED -- LVHEAP = 4/5/67
rppsab_rf = TMP<23> AND nwelcon
rppsab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 382 OF 455  ELAPSED TIME = 1
Layer TMP<23> DELETED -- LVHEAP = 4/5/67
rnisab_rf = rndiff_sab2 INTERACT RFDUM_mark
rnisab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 383 OF 455  ELAPSED TIME = 1
Layer rndiff_sab2 DELETED -- LVHEAP = 4/5/67
VARJUN_mark = OR VARJUN_mark
VARJUN_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 384 OF 455  ELAPSED TIME = 1
Original Layer VARJUN_mark DELETED -- LVHEAP = 4/5/67
jvarnw = nwelcon AND VARJUN_mark
jvarnw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 385 OF 455  ELAPSED TIME = 1
TMP<25> = jvarnw INTERACT psd
TMP<25> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 386 OF 455  ELAPSED TIME = 1
Layer jvarnw DELETED -- LVHEAP = 4/5/67
TMP<24> = TMP<25> INTERACT nsd
TMP<24> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 387 OF 455  ELAPSED TIME = 1
Layer TMP<25> DELETED -- LVHEAP = 4/5/67
jvarreg = TMP<24> AND psd
jvarreg (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 388 OF 455  ELAPSED TIME = 1
Layer TMP<24> DELETED -- LVHEAP = 4/5/67
TMP<26> = jvarreg AND HV_drc
TMP<26> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 389 OF 455  ELAPSED TIME = 1
Layer HV_drc DELETED -- LVHEAP = 4/5/67
jpvar33dio = VARJUN_mark ENCLOSE TMP<26>
jpvar33dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 390 OF 455  ELAPSED TIME = 1
Layer TMP<26> DELETED -- LVHEAP = 4/5/67
TMP<27> = jvarreg NOT jpvar33dio
TMP<27> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 391 OF 455  ELAPSED TIME = 1
Layer jvarreg DELETED -- LVHEAP = 4/5/67
jpvar18dio = VARJUN_mark ENCLOSE TMP<27>
jpvar18dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 392 OF 455  ELAPSED TIME = 1
Layer TMP<27> DELETED -- LVHEAP = 4/5/67
mimcap5_rf = mimcap5x AND RFDUM_mark
mimcap5_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 393 OF 455  ELAPSED TIME = 1
Layer mimcap5x DELETED -- LVHEAP = 4/5/67
var18_rf_mos = var18 AND RFDUM_mark
var18_rf_mos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 394 OF 455  ELAPSED TIME = 1
Layer var18 DELETED -- LVHEAP = 4/5/67
var33_rf_mos = var33 AND RFDUM_mark
var33_rf_mos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 395 OF 455  ELAPSED TIME = 1
Layer var33 DELETED -- LVHEAP = 4/5/67
Layer RFDUM_mark DELETED -- LVHEAP = 4/5/67
metal_ind = tt_ind OR am_ind
metal_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 396 OF 455  ELAPSED TIME = 1
ttind_hole1 = HOLES metal_ind INNER EMPTY
ttind_hole1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 397 OF 455  ELAPSED TIME = 1
ttind_hole2 = SIZE ttind_hole1 BY 3.5 UNDEROVER
ttind_hole2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 398 OF 455  ELAPSED TIME = 1
Layer ttind_hole1 DELETED -- LVHEAP = 4/5/67
ttind_hole = EXTENTS ttind_hole2
ttind_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 399 OF 455  ELAPSED TIME = 1
Layer ttind_hole2 DELETED -- LVHEAP = 4/5/67
ttind_body = tt_ind INTERACT ttind_hole
ttind_body (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 400 OF 455  ELAPSED TIME = 1
diff_amedge = ANGLE am_ind > 0 < 90
diff_amedge (HIER-PMF TYP=2 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 401 OF 455  ELAPSED TIME = 1
diff_am_ind = am_ind WITH EDGE diff_amedge
diff_am_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 402 OF 455  ELAPSED TIME = 1
Layer diff_amedge DELETED -- LVHEAP = 4/5/67
difnum_touch = tt_ind AND diff_am_ind
difnum_touch (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 403 OF 455  ELAPSED TIME = 1
diff_ind = INDUM_mark ENCLOSE diff_am_ind
diff_ind (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 404 OF 455  ELAPSED TIME = 1
Layer diff_am_ind DELETED -- LVHEAP = 4/5/67
diff_ind_hole = diff_ind AND ttind_hole
diff_ind_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 405 OF 455  ELAPSED TIME = 1
diff_ind_r60 = INT diff_ind_hole < 180 REGION OPPOSITE PARALLEL ONLY
diff_ind_r120 = INT diff_ind_hole > 180 < 250 REGION OPPOSITE PARALLEL ONLY
diff_ind_r60 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r120 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 407 OF 455  ELAPSED TIME = 1
Layer diff_ind_hole DELETED -- LVHEAP = 4/5/67
TMP<32> = metal_ind INTERACT diff_ind_r60
TMP<32> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 408 OF 455  ELAPSED TIME = 1
Layer diff_ind_r60 DELETED -- LVHEAP = 4/5/67
diff_ind_r60n3d5 = TMP<32> INTERACT difnum_touch > 8 < 10
diff_ind_r60n5d5 = TMP<32> INTERACT difnum_touch > 14 < 16
diff_ind_r60n7d5 = TMP<32> INTERACT difnum_touch > 20 < 22
diff_ind_r60n3d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r60n5d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r60n7d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 411 OF 455  ELAPSED TIME = 1
Layer TMP<32> DELETED -- LVHEAP = 4/5/67
TMP<33> = metal_ind INTERACT diff_ind_r120
TMP<33> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 412 OF 455  ELAPSED TIME = 1
Layer diff_ind_r120 DELETED -- LVHEAP = 4/5/67
diff_ind_r120n3d5 = TMP<33> INTERACT difnum_touch > 8 < 10
diff_ind_r120n3d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 413 OF 455  ELAPSED TIME = 1
Layer TMP<33> DELETED -- LVHEAP = 4/5/67
ttind_hole_edge = EXPAND EDGE ttind_hole OUTSIDE BY 1
ttind_hole_edge (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 414 OF 455  ELAPSED TIME = 1
Layer ttind_hole DELETED -- LVHEAP = 4/5/67
diff_ind_w = ttind_hole_edge INTERACT difnum_touch
diff_ind_w (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 415 OF 455  ELAPSED TIME = 1
spri_ind = INDUM_mark NOT diff_ind
spri_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 416 OF 455  ELAPSED TIME = 1
Layer INDUM_mark DELETED -- LVHEAP = 4/5/67
Layer diff_ind DELETED -- LVHEAP = 4/5/67
spri_ind_rec = metal_ind INTERACT spri_ind
spri_ind_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 417 OF 455  ELAPSED TIME = 1
Layer metal_ind DELETED -- LVHEAP = 4/5/67
spri_am_ind = spri_ind AND am_ind
spri_am_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 418 OF 455  ELAPSED TIME = 1
Layer spri_ind DELETED -- LVHEAP = 4/5/67
Layer am_ind DELETED -- LVHEAP = 4/5/67
TMP<34> = spri_am_ind NOT tt_ind
TMP<34> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 419 OF 455  ELAPSED TIME = 1
ttind_term1 = tt_ind NOT INTERACT ttind_body
ttind_term1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 420 OF 455  ELAPSED TIME = 1
spri_am_spc = TMP<34> NOT INTERACT ttind_term1
spri_am_spc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 421 OF 455  ELAPSED TIME = 1
Layer TMP<34> DELETED -- LVHEAP = 4/5/67
Layer ttind_term1 DELETED -- LVHEAP = 4/5/67
sprinum_touch = tt_ind AND spri_am_ind
sprinum_touch (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 422 OF 455  ELAPSED TIME = 1
spri_ind_hole_edge = ttind_hole_edge INTERACT sprinum_touch
spri_ind_hole_edge (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 423 OF 455  ELAPSED TIME = 1
spri_ind_edge1 = SIZE spri_ind_hole_edge BY 1
spri_ind_edge1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 424 OF 455  ELAPSED TIME = 1
spri_ind_cr = ttind_hole_edge INTERACT spri_ind_edge1
spri_ind_cr (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 425 OF 455  ELAPSED TIME = 1
Layer ttind_hole_edge DELETED -- LVHEAP = 4/5/67
Layer spri_ind_edge1 DELETED -- LVHEAP = 4/5/67
spri_ind_w = spri_ind_cr NOT spri_ind_hole_edge
spri_ind_w (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 426 OF 455  ELAPSED TIME = 1
Layer spri_ind_cr DELETED -- LVHEAP = 4/5/67
Layer spri_ind_hole_edge DELETED -- LVHEAP = 4/5/67
nlthin = ntgate18 OR nsd
nlthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 427 OF 455  ELAPSED TIME = 1
plthin = ptgate18 OR psd
plthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 428 OF 455  ELAPSED TIME = 1
nhthin = ntgate33 OR nsd
nhthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 429 OF 455  ELAPSED TIME = 1
phthin = ptgate33 OR psd
phthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 430 OF 455  ELAPSED TIME = 1
nn18thin = nngate18 OR nsd
nn18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 431 OF 455  ELAPSED TIME = 1
nn33thin = nngate33 OR nsd
nn33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 432 OF 455  ELAPSED TIME = 1
nm18thin = nmgate18 OR nsd
nm18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 433 OF 455  ELAPSED TIME = 1
pm18thin = pmgate18 OR psd
pm18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 434 OF 455  ELAPSED TIME = 1
nm33thin = nmgate33 OR nsd
nm33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 435 OF 455  ELAPSED TIME = 1
pm33thin = pmgate33 OR psd
pm33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 436 OF 455  ELAPSED TIME = 1
pdthin = pdgate OR psd
pdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 437 OF 455  ELAPSED TIME = 1
nesdlvthin = esdlvnmos OR nsd
nesdlvthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 438 OF 455  ELAPSED TIME = 1
nesdthin = esdnmos OR nsd
nesdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 439 OF 455  ELAPSED TIME = 1
pesdthin = esdpmos OR psd
pesdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 440 OF 455  ELAPSED TIME = 1
mn_acessthin = mn_acess OR nsd
mn_acessthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 441 OF 455  ELAPSED TIME = 1
mn_acessgc2thin = mn_acess_gc2 OR nsd
mn_acessgc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 442 OF 455  ELAPSED TIME = 1
mn_acessgc3thin = mn_acess_gc3 OR nsd
mn_acessgc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 443 OF 455  ELAPSED TIME = 1
mn_acesslthin = mn_acess_l OR nsd
mn_acesslthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 444 OF 455  ELAPSED TIME = 1
mn_acesslcthin = mn_acess_lc OR nsd
mn_acesslcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 445 OF 455  ELAPSED TIME = 1
mn_pudnthin = mn_pudn OR nsd
mn_pudnthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 446 OF 455  ELAPSED TIME = 1
mn_pudngc2thin = mn_pudn_gc2 OR nsd
mn_pudngc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 447 OF 455  ELAPSED TIME = 1
mn_pudngc3thin = mn_pudn_gc3 OR nsd
mn_pudngc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 448 OF 455  ELAPSED TIME = 1
mn_pudnlthin = mn_pudn_l OR nsd
mn_pudnlthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 449 OF 455  ELAPSED TIME = 1
mn_pudnlcthin = mn_pudn_lc OR nsd
mn_pudnlcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 450 OF 455  ELAPSED TIME = 1
mp_puupthin = mp_puup OR psd
mp_puupthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 451 OF 455  ELAPSED TIME = 1
mp_puupgc2thin = mp_puup_gc2 OR psd
mp_puupgc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 452 OF 455  ELAPSED TIME = 1
mp_puupgc3thin = mp_puup_gc3 OR psd
mp_puupgc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 453 OF 455  ELAPSED TIME = 1
mp_puuplthin = mp_puup_l OR psd
mp_puuplthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 454 OF 455  ELAPSED TIME = 1
mp_puuplcthin = mp_puup_lc OR psd
mp_puuplcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 455 OF 455  ELAPSED TIME = 1
DEVICE RECOGNITION TOTAL LAYER PREPARATION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67 ELAPSED TIME = 1
DEVICE RECOGNITION PRECISE INTERACTION BEGINS.
DEVICE RECOGNITION TOTAL PRECISE INTERACTION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 5/6/67 ELAPSED TIME = 1
TENTATIVE SEED PROMOTIONS:   seed layer  seeds  cell : layers touched
TENTATIVE SEED PROMOTIONS: ------------  -----  -----------------------------------------
SEED PROMOTIONS:
SEED PROMOTIONS: ==============================================================
SEED PROMOTIONS:
SEED PROMOTIONS:
SEED PROMOTIONS:       TOTAL:      0
DEVICE RECOGNITION completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 5/18/67  MALLOC = 47/47/47 ELAPSED TIME = 1
HIERARCHICAL SPICE NETLISTER
HIERARCHICAL SPICE NETLISTER completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/17/67  MALLOC = 47/47/47 ELAPSED TIME = 1
WRITING DEVICE INFORMATION to PHDB svdb
PHDB DEVICE INFORMATION written. CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/17/67  MALLOC = 47/47/47  ELAPSED TIME = 1
Layer ntgate18 DELETED -- LVHEAP = 4/17/67
Layer nlthin DELETED -- LVHEAP = 4/17/67
Layer ptgate18 DELETED -- LVHEAP = 4/17/67
Layer plthin DELETED -- LVHEAP = 4/17/67
Layer ntgate33 DELETED -- LVHEAP = 4/17/67
Layer nhthin DELETED -- LVHEAP = 4/17/67
Layer ptgate33 DELETED -- LVHEAP = 4/17/67
Layer phthin DELETED -- LVHEAP = 4/17/67
Layer nngate18 DELETED -- LVHEAP = 4/17/67
Layer nn18thin DELETED -- LVHEAP = 4/17/67
Layer nngate33 DELETED -- LVHEAP = 4/17/67
Layer nn33thin DELETED -- LVHEAP = 4/17/67
Layer nmgate18 DELETED -- LVHEAP = 4/17/67
Layer nm18thin DELETED -- LVHEAP = 4/17/67
Layer pmgate18 DELETED -- LVHEAP = 4/17/67
Layer pm18thin DELETED -- LVHEAP = 4/17/67
Layer nmgate33 DELETED -- LVHEAP = 4/17/67
Layer nm33thin DELETED -- LVHEAP = 4/17/67
Layer pmgate33 DELETED -- LVHEAP = 4/17/67
Layer pm33thin DELETED -- LVHEAP = 4/17/67
Layer pdgate DELETED -- LVHEAP = 4/17/67
Layer pdthin DELETED -- LVHEAP = 4/17/67
Layer esdlvnmos DELETED -- LVHEAP = 4/17/67
Layer nesdlvthin DELETED -- LVHEAP = 4/17/67
Layer esdnmos DELETED -- LVHEAP = 4/17/67
Layer nesdthin DELETED -- LVHEAP = 4/17/67
Layer esdpmos DELETED -- LVHEAP = 4/17/67
Layer pesdthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess DELETED -- LVHEAP = 4/17/67
Layer mn_acessthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_gc2 DELETED -- LVHEAP = 4/17/67
Layer mn_acessgc2thin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_gc3 DELETED -- LVHEAP = 4/17/67
Layer mn_acessgc3thin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_l DELETED -- LVHEAP = 4/17/67
Layer mn_acesslthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_lc DELETED -- LVHEAP = 4/17/67
Layer mn_acesslcthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn DELETED -- LVHEAP = 4/17/67
Layer mn_pudnthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_gc2 DELETED -- LVHEAP = 4/17/67
Layer mn_pudngc2thin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_gc3 DELETED -- LVHEAP = 4/17/67
Layer mn_pudngc3thin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_l DELETED -- LVHEAP = 4/17/67
Layer mn_pudnlthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_lc DELETED -- LVHEAP = 4/17/67
Layer mn_pudnlcthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup DELETED -- LVHEAP = 4/17/67
Layer mp_puupthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_gc2 DELETED -- LVHEAP = 4/17/67
Layer mp_puupgc2thin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_gc3 DELETED -- LVHEAP = 4/17/67
Layer mp_puupgc3thin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_l DELETED -- LVHEAP = 4/17/67
Layer mp_puuplthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_lc DELETED -- LVHEAP = 4/17/67
Layer mp_puuplcthin DELETED -- LVHEAP = 4/17/67
Layer var18_mix DELETED -- LVHEAP = 4/17/67
Layer var18a DELETED -- LVHEAP = 4/17/67
Layer var33_mix DELETED -- LVHEAP = 4/17/67
Layer var33a DELETED -- LVHEAP = 4/17/67
Layer ngate18_rf DELETED -- LVHEAP = 4/17/67
Layer ngate18a DELETED -- LVHEAP = 4/17/67
Layer pgate18_rf DELETED -- LVHEAP = 4/17/67
Layer pgate18a DELETED -- LVHEAP = 4/17/67
Layer ngate33_rf DELETED -- LVHEAP = 4/17/67
Layer ngate33a DELETED -- LVHEAP = 4/17/67
Layer pgate33_rf DELETED -- LVHEAP = 4/17/67
Layer pgate33a DELETED -- LVHEAP = 4/17/67
Layer var18_rf_rec DELETED -- LVHEAP = 4/17/67
Layer var18_rf_gt DELETED -- LVHEAP = 4/17/67
Layer var18_rf_to DELETED -- LVHEAP = 4/17/67
Layer var18_rf_mos DELETED -- LVHEAP = 4/17/67
Layer var33_rf_rec DELETED -- LVHEAP = 4/17/67
Layer var33_rf_gt DELETED -- LVHEAP = 4/17/67
Layer var33_rf_to DELETED -- LVHEAP = 4/17/67
Layer var33_rf_mos DELETED -- LVHEAP = 4/17/67
Layer v1Rec DELETED -- LVHEAP = 4/17/67
Layer v2Rec DELETED -- LVHEAP = 4/17/67
Layer v3Rec DELETED -- LVHEAP = 4/17/67
Layer p1Rec DELETED -- LVHEAP = 4/17/67
Layer p2Rec DELETED -- LVHEAP = 4/17/67
Layer p3Rec DELETED -- LVHEAP = 4/17/67
Layer n1Rec DELETED -- LVHEAP = 4/17/67
Layer n2Rec DELETED -- LVHEAP = 4/17/67
Layer n3Rec DELETED -- LVHEAP = 4/17/67
Layer n4Rec DELETED -- LVHEAP = 4/17/67
Layer h1Rec DELETED -- LVHEAP = 4/17/67
Layer h2Rec DELETED -- LVHEAP = 4/17/67
Layer h3Rec DELETED -- LVHEAP = 4/17/67
Layer h4Rec DELETED -- LVHEAP = 4/17/67
Layer dnpwesd DELETED -- LVHEAP = 4/17/67
Layer dpnw33 DELETED -- LVHEAP = 4/17/67
Layer dpnw18 DELETED -- LVHEAP = 4/17/67
Layer dnpw33 DELETED -- LVHEAP = 4/17/67
Layer dnpw18 DELETED -- LVHEAP = 4/17/67
Layer dnwpw33 DELETED -- LVHEAP = 4/17/67
Layer dnwpw18 DELETED -- LVHEAP = 4/17/67
Layer ddnwpw DELETED -- LVHEAP = 4/17/67
Layer m1_res DELETED -- LVHEAP = 4/17/67
Layer a1_conn DELETED -- LVHEAP = 4/17/67
Layer m2_res DELETED -- LVHEAP = 4/17/67
Layer a2_conn DELETED -- LVHEAP = 4/17/67
Layer m3_res DELETED -- LVHEAP = 4/17/67
Layer a3_conn DELETED -- LVHEAP = 4/17/67
Layer rnw_rec_2t DELETED -- LVHEAP = 4/17/67
Layer rnw_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rnimp_2t DELETED -- LVHEAP = 4/17/67
Layer rpimp_2t DELETED -- LVHEAP = 4/17/67
Layer rnimp_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rpimp_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rnpoly_sab DELETED -- LVHEAP = 4/17/67
Layer rnpoly DELETED -- LVHEAP = 4/17/67
Layer rppoly_sab DELETED -- LVHEAP = 4/17/67
Layer rppoly DELETED -- LVHEAP = 4/17/67
Layer hrpoly DELETED -- LVHEAP = 4/17/67
Layer rnw_rec_3t DELETED -- LVHEAP = 4/17/67
Layer rnw_sab_3t DELETED -- LVHEAP = 4/17/67
Layer rnimp_3t DELETED -- LVHEAP = 4/17/67
Layer rpimp_3t DELETED -- LVHEAP = 4/17/67
Layer rnimp_sab_3t DELETED -- LVHEAP = 4/17/67
Layer rpimp_sab_3t DELETED -- LVHEAP = 4/17/67
Layer tt_res DELETED -- LVHEAP = 4/17/67
Layer m5_res DELETED -- LVHEAP = 4/17/67
Layer m4_res DELETED -- LVHEAP = 4/17/67
Layer a4_conn DELETED -- LVHEAP = 4/17/67
Layer mimcap5 DELETED -- LVHEAP = 4/17/67
Layer jpvar18dio DELETED -- LVHEAP = 4/17/67
Layer jpvar33dio DELETED -- LVHEAP = 4/17/67
Layer rnisab_rf DELETED -- LVHEAP = 4/17/67
Layer rnpsab_rf DELETED -- LVHEAP = 4/17/67
Layer rppsab_rf DELETED -- LVHEAP = 4/17/67
Layer rppoly_rf DELETED -- LVHEAP = 4/17/67
Layer hrpoly_rf DELETED -- LVHEAP = 4/17/67
Layer gt_conn DELETED -- LVHEAP = 4/17/67
Layer spri_ind_rec DELETED -- LVHEAP = 4/17/67
Layer tt_ind DELETED -- LVHEAP = 4/17/67
Layer spri_ind_w DELETED -- LVHEAP = 4/17/67
Layer sprinum_touch DELETED -- LVHEAP = 4/17/67
Layer spri_am_ind DELETED -- LVHEAP = 4/17/67
Layer ttind_body DELETED -- LVHEAP = 4/17/67
Layer spri_am_spc DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n3d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n5d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n7d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r120n3d5 DELETED -- LVHEAP = 4/17/67
Layer tt_conn DELETED -- LVHEAP = 4/17/67
Layer diff_ind_w DELETED -- LVHEAP = 4/17/67
Layer difnum_touch DELETED -- LVHEAP = 4/17/67
Layer mimcap5_rf DELETED -- LVHEAP = 4/17/67
Layer mctcap DELETED -- LVHEAP = 4/17/67
Layer a5_conn DELETED -- LVHEAP = 4/17/67
WRITING PHDB to directory svdb
PHDB WRITE completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/17/67  MALLOC = 48/48/48  ELAPSED TIME = 1
Layer ntap DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_s_con DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_s DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_d_con DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_d DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_s_con DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_s DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_d_con DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_d DELETED -- LVHEAP = 3/17/67
Layer ptap DELETED -- LVHEAP = 3/17/67
Layer psub DELETED -- LVHEAP = 3/17/67
Layer dn_tbtap DELETED -- LVHEAP = 3/17/67
Layer dn_nw DELETED -- LVHEAP = 3/17/67
Layer qvp33B_con DELETED -- LVHEAP = 3/17/67
Layer qvp33_b DELETED -- LVHEAP = 3/17/67
Layer qvp18B_con DELETED -- LVHEAP = 3/17/67
Layer qvp18_b DELETED -- LVHEAP = 3/17/67
Layer qvp33E_con DELETED -- LVHEAP = 3/17/67
Layer qvp33_e DELETED -- LVHEAP = 3/17/67
Layer qvp18E_con DELETED -- LVHEAP = 3/17/67
Layer psd DELETED -- LVHEAP = 3/17/67
Layer qvp18_e DELETED -- LVHEAP = 3/17/67
Layer vnpnE_con DELETED -- LVHEAP = 3/17/67
Layer nsd DELETED -- LVHEAP = 3/17/67
Layer vnpn_e DELETED -- LVHEAP = 3/17/67
Layer nwResTerm_con DELETED -- LVHEAP = 3/17/67
Layer nwellRes_term DELETED -- LVHEAP = 3/17/67
Layer rnwsabTerm_con DELETED -- LVHEAP = 3/17/67
Layer nwelcon DELETED -- LVHEAP = 3/17/67
Layer rnw_sab_term DELETED -- LVHEAP = 3/17/67
--- CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR COMPLETED - Sun May 13 10:05:34 2018
--- TOTAL CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/17/67  MALLOC = 48/48/48  ELAPSED TIME = 1
--- PROCESSOR COUNT = 1
--- SPICE NETLIST FILE = /home/jshi/csmc18/lvs/cmim_test.sp
--- CIRCUIT EXTRACTION REPORT FILE = cmim_test.lvs.report.ext
--- PERSISTENT HIERARCHICAL DATABASE(PHDB) = svdb/cmim_test.phdb
--- QUERY DATABASE = svdb  TOP CELL = cmim_test
--- CALIBRE:VS-H - Sun May 13 10:05:34 2018
-----               CALIBRE:VS/xRC - INITIALIZATION MODULE               -----
Performing global initialization ...
Initializing LVS ...
--- CALIBRE:VS/xRC INITIALIZATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 50/50/50  ELAPSED TIME = 1
-----                 CALIBRE::LVS/xRC - EXECUTIVE MODULE                  -----
LVS started ...
//  Applying licensing policy...
//  Licensed Products
//  Base products running on 1 core:
//  - LVS (Hierarchical)
READING layout ...
Layout READ.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 50/50/50
READING source ...
Source READ.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 67/81/81  MALLOC = 50/50/50
Identifying CORRESPONDING cells ...
      ERROR:  Nothing in layout.
Writing REPORT ...
REPORT written.  CPU TIME = 0  REAL TIME = 0
Cumulative READING INPUTS Time:                          CPU =       0,     REAL =       0
Cumulative IDENTIFYING CORRESPONDING CELLS Time:         CPU =       0,     REAL =       0
    Cumulative CHECKING PORTS Time:                      CPU =       0,     REAL =       0
Cumulative REALLOCATING PINS Time:                       CPU =       0,     REAL =       0
Cumulative WRITING XDB HIERARCHY Time:                   CPU =       0,     REAL =       0
Cumulative ADDING GLOBALS Time:                          CPU =       0,     REAL =       0
Cumulative RESOLVING DEEP SHORTS Time:                   CPU =       0,     REAL =       0
Cumulative RESOLVING HIGH SHORTS Time:                   CPU =       0,     REAL =       0
Cumulative DELETING TRIVIAL PINS Time:                   CPU =       0,     REAL =       0
Cumulative EXPANDING UNBALANCED CELLS Time:              CPU =       0,     REAL =       0
Cumulative TRANSFORMS AND FLATTENING Time:               CPU =       0,     REAL =       0
    Cumulative FLATTENING Time:                          CPU =       0,     REAL =       0
    Cumulative TRANSFORMS Time:                          CPU =       0,     REAL =       0
        Cumulative INJECTION Time:                       CPU =       0,     REAL =       0
            Cumulative COMPACTION Time:                  CPU =       0,     REAL =       0
        Cumulative REDUCTION Time:                       CPU =       0,     REAL =       0
        Cumulative GATES Time:                           CPU =       0,     REAL =       0
        Cumulative UNUSED Time:                          CPU =       0,     REAL =       0
Cumulative COMPARISON Time:                              CPU =       0,     REAL =       0
    Cumulative MERGE PRIMITIVE TEMPLATES Time:           CPU =       0,     REAL =       0
    Cumulative MERGE SUBGRAPH TEMPLATES Time:            CPU =       0,     REAL =       0
    Cumulative NBD AND AMBIGUITY Time:                   CPU =       0,     REAL =       0
        Cumulative NBD Time:                             CPU =       0,     REAL =       0
            Cumulative INITIAL NBD IDS Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD CONVERT Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD BACK CONVERT Time:        CPU =       0,     REAL =       0
            Cumulative NEW NBD ALG RUN Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD IDS Time:                 CPU =       0,     REAL =       0
            Cumulative MATCH NBD NODES Time:             CPU =       0,     REAL =       0
        Cumulative TPL Time:                             CPU =       0,     REAL =       0
        Cumulative BIN Time:                             CPU =       0,     REAL =       0
        Cumulative PRP Time:                             CPU =       0,     REAL =       0
        Cumulative AMBIGUITY Time:                       CPU =       0,     REAL =       0
            Cumulative AMBIGUITY BY PROPERTIES Time:     CPU =       0,     REAL =       0
            Cumulative AMBIGUITY BY SUBTYPES Time:       CPU =       0,     REAL =       0
            Cumulative AMBIGUITY HIERARCHICAL Time:      CPU =       0,     REAL =       0
            Cumulative AMBIGUITY ARBITRARY Time:         CPU =       0,     REAL =       0
    Cumulative REWIRE Time:                              CPU =       0,     REAL =       0
    Cumulative REPAIR Time:                              CPU =       0,     REAL =       0
Cumulative REPORT Time:                                  CPU =       0,     REAL =       0
LVS completed. NOT COMPARED. See report file: cmim_test.lvs.report
LVS completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 51/51/51  ELAPSED TIME = 1
ERROR: Corresponding cells could not be identified.
*** Calibre finished with Exit Code: 4 ***
发表于 2018-5-13 06:16:27 | 显示全部楼层
回复 1# shijunhn
    需要看到对应的lvs code和你的版图结构才能分析,光看这些报错信息不够。
 楼主| 发表于 2018-5-13 10:07:45 | 显示全部楼层
Deleting PHDB cmim_test.phdb
Deleting XDB cmim_test.xdb
MGC_HOME = /apps/aoi_cal_2014.4_18.13
$MGC_HOME/bin/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
//  Calibre v2014.4_18.13    Wed Nov 5 16:04:06 PST 2014
//  Calibre Utility Library   v0-7_7-2014-2    Tue Jul 8 18:35:09 PDT 2014
//  Litho Libraries v2014.4_18.13  Wed Nov 5 16:04:06 PST 2014
//        Copyright Mentor Graphics Corporation 1996-2014
//                       All Rights Reserved.
//   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Mentor Graphics software executing under x86-64 Linux
//  Running on Linux eda 2.6.32-71.el6.x86_64 #1 SMP Wed Sep 1 01:33:01 EDT 2010 x86_64 glibc 2.12/NPTL 2.12
//  Entries in /proc/meminfo:
//  MemTotal:        2054708 kB
//  MemFree:          412224 kB
//  Buffers:          243272 kB
//  Cached:           714684 kB
//  SwapCached:            0 kB
//  Active:           674908 kB
//  Inactive:         635472 kB
//  Active(anon):     352636 kB
//  Inactive(anon):     5280 kB
//  Active(file):     322272 kB
//  Inactive(file):   630192 kB
//  Unevictable:           0 kB
//  Mlocked:               0 kB
//  SwapTotal:       4128760 kB
//  SwapFree:        4128760 kB
//  Dirty:               152 kB
//  Writeback:             0 kB
//  AnonPages:        348352 kB
//  Mapped:           128060 kB
//  Shmem:              5492 kB
//  Slab:             279656 kB
//  SReclaimable:     176012 kB
//  SUnreclaim:       103644 kB
//  KernelStack:        2064 kB
//  PageTables:        29628 kB
//  NFS_Unstable:          0 kB
//  Bounce:                0 kB
//  WritebackTmp:          0 kB
//  CommitLimit:     5156112 kB
//  Committed_AS:     829520 kB
//  VmallocTotal:   34359738367 kB
//  VmallocUsed:      274608 kB
//  VmallocChunk:   34359442720 kB
//  HardwareCorrupted:     0 kB
//  AnonHugePages:     88064 kB
//  HugePages_Total:       0
//  HugePages_Free:        0
//  HugePages_Rsvd:        0
//  HugePages_Surp:        0
//  Hugepagesize:       2048 kB
//  DirectMap4k:       10240 kB
//  DirectMap2M:     2086912 kB
//  CPU Info: Cores = 1
//  Max file descriptors: 1024
//  64 bit virtual addressing enabled
//  Running aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
//  Process ID: 25223
//  Starting time: Sun May 13 10:05:33 2018
//  Running on 1 CPU (pending licensing)
-----          STANDARD VERIFICATION RULE FILE COMPILATION MODULE          -----
--- RULE FILE = /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
WARNING: The PEX NETLIST keyword 'LOOP' is obsolete and will be ignored. Please remove from your ruledeck.
//  Rule file generated on Sun May 13 10:05:33 CST 2018
//     by Calibre Interactive - LVS (v2014.4_18.13)
//      *** PLEASE DO NOT MODIFY THIS FILE ***
LAYOUT PATH  "cmim_test.calibre.db"
LAYOUT PRIMARY "cmim_test"
LAYOUT SYSTEM GDSII
SOURCE PATH "/home/jshi/csmc18/lvs/cmim_test.src.net"
SOURCE PRIMARY "cmim_test"
SOURCE SYSTEM SPICE
MASK SVDB DIRECTORY "svdb" QUERY
LVS REPORT "cmim_test.lvs.report"
LVS REPORT OPTION NONE
LVS FILTER UNUSED OPTION NONE SOURCE
LVS FILTER UNUSED OPTION NONE LAYOUT
LVS REPORT MAXIMUM 50
LVS POWER NAME
        "VDD4"
LVS GROUND NAME
        "GND"
LVS RECOGNIZE GATES ALL
LVS ABORT ON SOFTCHK NO
LVS ABORT ON SUPPLY ERROR YES
LVS IGNORE PORTS NO
LVS SHOW SEED PROMOTIONS NO
LVS SHOW SEED PROMOTIONS MAXIMUM 50
LVS ISOLATE SHORTS NO
VIRTUAL CONNECT COLON NO
VIRTUAL CONNECT REPORT NO
LVS EXECUTE ERC YES
ERC RESULTS DATABASE "cmim_test.erc.results"
ERC SUMMARY REPORT "cmim_test.erc.summary" REPLACE HIER
ERC CELL NAME YES CELL SPACE XFORM
ERC MAXIMUM RESULTS 1000
ERC MAXIMUM VERTEX 4096
DRC ICSTATION YES
INCLUDE "/home/jshi/csmc18/lvs/CSMC018_mixRF_sali_calLVS.rul"
--- STANDARD VERIFICATION RULE FILE COMPILATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 1/3/4
--- CALIBRE_* ENVIRONMENT VARIABLES:
CALIBRE_CMD_LINE='/apps/aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre  -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_'
CALIBRE_ECHO_RULE_FILE=
CALIBRE_HOME=/apps/aoi_cal_2014.4_18.13
CALIBRE_INITIAL_CMD_LINE='/apps/aoi_cal_2014.4_18.13/bin/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_'
CALIBRE_READDB_LD_LIBRARY_PATH=/apps/aoi_cal_2014.4_18.13/pkgs/icv_lib/lib64:/apps/aoi_cal_2014.4_18.13/pkgs/icv_qt_comp/plugins:/apps/aoi_cal_2014.4_18.13/pkgs/umc_libs/lib/lnx32:/apps/aoi_cal_2014.4_18.13/shared/pkgs/icv_oa/22.41.004/lib/linux_rhel40_gcc44x_64/opt:/apps/Cadence/IC5141/tools/lib:/apps/Cadence/IC5141/tools/lib:/apps/Cadence/IC5141/tools/dfII/lib:/lib:/lib64:/usr/lib:/usr/lib64
CALIBRE_SKIP_OS_CHECKS=
CALIBRE_SSE3_SUPPORTED=1
--- CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR - Sun May 13 10:05:33 2018
//  mgc_s license acquired (calibrehlvs requested).
//  mgc_s license acquired (calibrelvs requested).
//  - LVS Extraction
-----                   CALIBRE LAYOUT DATA INPUT MODULE                   -----
--- LAYOUT SYSTEM = GDS
--- LAYOUT MAGNIFICATION = 1
-----                     GDS FILE SUMMARY INFORMATION                     -----
GDS FILENAME:        cmim_test.calibre.db
GDS VERSION:         5
LIBRARY NAME:        MLX.DB
LAST MODIFIED:       ON 2018/5/12 AT 21:40:29
LAST ACCESSED:       ON 2018/5/13 AT 10:5:30
DATABASE PRECISION:  0.001 user units per database unit
PHYSICAL PRECISION:  1e-09 meters per database unit
MAGNIFICATION:       1
-----                 GDS INPUT DATA FOR INDIVIDUAL CELLS                  -----
     CELL NAME                  PLACEMENTS   ARRAYS   POLYGONS    PATHS    TEXTS
OSC_C_1_cell                             0        0         39        0        0
cmim_test                                1        0          4        0        9
NOTE: UNUSED geometric data is present on the following layer/datatype pairs:
    LAYER = 94 DATATYPE = 0
    LAYER = 153 DATATYPE = 1
NOTE: The following required simple layers are EMPTY:
    1002
    1003
    1004
    1005
    1007
    1008
    1009
    1012
    1013
    1014
    1017
    1018
    1019
    1020
    1022
    1023
    1024
    1030
    1032
    1033
    1034
    1035
    1036
    1037
    1039
    1040
    1041
    1042
    1043
    1045
    1046
    1047
    1048
    1049
    1050
    1051
    1052
    1053
    1055
    1056
    1057
    1058
    1059
    1060
    1061
    1062
    1063
    1064
    1065
    1066
    1067
    1068
    1069
    1071
    1072
    1073
    1074
    1075
    1076
    1077
    1080
    1081
    1082
    1083
    1084
    1085
    1086
    1087
--- LAYOUT DATABASE CONSTRUCTOR COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/4/67
CONSTRUCTING HIERARCHICAL DATABASE
    COPYING LAYOUT DATABASE
    FLATTENING SELECTED LAYERS
    PROCESSING TEXT
    ELIMINATING DUPLICATE TEXT
    ELIMINATING EMPTY CELLS
    COMPUTING RECTANGULAR EXTENTS
    ELIMINATING DUPLICATE PLACEMENTS
    IDENTIFYING TOP LAYER CELLS
    IDENTIFYING ADDITIONAL TOP LAYER CELLS
    IDENTIFYING VERY SMALL CELLS
    CHECKING ACUTE/SKEW/ANGLED/OFFGRID
    FLATTENING SELECTED VERY SMALL CELL PLACEMENTS
    FLATTENING SELECTED TOP LAYER CELL PLACEMENTS
    EXPANDING UNIQUE VERY SMALL CELL PLACEMENTS
    EXPANDING UNIQUE TOP LAYER CELL PLACEMENTS
    EXPANDING UNIQUE MONO-GEOMETRIC CELL PLACEMENTS
    EXPANDING LARGE TOP LAYER CELL PLACEMENTS
    COMPUTING RECTILINEAR EXTENTS
    SORTING PLACEMENTS
    EXPANDING UNIQUE TRANSPARENT CELL PLACEMENTS
        OSC_C_1_cell in cmim_test at (1.978,30.175)
    EXPANDING UNIQUE LIGHT-WEIGHT CELL PLACEMENTS
    EXPANDING UNIQUE ROW CELL PLACEMENTS
    EXPANDING TRIVIAL CELL PLACEMENTS
    EXPANDING VERY SPARSE ARRAY PLACEMENTS
    EXPANDING LARGE CELL ARRAY PLACEMENTS
    EXPANDING VERY SPARSE CELL PLACEMENTS
    ELIMINATING DUPLICATE SUPER-HIERARCHICAL PLACEMENTS
    PROCESSING LAYOUT BLOAT LAYERS (auto-detected)
    PROCESSING LARGE CELL EXTENT-BLOATING LAYERS
    EXPANDING DENSE OVERLAPS
    EXPANDING UNIQUE META-CELL PLACEMENTS
    INJECTING HIERARCHY
    FLATTENING REMAINING VERY SMALL CELL PLACEMENTS
    SORTING PLACEMENTS
    PUSHING VERY SMALL CELL PLACEMENTS
    PUSHING TOP LAYER CELL PLACEMENTS
    COMPUTING CELL-TO-WORLD TRANSFORMS
    SORTING PLACEMENTS
    PACKING HIERARCHY
    COMPUTING PLACEMENT OVERLAP RECORDS
    COMPUTING CELL OVERLAP AREAS
    INTERSECTING PLACEMENTS AND OVERLAP AREAS
HIERARCHICAL DATABASE CONSTRUCTOR COMPLETE.
CPU TIME = 0  REAL TIME = 0  LVHEAP = 2/5/67
-----               TEXT OBJECTS FOR CONNECTIVITY EXTRACTION               -----
plus (-4.14,34.939) 1016 cmim_test      vdd (9.062,22.875) 1001 cmim_test
gnd! (28.739,35.463) 1011 cmim_test
-----                TEXT OBJECTS FOR WITH TEXT OPERATIONS                 -----
-----               TEXT OBJECTS FOR EXPAND TEXT OPERATIONS                -----
-----                  TEXT OBJECTS FOR CAPI OPERATIONS                    -----
-----                                PORTS                                 -----
-----             LAYER READ SUMMARY (SIMPLE LAYER GEOMETRIES)             -----
  1000                   1
  1002                   0
  1003                   0
  1004                   0
  1005                   0
  1007                   0
  1008                   0
  1009                   0
  1010                   2
  1012                   0
  1013                   0
  1014                   0
  1015                   1
  1017                   0
  1018                   0
  1019                   0
  1020                   0
  1022                   0
  1023                   0
  1024                   0
  1030                   0
  1032                   0
  1033                   0
  1034                   0
  1035                   0
  1036                   0
  1037                   0
  1038                  35
  1039                   0
  1040                   0
  1041                   0
  1042                   0
  1043                   0
  1045                   0
  1046                   0
  1047                   0
  1048                   0
  1049                   0
  1050                   0
  1051                   0
  1052                   0
  1053                   0
  1054                   2
  1055                   0
  1056                   0
  1057                   0
  1058                   0
  1059                   0
  1060                   0
  1061                   0
  1062                   0
  1063                   0
  1064                   0
  1065                   0
  1066                   0
  1067                   0
  1068                   0
  1069                   0
  1071                   0
  1072                   0
  1073                   0
  1074                   0
  1075                   0
  1076                   0
  1077                   0
  1080                   0
  1081                   0
  1082                   0
  1083                   0
  1084                   0
  1085                   0
  1086                   0
  1087                   0
-----            LAYER READ SUMMARY (ORIGINAL LAYER GEOMETRIES)            -----
ORIGINAL LAYER       INITIAL GEOMETRIES                 FINAL GEOMETRIES
  DCTY_mark                0 (0)                            0 (0)
  A1SLOT_slot              0 (0)                            0 (0)
  A2SLOT_slot              0 (0)                            0 (0)
  A3SLOT_slot              0 (0)                            0 (0)
  A4SLOT_slot              0 (0)                            0 (0)
  A5SLOT_slot              0 (0)                            0 (0)
  MTTSLOT_slot             0 (0)                            0 (0)
  TB                       0 (0)                            0 (0)
  RES_NW_mark              0 (0)                            0 (0)
  TO                       0 (0)                            0 (0)
  SN                       0 (0)                            0 (0)
  SP                       0 (0)                            0 (0)
  GT                       0 (0)                            0 (0)
  HV                       0 (0)                            0 (0)
  SE                       0 (0)                            0 (0)
  SI                       0 (0)                            0 (0)
  W1                       0 (0)                            0 (0)
  W2                       0 (0)                            0 (0)
  W3                       0 (0)                            0 (0)
  W4                       0 (0)                            0 (0)
  W5                       0 (0)                            0 (0)
  WT                      35 (35)                          35 (35)
  MTT                      0 (0)                            0 (0)
  DN                       0 (0)                            0 (0)
  PWB                      0 (0)                            0 (0)
  MN                       0 (0)                            0 (0)
  MP                       0 (0)                            0 (0)
  PD                       0 (0)                            0 (0)
  HR                       0 (0)                            0 (0)
  MCT                      2 (2)                            2 (2)
  A1_net                   0 (0)                            0 (0)
  A1                       1 (1)                            1 (1)
  A1_pin                   0 (0)                            0 (0)
  RES_M1                   0 (0)                            0 (0)
  A2_net                   0 (0)                            0 (0)
  A2                       0 (0)                            0 (0)
  A2_pin                   0 (0)                            0 (0)
  RES_M2                   0 (0)                            0 (0)
  A3_net                   0 (0)                            0 (0)
  A3                       2 (2)                            2 (2)
  A3_pin                   0 (0)                            0 (0)
  A4_net                   0 (0)                            0 (0)
  A4                       1 (1)                            1 (1)
  A4_pin                   0 (0)                            0 (0)
  A5_net                   0 (0)                            0 (0)
  A5                       0 (0)                            0 (0)
  A5_pin                   0 (0)                            0 (0)
  MCTM5                    0 (0)                            0 (0)
  RFDUM_mark               0 (0)                            0 (0)
  RES_M3                   0 (0)                            0 (0)
  RES_M4                   0 (0)                            0 (0)
  RES_M5                   0 (0)                            0 (0)
  RES_MT                   0 (0)                            0 (0)
  RES_PY_mark              0 (0)                            0 (0)
  BJT_mark                 0 (0)                            0 (0)
  RES_TO_mark              0 (0)                            0 (0)
  VARMOS_mark              0 (0)                            0 (0)
  RES_HR_mark              0 (0)                            0 (0)
  ESD_mark                 0 (0)                            0 (0)
  VTSRAM_mark              0 (0)                            0 (0)
  VTSRAM_gc2               0 (0)                            0 (0)
  VTSRAM_gc3               0 (0)                            0 (0)
  VTSRAM_l                 0 (0)                            0 (0)
  VTSRAM_lc                0 (0)                            0 (0)
  DIODE_mark               0 (0)                            0 (0)
  PSUB2                    0 (0)                            0 (0)
  RNDMY                    0 (0)                            0 (0)
  RES_3T_mark              0 (0)                            0 (0)
  RPDMY                    0 (0)                            0 (0)
  RFDUM_g2                 0 (0)                            0 (0)
  VARJUN_mark              0 (0)                            0 (0)
  INDUM_mark               0 (0)                            0 (0)
  EXCLU                    0 (0)                            0 (0)
-----         LAYER READ SUMMARY (TEXT FOR CONNECTIVITY EXTRACTION)        -----
SIMPLE LAYER              TEXTS
  1001                     1 (1)
  1011                     1 (1)
  1016                     1 (1)
-----          LAYER READ SUMMARY (TEXT FOR WITH TEXT OPERATIONS)          -----
SIMPLE LAYER              TEXTS
-----         LAYER READ SUMMARY (TEXT FOR EXPAND TEXT OPERATIONS)         -----
SIMPLE LAYER              TEXTS
-----            LAYER READ SUMMARY (TEXT FOR CAPI OPERATIONS)             -----
SIMPLE LAYER              TEXTS
-----                      LAYER READ SUMMARY (PORTS)                      -----
SIMPLE LAYER              TEXTS
  1001                     1 (1)
  1011                     1 (1)
  1016                     1 (1)
-----                      CELL AND PLACEMENT SUMMARY                      -----
CELL TYPE                 CELLS           PLACEMENTS       FLAT PLACEMENTS
USER                          1                    0                     0
VERY SMALL                   0                    0                     0
TOP LAYER                    0                    0                     0
  VERY SMALL                  0                    0                     0
PSEUDO                        0                    0                     0
TOTAL                         1                    0                     0
-----                   LAYOUT DATA INPUT MODULE SUMMARY                   -----
--- TOTAL GEOMETRIES READ FROM SIMPLE LAYERS = 41
--- TOTAL GEOMETRIES READ FROM ORIGINAL LAYERS = 41 (41)
--- TOTAL GEOMETRIES WRITTEN TO ORIGINAL LAYERS = 41 (41)
--- LVHEAP = 2/5/67
--- DATABASE EXTENT = [ -5.2 , 18.855 ] -> [ 31.622 , 41.475 ]
--- GEOMETRIC DEPTH = ALL
--- TEXT DEPTH FOR CONNECTIVITY EXTRACTION = PRIMARY
--- TOTAL TEXT OBJECTS FOR CONNECTIVITY EXTRACTION = 3 (3)
--- TOTAL TEXT OBJECTS FOR WITH TEXT OPERATIONS = 0 (0)
--- TOTAL TEXT OBJECTS FOR EXPAND TEXT OPERATIONS = 0 (0)
--- TOTAL TEXT OBJECTS FOR CAPI OPERATIONS = 0 (0)
--- TOTAL PORT OBJECTS = 3 (3)
--- GEOMETRY FLAGGING = ACUTE (NO)  SKEW (NO)  ANGLED (NO)  OFFGRID (NO)
                        NONSIMPLE POLYGON (NO)  NONSIMPLE PATH (NO)
--- PRIMARY CELL = cmim_test
--- EXCLUDED CELLS =
--- LAYOUT BASE LAYER = (NOT SPECIFIED)
--- LAYOUT TOP LAYER = (NOT SPECIFIED)
--- CALIBRE LAYOUT DATA INPUT MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0
-----      CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR - EXECUTIVE MODULE      -----
SN = OR SN
SN (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 1 OF 455  ELAPSED TIME = 0
Original Layer SN DELETED -- LVHEAP = 3/5/67
DCTY_mark = OR DCTY_mark
DCTY_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 2 OF 455  ELAPSED TIME = 0
Original Layer DCTY_mark DELETED -- LVHEAP = 3/5/67
SN_drc = SN NOT DCTY_mark
SN_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 3 OF 455  ELAPSED TIME = 0
TO = OR TO
TO (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 4 OF 455  ELAPSED TIME = 0
Original Layer TO DELETED -- LVHEAP = 3/5/67
TO_drc = TO NOT DCTY_mark
TO_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 5 OF 455  ELAPSED TIME = 0
ndiff = SN_drc AND TO_drc
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 6 OF 455  ELAPSED TIME = 0
GT = OR GT
GT (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 7 OF 455  ELAPSED TIME = 0
Original Layer GT DELETED -- LVHEAP = 3/5/67
GT_drc = GT NOT DCTY_mark
GT_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 8 OF 455  ELAPSED TIME = 0
nsd1 = ndiff NOT GT_drc
nsd1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 9 OF 455  ELAPSED TIME = 0
RES_TO_mark = OR RES_TO_mark
RES_TO_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 10 OF 455  ELAPSED TIME = 0
Original Layer RES_TO_mark DELETED -- LVHEAP = 3/5/67
nsd = nsd1 NOT RES_TO_mark
nsd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 11 OF 455  ELAPSED TIME = 0
Layer nsd1 DELETED -- LVHEAP = 3/5/67
SP = OR SP
SP (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 12 OF 455  ELAPSED TIME = 0
Original Layer SP DELETED -- LVHEAP = 3/5/67
TMP<38> = TO AND SP
TMP<38> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 13 OF 455  ELAPSED TIME = 0
TB = OR TB
TB (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 14 OF 455  ELAPSED TIME = 0
Original Layer TB DELETED -- LVHEAP = 3/5/67
TMP<37> = TMP<38> NOT TB
TMP<37> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 15 OF 455  ELAPSED TIME = 0
Layer TMP<38> DELETED -- LVHEAP = 3/5/67
TMP<36> = TMP<37> NOT GT
TMP<36> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 16 OF 455  ELAPSED TIME = 0
Layer TMP<37> DELETED -- LVHEAP = 3/5/67
W1 = OR W1
W1 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 17 OF 455  ELAPSED TIME = 0
Original Layer W1 DELETED -- LVHEAP = 3/5/67
TMP<35> = TMP<36> INTERACT W1
TMP<35> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 18 OF 455  ELAPSED TIME = 0
Layer TMP<36> DELETED -- LVHEAP = 3/5/67
EXCLU = OR EXCLU
EXCLU (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 19 OF 455  ELAPSED TIME = 0
Original Layer EXCLU DELETED -- LVHEAP = 3/5/67
lvpsb = TMP<35> AND EXCLU
lvpsb (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 20 OF 455  ELAPSED TIME = 0
Layer TMP<35> DELETED -- LVHEAP = 3/5/67
SP_drc = SP NOT DCTY_mark
SP_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 21 OF 455  ELAPSED TIME = 0
pdiff = SP_drc AND TO_drc
pdiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 22 OF 455  ELAPSED TIME = 0
psd1 = pdiff NOT GT_drc
psd1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 23 OF 455  ELAPSED TIME = 0
psd = psd1 NOT RES_TO_mark
psd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 24 OF 455  ELAPSED TIME = 0
Layer psd1 DELETED -- LVHEAP = 3/5/67
TMP<41> = TO AND SN
TMP<41> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 25 OF 455  ELAPSED TIME = 0
TMP<40> = TMP<41> AND TB
TMP<40> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 26 OF 455  ELAPSED TIME = 0
Layer TMP<41> DELETED -- LVHEAP = 3/5/67
TMP<39> = TMP<40> NOT GT
TMP<39> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 27 OF 455  ELAPSED TIME = 0
Layer TMP<40> DELETED -- LVHEAP = 3/5/67
lvnsb = TMP<39> AND EXCLU
lvnsb (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 28 OF 455  ELAPSED TIME = 0
Layer TMP<39> DELETED -- LVHEAP = 3/5/67
A1_pin = OR A1_pin
A1_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 29 OF 455  ELAPSED TIME = 0
Original Layer A1_pin DELETED -- LVHEAP = 3/5/67
A1 = OR A1
A1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 30 OF 455  ELAPSED TIME = 0
Original Layer A1 DELETED -- LVHEAP = 3/5/67
A1_net = OR A1_net
A1_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 31 OF 455  ELAPSED TIME = 0
Original Layer A1_net DELETED -- LVHEAP = 3/5/67
a1net = A1 OR A1_net
a1net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 32 OF 455  ELAPSED TIME = 0
a1_net_pin = A1_pin OR a1net
a1_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 33 OF 455  ELAPSED TIME = 0
Layer a1net DELETED -- LVHEAP = 3/5/67
A1_drc = a1_net_pin NOT DCTY_mark
A1_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 34 OF 455  ELAPSED TIME = 0
Layer a1_net_pin DELETED -- LVHEAP = 3/5/67
A1SLOT_slot = OR A1SLOT_slot
A1SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 35 OF 455  ELAPSED TIME = 0
Original Layer A1SLOT_slot DELETED -- LVHEAP = 3/5/67
A1SLOT_slot_drc = A1SLOT_slot NOT DCTY_mark
A1SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 36 OF 455  ELAPSED TIME = 0
a1_conn1 = A1_drc NOT A1SLOT_slot_drc
a1_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 37 OF 455  ELAPSED TIME = 0
Layer A1SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M1 = OR RES_M1
RES_M1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 38 OF 455  ELAPSED TIME = 0
Original Layer RES_M1 DELETED -- LVHEAP = 3/5/67
a1_conn = a1_conn1 NOT RES_M1
a1_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 39 OF 455  ELAPSED TIME = 0
Layer a1_conn1 DELETED -- LVHEAP = 3/5/67
W2 = OR W2
W2 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 40 OF 455  ELAPSED TIME = 0
Original Layer W2 DELETED -- LVHEAP = 3/5/67
A2_pin = OR A2_pin
A2_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 41 OF 455  ELAPSED TIME = 0
Original Layer A2_pin DELETED -- LVHEAP = 3/5/67
A2 = OR A2
A2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 42 OF 455  ELAPSED TIME = 0
Original Layer A2 DELETED -- LVHEAP = 3/5/67
A2_net = OR A2_net
A2_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 43 OF 455  ELAPSED TIME = 0
Original Layer A2_net DELETED -- LVHEAP = 3/5/67
a2net = A2 OR A2_net
a2net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 44 OF 455  ELAPSED TIME = 0
a2_net_pin = A2_pin OR a2net
a2_net_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 45 OF 455  ELAPSED TIME = 0
Layer a2net DELETED -- LVHEAP = 3/5/67
A2_drc = a2_net_pin NOT DCTY_mark
A2_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 46 OF 455  ELAPSED TIME = 0
Layer a2_net_pin DELETED -- LVHEAP = 3/5/67
A2SLOT_slot = OR A2SLOT_slot
A2SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 47 OF 455  ELAPSED TIME = 0
Original Layer A2SLOT_slot DELETED -- LVHEAP = 3/5/67
A2SLOT_slot_drc = A2SLOT_slot NOT DCTY_mark
A2SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 48 OF 455  ELAPSED TIME = 0
a2_conn1 = A2_drc NOT A2SLOT_slot_drc
a2_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 49 OF 455  ELAPSED TIME = 0
Layer A2SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M2 = OR RES_M2
RES_M2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 50 OF 455  ELAPSED TIME = 0
Original Layer RES_M2 DELETED -- LVHEAP = 3/5/67
a2_conn = a2_conn1 NOT RES_M2
a2_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 51 OF 455  ELAPSED TIME = 0
Layer a2_conn1 DELETED -- LVHEAP = 3/5/67
W3 = OR W3
W3 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 52 OF 455  ELAPSED TIME = 0
Original Layer W3 DELETED -- LVHEAP = 3/5/67
A3_pin = OR A3_pin
A3_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 53 OF 455  ELAPSED TIME = 0
Original Layer A3_pin DELETED -- LVHEAP = 3/5/67
A3 = OR A3
A3 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 54 OF 455  ELAPSED TIME = 0
Original Layer A3 DELETED -- LVHEAP = 3/5/67
A3_net = OR A3_net
A3_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 55 OF 455  ELAPSED TIME = 0
Original Layer A3_net DELETED -- LVHEAP = 3/5/67
a3net = A3 OR A3_net
a3net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 56 OF 455  ELAPSED TIME = 0
a3_net_pin = A3_pin OR a3net
a3_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 57 OF 455  ELAPSED TIME = 0
Layer a3net DELETED -- LVHEAP = 3/5/67
A3_drc = a3_net_pin NOT DCTY_mark
A3_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 58 OF 455  ELAPSED TIME = 0
Layer a3_net_pin DELETED -- LVHEAP = 3/5/67
A3SLOT_slot = OR A3SLOT_slot
A3SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 59 OF 455  ELAPSED TIME = 0
Original Layer A3SLOT_slot DELETED -- LVHEAP = 3/5/67
A3SLOT_slot_drc = A3SLOT_slot NOT DCTY_mark
A3SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 60 OF 455  ELAPSED TIME = 0
a3_conn1 = A3_drc NOT A3SLOT_slot_drc
a3_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 61 OF 455  ELAPSED TIME = 0
Layer A3SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M3 = OR RES_M3
RES_M3 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 62 OF 455  ELAPSED TIME = 0
Original Layer RES_M3 DELETED -- LVHEAP = 3/5/67
a3_conn2 = a3_conn1 NOT RES_M3
a3_conn2 (HIER TYP=1 CFG=1 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 63 OF 455  ELAPSED TIME = 0
Layer a3_conn1 DELETED -- LVHEAP = 3/5/67
a3_conn = COPY a3_conn2
a3_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 64 OF 455  ELAPSED TIME = 0
Layer a3_conn2 DELETED -- LVHEAP = 3/5/67
WT = OR WT
WT (HIER TYP=1 CFG=1 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 65 OF 455  ELAPSED TIME = 0
Original Layer WT DELETED -- LVHEAP = 3/5/67
WT_drc = WT NOT DCTY_mark
WT_drc (HIER TYP=1 CFG=1 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 66 OF 455  ELAPSED TIME = 0
MCT = OR MCT
MCT (HIER TYP=1 CFG=1 HGC=2 FGC=2 HEC=8 FEC=8 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 67 OF 455  ELAPSED TIME = 0
Original Layer MCT DELETED -- LVHEAP = 3/5/67
MCT_drc = MCT NOT DCTY_mark
MCT_drc (HIER TYP=1 CFG=1 HGC=2 FGC=2 HEC=8 FEC=8 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 68 OF 455  ELAPSED TIME = 0
mctcap = MCT_drc INTERACT WT_drc
mctcap (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 69 OF 455  ELAPSED TIME = 0
Layer MCT_drc DELETED -- LVHEAP = 3/5/67
wtmct = WT_drc AND mctcap
wtmct (HIER TYP=1 CFG=3 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 70 OF 455  ELAPSED TIME = 0
MTT = OR MTT
MTT (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 71 OF 455  ELAPSED TIME = 0
Original Layer MTT DELETED -- LVHEAP = 3/5/67
MTT_drc = MTT NOT DCTY_mark
MTT_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 72 OF 455  ELAPSED TIME = 0
MTTSLOT_slot = OR MTTSLOT_slot
MTTSLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 73 OF 455  ELAPSED TIME = 0
Original Layer MTTSLOT_slot DELETED -- LVHEAP = 3/5/67
MTTSLOT_slot_drc = MTTSLOT_slot NOT DCTY_mark
MTTSLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 74 OF 455  ELAPSED TIME = 0
tt_conn1 = MTT_drc NOT MTTSLOT_slot_drc
tt_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 75 OF 455  ELAPSED TIME = 0
Layer MTTSLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_MT = OR RES_MT
RES_MT (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 76 OF 455  ELAPSED TIME = 0
Original Layer RES_MT DELETED -- LVHEAP = 3/5/67
tt_conn2 = tt_conn1 NOT RES_MT
tt_conn2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 77 OF 455  ELAPSED TIME = 0
Layer tt_conn1 DELETED -- LVHEAP = 3/5/67
INDUM_mark = OR INDUM_mark
INDUM_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 78 OF 455  ELAPSED TIME = 0
Original Layer INDUM_mark DELETED -- LVHEAP = 3/5/67
tt_ind = tt_conn2 AND INDUM_mark
tt_ind (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 79 OF 455  ELAPSED TIME = 0
tt_conn = tt_conn2 NOT tt_ind
tt_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 80 OF 455  ELAPSED TIME = 0
Layer tt_conn2 DELETED -- LVHEAP = 3/5/67
wtcon = WT_drc OUTSIDE mctcap
wtcon (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 81 OF 455  ELAPSED TIME = 0
Layer WT_drc DELETED -- LVHEAP = 3/5/67
A5_pin = OR A5_pin
A5_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 82 OF 455  ELAPSED TIME = 0
Original Layer A5_pin DELETED -- LVHEAP = 3/5/67
A5 = OR A5
A5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 83 OF 455  ELAPSED TIME = 0
Original Layer A5 DELETED -- LVHEAP = 3/5/67
A5_net = OR A5_net
A5_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 84 OF 455  ELAPSED TIME = 0
Original Layer A5_net DELETED -- LVHEAP = 3/5/67
a5net = A5 OR A5_net
a5net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 85 OF 455  ELAPSED TIME = 0
a5_net_pin = A5_pin OR a5net
a5_net_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 86 OF 455  ELAPSED TIME = 0
Layer a5net DELETED -- LVHEAP = 3/5/67
A5_drc = a5_net_pin NOT DCTY_mark
A5_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 87 OF 455  ELAPSED TIME = 0
Layer a5_net_pin DELETED -- LVHEAP = 3/5/67
A5SLOT_slot = OR A5SLOT_slot
A5SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 88 OF 455  ELAPSED TIME = 0
Original Layer A5SLOT_slot DELETED -- LVHEAP = 3/5/67
A5SLOT_slot_drc = A5SLOT_slot NOT DCTY_mark
A5SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 89 OF 455  ELAPSED TIME = 0
a5_conn1 = A5_drc NOT A5SLOT_slot_drc
a5_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 90 OF 455  ELAPSED TIME = 0
Layer A5SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M5 = OR RES_M5
RES_M5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 91 OF 455  ELAPSED TIME = 0
Original Layer RES_M5 DELETED -- LVHEAP = 3/5/67
a5_conn2 = a5_conn1 NOT RES_M5
a5_conn2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 92 OF 455  ELAPSED TIME = 0
Layer a5_conn1 DELETED -- LVHEAP = 3/5/67
am_ind = a5_conn2 AND INDUM_mark
am_ind (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 93 OF 455  ELAPSED TIME = 0
a5_conn = a5_conn2 NOT am_ind
a5_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 94 OF 455  ELAPSED TIME = 0
Layer a5_conn2 DELETED -- LVHEAP = 3/5/67
W5 = OR W5
W5 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 95 OF 455  ELAPSED TIME = 0
Original Layer W5 DELETED -- LVHEAP = 3/5/67
A4_pin = OR A4_pin
A4_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 96 OF 455  ELAPSED TIME = 0
Original Layer A4_pin DELETED -- LVHEAP = 3/5/67
A4 = OR A4
A4 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 97 OF 455  ELAPSED TIME = 0
Original Layer A4 DELETED -- LVHEAP = 3/5/67
A4_net = OR A4_net
A4_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 98 OF 455  ELAPSED TIME = 0
Original Layer A4_net DELETED -- LVHEAP = 3/5/67
a4net = A4 OR A4_net
a4net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 99 OF 455  ELAPSED TIME = 0
a4_net_pin = A4_pin OR a4net
a4_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 100 OF 455  ELAPSED TIME = 0
Layer a4net DELETED -- LVHEAP = 3/5/67
A4_drc = a4_net_pin NOT DCTY_mark
A4_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 101 OF 455  ELAPSED TIME = 0
Layer a4_net_pin DELETED -- LVHEAP = 3/5/67
A4SLOT_slot = OR A4SLOT_slot
A4SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 102 OF 455  ELAPSED TIME = 0
Original Layer A4SLOT_slot DELETED -- LVHEAP = 3/5/67
A4SLOT_slot_drc = A4SLOT_slot NOT DCTY_mark
A4SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 103 OF 455  ELAPSED TIME = 0
a4_conn1 = A4_drc NOT A4SLOT_slot_drc
a4_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 104 OF 455  ELAPSED TIME = 0
Layer A4SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M4 = OR RES_M4
RES_M4 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 105 OF 455  ELAPSED TIME = 0
Original Layer RES_M4 DELETED -- LVHEAP = 3/5/67
a4_conn2 = a4_conn1 NOT RES_M4
a4_conn2 (HIER TYP=1 CFG=1 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 106 OF 455  ELAPSED TIME = 0
Layer a4_conn1 DELETED -- LVHEAP = 3/5/67
a4_conn = COPY a4_conn2
a4_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 107 OF 455  ELAPSED TIME = 0
Layer a4_conn2 DELETED -- LVHEAP = 3/5/67
W4 = OR W4
W4 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 108 OF 455  ELAPSED TIME = 0
Original Layer W4 DELETED -- LVHEAP = 3/5/67
W1_drc = W1 NOT DCTY_mark
W1_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 109 OF 455  ELAPSED TIME = 0
TB_drc = TB NOT DCTY_mark
TB_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 110 OF 455  ELAPSED TIME = 0
RFDUM_mark = OR RFDUM_mark
RFDUM_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 111 OF 455  ELAPSED TIME = 0
Original Layer RFDUM_mark DELETED -- LVHEAP = 3/5/67
TMP<29> = TB_drc INTERACT RFDUM_mark
TMP<29> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 112 OF 455  ELAPSED TIME = 0
ndiff_tb = ndiff INSIDE TB_drc
ndiff_tb (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 113 OF 455  ELAPSED TIME = 0
VARMOS_mark = OR VARMOS_mark
VARMOS_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 114 OF 455  ELAPSED TIME = 0
Original Layer VARMOS_mark DELETED -- LVHEAP = 3/5/67
var_ndiff = ndiff_tb INTERACT VARMOS_mark
var_ndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 115 OF 455  ELAPSED TIME = 0
Layer ndiff_tb DELETED -- LVHEAP = 3/5/67
vargate = var_ndiff AND GT_drc
vargate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 116 OF 455  ELAPSED TIME = 0
Layer var_ndiff DELETED -- LVHEAP = 3/5/67
HV = OR HV
HV (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 117 OF 455  ELAPSED TIME = 0
Original Layer HV DELETED -- LVHEAP = 3/5/67
HV_drc = HV NOT DCTY_mark
HV_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 118 OF 455  ELAPSED TIME = 0
var18 = vargate NOT HV_drc
var18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 119 OF 455  ELAPSED TIME = 0
var18_rf_rec = TMP<29> ENCLOSE var18
var18_rf_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 120 OF 455  ELAPSED TIME = 0
var18_rf_to = TO_drc INSIDE var18_rf_rec
var18_rf_to (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 121 OF 455  ELAPSED TIME = 0
var18_rf_gt = GT_drc NOT OUTSIDE var18_rf_to
var18_rf_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 122 OF 455  ELAPSED TIME = 0
var18_rf_gt_con = W1_drc AND var18_rf_gt
var18_rf_gt_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 123 OF 455  ELAPSED TIME = 0
var33 = vargate AND HV_drc
var33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 124 OF 455  ELAPSED TIME = 0
Layer vargate DELETED -- LVHEAP = 3/5/67
var33_rf_rec = TMP<29> ENCLOSE var33
var33_rf_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 125 OF 455  ELAPSED TIME = 0
Layer TMP<29> DELETED -- LVHEAP = 3/5/67
var33_rf_to = TO_drc INSIDE var33_rf_rec
var33_rf_to (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 126 OF 455  ELAPSED TIME = 0
var33_rf_gt = GT_drc NOT OUTSIDE var33_rf_to
var33_rf_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 127 OF 455  ELAPSED TIME = 0
var33_rf_gt_con = W1_drc AND var33_rf_gt
var33_rf_gt_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 128 OF 455  ELAPSED TIME = 0
w1_and_gt = GT_drc AND W1_drc
w1_and_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 129 OF 455  ELAPSED TIME = 0
RES_PY_mark = OR RES_PY_mark
RES_PY_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 130 OF 455  ELAPSED TIME = 0
Original Layer RES_PY_mark DELETED -- LVHEAP = 3/5/67
gt_conn1 = GT_drc NOT RES_PY_mark
gt_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 131 OF 455  ELAPSED TIME = 0
RES_HR_mark = OR RES_HR_mark
RES_HR_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 132 OF 455  ELAPSED TIME = 0
Original Layer RES_HR_mark DELETED -- LVHEAP = 3/5/67
TMP<1> = gt_conn1 NOT RES_HR_mark
TMP<1> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 133 OF 455  ELAPSED TIME = 0
Layer gt_conn1 DELETED -- LVHEAP = 3/5/67
TMP<2> = var18_rf_gt OR var33_rf_gt
TMP<2> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 134 OF 455  ELAPSED TIME = 0
gt_conn = TMP<1> NOT TMP<2>
gt_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 135 OF 455  ELAPSED TIME = 0
Layer TMP<1> DELETED -- LVHEAP = 3/5/67
Layer TMP<2> DELETED -- LVHEAP = 3/5/67
w1_and_nsd = W1_drc AND nsd
w1_and_nsd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 136 OF 455  ELAPSED TIME = 0
w1_and_psd = W1_drc AND psd
w1_and_psd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 137 OF 455  ELAPSED TIME = 0
Layer W1_drc DELETED -- LVHEAP = 3/5/67
ntap = TB_drc AND nsd
ntap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 138 OF 455  ELAPSED TIME = 0
RES_NW_mark = OR RES_NW_mark
RES_NW_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 139 OF 455  ELAPSED TIME = 0
Original Layer RES_NW_mark DELETED -- LVHEAP = 3/5/67
nwelcon = TB_drc NOT RES_NW_mark
nwelcon (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 140 OF 455  ELAPSED TIME = 0
RFDUM_g2 = OR RFDUM_g2
RFDUM_g2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 141 OF 455  ELAPSED TIME = 0
Original Layer RFDUM_g2 DELETED -- LVHEAP = 3/5/67
nmos_rf_s = nsd AND RFDUM_g2
nmos_rf_s (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 142 OF 455  ELAPSED TIME = 0
nmos_rf_s_con = nmos_rf_s AND nsd
nmos_rf_s_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 143 OF 455  ELAPSED TIME = 0
nmos_rf_d = nsd NOT RFDUM_g2
nmos_rf_d (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 144 OF 455  ELAPSED TIME = 0
nmos_rf_d_con = nmos_rf_d AND nsd
nmos_rf_d_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 145 OF 455  ELAPSED TIME = 0
pmos_rf_s = psd AND RFDUM_g2
pmos_rf_s (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 146 OF 455  ELAPSED TIME = 0
pmos_rf_s_con = psd AND pmos_rf_s
pmos_rf_s_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 147 OF 455  ELAPSED TIME = 0
pmos_rf_d = psd NOT RFDUM_g2
pmos_rf_d (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 148 OF 455  ELAPSED TIME = 0
pmos_rf_d_con = psd AND pmos_rf_d
pmos_rf_d_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 149 OF 455  ELAPSED TIME = 0
TMP<10> = pdiff NOT TB_drc
TMP<10> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 150 OF 455  ELAPSED TIME = 0
DN = OR DN
DN (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 151 OF 455  ELAPSED TIME = 0
Original Layer DN DELETED -- LVHEAP = 3/5/67
DN_drc = DN NOT DCTY_mark
DN_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 152 OF 455  ELAPSED TIME = 0
dn_hole = HOLES DN_drc
dn_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 153 OF 455  ELAPSED TIME = 0
dn_no_touch_hole = DN_drc NOT TOUCH dn_hole
dn_no_touch_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 154 OF 455  ELAPSED TIME = 0
Layer dn_hole DELETED -- LVHEAP = 3/5/67
dnwel_size01 = SIZE dn_no_touch_hole BY -0.005
dnwel_size01 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 155 OF 455  ELAPSED TIME = 0
TMP<19> = dn_no_touch_hole NOT dnwel_size01
TMP<19> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 156 OF 455  ELAPSED TIME = 0
Layer dn_no_touch_hole DELETED -- LVHEAP = 3/5/67
Layer dnwel_size01 DELETED -- LVHEAP = 3/5/67
DIODE_mark = OR DIODE_mark
DIODE_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 157 OF 455  ELAPSED TIME = 0
Original Layer DIODE_mark DELETED -- LVHEAP = 3/5/67
dnwel_ring = TMP<19> NOT INSIDE DIODE_mark
dnwel_ring (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 158 OF 455  ELAPSED TIME = 0
Layer TMP<19> DELETED -- LVHEAP = 3/5/67
dnwel_ptap = DN_drc NOT INTERACT dnwel_ring
dnwel_ptap (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 159 OF 455  ELAPSED TIME = 0
ptap = TMP<10> NOT dnwel_ptap
ptap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 160 OF 455  ELAPSED TIME = 0
Layer TMP<10> DELETED -- LVHEAP = 3/5/67
Layer dnwel_ptap DELETED -- LVHEAP = 3/5/67
bulk = EXTENT
bulk (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 161 OF 455  ELAPSED TIME = 0
psub_1 = bulk NOT dnwel_ring
psub_1 (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 162 OF 455  ELAPSED TIME = 0
Layer bulk DELETED -- LVHEAP = 3/5/67
Layer dnwel_ring DELETED -- LVHEAP = 3/5/67
PSUB2 = OR PSUB2
PSUB2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 163 OF 455  ELAPSED TIME = 1
Original Layer PSUB2 DELETED -- LVHEAP = 3/5/67
psub_size01 = SIZE PSUB2 BY 0.005
psub_size01 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 164 OF 455  ELAPSED TIME = 1
psub_cut = psub_size01 NOT PSUB2
psub_cut (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 165 OF 455  ELAPSED TIME = 1
Layer psub_size01 DELETED -- LVHEAP = 3/5/67
psub_2 = psub_1 NOT psub_cut
psub_2 (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 166 OF 455  ELAPSED TIME = 1
Layer psub_1 DELETED -- LVHEAP = 3/5/67
Layer psub_cut DELETED -- LVHEAP = 3/5/67
BJT_mark = OR BJT_mark
BJT_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 167 OF 455  ELAPSED TIME = 1
Original Layer BJT_mark DELETED -- LVHEAP = 3/5/67
pdiff_bjt = BJT_mark AND pdiff
pdiff_bjt (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 168 OF 455  ELAPSED TIME = 1
nw_bjt = BJT_mark AND TB_drc
nw_bjt (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 169 OF 455  ELAPSED TIME = 1
qvp_e = pdiff_bjt INSIDE nw_bjt
qvp_e (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 170 OF 455  ELAPSED TIME = 1
psub = psub_2 NOT qvp_e
psub (HIER-LSL TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 171 OF 455  ELAPSED TIME = 1
Layer psub_2 DELETED -- LVHEAP = 3/5/67
dn_nw = DN_drc INTERACT TB_drc
dn_nw (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 172 OF 455  ELAPSED TIME = 1
dn_tbtap = TB_drc AND dn_nw
dn_tbtap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 173 OF 455  ELAPSED TIME = 1
qvp33_e = qvp_e AND HV_drc
qvp33_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 174 OF 455  ELAPSED TIME = 1
qvp33_b = nw_bjt ENCLOSE qvp33_e
qvp33_b (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 175 OF 455  ELAPSED TIME = 1
qvp33B_con = qvp33_b AND ntap
qvp33B_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 176 OF 455  ELAPSED TIME = 1
qvp18_e = qvp_e NOT HV_drc
qvp18_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 177 OF 455  ELAPSED TIME = 1
Layer qvp_e DELETED -- LVHEAP = 3/5/67
qvp18_b = nw_bjt ENCLOSE qvp18_e
qvp18_b (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 178 OF 455  ELAPSED TIME = 1
Layer nw_bjt DELETED -- LVHEAP = 3/5/67
qvp18B_con = qvp18_b AND ntap
qvp18B_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 179 OF 455  ELAPSED TIME = 1
qvp33E_con = pdiff_bjt AND qvp33_e
qvp33E_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 180 OF 455  ELAPSED TIME = 1
qvp18E_con = pdiff_bjt AND qvp18_e
qvp18E_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 181 OF 455  ELAPSED TIME = 1
Layer pdiff_bjt DELETED -- LVHEAP = 3/5/67
ndiff_bjt = BJT_mark AND ndiff
ndiff_bjt (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 182 OF 455  ELAPSED TIME = 1
nw_Hole = HOLES TB_drc INNER
nw_Hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 183 OF 455  ELAPSED TIME = 1
dn_enc_nwHole = DN_drc ENCLOSE nw_Hole
dn_enc_nwHole (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 184 OF 455  ELAPSED TIME = 1
nwHole_dn = dn_enc_nwHole AND nw_Hole
nwHole_dn (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 185 OF 455  ELAPSED TIME = 1
Layer dn_enc_nwHole DELETED -- LVHEAP = 3/5/67
Layer nw_Hole DELETED -- LVHEAP = 3/5/67
vnpn_e = ndiff_bjt AND nwHole_dn
vnpn_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 186 OF 455  ELAPSED TIME = 1
Layer nwHole_dn DELETED -- LVHEAP = 3/5/67
vnpnE_con = ndiff_bjt AND vnpn_e
vnpnE_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 187 OF 455  ELAPSED TIME = 1
Layer ndiff_bjt DELETED -- LVHEAP = 3/5/67
resnw = TB_drc AND RES_NW_mark
resnw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 188 OF 455  ELAPSED TIME = 1
SI = OR SI
SI (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 189 OF 455  ELAPSED TIME = 1
Original Layer SI DELETED -- LVHEAP = 3/5/67
SI_drc = SI NOT DCTY_mark
SI_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 190 OF 455  ELAPSED TIME = 1
resnw_nosab = resnw OUTSIDE SI_drc
resnw_nosab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 191 OF 455  ELAPSED TIME = 1
Layer resnw DELETED -- LVHEAP = 3/5/67
RNDMY = OR RNDMY
RNDMY (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 192 OF 455  ELAPSED TIME = 1
Original Layer RNDMY DELETED -- LVHEAP = 3/5/67
rnw_rec = resnw_nosab NOT RNDMY
rnw_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 193 OF 455  ELAPSED TIME = 1
Layer resnw_nosab DELETED -- LVHEAP = 3/5/67
nwellRes_term = nwelcon TOUCH rnw_rec
nwellRes_term (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 194 OF 455  ELAPSED TIME = 1
nwResTerm_con = nwelcon AND nwellRes_term
nwResTerm_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 195 OF 455  ELAPSED TIME = 1
tb_in_to = TB_drc INSIDE TO_drc
tb_in_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 196 OF 455  ELAPSED TIME = 1
tb_to_res = tb_in_to AND RES_NW_mark
tb_to_res (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 197 OF 455  ELAPSED TIME = 1
Layer tb_in_to DELETED -- LVHEAP = 3/5/67
tb_to_sab_res = tb_to_res AND SI_drc
tb_to_sab_res (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 198 OF 455  ELAPSED TIME = 1
Layer tb_to_res DELETED -- LVHEAP = 3/5/67
rnw_sab = tb_to_sab_res AND RNDMY
rnw_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 199 OF 455  ELAPSED TIME = 1
Layer tb_to_sab_res DELETED -- LVHEAP = 3/5/67
rnw_sab_term = nwelcon TOUCH rnw_sab
rnw_sab_term (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 200 OF 455  ELAPSED TIME = 1
rnwsabTerm_con = nwelcon AND rnw_sab_term
rnwsabTerm_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 201 OF 455  ELAPSED TIME = 1
CONNECTIVITY EXTRACTION TOTAL LAYER PREPARATION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
NC = Net Count  IPC = Internal Pin Count
CEC = Cell Edge Count  PEC = Promoted Edge Count
LVHEAP = Geometry heap memory allocation.
MALLOC = Total heap memory allocation.
CELL cmim_test
     cmim_test (NC=40 IPC=0 CEC=80 PEC=0 CFGC=40)
     cmim_test  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
TOTAL CEC=80 PEC=0
POST-PROCESSING CONNECTIVITY DATA STRUCTURE...
    MARKING TRUE NETS AND EXTERNAL PINS...
    DISCARDING FALSE VIRTUAL NETS, RESOLVING DEEP SHORTS AND PERFORMING VIRTUAL CONNECTIONS...
    CREATING COMPACT PIN DATA STRUCTURE...
    FINALIZING NODE NUMBERS ON SCONNECT LAYERS...
    RESOLVING SHORT CIRCUIT TEXT...
    PROCESSING HIGH SHORTS...
    COMPUTING FINAL NET NAMES AND REPORTING TEXT WARNINGS...
    PROCESSING LINK OPTIONS OF SCONNECT STATEMENTS...
POST-PROCESSING completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34
CONNECTIVITY EXTRACTION completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
WRITING CELL INFORMATION to PHDB svdb
PHDB CELL DATA WRITE completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  ELAPSED TIME = 1
WRITING CONNECT INFORMATION to PHDB svdb
PHDB CONNECT INFORMATION written. CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 35/35/35  ELAPSED TIME = 1
Layer lvpsb DELETED -- LVHEAP = 3/5/67
Layer lvnsb DELETED -- LVHEAP = 3/5/67
Layer wtmct DELETED -- LVHEAP = 3/5/67
Layer wtcon DELETED -- LVHEAP = 3/5/67
Layer var18_rf_gt_con DELETED -- LVHEAP = 3/5/67
Layer var33_rf_gt_con DELETED -- LVHEAP = 3/5/67
Layer w1_and_gt DELETED -- LVHEAP = 3/5/67
Layer w1_and_nsd DELETED -- LVHEAP = 3/5/67
Layer w1_and_psd DELETED -- LVHEAP = 3/5/67
DEVICE RECOGNITION
LVS PUSH DEVICES enabled.
MCTM5 = OR MCTM5
MCTM5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 202 OF 455  ELAPSED TIME = 1
Original Layer MCTM5 DELETED -- LVHEAP = 4/5/67
mct5 = mctcap AND MCTM5
mct5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 203 OF 455  ELAPSED TIME = 1
mimcap5x = mct5 AND A5_drc
mimcap5x (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 204 OF 455  ELAPSED TIME = 1
Layer mct5 DELETED -- LVHEAP = 4/5/67
mimcap5 = mimcap5x NOT RFDUM_mark
mimcap5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 205 OF 455  ELAPSED TIME = 1
var33a = var33 NOT RFDUM_mark
var33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 206 OF 455  ELAPSED TIME = 1
var33_mix = VARMOS_mark ENCLOSE var33a
var33_mix (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 207 OF 455  ELAPSED TIME = 1
var18a = var18 NOT RFDUM_mark
var18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 208 OF 455  ELAPSED TIME = 1
var18_mix = VARMOS_mark ENCLOSE var18a
var18_mix (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 209 OF 455  ELAPSED TIME = 1
Layer VARMOS_mark DELETED -- LVHEAP = 4/5/67
ngate = GT_drc AND ndiff
ngate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 210 OF 455  ELAPSED TIME = 1
mosngate = ngate OUTSIDE TB_drc
mosngate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 211 OF 455  ELAPSED TIME = 1
Layer ngate DELETED -- LVHEAP = 4/5/67
ngate33 = mosngate AND HV_drc
ngate33 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 212 OF 455  ELAPSED TIME = 1
ngate18 = mosngate NOT ngate33
ngate18 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 213 OF 455  ELAPSED TIME = 1
PWB = OR PWB
PWB (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 214 OF 455  ELAPSED TIME = 1
Original Layer PWB DELETED -- LVHEAP = 4/5/67
PWB_drc = PWB NOT DCTY_mark
PWB_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 215 OF 455  ELAPSED TIME = 1
nngate18 = ngate18 AND PWB_drc
nngate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 216 OF 455  ELAPSED TIME = 1
nngate33 = ngate33 AND PWB_drc
nngate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 217 OF 455  ELAPSED TIME = 1
MN = OR MN
MN (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 218 OF 455  ELAPSED TIME = 1
Original Layer MN DELETED -- LVHEAP = 4/5/67
MN_drc = MN NOT DCTY_mark
MN_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 219 OF 455  ELAPSED TIME = 1
nmgate18 = ngate18 AND MN_drc
nmgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 220 OF 455  ELAPSED TIME = 1
nmgate33 = ngate33 AND MN_drc
nmgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 221 OF 455  ELAPSED TIME = 1
pgate = GT_drc AND pdiff
pgate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 222 OF 455  ELAPSED TIME = 1
mospgate = pgate INSIDE TB_drc
mospgate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 223 OF 455  ELAPSED TIME = 1
pgate33 = mospgate AND HV_drc
pgate33 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 224 OF 455  ELAPSED TIME = 1
pgate18 = mospgate NOT pgate33
pgate18 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 225 OF 455  ELAPSED TIME = 1
MP = OR MP
MP (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 226 OF 455  ELAPSED TIME = 1
Original Layer MP DELETED -- LVHEAP = 4/5/67
MP_drc = MP NOT DCTY_mark
MP_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 227 OF 455  ELAPSED TIME = 1
pmgate18 = pgate18 AND MP_drc
pmgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 228 OF 455  ELAPSED TIME = 1
pmgate33 = pgate33 AND MP_drc
pmgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 229 OF 455  ELAPSED TIME = 1
PD = OR PD
PD (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 230 OF 455  ELAPSED TIME = 1
Original Layer PD DELETED -- LVHEAP = 4/5/67
PD_drc = PD NOT DCTY_mark
PD_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 231 OF 455  ELAPSED TIME = 1
pdgate = pgate AND PD_drc
pdgate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 232 OF 455  ELAPSED TIME = 1
Layer pgate DELETED -- LVHEAP = 4/5/67
ESD_mark = OR ESD_mark
ESD_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 233 OF 455  ELAPSED TIME = 1
Original Layer ESD_mark DELETED -- LVHEAP = 4/5/67
esd_to = TO_drc AND ESD_mark
esd_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 234 OF 455  ELAPSED TIME = 1
Layer TO_drc DELETED -- LVHEAP = 4/5/67
SE = OR SE
SE (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 235 OF 455  ELAPSED TIME = 1
Original Layer SE DELETED -- LVHEAP = 4/5/67
SE_drc = SE NOT DCTY_mark
SE_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 236 OF 455  ELAPSED TIME = 1
nesd_to = esd_to AND SE_drc
nesd_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 237 OF 455  ELAPSED TIME = 1
esdnmos = ngate33 AND nesd_to
esdnmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 238 OF 455  ELAPSED TIME = 1
esdlvnmos = ngate18 AND nesd_to
esdlvnmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 239 OF 455  ELAPSED TIME = 1
Layer nesd_to DELETED -- LVHEAP = 4/5/67
esdpmos = pgate33 AND esd_to
esdpmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 240 OF 455  ELAPSED TIME = 1
Layer esd_to DELETED -- LVHEAP = 4/5/67
VTSRAM_mark = OR VTSRAM_mark
VTSRAM_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 241 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_mark DELETED -- LVHEAP = 4/5/67
nsram = mosngate AND VTSRAM_mark
nsram (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 242 OF 455  ELAPSED TIME = 1
mn_acess = AREA nsram > 0.054 <= 0.056
mn_pudn = AREA nsram > 0.052 <= 0.053
mn_acess (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 244 OF 455  ELAPSED TIME = 1
Layer nsram DELETED -- LVHEAP = 4/5/67
VTSRAM_gc2 = OR VTSRAM_gc2
VTSRAM_gc2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 245 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_gc2 DELETED -- LVHEAP = 4/5/67
nsram_gc2 = mosngate AND VTSRAM_gc2
nsram_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 246 OF 455  ELAPSED TIME = 1
mn_acess_gc2 = AREA nsram_gc2 > 0.054 <= 0.056
mn_pudn_gc2 = AREA nsram_gc2 > 0.052 <= 0.053
mn_acess_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 248 OF 455  ELAPSED TIME = 1
Layer nsram_gc2 DELETED -- LVHEAP = 4/5/67
VTSRAM_gc3 = OR VTSRAM_gc3
VTSRAM_gc3 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 249 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_gc3 DELETED -- LVHEAP = 4/5/67
nsram_gc3 = mosngate AND VTSRAM_gc3
nsram_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 250 OF 455  ELAPSED TIME = 1
mn_acess_gc3 = AREA nsram_gc3 > 0.054 <= 0.056
mn_pudn_gc3 = AREA nsram_gc3 > 0.059 <= 0.06
mn_acess_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 252 OF 455  ELAPSED TIME = 1
Layer nsram_gc3 DELETED -- LVHEAP = 4/5/67
VTSRAM_l = OR VTSRAM_l
VTSRAM_l (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 253 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_l DELETED -- LVHEAP = 4/5/67
nsram_l = mosngate AND VTSRAM_l
nsram_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 254 OF 455  ELAPSED TIME = 1
mn_acess_l = AREA nsram_l > 0.0774 <= 0.0776
mn_pudn_l = AREA nsram_l > 0.0721 <= 0.0723
mn_acess_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 256 OF 455  ELAPSED TIME = 1
Layer nsram_l DELETED -- LVHEAP = 4/5/67
VTSRAM_lc = OR VTSRAM_lc
VTSRAM_lc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 257 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_lc DELETED -- LVHEAP = 4/5/67
nsram_lc = mosngate AND VTSRAM_lc
nsram_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 258 OF 455  ELAPSED TIME = 1
Layer mosngate DELETED -- LVHEAP = 4/5/67
mn_acess_lc = AREA nsram_lc > 0.0774 <= 0.0776
mn_pudn_lc = AREA nsram_lc > 0.0721 <= 0.0723
mn_acess_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 260 OF 455  ELAPSED TIME = 1
Layer nsram_lc DELETED -- LVHEAP = 4/5/67
mp_puup = mospgate AND VTSRAM_mark
mp_puup (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 261 OF 455  ELAPSED TIME = 1
mp_puup_gc2 = mospgate AND VTSRAM_gc2
mp_puup_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 262 OF 455  ELAPSED TIME = 1
mp_puup_gc3 = mospgate AND VTSRAM_gc3
mp_puup_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 263 OF 455  ELAPSED TIME = 1
mp_puup_l = mospgate AND VTSRAM_l
mp_puup_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 264 OF 455  ELAPSED TIME = 1
mp_puup_lc = mospgate AND VTSRAM_lc
mp_puup_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 265 OF 455  ELAPSED TIME = 1
Layer mospgate DELETED -- LVHEAP = 4/5/67
TMP<9> = PWB_drc OR MN_drc
TMP<9> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 266 OF 455  ELAPSED TIME = 1
Layer PWB_drc DELETED -- LVHEAP = 4/5/67
Layer MN_drc DELETED -- LVHEAP = 4/5/67
TMP<8> = TMP<9> OR MP_drc
TMP<8> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 267 OF 455  ELAPSED TIME = 1
Layer TMP<9> DELETED -- LVHEAP = 4/5/67
Layer MP_drc DELETED -- LVHEAP = 4/5/67
TMP<7> = TMP<8> OR PD_drc
TMP<7> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 268 OF 455  ELAPSED TIME = 1
Layer TMP<8> DELETED -- LVHEAP = 4/5/67
Layer PD_drc DELETED -- LVHEAP = 4/5/67
TMP<6> = TMP<7> OR VTSRAM_mark
TMP<6> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 269 OF 455  ELAPSED TIME = 1
Layer TMP<7> DELETED -- LVHEAP = 4/5/67
TMP<5> = TMP<6> OR VTSRAM_gc2
TMP<5> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 270 OF 455  ELAPSED TIME = 1
Layer TMP<6> DELETED -- LVHEAP = 4/5/67
TMP<4> = TMP<5> OR VTSRAM_gc3
TMP<4> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 271 OF 455  ELAPSED TIME = 1
Layer TMP<5> DELETED -- LVHEAP = 4/5/67
TMP<3> = TMP<4> OR VTSRAM_l
TMP<3> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 272 OF 455  ELAPSED TIME = 1
Layer TMP<4> DELETED -- LVHEAP = 4/5/67
nonom_5 = TMP<3> OR VTSRAM_lc
nonom_5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 273 OF 455  ELAPSED TIME = 1
Layer TMP<3> DELETED -- LVHEAP = 4/5/67
ngate18a = ngate18 NOT nonom_5
ngate18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 274 OF 455  ELAPSED TIME = 1
Layer ngate18 DELETED -- LVHEAP = 4/5/67
ntgate18 = ngate18a NOT RFDUM_mark
ntgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 275 OF 455  ELAPSED TIME = 1
nonom_6 = ESD_mark OR nonom_5
nonom_6 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 276 OF 455  ELAPSED TIME = 1
ngate33a = ngate33 NOT nonom_6
ngate33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 277 OF 455  ELAPSED TIME = 1
Layer ngate33 DELETED -- LVHEAP = 4/5/67
ntgate33 = ngate33a NOT RFDUM_mark
ntgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 278 OF 455  ELAPSED TIME = 1
pgate18a = pgate18 NOT nonom_5
pgate18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 279 OF 455  ELAPSED TIME = 1
Layer pgate18 DELETED -- LVHEAP = 4/5/67
Layer nonom_5 DELETED -- LVHEAP = 4/5/67
ptgate18 = pgate18a NOT RFDUM_mark
ptgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 280 OF 455  ELAPSED TIME = 1
pgate33a = pgate33 NOT nonom_6
pgate33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 281 OF 455  ELAPSED TIME = 1
Layer pgate33 DELETED -- LVHEAP = 4/5/67
Layer nonom_6 DELETED -- LVHEAP = 4/5/67
ptgate33 = pgate33a NOT RFDUM_mark
ptgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 282 OF 455  ELAPSED TIME = 1
v1Rec = RECTANGLE qvp33_e == 2 BY == 2
v2Rec = RECTANGLE qvp33_e == 5 BY == 5
v3Rec = RECTANGLE qvp33_e == 10 BY == 10
v1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
v2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
v3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 285 OF 455  ELAPSED TIME = 1
p1Rec = RECTANGLE qvp18_e == 2 BY == 2
p2Rec = RECTANGLE qvp18_e == 5 BY == 5
p3Rec = RECTANGLE qvp18_e == 10 BY == 10
p1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
p2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
p3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 288 OF 455  ELAPSED TIME = 1
TMP<14> = vnpn_e NOT HV_drc
TMP<14> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 289 OF 455  ELAPSED TIME = 1
n4Rec = RECTANGLE TMP<14> == 0.6 BY == 0.6
n1Rec = RECTANGLE TMP<14> == 2 BY == 2
n2Rec = RECTANGLE TMP<14> == 5 BY == 5
n3Rec = RECTANGLE TMP<14> == 10 BY == 10
n4Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 293 OF 455  ELAPSED TIME = 1
Layer TMP<14> DELETED -- LVHEAP = 4/5/67
TMP<18> = vnpn_e AND HV_drc
TMP<18> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 294 OF 455  ELAPSED TIME = 1
h4Rec = RECTANGLE TMP<18> == 0.6 BY == 0.6
h1Rec = RECTANGLE TMP<18> == 2 BY == 2
h2Rec = RECTANGLE TMP<18> == 5 BY == 5
h3Rec = RECTANGLE TMP<18> == 10 BY == 10
h4Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 298 OF 455  ELAPSED TIME = 1
Layer TMP<18> DELETED -- LVHEAP = 4/5/67
esdndiff = ndiff AND SE_drc
esdndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 299 OF 455  ELAPSED TIME = 1
dioesd = esdndiff AND DIODE_mark
dioesd (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 300 OF 455  ELAPSED TIME = 1
Layer esdndiff DELETED -- LVHEAP = 4/5/67
dnpwesd = dioesd NOT INTERACT nwelcon
dnpwesd (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 301 OF 455  ELAPSED TIME = 1
Layer dioesd DELETED -- LVHEAP = 4/5/67
ndiff_dio = ndiff AND DIODE_mark
ndiff_dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 302 OF 455  ELAPSED TIME = 1
ndiff_dio_no_esd = ndiff_dio NOT INTERACT SE_drc
ndiff_dio_no_esd (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 303 OF 455  ELAPSED TIME = 1
Layer SE_drc DELETED -- LVHEAP = 4/5/67
dnpw = ndiff_dio_no_esd NOT nwelcon
dnpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 304 OF 455  ELAPSED TIME = 1
Layer ndiff_dio_no_esd DELETED -- LVHEAP = 4/5/67
dnpw33 = dnpw AND HV_drc
dnpw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 305 OF 455  ELAPSED TIME = 1
dnpw18 = dnpw OUTSIDE HV_drc
dnpw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 306 OF 455  ELAPSED TIME = 1
Layer dnpw DELETED -- LVHEAP = 4/5/67
dnwdio = TB_drc ENCLOSE ndiff_dio
dnwdio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 307 OF 455  ELAPSED TIME = 1
Layer ndiff_dio DELETED -- LVHEAP = 4/5/67
dnwpw = dnwdio NOT INTERACT DN_drc
dnwpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 308 OF 455  ELAPSED TIME = 1
Layer dnwdio DELETED -- LVHEAP = 4/5/67
dnwpw33 = dnwpw AND HV_drc
dnwpw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 309 OF 455  ELAPSED TIME = 1
dnwpw18 = dnwpw OUTSIDE HV_drc
dnwpw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 310 OF 455  ELAPSED TIME = 1
Layer dnwpw DELETED -- LVHEAP = 4/5/67
pdiff_dio = pdiff AND DIODE_mark
pdiff_dio (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 311 OF 455  ELAPSED TIME = 1
dpnw = pdiff_dio AND nwelcon
dpnw (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 312 OF 455  ELAPSED TIME = 1
Layer pdiff_dio DELETED -- LVHEAP = 4/5/67
dpnw33 = dpnw AND HV_drc
dpnw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 313 OF 455  ELAPSED TIME = 1
dpnw18 = dpnw NOT HV_drc
dpnw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 314 OF 455  ELAPSED TIME = 1
Layer dpnw DELETED -- LVHEAP = 4/5/67
dnndiff = DN_drc ENCLOSE ndiff
dnndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 315 OF 455  ELAPSED TIME = 1
Layer DN_drc DELETED -- LVHEAP = 4/5/67
ddepdio = dnndiff AND DIODE_mark
ddepdio (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 316 OF 455  ELAPSED TIME = 1
Layer dnndiff DELETED -- LVHEAP = 4/5/67
Layer DIODE_mark DELETED -- LVHEAP = 4/5/67
ddnwpw = ddepdio AND TB_drc
ddnwpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 317 OF 455  ELAPSED TIME = 1
Layer ddepdio DELETED -- LVHEAP = 4/5/67
Layer TB_drc DELETED -- LVHEAP = 4/5/67
m1_res = A1_drc AND RES_M1
m1_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 318 OF 455  ELAPSED TIME = 1
Layer A1_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M1 DELETED -- LVHEAP = 4/5/67
m2_res = A2_drc AND RES_M2
m2_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 319 OF 455  ELAPSED TIME = 1
Layer A2_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M2 DELETED -- LVHEAP = 4/5/67
m3_res = A3_drc AND RES_M3
m3_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 320 OF 455  ELAPSED TIME = 1
Layer A3_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M3 DELETED -- LVHEAP = 4/5/67
m4_res = A4_drc AND RES_M4
m4_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 321 OF 455  ELAPSED TIME = 1
Layer A4_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M4 DELETED -- LVHEAP = 4/5/67
m5_res = A5_drc AND RES_M5
m5_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 322 OF 455  ELAPSED TIME = 1
Layer A5_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M5 DELETED -- LVHEAP = 4/5/67
tt_res = MTT_drc AND RES_MT
tt_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 323 OF 455  ELAPSED TIME = 1
Layer MTT_drc DELETED -- LVHEAP = 4/5/67
Layer RES_MT DELETED -- LVHEAP = 4/5/67
RES_3T_mark = OR RES_3T_mark
RES_3T_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 324 OF 455  ELAPSED TIME = 1
Original Layer RES_3T_mark DELETED -- LVHEAP = 4/5/67
rnw_rec_2t = rnw_rec OUTSIDE RES_3T_mark
rnw_rec_3t = rnw_rec NOT OUTSIDE RES_3T_mark
rnw_rec_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnw_rec_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 326 OF 455  ELAPSED TIME = 1
Layer rnw_rec DELETED -- LVHEAP = 4/5/67
rnw_sab_2t = rnw_sab OUTSIDE RES_3T_mark
rnw_sab_3t = rnw_sab NOT OUTSIDE RES_3T_mark
rnw_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnw_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 328 OF 455  ELAPSED TIME = 1
Layer rnw_sab DELETED -- LVHEAP = 4/5/67
rndiff = ndiff AND RES_TO_mark
rndiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 329 OF 455  ELAPSED TIME = 1
Layer ndiff DELETED -- LVHEAP = 4/5/67
rndiff_nsab1 = rndiff OUTSIDE SI_drc
rndiff_sab1 = rndiff NOT OUTSIDE SI_drc
rndiff_nsab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rndiff_sab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 331 OF 455  ELAPSED TIME = 1
Layer rndiff DELETED -- LVHEAP = 4/5/67
rndiff_sab2 = rndiff_sab1 AND RNDMY
rndiff_sab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 332 OF 455  ELAPSED TIME = 1
Layer rndiff_sab1 DELETED -- LVHEAP = 4/5/67
rndiff_sab3 = rndiff_sab2 OUTSIDE RES_3T_mark
rnimp_sab_3t = rndiff_sab2 NOT OUTSIDE RES_3T_mark
rndiff_sab3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnimp_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 334 OF 455  ELAPSED TIME = 1
rnimp_sab_2t = rndiff_sab3 OUTSIDE RFDUM_mark
rnimp_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 335 OF 455  ELAPSED TIME = 1
Layer rndiff_sab3 DELETED -- LVHEAP = 4/5/67
rndiff_nsab2 = rndiff_nsab1 NOT RNDMY
rndiff_nsab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 336 OF 455  ELAPSED TIME = 1
Layer rndiff_nsab1 DELETED -- LVHEAP = 4/5/67
rnimp_2t = rndiff_nsab2 OUTSIDE RES_3T_mark
rnimp_3t = rndiff_nsab2 NOT OUTSIDE RES_3T_mark
rnimp_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnimp_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 338 OF 455  ELAPSED TIME = 1
Layer rndiff_nsab2 DELETED -- LVHEAP = 4/5/67
rpdiff = pdiff AND RES_TO_mark
rpdiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 339 OF 455  ELAPSED TIME = 1
Layer pdiff DELETED -- LVHEAP = 4/5/67
Layer RES_TO_mark DELETED -- LVHEAP = 4/5/67
rpdiff_nsab1 = rpdiff OUTSIDE SI_drc
rpdiff_sab1 = rpdiff NOT OUTSIDE SI_drc
rpdiff_nsab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpdiff_sab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 341 OF 455  ELAPSED TIME = 1
Layer rpdiff DELETED -- LVHEAP = 4/5/67
RPDMY = OR RPDMY
RPDMY (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 342 OF 455  ELAPSED TIME = 1
Original Layer RPDMY DELETED -- LVHEAP = 4/5/67
rpdiff_sab2 = rpdiff_sab1 AND RPDMY
rpdiff_sab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 343 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab1 DELETED -- LVHEAP = 4/5/67
rpdiff_sab3 = rpdiff_sab2 OUTSIDE RES_3T_mark
rpimp_sab_3t = rpdiff_sab2 NOT OUTSIDE RES_3T_mark
rpdiff_sab3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpimp_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 345 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab2 DELETED -- LVHEAP = 4/5/67
rpimp_sab_2t = rpdiff_sab3 OUTSIDE RFDUM_mark
rpimp_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 346 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab3 DELETED -- LVHEAP = 4/5/67
rpdiff_nsab2 = rpdiff_nsab1 NOT RPDMY
rpdiff_nsab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 347 OF 455  ELAPSED TIME = 1
Layer rpdiff_nsab1 DELETED -- LVHEAP = 4/5/67
rpimp_2t = rpdiff_nsab2 OUTSIDE RES_3T_mark
rpimp_3t = rpdiff_nsab2 NOT OUTSIDE RES_3T_mark
rpimp_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpimp_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 349 OF 455  ELAPSED TIME = 1
Layer rpdiff_nsab2 DELETED -- LVHEAP = 4/5/67
ndifpoly = GT_drc INSIDE SN_drc
ndifpoly (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 350 OF 455  ELAPSED TIME = 1
Layer SN_drc DELETED -- LVHEAP = 4/5/67
rndifpoly = ndifpoly AND RES_PY_mark
rndifpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 351 OF 455  ELAPSED TIME = 1
Layer ndifpoly DELETED -- LVHEAP = 4/5/67
rndifpoly_sab_o = rndifpoly OUTSIDE SI_drc
rndifpoly_sab = rndifpoly NOT OUTSIDE SI_drc
rndifpoly_sab_o (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rndifpoly_sab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 353 OF 455  ELAPSED TIME = 1
Layer rndifpoly DELETED -- LVHEAP = 4/5/67
rnpoly_sab1 = rndifpoly_sab AND RNDMY
rnpoly_sab1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 354 OF 455  ELAPSED TIME = 1
Layer rndifpoly_sab DELETED -- LVHEAP = 4/5/67
TMP<22> = rnpoly_sab1 INTERACT RFDUM_mark
rnpoly_sab = rnpoly_sab1 NOT INTERACT RFDUM_mark
TMP<22> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnpoly_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 356 OF 455  ELAPSED TIME = 1
Layer rnpoly_sab1 DELETED -- LVHEAP = 4/5/67
rnpoly = rndifpoly_sab_o NOT RNDMY
rnpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 357 OF 455  ELAPSED TIME = 1
Layer rndifpoly_sab_o DELETED -- LVHEAP = 4/5/67
Layer RNDMY DELETED -- LVHEAP = 4/5/67
pdifpoly = GT_drc INSIDE SP_drc
sp2poly = GT_drc CUT SP_drc
pdifpoly (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
sp2poly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 359 OF 455  ELAPSED TIME = 1
Layer GT_drc DELETED -- LVHEAP = 4/5/67
Layer SP_drc DELETED -- LVHEAP = 4/5/67
rpdifpoly = pdifpoly AND RES_PY_mark
rpdifpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 360 OF 455  ELAPSED TIME = 1
Layer pdifpoly DELETED -- LVHEAP = 4/5/67
Layer RES_PY_mark DELETED -- LVHEAP = 4/5/67
rpdifpoly_sab_o = rpdifpoly OUTSIDE SI_drc
rpdifpoly_sab = rpdifpoly NOT OUTSIDE SI_drc
rpdifpoly_sab_o (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpdifpoly_sab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 362 OF 455  ELAPSED TIME = 1
Layer rpdifpoly DELETED -- LVHEAP = 4/5/67
rppoly_sab1 = rpdifpoly_sab AND RPDMY
rppoly_sab1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 363 OF 455  ELAPSED TIME = 1
Layer rpdifpoly_sab DELETED -- LVHEAP = 4/5/67
TMP<23> = rppoly_sab1 INTERACT RFDUM_mark
rppoly_sab = rppoly_sab1 NOT INTERACT RFDUM_mark
TMP<23> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rppoly_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 365 OF 455  ELAPSED TIME = 1
Layer rppoly_sab1 DELETED -- LVHEAP = 4/5/67
TMP<21> = rpdifpoly_sab_o NOT RPDMY
TMP<21> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 366 OF 455  ELAPSED TIME = 1
Layer rpdifpoly_sab_o DELETED -- LVHEAP = 4/5/67
rppoly_rf = TMP<21> INTERACT RFDUM_mark
rppoly = TMP<21> NOT INTERACT RFDUM_mark
rppoly_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rppoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 368 OF 455  ELAPSED TIME = 1
Layer TMP<21> DELETED -- LVHEAP = 4/5/67
sipoly = sp2poly INTERACT SI_drc
sipoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 369 OF 455  ELAPSED TIME = 1
Layer sp2poly DELETED -- LVHEAP = 4/5/67
Layer SI_drc DELETED -- LVHEAP = 4/5/67
HR = OR HR
HR (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 370 OF 455  ELAPSED TIME = 1
Original Layer HR DELETED -- LVHEAP = 4/5/67
HR_drc = HR NOT DCTY_mark
HR_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 371 OF 455  ELAPSED TIME = 1
Layer DCTY_mark DELETED -- LVHEAP = 4/5/67
hrpoly1 = sipoly NOT OUTSIDE HR_drc
hrpoly1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 372 OF 455  ELAPSED TIME = 1
Layer sipoly DELETED -- LVHEAP = 4/5/67
Layer HR_drc DELETED -- LVHEAP = 4/5/67
hrpoly2 = hrpoly1 AND RES_HR_mark
hrpoly2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 373 OF 455  ELAPSED TIME = 1
Layer hrpoly1 DELETED -- LVHEAP = 4/5/67
Layer RES_HR_mark DELETED -- LVHEAP = 4/5/67
hrpoly3 = hrpoly2 AND RPDMY
hrpoly3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 374 OF 455  ELAPSED TIME = 1
Layer hrpoly2 DELETED -- LVHEAP = 4/5/67
hrpoly_rf = hrpoly3 INTERACT RFDUM_mark
hrpoly = hrpoly3 NOT INTERACT RFDUM_mark
hrpoly_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
hrpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 376 OF 455  ELAPSED TIME = 1
Layer hrpoly3 DELETED -- LVHEAP = 4/5/67
ngate18_rf = RFDUM_mark ENCLOSE ngate18a
ngate18_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 377 OF 455  ELAPSED TIME = 1
ngate33_rf = RFDUM_mark ENCLOSE ngate33a
ngate33_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 378 OF 455  ELAPSED TIME = 1
pgate18_rf = RFDUM_mark ENCLOSE pgate18a
pgate18_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 379 OF 455  ELAPSED TIME = 1
pgate33_rf = RFDUM_mark ENCLOSE pgate33a
pgate33_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 380 OF 455  ELAPSED TIME = 1
rnpsab_rf = TMP<22> AND nwelcon
rnpsab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 381 OF 455  ELAPSED TIME = 1
Layer TMP<22> DELETED -- LVHEAP = 4/5/67
rppsab_rf = TMP<23> AND nwelcon
rppsab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 382 OF 455  ELAPSED TIME = 1
Layer TMP<23> DELETED -- LVHEAP = 4/5/67
rnisab_rf = rndiff_sab2 INTERACT RFDUM_mark
rnisab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 383 OF 455  ELAPSED TIME = 1
Layer rndiff_sab2 DELETED -- LVHEAP = 4/5/67
VARJUN_mark = OR VARJUN_mark
VARJUN_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 384 OF 455  ELAPSED TIME = 1
Original Layer VARJUN_mark DELETED -- LVHEAP = 4/5/67
jvarnw = nwelcon AND VARJUN_mark
jvarnw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 385 OF 455  ELAPSED TIME = 1
TMP<25> = jvarnw INTERACT psd
TMP<25> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 386 OF 455  ELAPSED TIME = 1
Layer jvarnw DELETED -- LVHEAP = 4/5/67
TMP<24> = TMP<25> INTERACT nsd
TMP<24> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 387 OF 455  ELAPSED TIME = 1
Layer TMP<25> DELETED -- LVHEAP = 4/5/67
jvarreg = TMP<24> AND psd
jvarreg (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 388 OF 455  ELAPSED TIME = 1
Layer TMP<24> DELETED -- LVHEAP = 4/5/67
TMP<26> = jvarreg AND HV_drc
TMP<26> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 389 OF 455  ELAPSED TIME = 1
Layer HV_drc DELETED -- LVHEAP = 4/5/67
jpvar33dio = VARJUN_mark ENCLOSE TMP<26>
jpvar33dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 390 OF 455  ELAPSED TIME = 1
Layer TMP<26> DELETED -- LVHEAP = 4/5/67
TMP<27> = jvarreg NOT jpvar33dio
TMP<27> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 391 OF 455  ELAPSED TIME = 1
Layer jvarreg DELETED -- LVHEAP = 4/5/67
jpvar18dio = VARJUN_mark ENCLOSE TMP<27>
jpvar18dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 392 OF 455  ELAPSED TIME = 1
Layer TMP<27> DELETED -- LVHEAP = 4/5/67
mimcap5_rf = mimcap5x AND RFDUM_mark
mimcap5_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 393 OF 455  ELAPSED TIME = 1
Layer mimcap5x DELETED -- LVHEAP = 4/5/67
var18_rf_mos = var18 AND RFDUM_mark
var18_rf_mos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 394 OF 455  ELAPSED TIME = 1
Layer var18 DELETED -- LVHEAP = 4/5/67
var33_rf_mos = var33 AND RFDUM_mark
var33_rf_mos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 395 OF 455  ELAPSED TIME = 1
Layer var33 DELETED -- LVHEAP = 4/5/67
Layer RFDUM_mark DELETED -- LVHEAP = 4/5/67
metal_ind = tt_ind OR am_ind
metal_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 396 OF 455  ELAPSED TIME = 1
ttind_hole1 = HOLES metal_ind INNER EMPTY
ttind_hole1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 397 OF 455  ELAPSED TIME = 1
ttind_hole2 = SIZE ttind_hole1 BY 3.5 UNDEROVER
ttind_hole2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 398 OF 455  ELAPSED TIME = 1
Layer ttind_hole1 DELETED -- LVHEAP = 4/5/67
ttind_hole = EXTENTS ttind_hole2
ttind_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 399 OF 455  ELAPSED TIME = 1
Layer ttind_hole2 DELETED -- LVHEAP = 4/5/67
ttind_body = tt_ind INTERACT ttind_hole
ttind_body (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 400 OF 455  ELAPSED TIME = 1
diff_amedge = ANGLE am_ind > 0 < 90
diff_amedge (HIER-PMF TYP=2 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 401 OF 455  ELAPSED TIME = 1
diff_am_ind = am_ind WITH EDGE diff_amedge
diff_am_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 402 OF 455  ELAPSED TIME = 1
Layer diff_amedge DELETED -- LVHEAP = 4/5/67
difnum_touch = tt_ind AND diff_am_ind
difnum_touch (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 403 OF 455  ELAPSED TIME = 1
diff_ind = INDUM_mark ENCLOSE diff_am_ind
diff_ind (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 404 OF 455  ELAPSED TIME = 1
Layer diff_am_ind DELETED -- LVHEAP = 4/5/67
diff_ind_hole = diff_ind AND ttind_hole
diff_ind_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 405 OF 455  ELAPSED TIME = 1
diff_ind_r60 = INT diff_ind_hole < 180 REGION OPPOSITE PARALLEL ONLY
diff_ind_r120 = INT diff_ind_hole > 180 < 250 REGION OPPOSITE PARALLEL ONLY
diff_ind_r60 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r120 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 407 OF 455  ELAPSED TIME = 1
Layer diff_ind_hole DELETED -- LVHEAP = 4/5/67
TMP<32> = metal_ind INTERACT diff_ind_r60
TMP<32> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 408 OF 455  ELAPSED TIME = 1
Layer diff_ind_r60 DELETED -- LVHEAP = 4/5/67
diff_ind_r60n3d5 = TMP<32> INTERACT difnum_touch > 8 < 10
diff_ind_r60n5d5 = TMP<32> INTERACT difnum_touch > 14 < 16
diff_ind_r60n7d5 = TMP<32> INTERACT difnum_touch > 20 < 22
diff_ind_r60n3d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r60n5d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r60n7d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 411 OF 455  ELAPSED TIME = 1
Layer TMP<32> DELETED -- LVHEAP = 4/5/67
TMP<33> = metal_ind INTERACT diff_ind_r120
TMP<33> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 412 OF 455  ELAPSED TIME = 1
Layer diff_ind_r120 DELETED -- LVHEAP = 4/5/67
diff_ind_r120n3d5 = TMP<33> INTERACT difnum_touch > 8 < 10
diff_ind_r120n3d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 413 OF 455  ELAPSED TIME = 1
Layer TMP<33> DELETED -- LVHEAP = 4/5/67
ttind_hole_edge = EXPAND EDGE ttind_hole OUTSIDE BY 1
ttind_hole_edge (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 414 OF 455  ELAPSED TIME = 1
Layer ttind_hole DELETED -- LVHEAP = 4/5/67
diff_ind_w = ttind_hole_edge INTERACT difnum_touch
diff_ind_w (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 415 OF 455  ELAPSED TIME = 1
spri_ind = INDUM_mark NOT diff_ind
spri_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 416 OF 455  ELAPSED TIME = 1
Layer INDUM_mark DELETED -- LVHEAP = 4/5/67
Layer diff_ind DELETED -- LVHEAP = 4/5/67
spri_ind_rec = metal_ind INTERACT spri_ind
spri_ind_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 417 OF 455  ELAPSED TIME = 1
Layer metal_ind DELETED -- LVHEAP = 4/5/67
spri_am_ind = spri_ind AND am_ind
spri_am_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 418 OF 455  ELAPSED TIME = 1
Layer spri_ind DELETED -- LVHEAP = 4/5/67
Layer am_ind DELETED -- LVHEAP = 4/5/67
TMP<34> = spri_am_ind NOT tt_ind
TMP<34> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 419 OF 455  ELAPSED TIME = 1
ttind_term1 = tt_ind NOT INTERACT ttind_body
ttind_term1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 420 OF 455  ELAPSED TIME = 1
spri_am_spc = TMP<34> NOT INTERACT ttind_term1
spri_am_spc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 421 OF 455  ELAPSED TIME = 1
Layer TMP<34> DELETED -- LVHEAP = 4/5/67
Layer ttind_term1 DELETED -- LVHEAP = 4/5/67
sprinum_touch = tt_ind AND spri_am_ind
sprinum_touch (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 422 OF 455  ELAPSED TIME = 1
spri_ind_hole_edge = ttind_hole_edge INTERACT sprinum_touch
spri_ind_hole_edge (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 423 OF 455  ELAPSED TIME = 1
spri_ind_edge1 = SIZE spri_ind_hole_edge BY 1
spri_ind_edge1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 424 OF 455  ELAPSED TIME = 1
spri_ind_cr = ttind_hole_edge INTERACT spri_ind_edge1
spri_ind_cr (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 425 OF 455  ELAPSED TIME = 1
Layer ttind_hole_edge DELETED -- LVHEAP = 4/5/67
Layer spri_ind_edge1 DELETED -- LVHEAP = 4/5/67
spri_ind_w = spri_ind_cr NOT spri_ind_hole_edge
spri_ind_w (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 426 OF 455  ELAPSED TIME = 1
Layer spri_ind_cr DELETED -- LVHEAP = 4/5/67
Layer spri_ind_hole_edge DELETED -- LVHEAP = 4/5/67
nlthin = ntgate18 OR nsd
nlthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 427 OF 455  ELAPSED TIME = 1
plthin = ptgate18 OR psd
plthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 428 OF 455  ELAPSED TIME = 1
nhthin = ntgate33 OR nsd
nhthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 429 OF 455  ELAPSED TIME = 1
phthin = ptgate33 OR psd
phthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 430 OF 455  ELAPSED TIME = 1
nn18thin = nngate18 OR nsd
nn18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 431 OF 455  ELAPSED TIME = 1
nn33thin = nngate33 OR nsd
nn33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 432 OF 455  ELAPSED TIME = 1
nm18thin = nmgate18 OR nsd
nm18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 433 OF 455  ELAPSED TIME = 1
pm18thin = pmgate18 OR psd
pm18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 434 OF 455  ELAPSED TIME = 1
nm33thin = nmgate33 OR nsd
nm33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 435 OF 455  ELAPSED TIME = 1
pm33thin = pmgate33 OR psd
pm33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 436 OF 455  ELAPSED TIME = 1
pdthin = pdgate OR psd
pdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 437 OF 455  ELAPSED TIME = 1
nesdlvthin = esdlvnmos OR nsd
nesdlvthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 438 OF 455  ELAPSED TIME = 1
nesdthin = esdnmos OR nsd
nesdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 439 OF 455  ELAPSED TIME = 1
pesdthin = esdpmos OR psd
pesdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 440 OF 455  ELAPSED TIME = 1
mn_acessthin = mn_acess OR nsd
mn_acessthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 441 OF 455  ELAPSED TIME = 1
mn_acessgc2thin = mn_acess_gc2 OR nsd
mn_acessgc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 442 OF 455  ELAPSED TIME = 1
mn_acessgc3thin = mn_acess_gc3 OR nsd
mn_acessgc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 443 OF 455  ELAPSED TIME = 1
mn_acesslthin = mn_acess_l OR nsd
mn_acesslthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 444 OF 455  ELAPSED TIME = 1
mn_acesslcthin = mn_acess_lc OR nsd
mn_acesslcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 445 OF 455  ELAPSED TIME = 1
mn_pudnthin = mn_pudn OR nsd
mn_pudnthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 446 OF 455  ELAPSED TIME = 1
mn_pudngc2thin = mn_pudn_gc2 OR nsd
mn_pudngc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 447 OF 455  ELAPSED TIME = 1
mn_pudngc3thin = mn_pudn_gc3 OR nsd
mn_pudngc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 448 OF 455  ELAPSED TIME = 1
mn_pudnlthin = mn_pudn_l OR nsd
mn_pudnlthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 449 OF 455  ELAPSED TIME = 1
mn_pudnlcthin = mn_pudn_lc OR nsd
mn_pudnlcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 450 OF 455  ELAPSED TIME = 1
mp_puupthin = mp_puup OR psd
mp_puupthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 451 OF 455  ELAPSED TIME = 1
mp_puupgc2thin = mp_puup_gc2 OR psd
mp_puupgc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 452 OF 455  ELAPSED TIME = 1
mp_puupgc3thin = mp_puup_gc3 OR psd
mp_puupgc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 453 OF 455  ELAPSED TIME = 1
mp_puuplthin = mp_puup_l OR psd
mp_puuplthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 454 OF 455  ELAPSED TIME = 1
mp_puuplcthin = mp_puup_lc OR psd
mp_puuplcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 455 OF 455  ELAPSED TIME = 1
DEVICE RECOGNITION TOTAL LAYER PREPARATION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67 ELAPSED TIME = 1
DEVICE RECOGNITION PRECISE INTERACTION BEGINS.
DEVICE RECOGNITION TOTAL PRECISE INTERACTION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 5/6/67 ELAPSED TIME = 1
TENTATIVE SEED PROMOTIONS:   seed layer  seeds  cell : layers touched
TENTATIVE SEED PROMOTIONS: ------------  -----  -----------------------------------------
SEED PROMOTIONS:
SEED PROMOTIONS: ==============================================================
SEED PROMOTIONS:
SEED PROMOTIONS:
SEED PROMOTIONS:       TOTAL:      0
DEVICE RECOGNITION completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 5/18/67  MALLOC = 47/47/47 ELAPSED TIME = 1
HIERARCHICAL SPICE NETLISTER
HIERARCHICAL SPICE NETLISTER completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/17/67  MALLOC = 47/47/47 ELAPSED TIME = 1
WRITING DEVICE INFORMATION to PHDB svdb
PHDB DEVICE INFORMATION written. CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/17/67  MALLOC = 47/47/47  ELAPSED TIME = 1
Layer ntgate18 DELETED -- LVHEAP = 4/17/67
Layer nlthin DELETED -- LVHEAP = 4/17/67
Layer ptgate18 DELETED -- LVHEAP = 4/17/67
Layer plthin DELETED -- LVHEAP = 4/17/67
Layer ntgate33 DELETED -- LVHEAP = 4/17/67
Layer nhthin DELETED -- LVHEAP = 4/17/67
Layer ptgate33 DELETED -- LVHEAP = 4/17/67
Layer phthin DELETED -- LVHEAP = 4/17/67
Layer nngate18 DELETED -- LVHEAP = 4/17/67
Layer nn18thin DELETED -- LVHEAP = 4/17/67
Layer nngate33 DELETED -- LVHEAP = 4/17/67
Layer nn33thin DELETED -- LVHEAP = 4/17/67
Layer nmgate18 DELETED -- LVHEAP = 4/17/67
Layer nm18thin DELETED -- LVHEAP = 4/17/67
Layer pmgate18 DELETED -- LVHEAP = 4/17/67
Layer pm18thin DELETED -- LVHEAP = 4/17/67
Layer nmgate33 DELETED -- LVHEAP = 4/17/67
Layer nm33thin DELETED -- LVHEAP = 4/17/67
Layer pmgate33 DELETED -- LVHEAP = 4/17/67
Layer pm33thin DELETED -- LVHEAP = 4/17/67
Layer pdgate DELETED -- LVHEAP = 4/17/67
Layer pdthin DELETED -- LVHEAP = 4/17/67
Layer esdlvnmos DELETED -- LVHEAP = 4/17/67
Layer nesdlvthin DELETED -- LVHEAP = 4/17/67
Layer esdnmos DELETED -- LVHEAP = 4/17/67
Layer nesdthin DELETED -- LVHEAP = 4/17/67
Layer esdpmos DELETED -- LVHEAP = 4/17/67
Layer pesdthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess DELETED -- LVHEAP = 4/17/67
Layer mn_acessthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_gc2 DELETED -- LVHEAP = 4/17/67
Layer mn_acessgc2thin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_gc3 DELETED -- LVHEAP = 4/17/67
Layer mn_acessgc3thin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_l DELETED -- LVHEAP = 4/17/67
Layer mn_acesslthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_lc DELETED -- LVHEAP = 4/17/67
Layer mn_acesslcthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn DELETED -- LVHEAP = 4/17/67
Layer mn_pudnthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_gc2 DELETED -- LVHEAP = 4/17/67
Layer mn_pudngc2thin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_gc3 DELETED -- LVHEAP = 4/17/67
Layer mn_pudngc3thin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_l DELETED -- LVHEAP = 4/17/67
Layer mn_pudnlthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_lc DELETED -- LVHEAP = 4/17/67
Layer mn_pudnlcthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup DELETED -- LVHEAP = 4/17/67
Layer mp_puupthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_gc2 DELETED -- LVHEAP = 4/17/67
Layer mp_puupgc2thin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_gc3 DELETED -- LVHEAP = 4/17/67
Layer mp_puupgc3thin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_l DELETED -- LVHEAP = 4/17/67
Layer mp_puuplthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_lc DELETED -- LVHEAP = 4/17/67
Layer mp_puuplcthin DELETED -- LVHEAP = 4/17/67
Layer var18_mix DELETED -- LVHEAP = 4/17/67
Layer var18a DELETED -- LVHEAP = 4/17/67
Layer var33_mix DELETED -- LVHEAP = 4/17/67
Layer var33a DELETED -- LVHEAP = 4/17/67
Layer ngate18_rf DELETED -- LVHEAP = 4/17/67
Layer ngate18a DELETED -- LVHEAP = 4/17/67
Layer pgate18_rf DELETED -- LVHEAP = 4/17/67
Layer pgate18a DELETED -- LVHEAP = 4/17/67
Layer ngate33_rf DELETED -- LVHEAP = 4/17/67
Layer ngate33a DELETED -- LVHEAP = 4/17/67
Layer pgate33_rf DELETED -- LVHEAP = 4/17/67
Layer pgate33a DELETED -- LVHEAP = 4/17/67
Layer var18_rf_rec DELETED -- LVHEAP = 4/17/67
Layer var18_rf_gt DELETED -- LVHEAP = 4/17/67
Layer var18_rf_to DELETED -- LVHEAP = 4/17/67
Layer var18_rf_mos DELETED -- LVHEAP = 4/17/67
Layer var33_rf_rec DELETED -- LVHEAP = 4/17/67
Layer var33_rf_gt DELETED -- LVHEAP = 4/17/67
Layer var33_rf_to DELETED -- LVHEAP = 4/17/67
Layer var33_rf_mos DELETED -- LVHEAP = 4/17/67
Layer v1Rec DELETED -- LVHEAP = 4/17/67
Layer v2Rec DELETED -- LVHEAP = 4/17/67
Layer v3Rec DELETED -- LVHEAP = 4/17/67
Layer p1Rec DELETED -- LVHEAP = 4/17/67
Layer p2Rec DELETED -- LVHEAP = 4/17/67
Layer p3Rec DELETED -- LVHEAP = 4/17/67
Layer n1Rec DELETED -- LVHEAP = 4/17/67
Layer n2Rec DELETED -- LVHEAP = 4/17/67
Layer n3Rec DELETED -- LVHEAP = 4/17/67
Layer n4Rec DELETED -- LVHEAP = 4/17/67
Layer h1Rec DELETED -- LVHEAP = 4/17/67
Layer h2Rec DELETED -- LVHEAP = 4/17/67
Layer h3Rec DELETED -- LVHEAP = 4/17/67
Layer h4Rec DELETED -- LVHEAP = 4/17/67
Layer dnpwesd DELETED -- LVHEAP = 4/17/67
Layer dpnw33 DELETED -- LVHEAP = 4/17/67
Layer dpnw18 DELETED -- LVHEAP = 4/17/67
Layer dnpw33 DELETED -- LVHEAP = 4/17/67
Layer dnpw18 DELETED -- LVHEAP = 4/17/67
Layer dnwpw33 DELETED -- LVHEAP = 4/17/67
Layer dnwpw18 DELETED -- LVHEAP = 4/17/67
Layer ddnwpw DELETED -- LVHEAP = 4/17/67
Layer m1_res DELETED -- LVHEAP = 4/17/67
Layer a1_conn DELETED -- LVHEAP = 4/17/67
Layer m2_res DELETED -- LVHEAP = 4/17/67
Layer a2_conn DELETED -- LVHEAP = 4/17/67
Layer m3_res DELETED -- LVHEAP = 4/17/67
Layer a3_conn DELETED -- LVHEAP = 4/17/67
Layer rnw_rec_2t DELETED -- LVHEAP = 4/17/67
Layer rnw_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rnimp_2t DELETED -- LVHEAP = 4/17/67
Layer rpimp_2t DELETED -- LVHEAP = 4/17/67
Layer rnimp_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rpimp_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rnpoly_sab DELETED -- LVHEAP = 4/17/67
Layer rnpoly DELETED -- LVHEAP = 4/17/67
Layer rppoly_sab DELETED -- LVHEAP = 4/17/67
Layer rppoly DELETED -- LVHEAP = 4/17/67
Layer hrpoly DELETED -- LVHEAP = 4/17/67
Layer rnw_rec_3t DELETED -- LVHEAP = 4/17/67
Layer rnw_sab_3t DELETED -- LVHEAP = 4/17/67
Layer rnimp_3t DELETED -- LVHEAP = 4/17/67
Layer rpimp_3t DELETED -- LVHEAP = 4/17/67
Layer rnimp_sab_3t DELETED -- LVHEAP = 4/17/67
Layer rpimp_sab_3t DELETED -- LVHEAP = 4/17/67
Layer tt_res DELETED -- LVHEAP = 4/17/67
Layer m5_res DELETED -- LVHEAP = 4/17/67
Layer m4_res DELETED -- LVHEAP = 4/17/67
Layer a4_conn DELETED -- LVHEAP = 4/17/67
Layer mimcap5 DELETED -- LVHEAP = 4/17/67
Layer jpvar18dio DELETED -- LVHEAP = 4/17/67
Layer jpvar33dio DELETED -- LVHEAP = 4/17/67
Layer rnisab_rf DELETED -- LVHEAP = 4/17/67
Layer rnpsab_rf DELETED -- LVHEAP = 4/17/67
Layer rppsab_rf DELETED -- LVHEAP = 4/17/67
Layer rppoly_rf DELETED -- LVHEAP = 4/17/67
Layer hrpoly_rf DELETED -- LVHEAP = 4/17/67
Layer gt_conn DELETED -- LVHEAP = 4/17/67
Layer spri_ind_rec DELETED -- LVHEAP = 4/17/67
Layer tt_ind DELETED -- LVHEAP = 4/17/67
Layer spri_ind_w DELETED -- LVHEAP = 4/17/67
Layer sprinum_touch DELETED -- LVHEAP = 4/17/67
Layer spri_am_ind DELETED -- LVHEAP = 4/17/67
Layer ttind_body DELETED -- LVHEAP = 4/17/67
Layer spri_am_spc DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n3d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n5d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n7d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r120n3d5 DELETED -- LVHEAP = 4/17/67
Layer tt_conn DELETED -- LVHEAP = 4/17/67
Layer diff_ind_w DELETED -- LVHEAP = 4/17/67
Layer difnum_touch DELETED -- LVHEAP = 4/17/67
Layer mimcap5_rf DELETED -- LVHEAP = 4/17/67
Layer mctcap DELETED -- LVHEAP = 4/17/67
Layer a5_conn DELETED -- LVHEAP = 4/17/67
WRITING PHDB to directory svdb
PHDB WRITE completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/17/67  MALLOC = 48/48/48  ELAPSED TIME = 1
Layer ntap DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_s_con DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_s DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_d_con DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_d DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_s_con DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_s DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_d_con DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_d DELETED -- LVHEAP = 3/17/67
Layer ptap DELETED -- LVHEAP = 3/17/67
Layer psub DELETED -- LVHEAP = 3/17/67
Layer dn_tbtap DELETED -- LVHEAP = 3/17/67
Layer dn_nw DELETED -- LVHEAP = 3/17/67
Layer qvp33B_con DELETED -- LVHEAP = 3/17/67
Layer qvp33_b DELETED -- LVHEAP = 3/17/67
Layer qvp18B_con DELETED -- LVHEAP = 3/17/67
Layer qvp18_b DELETED -- LVHEAP = 3/17/67
Layer qvp33E_con DELETED -- LVHEAP = 3/17/67
Layer qvp33_e DELETED -- LVHEAP = 3/17/67
Layer qvp18E_con DELETED -- LVHEAP = 3/17/67
Layer psd DELETED -- LVHEAP = 3/17/67
Layer qvp18_e DELETED -- LVHEAP = 3/17/67
Layer vnpnE_con DELETED -- LVHEAP = 3/17/67
Layer nsd DELETED -- LVHEAP = 3/17/67
Layer vnpn_e DELETED -- LVHEAP = 3/17/67
Layer nwResTerm_con DELETED -- LVHEAP = 3/17/67
Layer nwellRes_term DELETED -- LVHEAP = 3/17/67
Layer rnwsabTerm_con DELETED -- LVHEAP = 3/17/67
Layer nwelcon DELETED -- LVHEAP = 3/17/67
Layer rnw_sab_term DELETED -- LVHEAP = 3/17/67
--- CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR COMPLETED - Sun May 13 10:05:34 2018
--- TOTAL CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/17/67  MALLOC = 48/48/48  ELAPSED TIME = 1
--- PROCESSOR COUNT = 1
--- SPICE NETLIST FILE = /home/jshi/csmc18/lvs/cmim_test.sp
--- CIRCUIT EXTRACTION REPORT FILE = cmim_test.lvs.report.ext
--- PERSISTENT HIERARCHICAL DATABASE(PHDB) = svdb/cmim_test.phdb
--- QUERY DATABASE = svdb  TOP CELL = cmim_test
--- CALIBRE:VS-H - Sun May 13 10:05:34 2018
-----               CALIBRE:VS/xRC - INITIALIZATION MODULE               -----
Performing global initialization ...
Initializing LVS ...
--- CALIBRE:VS/xRC INITIALIZATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 50/50/50  ELAPSED TIME = 1
-----                 CALIBRE::LVS/xRC - EXECUTIVE MODULE                  -----
LVS started ...
//  Applying licensing policy...
//  Licensed Products
//  Base products running on 1 core:
//  - LVS (Hierarchical)
READING layout ...
Layout READ.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 50/50/50
READING source ...
Source READ.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 67/81/81  MALLOC = 50/50/50
Identifying CORRESPONDING cells ...
      ERROR:  Nothing in layout.
Writing REPORT ...
REPORT written.  CPU TIME = 0  REAL TIME = 0
Cumulative READING INPUTS Time:                          CPU =       0,     REAL =       0
Cumulative IDENTIFYING CORRESPONDING CELLS Time:         CPU =       0,     REAL =       0
    Cumulative CHECKING PORTS Time:                      CPU =       0,     REAL =       0
Cumulative REALLOCATING PINS Time:                       CPU =       0,     REAL =       0
Cumulative WRITING XDB HIERARCHY Time:                   CPU =       0,     REAL =       0
Cumulative ADDING GLOBALS Time:                          CPU =       0,     REAL =       0
Cumulative RESOLVING DEEP SHORTS Time:                   CPU =       0,     REAL =       0
Cumulative RESOLVING HIGH SHORTS Time:                   CPU =       0,     REAL =       0
Cumulative DELETING TRIVIAL PINS Time:                   CPU =       0,     REAL =       0
Cumulative EXPANDING UNBALANCED CELLS Time:              CPU =       0,     REAL =       0
Cumulative TRANSFORMS AND FLATTENING Time:               CPU =       0,     REAL =       0
    Cumulative FLATTENING Time:                          CPU =       0,     REAL =       0
    Cumulative TRANSFORMS Time:                          CPU =       0,     REAL =       0
        Cumulative INJECTION Time:                       CPU =       0,     REAL =       0
            Cumulative COMPACTION Time:                  CPU =       0,     REAL =       0
        Cumulative REDUCTION Time:                       CPU =       0,     REAL =       0
        Cumulative GATES Time:                           CPU =       0,     REAL =       0
        Cumulative UNUSED Time:                          CPU =       0,     REAL =       0
Cumulative COMPARISON Time:                              CPU =       0,     REAL =       0
    Cumulative MERGE PRIMITIVE TEMPLATES Time:           CPU =       0,     REAL =       0
    Cumulative MERGE SUBGRAPH TEMPLATES Time:            CPU =       0,     REAL =       0
    Cumulative NBD AND AMBIGUITY Time:                   CPU =       0,     REAL =       0
        Cumulative NBD Time:                             CPU =       0,     REAL =       0
            Cumulative INITIAL NBD IDS Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD CONVERT Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD BACK CONVERT Time:        CPU =       0,     REAL =       0
            Cumulative NEW NBD ALG RUN Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD IDS Time:                 CPU =       0,     REAL =       0
            Cumulative MATCH NBD NODES Time:             CPU =       0,     REAL =       0
        Cumulative TPL Time:                             CPU =       0,     REAL =       0
        Cumulative BIN Time:                             CPU =       0,     REAL =       0
        Cumulative PRP Time:                             CPU =       0,     REAL =       0
        Cumulative AMBIGUITY Time:                       CPU =       0,     REAL =       0
            Cumulative AMBIGUITY BY PROPERTIES Time:     CPU =       0,     REAL =       0
            Cumulative AMBIGUITY BY SUBTYPES Time:       CPU =       0,     REAL =       0
            Cumulative AMBIGUITY HIERARCHICAL Time:      CPU =       0,     REAL =       0
            Cumulative AMBIGUITY ARBITRARY Time:         CPU =       0,     REAL =       0
    Cumulative REWIRE Time:                              CPU =       0,     REAL =       0
    Cumulative REPAIR Time:                              CPU =       0,     REAL =       0
Cumulative REPORT Time:                                  CPU =       0,     REAL =       0
LVS completed. NOT COMPARED. See report file: cmim_test.lvs.report
LVS completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 51/51/51  ELAPSED TIME = 1
ERROR: Corresponding cells could not be identified.
*** Calibre finished with Exit Code: 4 ***
这是LVS report
 楼主| 发表于 2018-5-13 10:09:19 | 显示全部楼层
回复 2# houjs
Deleting PHDB cmim_test.phdb
Deleting XDB cmim_test.xdb
MGC_HOME = /apps/aoi_cal_2014.4_18.13
$MGC_HOME/bin/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
//  Calibre v2014.4_18.13    Wed Nov 5 16:04:06 PST 2014
//  Calibre Utility Library   v0-7_7-2014-2    Tue Jul 8 18:35:09 PDT 2014
//  Litho Libraries v2014.4_18.13  Wed Nov 5 16:04:06 PST 2014
//        Copyright Mentor Graphics Corporation 1996-2014
//                       All Rights Reserved.
//   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Mentor Graphics software executing under x86-64 Linux
//  Running on Linux eda 2.6.32-71.el6.x86_64 #1 SMP Wed Sep 1 01:33:01 EDT 2010 x86_64 glibc 2.12/NPTL 2.12
//  Entries in /proc/meminfo:
//  MemTotal:        2054708 kB
//  MemFree:          412224 kB
//  Buffers:          243272 kB
//  Cached:           714684 kB
//  SwapCached:            0 kB
//  Active:           674908 kB
//  Inactive:         635472 kB
//  Active(anon):     352636 kB
//  Inactive(anon):     5280 kB
//  Active(file):     322272 kB
//  Inactive(file):   630192 kB
//  Unevictable:           0 kB
//  Mlocked:               0 kB
//  SwapTotal:       4128760 kB
//  SwapFree:        4128760 kB
//  Dirty:               152 kB
//  Writeback:             0 kB
//  AnonPages:        348352 kB
//  Mapped:           128060 kB
//  Shmem:              5492 kB
//  Slab:             279656 kB
//  SReclaimable:     176012 kB
//  SUnreclaim:       103644 kB
//  KernelStack:        2064 kB
//  PageTables:        29628 kB
//  NFS_Unstable:          0 kB
//  Bounce:                0 kB
//  WritebackTmp:          0 kB
//  CommitLimit:     5156112 kB
//  Committed_AS:     829520 kB
//  VmallocTotal:   34359738367 kB
//  VmallocUsed:      274608 kB
//  VmallocChunk:   34359442720 kB
//  HardwareCorrupted:     0 kB
//  AnonHugePages:     88064 kB
//  HugePages_Total:       0
//  HugePages_Free:        0
//  HugePages_Rsvd:        0
//  HugePages_Surp:        0
//  Hugepagesize:       2048 kB
//  DirectMap4k:       10240 kB
//  DirectMap2M:     2086912 kB
//  CPU Info: Cores = 1
//  Max file descriptors: 1024
//  64 bit virtual addressing enabled
//  Running aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
//  Process ID: 25223
//  Starting time: Sun May 13 10:05:33 2018
//  Running on 1 CPU (pending licensing)
-----          STANDARD VERIFICATION RULE FILE COMPILATION MODULE          -----
--- RULE FILE = /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_
WARNING: The PEX NETLIST keyword 'LOOP' is obsolete and will be ignored. Please remove from your ruledeck.
//  Rule file generated on Sun May 13 10:05:33 CST 2018
//     by Calibre Interactive - LVS (v2014.4_18.13)
//      *** PLEASE DO NOT MODIFY THIS FILE ***
LAYOUT PATH  "cmim_test.calibre.db"
LAYOUT PRIMARY "cmim_test"
LAYOUT SYSTEM GDSII
SOURCE PATH "/home/jshi/csmc18/lvs/cmim_test.src.net"
SOURCE PRIMARY "cmim_test"
SOURCE SYSTEM SPICE
MASK SVDB DIRECTORY "svdb" QUERY
LVS REPORT "cmim_test.lvs.report"
LVS REPORT OPTION NONE
LVS FILTER UNUSED OPTION NONE SOURCE
LVS FILTER UNUSED OPTION NONE LAYOUT
LVS REPORT MAXIMUM 50
LVS POWER NAME
"VDD4"
LVS GROUND NAME
"GND"
LVS RECOGNIZE GATES ALL
LVS ABORT ON SOFTCHK NO
LVS ABORT ON SUPPLY ERROR YES
LVS IGNORE PORTS NO
LVS SHOW SEED PROMOTIONS NO
LVS SHOW SEED PROMOTIONS MAXIMUM 50
LVS ISOLATE SHORTS NO
VIRTUAL CONNECT COLON NO
VIRTUAL CONNECT REPORT NO
LVS EXECUTE ERC YES
ERC RESULTS DATABASE "cmim_test.erc.results"
ERC SUMMARY REPORT "cmim_test.erc.summary" REPLACE HIER
ERC CELL NAME YES CELL SPACE XFORM
ERC MAXIMUM RESULTS 1000
ERC MAXIMUM VERTEX 4096
DRC ICSTATION YES
INCLUDE "/home/jshi/csmc18/lvs/CSMC018_mixRF_sali_calLVS.rul"
--- STANDARD VERIFICATION RULE FILE COMPILATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 1/3/4
--- CALIBRE_* ENVIRONMENT VARIABLES:
CALIBRE_CMD_LINE='/apps/aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre  -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_'
CALIBRE_ECHO_RULE_FILE=
CALIBRE_HOME=/apps/aoi_cal_2014.4_18.13
CALIBRE_INITIAL_CMD_LINE='/apps/aoi_cal_2014.4_18.13/bin/calibre -spice /home/jshi/csmc18/lvs/cmim_test.sp -lvs -hier -nowait /home/jshi/csmc18/lvs/_CSMC018_mixRF_sali_calLVS.rul_'
CALIBRE_READDB_LD_LIBRARY_PATH=/apps/aoi_cal_2014.4_18.13/pkgs/icv_lib/lib64:/apps/aoi_cal_2014.4_18.13/pkgs/icv_qt_comp/plugins:/apps/aoi_cal_2014.4_18.13/pkgs/umc_libs/lib/lnx32:/apps/aoi_cal_2014.4_18.13/shared/pkgs/icv_oa/22.41.004/lib/linux_rhel40_gcc44x_64/opt:/apps/Cadence/IC5141/tools/lib:/apps/Cadence/IC5141/tools/lib:/apps/Cadence/IC5141/tools/dfII/lib:/lib:/lib64:/usr/lib:/usr/lib64
CALIBRE_SKIP_OS_CHECKS=
CALIBRE_SSE3_SUPPORTED=1
--- CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR - Sun May 13 10:05:33 2018
//  mgc_s license acquired (calibrehlvs requested).
//  mgc_s license acquired (calibrelvs requested).
//  - LVS Extraction
-----                   CALIBRE LAYOUT DATA INPUT MODULE                   -----
--- LAYOUT SYSTEM = GDS
--- LAYOUT MAGNIFICATION = 1
-----                     GDS FILE SUMMARY INFORMATION                     -----
GDS FILENAME:        cmim_test.calibre.db
GDS VERSION:         5
LIBRARY NAME:        MLX.DB
LAST MODIFIED:       ON 2018/5/12 AT 21:40:29
LAST ACCESSED:       ON 2018/5/13 AT 10:5:30
DATABASE PRECISION:  0.001 user units per database unit
PHYSICAL PRECISION:  1e-09 meters per database unit
MAGNIFICATION:       1
-----                 GDS INPUT DATA FOR INDIVIDUAL CELLS                  -----
     CELL NAME                  PLACEMENTS   ARRAYS   POLYGONS    PATHS    TEXTS
OSC_C_1_cell                             0        0         39        0        0
cmim_test                                1        0          4        0        9
NOTE: UNUSED geometric data is present on the following layer/datatype pairs:
    LAYER = 94 DATATYPE = 0
    LAYER = 153 DATATYPE = 1
NOTE: The following required simple layers are EMPTY:
    1002
    1003
    1004
    1005
    1007
    1008
    1009
    1012
    1013
    1014
    1017
    1018
    1019
    1020
    1022
    1023
    1024
    1030
    1032
    1033
    1034
    1035
    1036
    1037
    1039
    1040
    1041
    1042
    1043
    1045
    1046
    1047
    1048
    1049
    1050
    1051
    1052
    1053
    1055
    1056
    1057
    1058
    1059
    1060
    1061
    1062
    1063
    1064
    1065
    1066
    1067
    1068
    1069
    1071
    1072
    1073
    1074
    1075
    1076
    1077
    1080
    1081
    1082
    1083
    1084
    1085
    1086
    1087
--- LAYOUT DATABASE CONSTRUCTOR COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/4/67
CONSTRUCTING HIERARCHICAL DATABASE
    COPYING LAYOUT DATABASE
    FLATTENING SELECTED LAYERS
    PROCESSING TEXT
    ELIMINATING DUPLICATE TEXT
    ELIMINATING EMPTY CELLS
    COMPUTING RECTANGULAR EXTENTS
    ELIMINATING DUPLICATE PLACEMENTS
    IDENTIFYING TOP LAYER CELLS
    IDENTIFYING ADDITIONAL TOP LAYER CELLS
    IDENTIFYING VERY SMALL CELLS
    CHECKING ACUTE/SKEW/ANGLED/OFFGRID
    FLATTENING SELECTED VERY SMALL CELL PLACEMENTS
    FLATTENING SELECTED TOP LAYER CELL PLACEMENTS
    EXPANDING UNIQUE VERY SMALL CELL PLACEMENTS
    EXPANDING UNIQUE TOP LAYER CELL PLACEMENTS
    EXPANDING UNIQUE MONO-GEOMETRIC CELL PLACEMENTS
    EXPANDING LARGE TOP LAYER CELL PLACEMENTS
    COMPUTING RECTILINEAR EXTENTS
    SORTING PLACEMENTS
    EXPANDING UNIQUE TRANSPARENT CELL PLACEMENTS
        OSC_C_1_cell in cmim_test at (1.978,30.175)
    EXPANDING UNIQUE LIGHT-WEIGHT CELL PLACEMENTS
    EXPANDING UNIQUE ROW CELL PLACEMENTS
    EXPANDING TRIVIAL CELL PLACEMENTS
    EXPANDING VERY SPARSE ARRAY PLACEMENTS
    EXPANDING LARGE CELL ARRAY PLACEMENTS
    EXPANDING VERY SPARSE CELL PLACEMENTS
    ELIMINATING DUPLICATE SUPER-HIERARCHICAL PLACEMENTS
    PROCESSING LAYOUT BLOAT LAYERS (auto-detected)
    PROCESSING LARGE CELL EXTENT-BLOATING LAYERS
    EXPANDING DENSE OVERLAPS
    EXPANDING UNIQUE META-CELL PLACEMENTS
    INJECTING HIERARCHY
    FLATTENING REMAINING VERY SMALL CELL PLACEMENTS
    SORTING PLACEMENTS
    PUSHING VERY SMALL CELL PLACEMENTS
    PUSHING TOP LAYER CELL PLACEMENTS
    COMPUTING CELL-TO-WORLD TRANSFORMS
    SORTING PLACEMENTS
    PACKING HIERARCHY
    COMPUTING PLACEMENT OVERLAP RECORDS
    COMPUTING CELL OVERLAP AREAS
    INTERSECTING PLACEMENTS AND OVERLAP AREAS
HIERARCHICAL DATABASE CONSTRUCTOR COMPLETE.
CPU TIME = 0  REAL TIME = 0  LVHEAP = 2/5/67
-----               TEXT OBJECTS FOR CONNECTIVITY EXTRACTION               -----
plus (-4.14,34.939) 1016 cmim_test      vdd (9.062,22.875) 1001 cmim_test
gnd! (28.739,35.463) 1011 cmim_test
-----                TEXT OBJECTS FOR WITH TEXT OPERATIONS                 -----
-----               TEXT OBJECTS FOR EXPAND TEXT OPERATIONS                -----
-----                  TEXT OBJECTS FOR CAPI OPERATIONS                    -----
-----                                PORTS                                 -----
-----             LAYER READ SUMMARY (SIMPLE LAYER GEOMETRIES)             -----
  1000                   1
  1002                   0
  1003                   0
  1004                   0
  1005                   0
  1007                   0
  1008                   0
  1009                   0
  1010                   2
  1012                   0
  1013                   0
  1014                   0
  1015                   1
  1017                   0
  1018                   0
  1019                   0
  1020                   0
  1022                   0
  1023                   0
  1024                   0
  1030                   0
  1032                   0
  1033                   0
  1034                   0
  1035                   0
  1036                   0
  1037                   0
  1038                  35
  1039                   0
  1040                   0
  1041                   0
  1042                   0
  1043                   0
  1045                   0
  1046                   0
  1047                   0
  1048                   0
  1049                   0
  1050                   0
  1051                   0
  1052                   0
  1053                   0
  1054                   2
  1055                   0
  1056                   0
  1057                   0
  1058                   0
  1059                   0
  1060                   0
  1061                   0
  1062                   0
  1063                   0
  1064                   0
  1065                   0
  1066                   0
  1067                   0
  1068                   0
  1069                   0
  1071                   0
  1072                   0
  1073                   0
  1074                   0
  1075                   0
  1076                   0
  1077                   0
  1080                   0
  1081                   0
  1082                   0
  1083                   0
  1084                   0
  1085                   0
  1086                   0
  1087                   0
-----            LAYER READ SUMMARY (ORIGINAL LAYER GEOMETRIES)            -----
ORIGINAL LAYER       INITIAL GEOMETRIES                 FINAL GEOMETRIES
  DCTY_mark                0 (0)                            0 (0)
  A1SLOT_slot              0 (0)                            0 (0)
  A2SLOT_slot              0 (0)                            0 (0)
  A3SLOT_slot              0 (0)                            0 (0)
  A4SLOT_slot              0 (0)                            0 (0)
  A5SLOT_slot              0 (0)                            0 (0)
  MTTSLOT_slot             0 (0)                            0 (0)
  TB                       0 (0)                            0 (0)
  RES_NW_mark              0 (0)                            0 (0)
  TO                       0 (0)                            0 (0)
  SN                       0 (0)                            0 (0)
  SP                       0 (0)                            0 (0)
  GT                       0 (0)                            0 (0)
  HV                       0 (0)                            0 (0)
  SE                       0 (0)                            0 (0)
  SI                       0 (0)                            0 (0)
  W1                       0 (0)                            0 (0)
  W2                       0 (0)                            0 (0)
  W3                       0 (0)                            0 (0)
  W4                       0 (0)                            0 (0)
  W5                       0 (0)                            0 (0)
  WT                      35 (35)                          35 (35)
  MTT                      0 (0)                            0 (0)
  DN                       0 (0)                            0 (0)
  PWB                      0 (0)                            0 (0)
  MN                       0 (0)                            0 (0)
  MP                       0 (0)                            0 (0)
  PD                       0 (0)                            0 (0)
  HR                       0 (0)                            0 (0)
  MCT                      2 (2)                            2 (2)
  A1_net                   0 (0)                            0 (0)
  A1                       1 (1)                            1 (1)
  A1_pin                   0 (0)                            0 (0)
  RES_M1                   0 (0)                            0 (0)
  A2_net                   0 (0)                            0 (0)
  A2                       0 (0)                            0 (0)
  A2_pin                   0 (0)                            0 (0)
  RES_M2                   0 (0)                            0 (0)
  A3_net                   0 (0)                            0 (0)
  A3                       2 (2)                            2 (2)
  A3_pin                   0 (0)                            0 (0)
  A4_net                   0 (0)                            0 (0)
  A4                       1 (1)                            1 (1)
  A4_pin                   0 (0)                            0 (0)
  A5_net                   0 (0)                            0 (0)
  A5                       0 (0)                            0 (0)
  A5_pin                   0 (0)                            0 (0)
  MCTM5                    0 (0)                            0 (0)
  RFDUM_mark               0 (0)                            0 (0)
  RES_M3                   0 (0)                            0 (0)
  RES_M4                   0 (0)                            0 (0)
  RES_M5                   0 (0)                            0 (0)
  RES_MT                   0 (0)                            0 (0)
  RES_PY_mark              0 (0)                            0 (0)
  BJT_mark                 0 (0)                            0 (0)
  RES_TO_mark              0 (0)                            0 (0)
  VARMOS_mark              0 (0)                            0 (0)
  RES_HR_mark              0 (0)                            0 (0)
  ESD_mark                 0 (0)                            0 (0)
  VTSRAM_mark              0 (0)                            0 (0)
  VTSRAM_gc2               0 (0)                            0 (0)
  VTSRAM_gc3               0 (0)                            0 (0)
  VTSRAM_l                 0 (0)                            0 (0)
  VTSRAM_lc                0 (0)                            0 (0)
  DIODE_mark               0 (0)                            0 (0)
  PSUB2                    0 (0)                            0 (0)
  RNDMY                    0 (0)                            0 (0)
  RES_3T_mark              0 (0)                            0 (0)
  RPDMY                    0 (0)                            0 (0)
  RFDUM_g2                 0 (0)                            0 (0)
  VARJUN_mark              0 (0)                            0 (0)
  INDUM_mark               0 (0)                            0 (0)
  EXCLU                    0 (0)                            0 (0)
-----         LAYER READ SUMMARY (TEXT FOR CONNECTIVITY EXTRACTION)        -----
SIMPLE LAYER              TEXTS
  1001                     1 (1)
  1011                     1 (1)
  1016                     1 (1)
-----          LAYER READ SUMMARY (TEXT FOR WITH TEXT OPERATIONS)          -----
SIMPLE LAYER              TEXTS
-----         LAYER READ SUMMARY (TEXT FOR EXPAND TEXT OPERATIONS)         -----
SIMPLE LAYER              TEXTS
-----            LAYER READ SUMMARY (TEXT FOR CAPI OPERATIONS)             -----
SIMPLE LAYER              TEXTS
-----                      LAYER READ SUMMARY (PORTS)                      -----
SIMPLE LAYER              TEXTS
  1001                     1 (1)
  1011                     1 (1)
  1016                     1 (1)
-----                      CELL AND PLACEMENT SUMMARY                      -----
CELL TYPE                 CELLS           PLACEMENTS       FLAT PLACEMENTS
USER                          1                    0                     0
VERY SMALL                   0                    0                     0
TOP LAYER                    0                    0                     0
  VERY SMALL                  0                    0                     0
PSEUDO                        0                    0                     0
TOTAL                         1                    0                     0
-----                   LAYOUT DATA INPUT MODULE SUMMARY                   -----
--- TOTAL GEOMETRIES READ FROM SIMPLE LAYERS = 41
--- TOTAL GEOMETRIES READ FROM ORIGINAL LAYERS = 41 (41)
--- TOTAL GEOMETRIES WRITTEN TO ORIGINAL LAYERS = 41 (41)
--- LVHEAP = 2/5/67
--- DATABASE EXTENT = [ -5.2 , 18.855 ] -> [ 31.622 , 41.475 ]
--- GEOMETRIC DEPTH = ALL
--- TEXT DEPTH FOR CONNECTIVITY EXTRACTION = PRIMARY
--- TOTAL TEXT OBJECTS FOR CONNECTIVITY EXTRACTION = 3 (3)
--- TOTAL TEXT OBJECTS FOR WITH TEXT OPERATIONS = 0 (0)
--- TOTAL TEXT OBJECTS FOR EXPAND TEXT OPERATIONS = 0 (0)
--- TOTAL TEXT OBJECTS FOR CAPI OPERATIONS = 0 (0)
--- TOTAL PORT OBJECTS = 3 (3)
--- GEOMETRY FLAGGING = ACUTE (NO)  SKEW (NO)  ANGLED (NO)  OFFGRID (NO)
                        NONSIMPLE POLYGON (NO)  NONSIMPLE PATH (NO)
--- PRIMARY CELL = cmim_test
--- EXCLUDED CELLS =
--- LAYOUT BASE LAYER = (NOT SPECIFIED)
--- LAYOUT TOP LAYER = (NOT SPECIFIED)
--- CALIBRE LAYOUT DATA INPUT MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0
-----      CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR - EXECUTIVE MODULE      -----
SN = OR SN
SN (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 1 OF 455  ELAPSED TIME = 0
Original Layer SN DELETED -- LVHEAP = 3/5/67
DCTY_mark = OR DCTY_mark
DCTY_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 2 OF 455  ELAPSED TIME = 0
Original Layer DCTY_mark DELETED -- LVHEAP = 3/5/67
SN_drc = SN NOT DCTY_mark
SN_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 3 OF 455  ELAPSED TIME = 0
TO = OR TO
TO (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 4 OF 455  ELAPSED TIME = 0
Original Layer TO DELETED -- LVHEAP = 3/5/67
TO_drc = TO NOT DCTY_mark
TO_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 5 OF 455  ELAPSED TIME = 0
ndiff = SN_drc AND TO_drc
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 6 OF 455  ELAPSED TIME = 0
GT = OR GT
GT (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 7 OF 455  ELAPSED TIME = 0
Original Layer GT DELETED -- LVHEAP = 3/5/67
GT_drc = GT NOT DCTY_mark
GT_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 8 OF 455  ELAPSED TIME = 0
nsd1 = ndiff NOT GT_drc
nsd1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 9 OF 455  ELAPSED TIME = 0
RES_TO_mark = OR RES_TO_mark
RES_TO_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 10 OF 455  ELAPSED TIME = 0
Original Layer RES_TO_mark DELETED -- LVHEAP = 3/5/67
nsd = nsd1 NOT RES_TO_mark
nsd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 11 OF 455  ELAPSED TIME = 0
Layer nsd1 DELETED -- LVHEAP = 3/5/67
SP = OR SP
SP (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 12 OF 455  ELAPSED TIME = 0
Original Layer SP DELETED -- LVHEAP = 3/5/67
TMP<38> = TO AND SP
TMP<38> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 13 OF 455  ELAPSED TIME = 0
TB = OR TB
TB (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 14 OF 455  ELAPSED TIME = 0
Original Layer TB DELETED -- LVHEAP = 3/5/67
TMP<37> = TMP<38> NOT TB
TMP<37> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 15 OF 455  ELAPSED TIME = 0
Layer TMP<38> DELETED -- LVHEAP = 3/5/67
TMP<36> = TMP<37> NOT GT
TMP<36> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 16 OF 455  ELAPSED TIME = 0
Layer TMP<37> DELETED -- LVHEAP = 3/5/67
W1 = OR W1
W1 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 17 OF 455  ELAPSED TIME = 0
Original Layer W1 DELETED -- LVHEAP = 3/5/67
TMP<35> = TMP<36> INTERACT W1
TMP<35> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 18 OF 455  ELAPSED TIME = 0
Layer TMP<36> DELETED -- LVHEAP = 3/5/67
EXCLU = OR EXCLU
EXCLU (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 19 OF 455  ELAPSED TIME = 0
Original Layer EXCLU DELETED -- LVHEAP = 3/5/67
lvpsb = TMP<35> AND EXCLU
lvpsb (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 20 OF 455  ELAPSED TIME = 0
Layer TMP<35> DELETED -- LVHEAP = 3/5/67
SP_drc = SP NOT DCTY_mark
SP_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 21 OF 455  ELAPSED TIME = 0
pdiff = SP_drc AND TO_drc
pdiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 22 OF 455  ELAPSED TIME = 0
psd1 = pdiff NOT GT_drc
psd1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 23 OF 455  ELAPSED TIME = 0
psd = psd1 NOT RES_TO_mark
psd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 24 OF 455  ELAPSED TIME = 0
Layer psd1 DELETED -- LVHEAP = 3/5/67
TMP<41> = TO AND SN
TMP<41> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 25 OF 455  ELAPSED TIME = 0
TMP<40> = TMP<41> AND TB
TMP<40> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 26 OF 455  ELAPSED TIME = 0
Layer TMP<41> DELETED -- LVHEAP = 3/5/67
TMP<39> = TMP<40> NOT GT
TMP<39> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 27 OF 455  ELAPSED TIME = 0
Layer TMP<40> DELETED -- LVHEAP = 3/5/67
lvnsb = TMP<39> AND EXCLU
lvnsb (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 28 OF 455  ELAPSED TIME = 0
Layer TMP<39> DELETED -- LVHEAP = 3/5/67
A1_pin = OR A1_pin
A1_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 29 OF 455  ELAPSED TIME = 0
Original Layer A1_pin DELETED -- LVHEAP = 3/5/67
A1 = OR A1
A1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 30 OF 455  ELAPSED TIME = 0
Original Layer A1 DELETED -- LVHEAP = 3/5/67
A1_net = OR A1_net
A1_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 31 OF 455  ELAPSED TIME = 0
Original Layer A1_net DELETED -- LVHEAP = 3/5/67
a1net = A1 OR A1_net
a1net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 32 OF 455  ELAPSED TIME = 0
a1_net_pin = A1_pin OR a1net
a1_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 33 OF 455  ELAPSED TIME = 0
Layer a1net DELETED -- LVHEAP = 3/5/67
A1_drc = a1_net_pin NOT DCTY_mark
A1_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 34 OF 455  ELAPSED TIME = 0
Layer a1_net_pin DELETED -- LVHEAP = 3/5/67
A1SLOT_slot = OR A1SLOT_slot
A1SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 35 OF 455  ELAPSED TIME = 0
Original Layer A1SLOT_slot DELETED -- LVHEAP = 3/5/67
A1SLOT_slot_drc = A1SLOT_slot NOT DCTY_mark
A1SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 36 OF 455  ELAPSED TIME = 0
a1_conn1 = A1_drc NOT A1SLOT_slot_drc
a1_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 37 OF 455  ELAPSED TIME = 0
Layer A1SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M1 = OR RES_M1
RES_M1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 38 OF 455  ELAPSED TIME = 0
Original Layer RES_M1 DELETED -- LVHEAP = 3/5/67
a1_conn = a1_conn1 NOT RES_M1
a1_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 39 OF 455  ELAPSED TIME = 0
Layer a1_conn1 DELETED -- LVHEAP = 3/5/67
W2 = OR W2
W2 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 40 OF 455  ELAPSED TIME = 0
Original Layer W2 DELETED -- LVHEAP = 3/5/67
A2_pin = OR A2_pin
A2_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 41 OF 455  ELAPSED TIME = 0
Original Layer A2_pin DELETED -- LVHEAP = 3/5/67
A2 = OR A2
A2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 42 OF 455  ELAPSED TIME = 0
Original Layer A2 DELETED -- LVHEAP = 3/5/67
A2_net = OR A2_net
A2_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 43 OF 455  ELAPSED TIME = 0
Original Layer A2_net DELETED -- LVHEAP = 3/5/67
a2net = A2 OR A2_net
a2net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 44 OF 455  ELAPSED TIME = 0
a2_net_pin = A2_pin OR a2net
a2_net_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 45 OF 455  ELAPSED TIME = 0
Layer a2net DELETED -- LVHEAP = 3/5/67
A2_drc = a2_net_pin NOT DCTY_mark
A2_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 46 OF 455  ELAPSED TIME = 0
Layer a2_net_pin DELETED -- LVHEAP = 3/5/67
A2SLOT_slot = OR A2SLOT_slot
A2SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 47 OF 455  ELAPSED TIME = 0
Original Layer A2SLOT_slot DELETED -- LVHEAP = 3/5/67
A2SLOT_slot_drc = A2SLOT_slot NOT DCTY_mark
A2SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 48 OF 455  ELAPSED TIME = 0
a2_conn1 = A2_drc NOT A2SLOT_slot_drc
a2_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 49 OF 455  ELAPSED TIME = 0
Layer A2SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M2 = OR RES_M2
RES_M2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 50 OF 455  ELAPSED TIME = 0
Original Layer RES_M2 DELETED -- LVHEAP = 3/5/67
a2_conn = a2_conn1 NOT RES_M2
a2_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 51 OF 455  ELAPSED TIME = 0
Layer a2_conn1 DELETED -- LVHEAP = 3/5/67
W3 = OR W3
W3 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 52 OF 455  ELAPSED TIME = 0
Original Layer W3 DELETED -- LVHEAP = 3/5/67
A3_pin = OR A3_pin
A3_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 53 OF 455  ELAPSED TIME = 0
Original Layer A3_pin DELETED -- LVHEAP = 3/5/67
A3 = OR A3
A3 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 54 OF 455  ELAPSED TIME = 0
Original Layer A3 DELETED -- LVHEAP = 3/5/67
A3_net = OR A3_net
A3_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 55 OF 455  ELAPSED TIME = 0
Original Layer A3_net DELETED -- LVHEAP = 3/5/67
a3net = A3 OR A3_net
a3net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 56 OF 455  ELAPSED TIME = 0
a3_net_pin = A3_pin OR a3net
a3_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 57 OF 455  ELAPSED TIME = 0
Layer a3net DELETED -- LVHEAP = 3/5/67
A3_drc = a3_net_pin NOT DCTY_mark
A3_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 58 OF 455  ELAPSED TIME = 0
Layer a3_net_pin DELETED -- LVHEAP = 3/5/67
A3SLOT_slot = OR A3SLOT_slot
A3SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 59 OF 455  ELAPSED TIME = 0
Original Layer A3SLOT_slot DELETED -- LVHEAP = 3/5/67
A3SLOT_slot_drc = A3SLOT_slot NOT DCTY_mark
A3SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 60 OF 455  ELAPSED TIME = 0
a3_conn1 = A3_drc NOT A3SLOT_slot_drc
a3_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 61 OF 455  ELAPSED TIME = 0
Layer A3SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M3 = OR RES_M3
RES_M3 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 62 OF 455  ELAPSED TIME = 0
Original Layer RES_M3 DELETED -- LVHEAP = 3/5/67
a3_conn2 = a3_conn1 NOT RES_M3
a3_conn2 (HIER TYP=1 CFG=1 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 63 OF 455  ELAPSED TIME = 0
Layer a3_conn1 DELETED -- LVHEAP = 3/5/67
a3_conn = COPY a3_conn2
a3_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 64 OF 455  ELAPSED TIME = 0
Layer a3_conn2 DELETED -- LVHEAP = 3/5/67
WT = OR WT
WT (HIER TYP=1 CFG=1 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 65 OF 455  ELAPSED TIME = 0
Original Layer WT DELETED -- LVHEAP = 3/5/67
WT_drc = WT NOT DCTY_mark
WT_drc (HIER TYP=1 CFG=1 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 66 OF 455  ELAPSED TIME = 0
MCT = OR MCT
MCT (HIER TYP=1 CFG=1 HGC=2 FGC=2 HEC=8 FEC=8 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 67 OF 455  ELAPSED TIME = 0
Original Layer MCT DELETED -- LVHEAP = 3/5/67
MCT_drc = MCT NOT DCTY_mark
MCT_drc (HIER TYP=1 CFG=1 HGC=2 FGC=2 HEC=8 FEC=8 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 33/33/33  OPS COMPLETE = 68 OF 455  ELAPSED TIME = 0
mctcap = MCT_drc INTERACT WT_drc
mctcap (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 69 OF 455  ELAPSED TIME = 0
Layer MCT_drc DELETED -- LVHEAP = 3/5/67
wtmct = WT_drc AND mctcap
wtmct (HIER TYP=1 CFG=3 HGC=35 FGC=35 HEC=140 FEC=140 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 70 OF 455  ELAPSED TIME = 0
MTT = OR MTT
MTT (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 71 OF 455  ELAPSED TIME = 0
Original Layer MTT DELETED -- LVHEAP = 3/5/67
MTT_drc = MTT NOT DCTY_mark
MTT_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 72 OF 455  ELAPSED TIME = 0
MTTSLOT_slot = OR MTTSLOT_slot
MTTSLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 73 OF 455  ELAPSED TIME = 0
Original Layer MTTSLOT_slot DELETED -- LVHEAP = 3/5/67
MTTSLOT_slot_drc = MTTSLOT_slot NOT DCTY_mark
MTTSLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 74 OF 455  ELAPSED TIME = 0
tt_conn1 = MTT_drc NOT MTTSLOT_slot_drc
tt_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 75 OF 455  ELAPSED TIME = 0
Layer MTTSLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_MT = OR RES_MT
RES_MT (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 76 OF 455  ELAPSED TIME = 0
Original Layer RES_MT DELETED -- LVHEAP = 3/5/67
tt_conn2 = tt_conn1 NOT RES_MT
tt_conn2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 77 OF 455  ELAPSED TIME = 0
Layer tt_conn1 DELETED -- LVHEAP = 3/5/67
INDUM_mark = OR INDUM_mark
INDUM_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 78 OF 455  ELAPSED TIME = 0
Original Layer INDUM_mark DELETED -- LVHEAP = 3/5/67
tt_ind = tt_conn2 AND INDUM_mark
tt_ind (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 79 OF 455  ELAPSED TIME = 0
tt_conn = tt_conn2 NOT tt_ind
tt_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 80 OF 455  ELAPSED TIME = 0
Layer tt_conn2 DELETED -- LVHEAP = 3/5/67
wtcon = WT_drc OUTSIDE mctcap
wtcon (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 81 OF 455  ELAPSED TIME = 0
Layer WT_drc DELETED -- LVHEAP = 3/5/67
A5_pin = OR A5_pin
A5_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 82 OF 455  ELAPSED TIME = 0
Original Layer A5_pin DELETED -- LVHEAP = 3/5/67
A5 = OR A5
A5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 83 OF 455  ELAPSED TIME = 0
Original Layer A5 DELETED -- LVHEAP = 3/5/67
A5_net = OR A5_net
A5_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 84 OF 455  ELAPSED TIME = 0
Original Layer A5_net DELETED -- LVHEAP = 3/5/67
a5net = A5 OR A5_net
a5net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 85 OF 455  ELAPSED TIME = 0
a5_net_pin = A5_pin OR a5net
a5_net_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 86 OF 455  ELAPSED TIME = 0
Layer a5net DELETED -- LVHEAP = 3/5/67
A5_drc = a5_net_pin NOT DCTY_mark
A5_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 87 OF 455  ELAPSED TIME = 0
Layer a5_net_pin DELETED -- LVHEAP = 3/5/67
A5SLOT_slot = OR A5SLOT_slot
A5SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 88 OF 455  ELAPSED TIME = 0
Original Layer A5SLOT_slot DELETED -- LVHEAP = 3/5/67
A5SLOT_slot_drc = A5SLOT_slot NOT DCTY_mark
A5SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 89 OF 455  ELAPSED TIME = 0
a5_conn1 = A5_drc NOT A5SLOT_slot_drc
a5_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 90 OF 455  ELAPSED TIME = 0
Layer A5SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M5 = OR RES_M5
RES_M5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 91 OF 455  ELAPSED TIME = 0
Original Layer RES_M5 DELETED -- LVHEAP = 3/5/67
a5_conn2 = a5_conn1 NOT RES_M5
a5_conn2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 92 OF 455  ELAPSED TIME = 0
Layer a5_conn1 DELETED -- LVHEAP = 3/5/67
am_ind = a5_conn2 AND INDUM_mark
am_ind (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 93 OF 455  ELAPSED TIME = 0
a5_conn = a5_conn2 NOT am_ind
a5_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 94 OF 455  ELAPSED TIME = 0
Layer a5_conn2 DELETED -- LVHEAP = 3/5/67
W5 = OR W5
W5 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 95 OF 455  ELAPSED TIME = 0
Original Layer W5 DELETED -- LVHEAP = 3/5/67
A4_pin = OR A4_pin
A4_pin (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 96 OF 455  ELAPSED TIME = 0
Original Layer A4_pin DELETED -- LVHEAP = 3/5/67
A4 = OR A4
A4 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 97 OF 455  ELAPSED TIME = 0
Original Layer A4 DELETED -- LVHEAP = 3/5/67
A4_net = OR A4_net
A4_net (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 98 OF 455  ELAPSED TIME = 0
Original Layer A4_net DELETED -- LVHEAP = 3/5/67
a4net = A4 OR A4_net
a4net (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 99 OF 455  ELAPSED TIME = 0
a4_net_pin = A4_pin OR a4net
a4_net_pin (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 100 OF 455  ELAPSED TIME = 0
Layer a4net DELETED -- LVHEAP = 3/5/67
A4_drc = a4_net_pin NOT DCTY_mark
A4_drc (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 101 OF 455  ELAPSED TIME = 0
Layer a4_net_pin DELETED -- LVHEAP = 3/5/67
A4SLOT_slot = OR A4SLOT_slot
A4SLOT_slot (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 102 OF 455  ELAPSED TIME = 0
Original Layer A4SLOT_slot DELETED -- LVHEAP = 3/5/67
A4SLOT_slot_drc = A4SLOT_slot NOT DCTY_mark
A4SLOT_slot_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 103 OF 455  ELAPSED TIME = 0
a4_conn1 = A4_drc NOT A4SLOT_slot_drc
a4_conn1 (HIER TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 104 OF 455  ELAPSED TIME = 0
Layer A4SLOT_slot_drc DELETED -- LVHEAP = 3/5/67
RES_M4 = OR RES_M4
RES_M4 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 105 OF 455  ELAPSED TIME = 0
Original Layer RES_M4 DELETED -- LVHEAP = 3/5/67
a4_conn2 = a4_conn1 NOT RES_M4
a4_conn2 (HIER TYP=1 CFG=1 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 106 OF 455  ELAPSED TIME = 0
Layer a4_conn1 DELETED -- LVHEAP = 3/5/67
a4_conn = COPY a4_conn2
a4_conn (HIER TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 107 OF 455  ELAPSED TIME = 0
Layer a4_conn2 DELETED -- LVHEAP = 3/5/67
W4 = OR W4
W4 (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 108 OF 455  ELAPSED TIME = 0
Original Layer W4 DELETED -- LVHEAP = 3/5/67
W1_drc = W1 NOT DCTY_mark
W1_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 109 OF 455  ELAPSED TIME = 0
TB_drc = TB NOT DCTY_mark
TB_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 110 OF 455  ELAPSED TIME = 0
RFDUM_mark = OR RFDUM_mark
RFDUM_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 111 OF 455  ELAPSED TIME = 0
Original Layer RFDUM_mark DELETED -- LVHEAP = 3/5/67
TMP<29> = TB_drc INTERACT RFDUM_mark
TMP<29> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 112 OF 455  ELAPSED TIME = 0
ndiff_tb = ndiff INSIDE TB_drc
ndiff_tb (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 113 OF 455  ELAPSED TIME = 0
VARMOS_mark = OR VARMOS_mark
VARMOS_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 114 OF 455  ELAPSED TIME = 0
Original Layer VARMOS_mark DELETED -- LVHEAP = 3/5/67
var_ndiff = ndiff_tb INTERACT VARMOS_mark
var_ndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 115 OF 455  ELAPSED TIME = 0
Layer ndiff_tb DELETED -- LVHEAP = 3/5/67
vargate = var_ndiff AND GT_drc
vargate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 116 OF 455  ELAPSED TIME = 0
Layer var_ndiff DELETED -- LVHEAP = 3/5/67
HV = OR HV
HV (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 117 OF 455  ELAPSED TIME = 0
Original Layer HV DELETED -- LVHEAP = 3/5/67
HV_drc = HV NOT DCTY_mark
HV_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 118 OF 455  ELAPSED TIME = 0
var18 = vargate NOT HV_drc
var18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 119 OF 455  ELAPSED TIME = 0
var18_rf_rec = TMP<29> ENCLOSE var18
var18_rf_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 120 OF 455  ELAPSED TIME = 0
var18_rf_to = TO_drc INSIDE var18_rf_rec
var18_rf_to (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 121 OF 455  ELAPSED TIME = 0
var18_rf_gt = GT_drc NOT OUTSIDE var18_rf_to
var18_rf_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 122 OF 455  ELAPSED TIME = 0
var18_rf_gt_con = W1_drc AND var18_rf_gt
var18_rf_gt_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 123 OF 455  ELAPSED TIME = 0
var33 = vargate AND HV_drc
var33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 124 OF 455  ELAPSED TIME = 0
Layer vargate DELETED -- LVHEAP = 3/5/67
var33_rf_rec = TMP<29> ENCLOSE var33
var33_rf_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 125 OF 455  ELAPSED TIME = 0
Layer TMP<29> DELETED -- LVHEAP = 3/5/67
var33_rf_to = TO_drc INSIDE var33_rf_rec
var33_rf_to (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 126 OF 455  ELAPSED TIME = 0
var33_rf_gt = GT_drc NOT OUTSIDE var33_rf_to
var33_rf_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 127 OF 455  ELAPSED TIME = 0
var33_rf_gt_con = W1_drc AND var33_rf_gt
var33_rf_gt_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 128 OF 455  ELAPSED TIME = 0
w1_and_gt = GT_drc AND W1_drc
w1_and_gt (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 129 OF 455  ELAPSED TIME = 0
RES_PY_mark = OR RES_PY_mark
RES_PY_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 130 OF 455  ELAPSED TIME = 0
Original Layer RES_PY_mark DELETED -- LVHEAP = 3/5/67
gt_conn1 = GT_drc NOT RES_PY_mark
gt_conn1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 131 OF 455  ELAPSED TIME = 0
RES_HR_mark = OR RES_HR_mark
RES_HR_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 132 OF 455  ELAPSED TIME = 0
Original Layer RES_HR_mark DELETED -- LVHEAP = 3/5/67
TMP<1> = gt_conn1 NOT RES_HR_mark
TMP<1> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 133 OF 455  ELAPSED TIME = 0
Layer gt_conn1 DELETED -- LVHEAP = 3/5/67
TMP<2> = var18_rf_gt OR var33_rf_gt
TMP<2> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 134 OF 455  ELAPSED TIME = 0
gt_conn = TMP<1> NOT TMP<2>
gt_conn (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 135 OF 455  ELAPSED TIME = 0
Layer TMP<1> DELETED -- LVHEAP = 3/5/67
Layer TMP<2> DELETED -- LVHEAP = 3/5/67
w1_and_nsd = W1_drc AND nsd
w1_and_nsd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 136 OF 455  ELAPSED TIME = 0
w1_and_psd = W1_drc AND psd
w1_and_psd (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 137 OF 455  ELAPSED TIME = 0
Layer W1_drc DELETED -- LVHEAP = 3/5/67
ntap = TB_drc AND nsd
ntap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 138 OF 455  ELAPSED TIME = 0
RES_NW_mark = OR RES_NW_mark
RES_NW_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 139 OF 455  ELAPSED TIME = 0
Original Layer RES_NW_mark DELETED -- LVHEAP = 3/5/67
nwelcon = TB_drc NOT RES_NW_mark
nwelcon (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 140 OF 455  ELAPSED TIME = 0
RFDUM_g2 = OR RFDUM_g2
RFDUM_g2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 141 OF 455  ELAPSED TIME = 0
Original Layer RFDUM_g2 DELETED -- LVHEAP = 3/5/67
nmos_rf_s = nsd AND RFDUM_g2
nmos_rf_s (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 142 OF 455  ELAPSED TIME = 0
nmos_rf_s_con = nmos_rf_s AND nsd
nmos_rf_s_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 143 OF 455  ELAPSED TIME = 0
nmos_rf_d = nsd NOT RFDUM_g2
nmos_rf_d (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 144 OF 455  ELAPSED TIME = 0
nmos_rf_d_con = nmos_rf_d AND nsd
nmos_rf_d_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 145 OF 455  ELAPSED TIME = 0
pmos_rf_s = psd AND RFDUM_g2
pmos_rf_s (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 146 OF 455  ELAPSED TIME = 0
pmos_rf_s_con = psd AND pmos_rf_s
pmos_rf_s_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 147 OF 455  ELAPSED TIME = 0
pmos_rf_d = psd NOT RFDUM_g2
pmos_rf_d (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 148 OF 455  ELAPSED TIME = 0
pmos_rf_d_con = psd AND pmos_rf_d
pmos_rf_d_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 149 OF 455  ELAPSED TIME = 0
TMP<10> = pdiff NOT TB_drc
TMP<10> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 150 OF 455  ELAPSED TIME = 0
DN = OR DN
DN (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 151 OF 455  ELAPSED TIME = 0
Original Layer DN DELETED -- LVHEAP = 3/5/67
DN_drc = DN NOT DCTY_mark
DN_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 152 OF 455  ELAPSED TIME = 0
dn_hole = HOLES DN_drc
dn_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 153 OF 455  ELAPSED TIME = 0
dn_no_touch_hole = DN_drc NOT TOUCH dn_hole
dn_no_touch_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 154 OF 455  ELAPSED TIME = 0
Layer dn_hole DELETED -- LVHEAP = 3/5/67
dnwel_size01 = SIZE dn_no_touch_hole BY -0.005
dnwel_size01 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 155 OF 455  ELAPSED TIME = 0
TMP<19> = dn_no_touch_hole NOT dnwel_size01
TMP<19> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 156 OF 455  ELAPSED TIME = 0
Layer dn_no_touch_hole DELETED -- LVHEAP = 3/5/67
Layer dnwel_size01 DELETED -- LVHEAP = 3/5/67
DIODE_mark = OR DIODE_mark
DIODE_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 157 OF 455  ELAPSED TIME = 0
Original Layer DIODE_mark DELETED -- LVHEAP = 3/5/67
dnwel_ring = TMP<19> NOT INSIDE DIODE_mark
dnwel_ring (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 158 OF 455  ELAPSED TIME = 0
Layer TMP<19> DELETED -- LVHEAP = 3/5/67
dnwel_ptap = DN_drc NOT INTERACT dnwel_ring
dnwel_ptap (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 159 OF 455  ELAPSED TIME = 0
ptap = TMP<10> NOT dnwel_ptap
ptap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 160 OF 455  ELAPSED TIME = 0
Layer TMP<10> DELETED -- LVHEAP = 3/5/67
Layer dnwel_ptap DELETED -- LVHEAP = 3/5/67
bulk = EXTENT
bulk (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 161 OF 455  ELAPSED TIME = 0
psub_1 = bulk NOT dnwel_ring
psub_1 (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 162 OF 455  ELAPSED TIME = 0
Layer bulk DELETED -- LVHEAP = 3/5/67
Layer dnwel_ring DELETED -- LVHEAP = 3/5/67
PSUB2 = OR PSUB2
PSUB2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 163 OF 455  ELAPSED TIME = 1
Original Layer PSUB2 DELETED -- LVHEAP = 3/5/67
psub_size01 = SIZE PSUB2 BY 0.005
psub_size01 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 164 OF 455  ELAPSED TIME = 1
psub_cut = psub_size01 NOT PSUB2
psub_cut (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 165 OF 455  ELAPSED TIME = 1
Layer psub_size01 DELETED -- LVHEAP = 3/5/67
psub_2 = psub_1 NOT psub_cut
psub_2 (HIER-LSL TYP=1 CFG=0 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 166 OF 455  ELAPSED TIME = 1
Layer psub_1 DELETED -- LVHEAP = 3/5/67
Layer psub_cut DELETED -- LVHEAP = 3/5/67
BJT_mark = OR BJT_mark
BJT_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 167 OF 455  ELAPSED TIME = 1
Original Layer BJT_mark DELETED -- LVHEAP = 3/5/67
pdiff_bjt = BJT_mark AND pdiff
pdiff_bjt (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 168 OF 455  ELAPSED TIME = 1
nw_bjt = BJT_mark AND TB_drc
nw_bjt (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 169 OF 455  ELAPSED TIME = 1
qvp_e = pdiff_bjt INSIDE nw_bjt
qvp_e (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 170 OF 455  ELAPSED TIME = 1
psub = psub_2 NOT qvp_e
psub (HIER-LSL TYP=1 CFG=3 HGC=1 FGC=1 HEC=4 FEC=4 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 171 OF 455  ELAPSED TIME = 1
Layer psub_2 DELETED -- LVHEAP = 3/5/67
dn_nw = DN_drc INTERACT TB_drc
dn_nw (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 172 OF 455  ELAPSED TIME = 1
dn_tbtap = TB_drc AND dn_nw
dn_tbtap (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 173 OF 455  ELAPSED TIME = 1
qvp33_e = qvp_e AND HV_drc
qvp33_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 174 OF 455  ELAPSED TIME = 1
qvp33_b = nw_bjt ENCLOSE qvp33_e
qvp33_b (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 175 OF 455  ELAPSED TIME = 1
qvp33B_con = qvp33_b AND ntap
qvp33B_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 176 OF 455  ELAPSED TIME = 1
qvp18_e = qvp_e NOT HV_drc
qvp18_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 177 OF 455  ELAPSED TIME = 1
Layer qvp_e DELETED -- LVHEAP = 3/5/67
qvp18_b = nw_bjt ENCLOSE qvp18_e
qvp18_b (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 178 OF 455  ELAPSED TIME = 1
Layer nw_bjt DELETED -- LVHEAP = 3/5/67
qvp18B_con = qvp18_b AND ntap
qvp18B_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 179 OF 455  ELAPSED TIME = 1
qvp33E_con = pdiff_bjt AND qvp33_e
qvp33E_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 180 OF 455  ELAPSED TIME = 1
qvp18E_con = pdiff_bjt AND qvp18_e
qvp18E_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 181 OF 455  ELAPSED TIME = 1
Layer pdiff_bjt DELETED -- LVHEAP = 3/5/67
ndiff_bjt = BJT_mark AND ndiff
ndiff_bjt (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 182 OF 455  ELAPSED TIME = 1
nw_Hole = HOLES TB_drc INNER
nw_Hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 183 OF 455  ELAPSED TIME = 1
dn_enc_nwHole = DN_drc ENCLOSE nw_Hole
dn_enc_nwHole (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 184 OF 455  ELAPSED TIME = 1
nwHole_dn = dn_enc_nwHole AND nw_Hole
nwHole_dn (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 185 OF 455  ELAPSED TIME = 1
Layer dn_enc_nwHole DELETED -- LVHEAP = 3/5/67
Layer nw_Hole DELETED -- LVHEAP = 3/5/67
vnpn_e = ndiff_bjt AND nwHole_dn
vnpn_e (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 186 OF 455  ELAPSED TIME = 1
Layer nwHole_dn DELETED -- LVHEAP = 3/5/67
vnpnE_con = ndiff_bjt AND vnpn_e
vnpnE_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 187 OF 455  ELAPSED TIME = 1
Layer ndiff_bjt DELETED -- LVHEAP = 3/5/67
resnw = TB_drc AND RES_NW_mark
resnw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 188 OF 455  ELAPSED TIME = 1
SI = OR SI
SI (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 189 OF 455  ELAPSED TIME = 1
Original Layer SI DELETED -- LVHEAP = 3/5/67
SI_drc = SI NOT DCTY_mark
SI_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 190 OF 455  ELAPSED TIME = 1
resnw_nosab = resnw OUTSIDE SI_drc
resnw_nosab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 191 OF 455  ELAPSED TIME = 1
Layer resnw DELETED -- LVHEAP = 3/5/67
RNDMY = OR RNDMY
RNDMY (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 192 OF 455  ELAPSED TIME = 1
Original Layer RNDMY DELETED -- LVHEAP = 3/5/67
rnw_rec = resnw_nosab NOT RNDMY
rnw_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 193 OF 455  ELAPSED TIME = 1
Layer resnw_nosab DELETED -- LVHEAP = 3/5/67
nwellRes_term = nwelcon TOUCH rnw_rec
nwellRes_term (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 194 OF 455  ELAPSED TIME = 1
nwResTerm_con = nwelcon AND nwellRes_term
nwResTerm_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 195 OF 455  ELAPSED TIME = 1
tb_in_to = TB_drc INSIDE TO_drc
tb_in_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 196 OF 455  ELAPSED TIME = 1
tb_to_res = tb_in_to AND RES_NW_mark
tb_to_res (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 197 OF 455  ELAPSED TIME = 1
Layer tb_in_to DELETED -- LVHEAP = 3/5/67
tb_to_sab_res = tb_to_res AND SI_drc
tb_to_sab_res (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 198 OF 455  ELAPSED TIME = 1
Layer tb_to_res DELETED -- LVHEAP = 3/5/67
rnw_sab = tb_to_sab_res AND RNDMY
rnw_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 199 OF 455  ELAPSED TIME = 1
Layer tb_to_sab_res DELETED -- LVHEAP = 3/5/67
rnw_sab_term = nwelcon TOUCH rnw_sab
rnw_sab_term (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 200 OF 455  ELAPSED TIME = 1
rnwsabTerm_con = nwelcon AND rnw_sab_term
rnwsabTerm_con (HIER TYP=1 CFG=3 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  OPS COMPLETE = 201 OF 455  ELAPSED TIME = 1
CONNECTIVITY EXTRACTION TOTAL LAYER PREPARATION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
NC = Net Count  IPC = Internal Pin Count
CEC = Cell Edge Count  PEC = Promoted Edge Count
LVHEAP = Geometry heap memory allocation.
MALLOC = Total heap memory allocation.
CELL cmim_test
     cmim_test (NC=40 IPC=0 CEC=80 PEC=0 CFGC=40)
     cmim_test  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
TOTAL CEC=80 PEC=0
POST-PROCESSING CONNECTIVITY DATA STRUCTURE...
    MARKING TRUE NETS AND EXTERNAL PINS...
    DISCARDING FALSE VIRTUAL NETS, RESOLVING DEEP SHORTS AND PERFORMING VIRTUAL CONNECTIONS...
    CREATING COMPACT PIN DATA STRUCTURE...
    FINALIZING NODE NUMBERS ON SCONNECT LAYERS...
    RESOLVING SHORT CIRCUIT TEXT...
    PROCESSING HIGH SHORTS...
    COMPUTING FINAL NET NAMES AND REPORTING TEXT WARNINGS...
    PROCESSING LINK OPTIONS OF SCONNECT STATEMENTS...
POST-PROCESSING completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34
CONNECTIVITY EXTRACTION completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34 ELAPSED TIME = 1
WRITING CELL INFORMATION to PHDB svdb
PHDB CELL DATA WRITE completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 34/34/34  ELAPSED TIME = 1
WRITING CONNECT INFORMATION to PHDB svdb
PHDB CONNECT INFORMATION written. CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/5/67  MALLOC = 35/35/35  ELAPSED TIME = 1
Layer lvpsb DELETED -- LVHEAP = 3/5/67
Layer lvnsb DELETED -- LVHEAP = 3/5/67
Layer wtmct DELETED -- LVHEAP = 3/5/67
Layer wtcon DELETED -- LVHEAP = 3/5/67
Layer var18_rf_gt_con DELETED -- LVHEAP = 3/5/67
Layer var33_rf_gt_con DELETED -- LVHEAP = 3/5/67
Layer w1_and_gt DELETED -- LVHEAP = 3/5/67
Layer w1_and_nsd DELETED -- LVHEAP = 3/5/67
Layer w1_and_psd DELETED -- LVHEAP = 3/5/67
DEVICE RECOGNITION
LVS PUSH DEVICES enabled.
MCTM5 = OR MCTM5
MCTM5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 202 OF 455  ELAPSED TIME = 1
Original Layer MCTM5 DELETED -- LVHEAP = 4/5/67
mct5 = mctcap AND MCTM5
mct5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 203 OF 455  ELAPSED TIME = 1
mimcap5x = mct5 AND A5_drc
mimcap5x (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 204 OF 455  ELAPSED TIME = 1
Layer mct5 DELETED -- LVHEAP = 4/5/67
mimcap5 = mimcap5x NOT RFDUM_mark
mimcap5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 205 OF 455  ELAPSED TIME = 1
var33a = var33 NOT RFDUM_mark
var33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 206 OF 455  ELAPSED TIME = 1
var33_mix = VARMOS_mark ENCLOSE var33a
var33_mix (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 207 OF 455  ELAPSED TIME = 1
var18a = var18 NOT RFDUM_mark
var18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 208 OF 455  ELAPSED TIME = 1
var18_mix = VARMOS_mark ENCLOSE var18a
var18_mix (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 209 OF 455  ELAPSED TIME = 1
Layer VARMOS_mark DELETED -- LVHEAP = 4/5/67
ngate = GT_drc AND ndiff
ngate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 210 OF 455  ELAPSED TIME = 1
mosngate = ngate OUTSIDE TB_drc
mosngate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 211 OF 455  ELAPSED TIME = 1
Layer ngate DELETED -- LVHEAP = 4/5/67
ngate33 = mosngate AND HV_drc
ngate33 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 212 OF 455  ELAPSED TIME = 1
ngate18 = mosngate NOT ngate33
ngate18 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 213 OF 455  ELAPSED TIME = 1
PWB = OR PWB
PWB (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 214 OF 455  ELAPSED TIME = 1
Original Layer PWB DELETED -- LVHEAP = 4/5/67
PWB_drc = PWB NOT DCTY_mark
PWB_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 215 OF 455  ELAPSED TIME = 1
nngate18 = ngate18 AND PWB_drc
nngate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 216 OF 455  ELAPSED TIME = 1
nngate33 = ngate33 AND PWB_drc
nngate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 217 OF 455  ELAPSED TIME = 1
MN = OR MN
MN (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 218 OF 455  ELAPSED TIME = 1
Original Layer MN DELETED -- LVHEAP = 4/5/67
MN_drc = MN NOT DCTY_mark
MN_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 219 OF 455  ELAPSED TIME = 1
nmgate18 = ngate18 AND MN_drc
nmgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 220 OF 455  ELAPSED TIME = 1
nmgate33 = ngate33 AND MN_drc
nmgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 221 OF 455  ELAPSED TIME = 1
pgate = GT_drc AND pdiff
pgate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 222 OF 455  ELAPSED TIME = 1
mospgate = pgate INSIDE TB_drc
mospgate (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 223 OF 455  ELAPSED TIME = 1
pgate33 = mospgate AND HV_drc
pgate33 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 224 OF 455  ELAPSED TIME = 1
pgate18 = mospgate NOT pgate33
pgate18 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 225 OF 455  ELAPSED TIME = 1
MP = OR MP
MP (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 226 OF 455  ELAPSED TIME = 1
Original Layer MP DELETED -- LVHEAP = 4/5/67
MP_drc = MP NOT DCTY_mark
MP_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 227 OF 455  ELAPSED TIME = 1
pmgate18 = pgate18 AND MP_drc
pmgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 228 OF 455  ELAPSED TIME = 1
pmgate33 = pgate33 AND MP_drc
pmgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 229 OF 455  ELAPSED TIME = 1
PD = OR PD
PD (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 230 OF 455  ELAPSED TIME = 1
Original Layer PD DELETED -- LVHEAP = 4/5/67
PD_drc = PD NOT DCTY_mark
PD_drc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 231 OF 455  ELAPSED TIME = 1
pdgate = pgate AND PD_drc
pdgate (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 232 OF 455  ELAPSED TIME = 1
Layer pgate DELETED -- LVHEAP = 4/5/67
ESD_mark = OR ESD_mark
ESD_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 233 OF 455  ELAPSED TIME = 1
Original Layer ESD_mark DELETED -- LVHEAP = 4/5/67
esd_to = TO_drc AND ESD_mark
esd_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 234 OF 455  ELAPSED TIME = 1
Layer TO_drc DELETED -- LVHEAP = 4/5/67
SE = OR SE
SE (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 235 OF 455  ELAPSED TIME = 1
Original Layer SE DELETED -- LVHEAP = 4/5/67
SE_drc = SE NOT DCTY_mark
SE_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 236 OF 455  ELAPSED TIME = 1
nesd_to = esd_to AND SE_drc
nesd_to (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 237 OF 455  ELAPSED TIME = 1
esdnmos = ngate33 AND nesd_to
esdnmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 238 OF 455  ELAPSED TIME = 1
esdlvnmos = ngate18 AND nesd_to
esdlvnmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 239 OF 455  ELAPSED TIME = 1
Layer nesd_to DELETED -- LVHEAP = 4/5/67
esdpmos = pgate33 AND esd_to
esdpmos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 240 OF 455  ELAPSED TIME = 1
Layer esd_to DELETED -- LVHEAP = 4/5/67
VTSRAM_mark = OR VTSRAM_mark
VTSRAM_mark (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 241 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_mark DELETED -- LVHEAP = 4/5/67
nsram = mosngate AND VTSRAM_mark
nsram (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 242 OF 455  ELAPSED TIME = 1
mn_acess = AREA nsram > 0.054 <= 0.056
mn_pudn = AREA nsram > 0.052 <= 0.053
mn_acess (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 244 OF 455  ELAPSED TIME = 1
Layer nsram DELETED -- LVHEAP = 4/5/67
VTSRAM_gc2 = OR VTSRAM_gc2
VTSRAM_gc2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 245 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_gc2 DELETED -- LVHEAP = 4/5/67
nsram_gc2 = mosngate AND VTSRAM_gc2
nsram_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 246 OF 455  ELAPSED TIME = 1
mn_acess_gc2 = AREA nsram_gc2 > 0.054 <= 0.056
mn_pudn_gc2 = AREA nsram_gc2 > 0.052 <= 0.053
mn_acess_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 248 OF 455  ELAPSED TIME = 1
Layer nsram_gc2 DELETED -- LVHEAP = 4/5/67
VTSRAM_gc3 = OR VTSRAM_gc3
VTSRAM_gc3 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 249 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_gc3 DELETED -- LVHEAP = 4/5/67
nsram_gc3 = mosngate AND VTSRAM_gc3
nsram_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 250 OF 455  ELAPSED TIME = 1
mn_acess_gc3 = AREA nsram_gc3 > 0.054 <= 0.056
mn_pudn_gc3 = AREA nsram_gc3 > 0.059 <= 0.06
mn_acess_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 252 OF 455  ELAPSED TIME = 1
Layer nsram_gc3 DELETED -- LVHEAP = 4/5/67
VTSRAM_l = OR VTSRAM_l
VTSRAM_l (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 253 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_l DELETED -- LVHEAP = 4/5/67
nsram_l = mosngate AND VTSRAM_l
nsram_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 254 OF 455  ELAPSED TIME = 1
mn_acess_l = AREA nsram_l > 0.0774 <= 0.0776
mn_pudn_l = AREA nsram_l > 0.0721 <= 0.0723
mn_acess_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 256 OF 455  ELAPSED TIME = 1
Layer nsram_l DELETED -- LVHEAP = 4/5/67
VTSRAM_lc = OR VTSRAM_lc
VTSRAM_lc (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 257 OF 455  ELAPSED TIME = 1
Original Layer VTSRAM_lc DELETED -- LVHEAP = 4/5/67
nsram_lc = mosngate AND VTSRAM_lc
nsram_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 258 OF 455  ELAPSED TIME = 1
Layer mosngate DELETED -- LVHEAP = 4/5/67
mn_acess_lc = AREA nsram_lc > 0.0774 <= 0.0776
mn_pudn_lc = AREA nsram_lc > 0.0721 <= 0.0723
mn_acess_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
mn_pudn_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 260 OF 455  ELAPSED TIME = 1
Layer nsram_lc DELETED -- LVHEAP = 4/5/67
mp_puup = mospgate AND VTSRAM_mark
mp_puup (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 261 OF 455  ELAPSED TIME = 1
mp_puup_gc2 = mospgate AND VTSRAM_gc2
mp_puup_gc2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 262 OF 455  ELAPSED TIME = 1
mp_puup_gc3 = mospgate AND VTSRAM_gc3
mp_puup_gc3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 263 OF 455  ELAPSED TIME = 1
mp_puup_l = mospgate AND VTSRAM_l
mp_puup_l (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 264 OF 455  ELAPSED TIME = 1
mp_puup_lc = mospgate AND VTSRAM_lc
mp_puup_lc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 265 OF 455  ELAPSED TIME = 1
Layer mospgate DELETED -- LVHEAP = 4/5/67
TMP<9> = PWB_drc OR MN_drc
TMP<9> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 266 OF 455  ELAPSED TIME = 1
Layer PWB_drc DELETED -- LVHEAP = 4/5/67
Layer MN_drc DELETED -- LVHEAP = 4/5/67
TMP<8> = TMP<9> OR MP_drc
TMP<8> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 267 OF 455  ELAPSED TIME = 1
Layer TMP<9> DELETED -- LVHEAP = 4/5/67
Layer MP_drc DELETED -- LVHEAP = 4/5/67
TMP<7> = TMP<8> OR PD_drc
TMP<7> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 268 OF 455  ELAPSED TIME = 1
Layer TMP<8> DELETED -- LVHEAP = 4/5/67
Layer PD_drc DELETED -- LVHEAP = 4/5/67
TMP<6> = TMP<7> OR VTSRAM_mark
TMP<6> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 269 OF 455  ELAPSED TIME = 1
Layer TMP<7> DELETED -- LVHEAP = 4/5/67
TMP<5> = TMP<6> OR VTSRAM_gc2
TMP<5> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 270 OF 455  ELAPSED TIME = 1
Layer TMP<6> DELETED -- LVHEAP = 4/5/67
TMP<4> = TMP<5> OR VTSRAM_gc3
TMP<4> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 271 OF 455  ELAPSED TIME = 1
Layer TMP<5> DELETED -- LVHEAP = 4/5/67
TMP<3> = TMP<4> OR VTSRAM_l
TMP<3> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 272 OF 455  ELAPSED TIME = 1
Layer TMP<4> DELETED -- LVHEAP = 4/5/67
nonom_5 = TMP<3> OR VTSRAM_lc
nonom_5 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 273 OF 455  ELAPSED TIME = 1
Layer TMP<3> DELETED -- LVHEAP = 4/5/67
ngate18a = ngate18 NOT nonom_5
ngate18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 274 OF 455  ELAPSED TIME = 1
Layer ngate18 DELETED -- LVHEAP = 4/5/67
ntgate18 = ngate18a NOT RFDUM_mark
ntgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 275 OF 455  ELAPSED TIME = 1
nonom_6 = ESD_mark OR nonom_5
nonom_6 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 276 OF 455  ELAPSED TIME = 1
ngate33a = ngate33 NOT nonom_6
ngate33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 277 OF 455  ELAPSED TIME = 1
Layer ngate33 DELETED -- LVHEAP = 4/5/67
ntgate33 = ngate33a NOT RFDUM_mark
ntgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 278 OF 455  ELAPSED TIME = 1
pgate18a = pgate18 NOT nonom_5
pgate18a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 279 OF 455  ELAPSED TIME = 1
Layer pgate18 DELETED -- LVHEAP = 4/5/67
Layer nonom_5 DELETED -- LVHEAP = 4/5/67
ptgate18 = pgate18a NOT RFDUM_mark
ptgate18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 280 OF 455  ELAPSED TIME = 1
pgate33a = pgate33 NOT nonom_6
pgate33a (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 281 OF 455  ELAPSED TIME = 1
Layer pgate33 DELETED -- LVHEAP = 4/5/67
Layer nonom_6 DELETED -- LVHEAP = 4/5/67
ptgate33 = pgate33a NOT RFDUM_mark
ptgate33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 282 OF 455  ELAPSED TIME = 1
v1Rec = RECTANGLE qvp33_e == 2 BY == 2
v2Rec = RECTANGLE qvp33_e == 5 BY == 5
v3Rec = RECTANGLE qvp33_e == 10 BY == 10
v1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
v2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
v3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 285 OF 455  ELAPSED TIME = 1
p1Rec = RECTANGLE qvp18_e == 2 BY == 2
p2Rec = RECTANGLE qvp18_e == 5 BY == 5
p3Rec = RECTANGLE qvp18_e == 10 BY == 10
p1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
p2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
p3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 288 OF 455  ELAPSED TIME = 1
TMP<14> = vnpn_e NOT HV_drc
TMP<14> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 289 OF 455  ELAPSED TIME = 1
n4Rec = RECTANGLE TMP<14> == 0.6 BY == 0.6
n1Rec = RECTANGLE TMP<14> == 2 BY == 2
n2Rec = RECTANGLE TMP<14> == 5 BY == 5
n3Rec = RECTANGLE TMP<14> == 10 BY == 10
n4Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
n3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 293 OF 455  ELAPSED TIME = 1
Layer TMP<14> DELETED -- LVHEAP = 4/5/67
TMP<18> = vnpn_e AND HV_drc
TMP<18> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 294 OF 455  ELAPSED TIME = 1
h4Rec = RECTANGLE TMP<18> == 0.6 BY == 0.6
h1Rec = RECTANGLE TMP<18> == 2 BY == 2
h2Rec = RECTANGLE TMP<18> == 5 BY == 5
h3Rec = RECTANGLE TMP<18> == 10 BY == 10
h4Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h1Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h2Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
h3Rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 298 OF 455  ELAPSED TIME = 1
Layer TMP<18> DELETED -- LVHEAP = 4/5/67
esdndiff = ndiff AND SE_drc
esdndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 299 OF 455  ELAPSED TIME = 1
dioesd = esdndiff AND DIODE_mark
dioesd (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 300 OF 455  ELAPSED TIME = 1
Layer esdndiff DELETED -- LVHEAP = 4/5/67
dnpwesd = dioesd NOT INTERACT nwelcon
dnpwesd (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 301 OF 455  ELAPSED TIME = 1
Layer dioesd DELETED -- LVHEAP = 4/5/67
ndiff_dio = ndiff AND DIODE_mark
ndiff_dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 302 OF 455  ELAPSED TIME = 1
ndiff_dio_no_esd = ndiff_dio NOT INTERACT SE_drc
ndiff_dio_no_esd (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 303 OF 455  ELAPSED TIME = 1
Layer SE_drc DELETED -- LVHEAP = 4/5/67
dnpw = ndiff_dio_no_esd NOT nwelcon
dnpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 304 OF 455  ELAPSED TIME = 1
Layer ndiff_dio_no_esd DELETED -- LVHEAP = 4/5/67
dnpw33 = dnpw AND HV_drc
dnpw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 305 OF 455  ELAPSED TIME = 1
dnpw18 = dnpw OUTSIDE HV_drc
dnpw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 306 OF 455  ELAPSED TIME = 1
Layer dnpw DELETED -- LVHEAP = 4/5/67
dnwdio = TB_drc ENCLOSE ndiff_dio
dnwdio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 307 OF 455  ELAPSED TIME = 1
Layer ndiff_dio DELETED -- LVHEAP = 4/5/67
dnwpw = dnwdio NOT INTERACT DN_drc
dnwpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 308 OF 455  ELAPSED TIME = 1
Layer dnwdio DELETED -- LVHEAP = 4/5/67
dnwpw33 = dnwpw AND HV_drc
dnwpw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 309 OF 455  ELAPSED TIME = 1
dnwpw18 = dnwpw OUTSIDE HV_drc
dnwpw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 310 OF 455  ELAPSED TIME = 1
Layer dnwpw DELETED -- LVHEAP = 4/5/67
pdiff_dio = pdiff AND DIODE_mark
pdiff_dio (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 311 OF 455  ELAPSED TIME = 1
dpnw = pdiff_dio AND nwelcon
dpnw (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 312 OF 455  ELAPSED TIME = 1
Layer pdiff_dio DELETED -- LVHEAP = 4/5/67
dpnw33 = dpnw AND HV_drc
dpnw33 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 313 OF 455  ELAPSED TIME = 1
dpnw18 = dpnw NOT HV_drc
dpnw18 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 314 OF 455  ELAPSED TIME = 1
Layer dpnw DELETED -- LVHEAP = 4/5/67
dnndiff = DN_drc ENCLOSE ndiff
dnndiff (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 315 OF 455  ELAPSED TIME = 1
Layer DN_drc DELETED -- LVHEAP = 4/5/67
ddepdio = dnndiff AND DIODE_mark
ddepdio (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 316 OF 455  ELAPSED TIME = 1
Layer dnndiff DELETED -- LVHEAP = 4/5/67
Layer DIODE_mark DELETED -- LVHEAP = 4/5/67
ddnwpw = ddepdio AND TB_drc
ddnwpw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 317 OF 455  ELAPSED TIME = 1
Layer ddepdio DELETED -- LVHEAP = 4/5/67
Layer TB_drc DELETED -- LVHEAP = 4/5/67
m1_res = A1_drc AND RES_M1
m1_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 318 OF 455  ELAPSED TIME = 1
Layer A1_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M1 DELETED -- LVHEAP = 4/5/67
m2_res = A2_drc AND RES_M2
m2_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 319 OF 455  ELAPSED TIME = 1
Layer A2_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M2 DELETED -- LVHEAP = 4/5/67
m3_res = A3_drc AND RES_M3
m3_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 320 OF 455  ELAPSED TIME = 1
Layer A3_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M3 DELETED -- LVHEAP = 4/5/67
m4_res = A4_drc AND RES_M4
m4_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 321 OF 455  ELAPSED TIME = 1
Layer A4_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M4 DELETED -- LVHEAP = 4/5/67
m5_res = A5_drc AND RES_M5
m5_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 322 OF 455  ELAPSED TIME = 1
Layer A5_drc DELETED -- LVHEAP = 4/5/67
Layer RES_M5 DELETED -- LVHEAP = 4/5/67
tt_res = MTT_drc AND RES_MT
tt_res (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 323 OF 455  ELAPSED TIME = 1
Layer MTT_drc DELETED -- LVHEAP = 4/5/67
Layer RES_MT DELETED -- LVHEAP = 4/5/67
RES_3T_mark = OR RES_3T_mark
RES_3T_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 324 OF 455  ELAPSED TIME = 1
Original Layer RES_3T_mark DELETED -- LVHEAP = 4/5/67
rnw_rec_2t = rnw_rec OUTSIDE RES_3T_mark
rnw_rec_3t = rnw_rec NOT OUTSIDE RES_3T_mark
rnw_rec_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnw_rec_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 326 OF 455  ELAPSED TIME = 1
Layer rnw_rec DELETED -- LVHEAP = 4/5/67
rnw_sab_2t = rnw_sab OUTSIDE RES_3T_mark
rnw_sab_3t = rnw_sab NOT OUTSIDE RES_3T_mark
rnw_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnw_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 328 OF 455  ELAPSED TIME = 1
Layer rnw_sab DELETED -- LVHEAP = 4/5/67
rndiff = ndiff AND RES_TO_mark
rndiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 329 OF 455  ELAPSED TIME = 1
Layer ndiff DELETED -- LVHEAP = 4/5/67
rndiff_nsab1 = rndiff OUTSIDE SI_drc
rndiff_sab1 = rndiff NOT OUTSIDE SI_drc
rndiff_nsab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rndiff_sab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 331 OF 455  ELAPSED TIME = 1
Layer rndiff DELETED -- LVHEAP = 4/5/67
rndiff_sab2 = rndiff_sab1 AND RNDMY
rndiff_sab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 332 OF 455  ELAPSED TIME = 1
Layer rndiff_sab1 DELETED -- LVHEAP = 4/5/67
rndiff_sab3 = rndiff_sab2 OUTSIDE RES_3T_mark
rnimp_sab_3t = rndiff_sab2 NOT OUTSIDE RES_3T_mark
rndiff_sab3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnimp_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 334 OF 455  ELAPSED TIME = 1
rnimp_sab_2t = rndiff_sab3 OUTSIDE RFDUM_mark
rnimp_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 335 OF 455  ELAPSED TIME = 1
Layer rndiff_sab3 DELETED -- LVHEAP = 4/5/67
rndiff_nsab2 = rndiff_nsab1 NOT RNDMY
rndiff_nsab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 336 OF 455  ELAPSED TIME = 1
Layer rndiff_nsab1 DELETED -- LVHEAP = 4/5/67
rnimp_2t = rndiff_nsab2 OUTSIDE RES_3T_mark
rnimp_3t = rndiff_nsab2 NOT OUTSIDE RES_3T_mark
rnimp_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnimp_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 338 OF 455  ELAPSED TIME = 1
Layer rndiff_nsab2 DELETED -- LVHEAP = 4/5/67
rpdiff = pdiff AND RES_TO_mark
rpdiff (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 339 OF 455  ELAPSED TIME = 1
Layer pdiff DELETED -- LVHEAP = 4/5/67
Layer RES_TO_mark DELETED -- LVHEAP = 4/5/67
rpdiff_nsab1 = rpdiff OUTSIDE SI_drc
rpdiff_sab1 = rpdiff NOT OUTSIDE SI_drc
rpdiff_nsab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpdiff_sab1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 341 OF 455  ELAPSED TIME = 1
Layer rpdiff DELETED -- LVHEAP = 4/5/67
RPDMY = OR RPDMY
RPDMY (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 342 OF 455  ELAPSED TIME = 1
Original Layer RPDMY DELETED -- LVHEAP = 4/5/67
rpdiff_sab2 = rpdiff_sab1 AND RPDMY
rpdiff_sab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 343 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab1 DELETED -- LVHEAP = 4/5/67
rpdiff_sab3 = rpdiff_sab2 OUTSIDE RES_3T_mark
rpimp_sab_3t = rpdiff_sab2 NOT OUTSIDE RES_3T_mark
rpdiff_sab3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpimp_sab_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 345 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab2 DELETED -- LVHEAP = 4/5/67
rpimp_sab_2t = rpdiff_sab3 OUTSIDE RFDUM_mark
rpimp_sab_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 346 OF 455  ELAPSED TIME = 1
Layer rpdiff_sab3 DELETED -- LVHEAP = 4/5/67
rpdiff_nsab2 = rpdiff_nsab1 NOT RPDMY
rpdiff_nsab2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 347 OF 455  ELAPSED TIME = 1
Layer rpdiff_nsab1 DELETED -- LVHEAP = 4/5/67
rpimp_2t = rpdiff_nsab2 OUTSIDE RES_3T_mark
rpimp_3t = rpdiff_nsab2 NOT OUTSIDE RES_3T_mark
rpimp_2t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpimp_3t (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 349 OF 455  ELAPSED TIME = 1
Layer rpdiff_nsab2 DELETED -- LVHEAP = 4/5/67
ndifpoly = GT_drc INSIDE SN_drc
ndifpoly (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 350 OF 455  ELAPSED TIME = 1
Layer SN_drc DELETED -- LVHEAP = 4/5/67
rndifpoly = ndifpoly AND RES_PY_mark
rndifpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 351 OF 455  ELAPSED TIME = 1
Layer ndifpoly DELETED -- LVHEAP = 4/5/67
rndifpoly_sab_o = rndifpoly OUTSIDE SI_drc
rndifpoly_sab = rndifpoly NOT OUTSIDE SI_drc
rndifpoly_sab_o (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rndifpoly_sab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 353 OF 455  ELAPSED TIME = 1
Layer rndifpoly DELETED -- LVHEAP = 4/5/67
rnpoly_sab1 = rndifpoly_sab AND RNDMY
rnpoly_sab1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 354 OF 455  ELAPSED TIME = 1
Layer rndifpoly_sab DELETED -- LVHEAP = 4/5/67
TMP<22> = rnpoly_sab1 INTERACT RFDUM_mark
rnpoly_sab = rnpoly_sab1 NOT INTERACT RFDUM_mark
TMP<22> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rnpoly_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 356 OF 455  ELAPSED TIME = 1
Layer rnpoly_sab1 DELETED -- LVHEAP = 4/5/67
rnpoly = rndifpoly_sab_o NOT RNDMY
rnpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 357 OF 455  ELAPSED TIME = 1
Layer rndifpoly_sab_o DELETED -- LVHEAP = 4/5/67
Layer RNDMY DELETED -- LVHEAP = 4/5/67
pdifpoly = GT_drc INSIDE SP_drc
sp2poly = GT_drc CUT SP_drc
pdifpoly (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
sp2poly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 359 OF 455  ELAPSED TIME = 1
Layer GT_drc DELETED -- LVHEAP = 4/5/67
Layer SP_drc DELETED -- LVHEAP = 4/5/67
rpdifpoly = pdifpoly AND RES_PY_mark
rpdifpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 360 OF 455  ELAPSED TIME = 1
Layer pdifpoly DELETED -- LVHEAP = 4/5/67
Layer RES_PY_mark DELETED -- LVHEAP = 4/5/67
rpdifpoly_sab_o = rpdifpoly OUTSIDE SI_drc
rpdifpoly_sab = rpdifpoly NOT OUTSIDE SI_drc
rpdifpoly_sab_o (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rpdifpoly_sab (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 362 OF 455  ELAPSED TIME = 1
Layer rpdifpoly DELETED -- LVHEAP = 4/5/67
rppoly_sab1 = rpdifpoly_sab AND RPDMY
rppoly_sab1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 363 OF 455  ELAPSED TIME = 1
Layer rpdifpoly_sab DELETED -- LVHEAP = 4/5/67
TMP<23> = rppoly_sab1 INTERACT RFDUM_mark
rppoly_sab = rppoly_sab1 NOT INTERACT RFDUM_mark
TMP<23> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rppoly_sab (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 365 OF 455  ELAPSED TIME = 1
Layer rppoly_sab1 DELETED -- LVHEAP = 4/5/67
TMP<21> = rpdifpoly_sab_o NOT RPDMY
TMP<21> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 366 OF 455  ELAPSED TIME = 1
Layer rpdifpoly_sab_o DELETED -- LVHEAP = 4/5/67
rppoly_rf = TMP<21> INTERACT RFDUM_mark
rppoly = TMP<21> NOT INTERACT RFDUM_mark
rppoly_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
rppoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 368 OF 455  ELAPSED TIME = 1
Layer TMP<21> DELETED -- LVHEAP = 4/5/67
sipoly = sp2poly INTERACT SI_drc
sipoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 369 OF 455  ELAPSED TIME = 1
Layer sp2poly DELETED -- LVHEAP = 4/5/67
Layer SI_drc DELETED -- LVHEAP = 4/5/67
HR = OR HR
HR (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 370 OF 455  ELAPSED TIME = 1
Original Layer HR DELETED -- LVHEAP = 4/5/67
HR_drc = HR NOT DCTY_mark
HR_drc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 371 OF 455  ELAPSED TIME = 1
Layer DCTY_mark DELETED -- LVHEAP = 4/5/67
hrpoly1 = sipoly NOT OUTSIDE HR_drc
hrpoly1 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 372 OF 455  ELAPSED TIME = 1
Layer sipoly DELETED -- LVHEAP = 4/5/67
Layer HR_drc DELETED -- LVHEAP = 4/5/67
hrpoly2 = hrpoly1 AND RES_HR_mark
hrpoly2 (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 373 OF 455  ELAPSED TIME = 1
Layer hrpoly1 DELETED -- LVHEAP = 4/5/67
Layer RES_HR_mark DELETED -- LVHEAP = 4/5/67
hrpoly3 = hrpoly2 AND RPDMY
hrpoly3 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 374 OF 455  ELAPSED TIME = 1
Layer hrpoly2 DELETED -- LVHEAP = 4/5/67
hrpoly_rf = hrpoly3 INTERACT RFDUM_mark
hrpoly = hrpoly3 NOT INTERACT RFDUM_mark
hrpoly_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
hrpoly (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 376 OF 455  ELAPSED TIME = 1
Layer hrpoly3 DELETED -- LVHEAP = 4/5/67
ngate18_rf = RFDUM_mark ENCLOSE ngate18a
ngate18_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 377 OF 455  ELAPSED TIME = 1
ngate33_rf = RFDUM_mark ENCLOSE ngate33a
ngate33_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 378 OF 455  ELAPSED TIME = 1
pgate18_rf = RFDUM_mark ENCLOSE pgate18a
pgate18_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 379 OF 455  ELAPSED TIME = 1
pgate33_rf = RFDUM_mark ENCLOSE pgate33a
pgate33_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 380 OF 455  ELAPSED TIME = 1
rnpsab_rf = TMP<22> AND nwelcon
rnpsab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 381 OF 455  ELAPSED TIME = 1
Layer TMP<22> DELETED -- LVHEAP = 4/5/67
rppsab_rf = TMP<23> AND nwelcon
rppsab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 382 OF 455  ELAPSED TIME = 1
Layer TMP<23> DELETED -- LVHEAP = 4/5/67
rnisab_rf = rndiff_sab2 INTERACT RFDUM_mark
rnisab_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 383 OF 455  ELAPSED TIME = 1
Layer rndiff_sab2 DELETED -- LVHEAP = 4/5/67
VARJUN_mark = OR VARJUN_mark
VARJUN_mark (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 384 OF 455  ELAPSED TIME = 1
Original Layer VARJUN_mark DELETED -- LVHEAP = 4/5/67
jvarnw = nwelcon AND VARJUN_mark
jvarnw (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 385 OF 455  ELAPSED TIME = 1
TMP<25> = jvarnw INTERACT psd
TMP<25> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 386 OF 455  ELAPSED TIME = 1
Layer jvarnw DELETED -- LVHEAP = 4/5/67
TMP<24> = TMP<25> INTERACT nsd
TMP<24> (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 387 OF 455  ELAPSED TIME = 1
Layer TMP<25> DELETED -- LVHEAP = 4/5/67
jvarreg = TMP<24> AND psd
jvarreg (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 388 OF 455  ELAPSED TIME = 1
Layer TMP<24> DELETED -- LVHEAP = 4/5/67
TMP<26> = jvarreg AND HV_drc
TMP<26> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 389 OF 455  ELAPSED TIME = 1
Layer HV_drc DELETED -- LVHEAP = 4/5/67
jpvar33dio = VARJUN_mark ENCLOSE TMP<26>
jpvar33dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 390 OF 455  ELAPSED TIME = 1
Layer TMP<26> DELETED -- LVHEAP = 4/5/67
TMP<27> = jvarreg NOT jpvar33dio
TMP<27> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 391 OF 455  ELAPSED TIME = 1
Layer jvarreg DELETED -- LVHEAP = 4/5/67
jpvar18dio = VARJUN_mark ENCLOSE TMP<27>
jpvar18dio (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 392 OF 455  ELAPSED TIME = 1
Layer TMP<27> DELETED -- LVHEAP = 4/5/67
mimcap5_rf = mimcap5x AND RFDUM_mark
mimcap5_rf (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 393 OF 455  ELAPSED TIME = 1
Layer mimcap5x DELETED -- LVHEAP = 4/5/67
var18_rf_mos = var18 AND RFDUM_mark
var18_rf_mos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 394 OF 455  ELAPSED TIME = 1
Layer var18 DELETED -- LVHEAP = 4/5/67
var33_rf_mos = var33 AND RFDUM_mark
var33_rf_mos (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 395 OF 455  ELAPSED TIME = 1
Layer var33 DELETED -- LVHEAP = 4/5/67
Layer RFDUM_mark DELETED -- LVHEAP = 4/5/67
metal_ind = tt_ind OR am_ind
metal_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 396 OF 455  ELAPSED TIME = 1
ttind_hole1 = HOLES metal_ind INNER EMPTY
ttind_hole1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 397 OF 455  ELAPSED TIME = 1
ttind_hole2 = SIZE ttind_hole1 BY 3.5 UNDEROVER
ttind_hole2 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 398 OF 455  ELAPSED TIME = 1
Layer ttind_hole1 DELETED -- LVHEAP = 4/5/67
ttind_hole = EXTENTS ttind_hole2
ttind_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 399 OF 455  ELAPSED TIME = 1
Layer ttind_hole2 DELETED -- LVHEAP = 4/5/67
ttind_body = tt_ind INTERACT ttind_hole
ttind_body (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 400 OF 455  ELAPSED TIME = 1
diff_amedge = ANGLE am_ind > 0 < 90
diff_amedge (HIER-PMF TYP=2 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 401 OF 455  ELAPSED TIME = 1
diff_am_ind = am_ind WITH EDGE diff_amedge
diff_am_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 402 OF 455  ELAPSED TIME = 1
Layer diff_amedge DELETED -- LVHEAP = 4/5/67
difnum_touch = tt_ind AND diff_am_ind
difnum_touch (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 403 OF 455  ELAPSED TIME = 1
diff_ind = INDUM_mark ENCLOSE diff_am_ind
diff_ind (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 404 OF 455  ELAPSED TIME = 1
Layer diff_am_ind DELETED -- LVHEAP = 4/5/67
diff_ind_hole = diff_ind AND ttind_hole
diff_ind_hole (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 405 OF 455  ELAPSED TIME = 1
diff_ind_r60 = INT diff_ind_hole < 180 REGION OPPOSITE PARALLEL ONLY
diff_ind_r120 = INT diff_ind_hole > 180 < 250 REGION OPPOSITE PARALLEL ONLY
diff_ind_r60 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r120 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 407 OF 455  ELAPSED TIME = 1
Layer diff_ind_hole DELETED -- LVHEAP = 4/5/67
TMP<32> = metal_ind INTERACT diff_ind_r60
TMP<32> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 408 OF 455  ELAPSED TIME = 1
Layer diff_ind_r60 DELETED -- LVHEAP = 4/5/67
diff_ind_r60n3d5 = TMP<32> INTERACT difnum_touch > 8 < 10
diff_ind_r60n5d5 = TMP<32> INTERACT difnum_touch > 14 < 16
diff_ind_r60n7d5 = TMP<32> INTERACT difnum_touch > 20 < 22
diff_ind_r60n3d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r60n5d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
diff_ind_r60n7d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 411 OF 455  ELAPSED TIME = 1
Layer TMP<32> DELETED -- LVHEAP = 4/5/67
TMP<33> = metal_ind INTERACT diff_ind_r120
TMP<33> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 412 OF 455  ELAPSED TIME = 1
Layer diff_ind_r120 DELETED -- LVHEAP = 4/5/67
diff_ind_r120n3d5 = TMP<33> INTERACT difnum_touch > 8 < 10
diff_ind_r120n3d5 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 413 OF 455  ELAPSED TIME = 1
Layer TMP<33> DELETED -- LVHEAP = 4/5/67
ttind_hole_edge = EXPAND EDGE ttind_hole OUTSIDE BY 1
ttind_hole_edge (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 414 OF 455  ELAPSED TIME = 1
Layer ttind_hole DELETED -- LVHEAP = 4/5/67
diff_ind_w = ttind_hole_edge INTERACT difnum_touch
diff_ind_w (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 415 OF 455  ELAPSED TIME = 1
spri_ind = INDUM_mark NOT diff_ind
spri_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 416 OF 455  ELAPSED TIME = 1
Layer INDUM_mark DELETED -- LVHEAP = 4/5/67
Layer diff_ind DELETED -- LVHEAP = 4/5/67
spri_ind_rec = metal_ind INTERACT spri_ind
spri_ind_rec (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 417 OF 455  ELAPSED TIME = 1
Layer metal_ind DELETED -- LVHEAP = 4/5/67
spri_am_ind = spri_ind AND am_ind
spri_am_ind (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 418 OF 455  ELAPSED TIME = 1
Layer spri_ind DELETED -- LVHEAP = 4/5/67
Layer am_ind DELETED -- LVHEAP = 4/5/67
TMP<34> = spri_am_ind NOT tt_ind
TMP<34> (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 419 OF 455  ELAPSED TIME = 1
ttind_term1 = tt_ind NOT INTERACT ttind_body
ttind_term1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 420 OF 455  ELAPSED TIME = 1
spri_am_spc = TMP<34> NOT INTERACT ttind_term1
spri_am_spc (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 421 OF 455  ELAPSED TIME = 1
Layer TMP<34> DELETED -- LVHEAP = 4/5/67
Layer ttind_term1 DELETED -- LVHEAP = 4/5/67
sprinum_touch = tt_ind AND spri_am_ind
sprinum_touch (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 422 OF 455  ELAPSED TIME = 1
spri_ind_hole_edge = ttind_hole_edge INTERACT sprinum_touch
spri_ind_hole_edge (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 423 OF 455  ELAPSED TIME = 1
spri_ind_edge1 = SIZE spri_ind_hole_edge BY 1
spri_ind_edge1 (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 424 OF 455  ELAPSED TIME = 1
spri_ind_cr = ttind_hole_edge INTERACT spri_ind_edge1
spri_ind_cr (HIER TYP=1 CFG=0 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 425 OF 455  ELAPSED TIME = 1
Layer ttind_hole_edge DELETED -- LVHEAP = 4/5/67
Layer spri_ind_edge1 DELETED -- LVHEAP = 4/5/67
spri_ind_w = spri_ind_cr NOT spri_ind_hole_edge
spri_ind_w (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 426 OF 455  ELAPSED TIME = 1
Layer spri_ind_cr DELETED -- LVHEAP = 4/5/67
Layer spri_ind_hole_edge DELETED -- LVHEAP = 4/5/67
nlthin = ntgate18 OR nsd
nlthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 427 OF 455  ELAPSED TIME = 1
plthin = ptgate18 OR psd
plthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 428 OF 455  ELAPSED TIME = 1
nhthin = ntgate33 OR nsd
nhthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 429 OF 455  ELAPSED TIME = 1
phthin = ptgate33 OR psd
phthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 430 OF 455  ELAPSED TIME = 1
nn18thin = nngate18 OR nsd
nn18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 431 OF 455  ELAPSED TIME = 1
nn33thin = nngate33 OR nsd
nn33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 432 OF 455  ELAPSED TIME = 1
nm18thin = nmgate18 OR nsd
nm18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 433 OF 455  ELAPSED TIME = 1
pm18thin = pmgate18 OR psd
pm18thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 434 OF 455  ELAPSED TIME = 1
nm33thin = nmgate33 OR nsd
nm33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 435 OF 455  ELAPSED TIME = 1
pm33thin = pmgate33 OR psd
pm33thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 436 OF 455  ELAPSED TIME = 1
pdthin = pdgate OR psd
pdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 437 OF 455  ELAPSED TIME = 1
nesdlvthin = esdlvnmos OR nsd
nesdlvthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 438 OF 455  ELAPSED TIME = 1
nesdthin = esdnmos OR nsd
nesdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 439 OF 455  ELAPSED TIME = 1
pesdthin = esdpmos OR psd
pesdthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 440 OF 455  ELAPSED TIME = 1
mn_acessthin = mn_acess OR nsd
mn_acessthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 441 OF 455  ELAPSED TIME = 1
mn_acessgc2thin = mn_acess_gc2 OR nsd
mn_acessgc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 442 OF 455  ELAPSED TIME = 1
mn_acessgc3thin = mn_acess_gc3 OR nsd
mn_acessgc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 443 OF 455  ELAPSED TIME = 1
mn_acesslthin = mn_acess_l OR nsd
mn_acesslthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 444 OF 455  ELAPSED TIME = 1
mn_acesslcthin = mn_acess_lc OR nsd
mn_acesslcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 445 OF 455  ELAPSED TIME = 1
mn_pudnthin = mn_pudn OR nsd
mn_pudnthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 446 OF 455  ELAPSED TIME = 1
mn_pudngc2thin = mn_pudn_gc2 OR nsd
mn_pudngc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 447 OF 455  ELAPSED TIME = 1
mn_pudngc3thin = mn_pudn_gc3 OR nsd
mn_pudngc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 448 OF 455  ELAPSED TIME = 1
mn_pudnlthin = mn_pudn_l OR nsd
mn_pudnlthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 449 OF 455  ELAPSED TIME = 1
mn_pudnlcthin = mn_pudn_lc OR nsd
mn_pudnlcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 450 OF 455  ELAPSED TIME = 1
mp_puupthin = mp_puup OR psd
mp_puupthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 451 OF 455  ELAPSED TIME = 1
mp_puupgc2thin = mp_puup_gc2 OR psd
mp_puupgc2thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 452 OF 455  ELAPSED TIME = 1
mp_puupgc3thin = mp_puup_gc3 OR psd
mp_puupgc3thin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 453 OF 455  ELAPSED TIME = 1
mp_puuplthin = mp_puup_l OR psd
mp_puuplthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 454 OF 455  ELAPSED TIME = 1
mp_puuplcthin = mp_puup_lc OR psd
mp_puuplcthin (HIER TYP=1 CFG=1 HGC=0 FGC=0 HEC=0 FEC=0 IGC=0 VHC=F VPC=F)
CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67  MALLOC = 35/35/35  OPS COMPLETE = 455 OF 455  ELAPSED TIME = 1
DEVICE RECOGNITION TOTAL LAYER PREPARATION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/5/67 ELAPSED TIME = 1
DEVICE RECOGNITION PRECISE INTERACTION BEGINS.
DEVICE RECOGNITION TOTAL PRECISE INTERACTION TIME:  CPU TIME = 0  REAL TIME = 0  LVHEAP = 5/6/67 ELAPSED TIME = 1
TENTATIVE SEED PROMOTIONS:   seed layer  seeds  cell : layers touched
TENTATIVE SEED PROMOTIONS: ------------  -----  -----------------------------------------
SEED PROMOTIONS:
SEED PROMOTIONS: ==============================================================
SEED PROMOTIONS:
SEED PROMOTIONS:
SEED PROMOTIONS:       TOTAL:      0
DEVICE RECOGNITION completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 5/18/67  MALLOC = 47/47/47 ELAPSED TIME = 1
HIERARCHICAL SPICE NETLISTER
HIERARCHICAL SPICE NETLISTER completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/17/67  MALLOC = 47/47/47 ELAPSED TIME = 1
WRITING DEVICE INFORMATION to PHDB svdb
PHDB DEVICE INFORMATION written. CPU TIME = 0  REAL TIME = 0  LVHEAP = 4/17/67  MALLOC = 47/47/47  ELAPSED TIME = 1
Layer ntgate18 DELETED -- LVHEAP = 4/17/67
Layer nlthin DELETED -- LVHEAP = 4/17/67
Layer ptgate18 DELETED -- LVHEAP = 4/17/67
Layer plthin DELETED -- LVHEAP = 4/17/67
Layer ntgate33 DELETED -- LVHEAP = 4/17/67
Layer nhthin DELETED -- LVHEAP = 4/17/67
Layer ptgate33 DELETED -- LVHEAP = 4/17/67
Layer phthin DELETED -- LVHEAP = 4/17/67
Layer nngate18 DELETED -- LVHEAP = 4/17/67
Layer nn18thin DELETED -- LVHEAP = 4/17/67
Layer nngate33 DELETED -- LVHEAP = 4/17/67
Layer nn33thin DELETED -- LVHEAP = 4/17/67
Layer nmgate18 DELETED -- LVHEAP = 4/17/67
Layer nm18thin DELETED -- LVHEAP = 4/17/67
Layer pmgate18 DELETED -- LVHEAP = 4/17/67
Layer pm18thin DELETED -- LVHEAP = 4/17/67
Layer nmgate33 DELETED -- LVHEAP = 4/17/67
Layer nm33thin DELETED -- LVHEAP = 4/17/67
Layer pmgate33 DELETED -- LVHEAP = 4/17/67
Layer pm33thin DELETED -- LVHEAP = 4/17/67
Layer pdgate DELETED -- LVHEAP = 4/17/67
Layer pdthin DELETED -- LVHEAP = 4/17/67
Layer esdlvnmos DELETED -- LVHEAP = 4/17/67
Layer nesdlvthin DELETED -- LVHEAP = 4/17/67
Layer esdnmos DELETED -- LVHEAP = 4/17/67
Layer nesdthin DELETED -- LVHEAP = 4/17/67
Layer esdpmos DELETED -- LVHEAP = 4/17/67
Layer pesdthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess DELETED -- LVHEAP = 4/17/67
Layer mn_acessthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_gc2 DELETED -- LVHEAP = 4/17/67
Layer mn_acessgc2thin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_gc3 DELETED -- LVHEAP = 4/17/67
Layer mn_acessgc3thin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_l DELETED -- LVHEAP = 4/17/67
Layer mn_acesslthin DELETED -- LVHEAP = 4/17/67
Layer mn_acess_lc DELETED -- LVHEAP = 4/17/67
Layer mn_acesslcthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn DELETED -- LVHEAP = 4/17/67
Layer mn_pudnthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_gc2 DELETED -- LVHEAP = 4/17/67
Layer mn_pudngc2thin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_gc3 DELETED -- LVHEAP = 4/17/67
Layer mn_pudngc3thin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_l DELETED -- LVHEAP = 4/17/67
Layer mn_pudnlthin DELETED -- LVHEAP = 4/17/67
Layer mn_pudn_lc DELETED -- LVHEAP = 4/17/67
Layer mn_pudnlcthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup DELETED -- LVHEAP = 4/17/67
Layer mp_puupthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_gc2 DELETED -- LVHEAP = 4/17/67
Layer mp_puupgc2thin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_gc3 DELETED -- LVHEAP = 4/17/67
Layer mp_puupgc3thin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_l DELETED -- LVHEAP = 4/17/67
Layer mp_puuplthin DELETED -- LVHEAP = 4/17/67
Layer mp_puup_lc DELETED -- LVHEAP = 4/17/67
Layer mp_puuplcthin DELETED -- LVHEAP = 4/17/67
Layer var18_mix DELETED -- LVHEAP = 4/17/67
Layer var18a DELETED -- LVHEAP = 4/17/67
Layer var33_mix DELETED -- LVHEAP = 4/17/67
Layer var33a DELETED -- LVHEAP = 4/17/67
Layer ngate18_rf DELETED -- LVHEAP = 4/17/67
Layer ngate18a DELETED -- LVHEAP = 4/17/67
Layer pgate18_rf DELETED -- LVHEAP = 4/17/67
Layer pgate18a DELETED -- LVHEAP = 4/17/67
Layer ngate33_rf DELETED -- LVHEAP = 4/17/67
Layer ngate33a DELETED -- LVHEAP = 4/17/67
Layer pgate33_rf DELETED -- LVHEAP = 4/17/67
Layer pgate33a DELETED -- LVHEAP = 4/17/67
Layer var18_rf_rec DELETED -- LVHEAP = 4/17/67
Layer var18_rf_gt DELETED -- LVHEAP = 4/17/67
Layer var18_rf_to DELETED -- LVHEAP = 4/17/67
Layer var18_rf_mos DELETED -- LVHEAP = 4/17/67
Layer var33_rf_rec DELETED -- LVHEAP = 4/17/67
Layer var33_rf_gt DELETED -- LVHEAP = 4/17/67
Layer var33_rf_to DELETED -- LVHEAP = 4/17/67
Layer var33_rf_mos DELETED -- LVHEAP = 4/17/67
Layer v1Rec DELETED -- LVHEAP = 4/17/67
Layer v2Rec DELETED -- LVHEAP = 4/17/67
Layer v3Rec DELETED -- LVHEAP = 4/17/67
Layer p1Rec DELETED -- LVHEAP = 4/17/67
Layer p2Rec DELETED -- LVHEAP = 4/17/67
Layer p3Rec DELETED -- LVHEAP = 4/17/67
Layer n1Rec DELETED -- LVHEAP = 4/17/67
Layer n2Rec DELETED -- LVHEAP = 4/17/67
Layer n3Rec DELETED -- LVHEAP = 4/17/67
Layer n4Rec DELETED -- LVHEAP = 4/17/67
Layer h1Rec DELETED -- LVHEAP = 4/17/67
Layer h2Rec DELETED -- LVHEAP = 4/17/67
Layer h3Rec DELETED -- LVHEAP = 4/17/67
Layer h4Rec DELETED -- LVHEAP = 4/17/67
Layer dnpwesd DELETED -- LVHEAP = 4/17/67
Layer dpnw33 DELETED -- LVHEAP = 4/17/67
Layer dpnw18 DELETED -- LVHEAP = 4/17/67
Layer dnpw33 DELETED -- LVHEAP = 4/17/67
Layer dnpw18 DELETED -- LVHEAP = 4/17/67
Layer dnwpw33 DELETED -- LVHEAP = 4/17/67
Layer dnwpw18 DELETED -- LVHEAP = 4/17/67
Layer ddnwpw DELETED -- LVHEAP = 4/17/67
Layer m1_res DELETED -- LVHEAP = 4/17/67
Layer a1_conn DELETED -- LVHEAP = 4/17/67
Layer m2_res DELETED -- LVHEAP = 4/17/67
Layer a2_conn DELETED -- LVHEAP = 4/17/67
Layer m3_res DELETED -- LVHEAP = 4/17/67
Layer a3_conn DELETED -- LVHEAP = 4/17/67
Layer rnw_rec_2t DELETED -- LVHEAP = 4/17/67
Layer rnw_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rnimp_2t DELETED -- LVHEAP = 4/17/67
Layer rpimp_2t DELETED -- LVHEAP = 4/17/67
Layer rnimp_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rpimp_sab_2t DELETED -- LVHEAP = 4/17/67
Layer rnpoly_sab DELETED -- LVHEAP = 4/17/67
Layer rnpoly DELETED -- LVHEAP = 4/17/67
Layer rppoly_sab DELETED -- LVHEAP = 4/17/67
Layer rppoly DELETED -- LVHEAP = 4/17/67
Layer hrpoly DELETED -- LVHEAP = 4/17/67
Layer rnw_rec_3t DELETED -- LVHEAP = 4/17/67
Layer rnw_sab_3t DELETED -- LVHEAP = 4/17/67
Layer rnimp_3t DELETED -- LVHEAP = 4/17/67
Layer rpimp_3t DELETED -- LVHEAP = 4/17/67
Layer rnimp_sab_3t DELETED -- LVHEAP = 4/17/67
Layer rpimp_sab_3t DELETED -- LVHEAP = 4/17/67
Layer tt_res DELETED -- LVHEAP = 4/17/67
Layer m5_res DELETED -- LVHEAP = 4/17/67
Layer m4_res DELETED -- LVHEAP = 4/17/67
Layer a4_conn DELETED -- LVHEAP = 4/17/67
Layer mimcap5 DELETED -- LVHEAP = 4/17/67
Layer jpvar18dio DELETED -- LVHEAP = 4/17/67
Layer jpvar33dio DELETED -- LVHEAP = 4/17/67
Layer rnisab_rf DELETED -- LVHEAP = 4/17/67
Layer rnpsab_rf DELETED -- LVHEAP = 4/17/67
Layer rppsab_rf DELETED -- LVHEAP = 4/17/67
Layer rppoly_rf DELETED -- LVHEAP = 4/17/67
Layer hrpoly_rf DELETED -- LVHEAP = 4/17/67
Layer gt_conn DELETED -- LVHEAP = 4/17/67
Layer spri_ind_rec DELETED -- LVHEAP = 4/17/67
Layer tt_ind DELETED -- LVHEAP = 4/17/67
Layer spri_ind_w DELETED -- LVHEAP = 4/17/67
Layer sprinum_touch DELETED -- LVHEAP = 4/17/67
Layer spri_am_ind DELETED -- LVHEAP = 4/17/67
Layer ttind_body DELETED -- LVHEAP = 4/17/67
Layer spri_am_spc DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n3d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n5d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r60n7d5 DELETED -- LVHEAP = 4/17/67
Layer diff_ind_r120n3d5 DELETED -- LVHEAP = 4/17/67
Layer tt_conn DELETED -- LVHEAP = 4/17/67
Layer diff_ind_w DELETED -- LVHEAP = 4/17/67
Layer difnum_touch DELETED -- LVHEAP = 4/17/67
Layer mimcap5_rf DELETED -- LVHEAP = 4/17/67
Layer mctcap DELETED -- LVHEAP = 4/17/67
Layer a5_conn DELETED -- LVHEAP = 4/17/67
WRITING PHDB to directory svdb
PHDB WRITE completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/17/67  MALLOC = 48/48/48  ELAPSED TIME = 1
Layer ntap DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_s_con DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_s DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_d_con DELETED -- LVHEAP = 3/17/67
Layer nmos_rf_d DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_s_con DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_s DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_d_con DELETED -- LVHEAP = 3/17/67
Layer pmos_rf_d DELETED -- LVHEAP = 3/17/67
Layer ptap DELETED -- LVHEAP = 3/17/67
Layer psub DELETED -- LVHEAP = 3/17/67
Layer dn_tbtap DELETED -- LVHEAP = 3/17/67
Layer dn_nw DELETED -- LVHEAP = 3/17/67
Layer qvp33B_con DELETED -- LVHEAP = 3/17/67
Layer qvp33_b DELETED -- LVHEAP = 3/17/67
Layer qvp18B_con DELETED -- LVHEAP = 3/17/67
Layer qvp18_b DELETED -- LVHEAP = 3/17/67
Layer qvp33E_con DELETED -- LVHEAP = 3/17/67
Layer qvp33_e DELETED -- LVHEAP = 3/17/67
Layer qvp18E_con DELETED -- LVHEAP = 3/17/67
Layer psd DELETED -- LVHEAP = 3/17/67
Layer qvp18_e DELETED -- LVHEAP = 3/17/67
Layer vnpnE_con DELETED -- LVHEAP = 3/17/67
Layer nsd DELETED -- LVHEAP = 3/17/67
Layer vnpn_e DELETED -- LVHEAP = 3/17/67
Layer nwResTerm_con DELETED -- LVHEAP = 3/17/67
Layer nwellRes_term DELETED -- LVHEAP = 3/17/67
Layer rnwsabTerm_con DELETED -- LVHEAP = 3/17/67
Layer nwelcon DELETED -- LVHEAP = 3/17/67
Layer rnw_sab_term DELETED -- LVHEAP = 3/17/67
--- CALIBRE::HIERARCHICAL CIRCUIT EXTRACTOR COMPLETED - Sun May 13 10:05:34 2018
--- TOTAL CPU TIME = 0  REAL TIME = 0  LVHEAP = 3/17/67  MALLOC = 48/48/48  ELAPSED TIME = 1
--- PROCESSOR COUNT = 1
--- SPICE NETLIST FILE = /home/jshi/csmc18/lvs/cmim_test.sp
--- CIRCUIT EXTRACTION REPORT FILE = cmim_test.lvs.report.ext
--- PERSISTENT HIERARCHICAL DATABASE(PHDB) = svdb/cmim_test.phdb
--- QUERY DATABASE = svdb  TOP CELL = cmim_test
--- CALIBRE:VS-H - Sun May 13 10:05:34 2018
-----               CALIBRE:VS/xRC - INITIALIZATION MODULE               -----
Performing global initialization ...
Initializing LVS ...
--- CALIBRE:VS/xRC INITIALIZATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 50/50/50  ELAPSED TIME = 1
-----                 CALIBRE::LVS/xRC - EXECUTIVE MODULE                  -----
LVS started ...
//  Applying licensing policy...
//  Licensed Products
//  Base products running on 1 core:
//  - LVS (Hierarchical)
READING layout ...
Layout READ.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 50/50/50
READING source ...
Source READ.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 67/81/81  MALLOC = 50/50/50
Identifying CORRESPONDING cells ...
      ERROR:  Nothing in layout.
Writing REPORT ...
REPORT written.  CPU TIME = 0  REAL TIME = 0
Cumulative READING INPUTS Time:                          CPU =       0,     REAL =       0
Cumulative IDENTIFYING CORRESPONDING CELLS Time:         CPU =       0,     REAL =       0
    Cumulative CHECKING PORTS Time:                      CPU =       0,     REAL =       0
Cumulative REALLOCATING PINS Time:                       CPU =       0,     REAL =       0
Cumulative WRITING XDB HIERARCHY Time:                   CPU =       0,     REAL =       0
Cumulative ADDING GLOBALS Time:                          CPU =       0,     REAL =       0
Cumulative RESOLVING DEEP SHORTS Time:                   CPU =       0,     REAL =       0
Cumulative RESOLVING HIGH SHORTS Time:                   CPU =       0,     REAL =       0
Cumulative DELETING TRIVIAL PINS Time:                   CPU =       0,     REAL =       0
Cumulative EXPANDING UNBALANCED CELLS Time:              CPU =       0,     REAL =       0
Cumulative TRANSFORMS AND FLATTENING Time:               CPU =       0,     REAL =       0
    Cumulative FLATTENING Time:                          CPU =       0,     REAL =       0
    Cumulative TRANSFORMS Time:                          CPU =       0,     REAL =       0
        Cumulative INJECTION Time:                       CPU =       0,     REAL =       0
            Cumulative COMPACTION Time:                  CPU =       0,     REAL =       0
        Cumulative REDUCTION Time:                       CPU =       0,     REAL =       0
        Cumulative GATES Time:                           CPU =       0,     REAL =       0
        Cumulative UNUSED Time:                          CPU =       0,     REAL =       0
Cumulative COMPARISON Time:                              CPU =       0,     REAL =       0
    Cumulative MERGE PRIMITIVE TEMPLATES Time:           CPU =       0,     REAL =       0
    Cumulative MERGE SUBGRAPH TEMPLATES Time:            CPU =       0,     REAL =       0
    Cumulative NBD AND AMBIGUITY Time:                   CPU =       0,     REAL =       0
        Cumulative NBD Time:                             CPU =       0,     REAL =       0
            Cumulative INITIAL NBD IDS Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD CONVERT Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD BACK CONVERT Time:        CPU =       0,     REAL =       0
            Cumulative NEW NBD ALG RUN Time:             CPU =       0,     REAL =       0
            Cumulative NEW NBD IDS Time:                 CPU =       0,     REAL =       0
            Cumulative MATCH NBD NODES Time:             CPU =       0,     REAL =       0
        Cumulative TPL Time:                             CPU =       0,     REAL =       0
        Cumulative BIN Time:                             CPU =       0,     REAL =       0
        Cumulative PRP Time:                             CPU =       0,     REAL =       0
        Cumulative AMBIGUITY Time:                       CPU =       0,     REAL =       0
            Cumulative AMBIGUITY BY PROPERTIES Time:     CPU =       0,     REAL =       0
            Cumulative AMBIGUITY BY SUBTYPES Time:       CPU =       0,     REAL =       0
            Cumulative AMBIGUITY HIERARCHICAL Time:      CPU =       0,     REAL =       0
            Cumulative AMBIGUITY ARBITRARY Time:         CPU =       0,     REAL =       0
    Cumulative REWIRE Time:                              CPU =       0,     REAL =       0
    Cumulative REPAIR Time:                              CPU =       0,     REAL =       0
Cumulative REPORT Time:                                  CPU =       0,     REAL =       0
LVS completed. NOT COMPARED. See report file: cmim_test.lvs.report
LVS completed.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 66/81/81  MALLOC = 51/51/51  ELAPSED TIME = 1
ERROR: Corresponding cells could not be identified.
*** Calibre finished with Exit Code: 4
以上为lvs  report
发表于 2018-5-13 13:59:25 | 显示全部楼层
回复 4# shijunhn
注意layout中, 没有画A5图形:
    A5                       0 (0)                            0 (0)
而在calibre code中有:
    mimcap5x = mct5 AND A5_drc
     因此,mimcap5x没有被提取出来。
可能原因: lvs code中有#DEFINE  metal5_process或者metal4_process, 你需要选择正确的metal option.
或者你画的layer少了metal5的图形。
发表于 2019-4-29 11:41:06 | 显示全部楼层
我csmc018也碰到了同样的问题,cmimLVS时版图提取不出,请问楼主解决了吗
发表于 2020-4-13 21:11:11 | 显示全部楼层
前辈们,方便分享一下CSMC.18的pdk吗    qq739779410
发表于 2020-4-13 23:04:27 | 显示全部楼层
有没有画Mark layer?
发表于 2022-4-18 04:26:54 | 显示全部楼层
前辈们,方便分享一下CSMC.18的pdk吗    qq1361035985
GMT+8, 2025-12-30 10:56 , Processed in 0.084500 second(s), 4 queries , Gzip On, Redis On.
