查看: 32420|回复: 107
热点材料:模拟电路中的数字calibration
发表于 2007-7-12 20:27:32 | 显示全部楼层 |阅读模式
一些经典的方法和技术。
abbr_421f2afd5a2452e28b26f66518c8877f.rar
1 MB, 下载次数: 320 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_776f6ac0e4c6d420dddd69d5133c4a6f.rar
950.03 KB, 下载次数: 289 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-7-12 20:53:58 | 显示全部楼层
kankan
发表于 2007-7-12 21:23:28 | 显示全部楼层
kankan
发表于 2007-7-13 09:08:56 | 显示全部楼层
发表于 2007-7-13 09:10:44 | 显示全部楼层
what is the content of your material?
发表于 2007-7-13 09:10:48 | 显示全部楼层
 楼主| 发表于 2007-7-13 19:31:54 | 显示全部楼层
内容简介:
Methodology for the Digital Calibration of Analog Circuits and Systems: with Case Studies
Book Description
Methodology for the Digital Calibration of Analog Circuits and Systems shows how to relax the extreme design constraints in analog circuits, allowing the realization of high-precision systems even with low-performance components. A complete methodology is proposed, and three applications are detailed.
To start with, an in-depth analysis of existing compensation techniques for analog circuit imperfections is carried out. The M/2+M sub-binary digital-to-analog converter is thoroughly studied, and the use of this very low-area circuit in conjunction with a successive approximations algorithm for digital compensation is described. A complete methodology based on this compensation circuit and algorithm is then proposed. The detection and correction of analog circuit imperfections is studied, and a simulation tool allowing the transparent simulation of analog circuits with automatic compensation blocks is introduced.
The first application shows how the sub-binary M/2+M structure can be employed as a conventional digital-to-analog converter if two calibration and radix conversion algorithms are implemented.
The second application, a SOI 1T DRAM, is then presented. A digital algorithm chooses a suitable reference value that compensates several circuit imperfections together, from the sense amplifier offset to the dispersion of the memory read currents.
The third application is the calibration of the sensitivity of a current measurement microsystem based on a Hall magnetic field sensor. Using a variant of the chopper modulation, the spinning current technique, combined with a second modulation of a reference signal, the sensitivity of the complete system is continuously measured without interrupting normal operation. A thermal drift lower than 50 ppm/°C is achieved, which is 6 to 10 times less than in state-of-the-art implementations. Furthermore, the calibration technique also compensates drifts due to mechanical stresses and ageing.
发表于 2007-7-13 19:55:37 | 显示全部楼层
这是身啊啊 啊啊啊啊 什么啊 大家说一说啊
发表于 2007-7-14 02:02:16 | 显示全部楼层
ooo, finally i can open it, thanks..
[ 本帖最后由 bonyou 于 2007-7-14 02:04 编辑 ]
发表于 2007-7-14 16:08:21 | 显示全部楼层
very good!!!!!!!!!
GMT+8, 2025-12-14 12:09 , Processed in 0.026468 second(s), 7 queries , Gzip On, Redis On.
