查看: 2262|回复: 2
这个程序编译有个警告!!!大家来帮一下!!谢谢
发表于 2007-8-30 16:34:52 | 显示全部楼层 |阅读模式
这个是8位移位运算器程序,在Quartus 11下运行,编译时有个警告,我不会改,请大家来帮我,谢谢各位了!!
发表于 2007-8-30 16:47:37 | 显示全部楼层
......................耍人玩呢?:)
 楼主| 发表于 2007-8-31 13:57:22 | 显示全部楼层
是这个程序!!!!!!!
Library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
ENTITY SHIFTER IS
PORT(CLK,M,C0:IN STD_LOGIC;
   S : IN    STD_LOGIC_VECTOR(1 DOWNTO 0);
   D : IN    STD_LOGIC_VECTOR(7 DOWNTO 0);
   QB: OUT   STD_LOGIC_VECTOR(7 DOWNTO 0);
   CN: OUT   STD_LOGIC);
END ENTITY;
ARCHITECTURE BEHAV OF SHIFTER IS
   SIGNAL ABC : STD_LOGIC_VECTOR(2 DOWNTO 0);
   SIGNAL REG : STD_LOGIC_VECTOR(7 DOWNTO 0);
   SIGNAL  CY : STD_LOGIC;
BEGIN
PROCESS(CLK,ABC,C0)
BEGIN
IF CLK'EVENT AND CLK = '1' THEN
CASE ABC IS
WHEN "011" =>REG(0)<= C0; REG(7 DOWNTO 1)<= REG (6 DOWNTO 0);
      CY <=REG(7);
WHEN "010" =>REG(0)<=REG(7); REG(7 DOWNTO 1)<=REG(6 DOWNTO 0);
WHEN "100" =>REG(7)<=REG(0); REG(6 DOWNTO 0)<=REG(7 DOWNTO 1);
WHEN "101" =>REG(7)<= C0 ; REG(6 DOWNTO 0) <= REG(7 DOWNTO 1);
      CY <= REG(0);
WHEN "110" =>REG(7 DOWNTO 0) <= D(7 DOWNTO 0);
WHEN "111" =>REG(7 DOWNTO 0) <= D(7 DOWNTO 0);
WHEN OTHERS => REG <= REG ; CY <= CY;
END CASE;
END IF;
END PROCESS;
ABC <= S & M; QB(7 DOWNTO 0)<= REG(7 DOWNTO 0);CN<=CY;
END BEHAV;
GMT+8, 2025-12-29 00:01 , Processed in 0.030886 second(s), 6 queries , Gzip On, Redis On.
