查看: 9901|回复: 16
[求助] 请教下,nlint和verdi VCS软件的license环境变量如何配置?
发表于 2018-4-9 20:22:07 | 显示全部楼层 |阅读模式
nlint应该是配合verdi使用的吧 ? 但二者分别都有license,这二者的软件路径和license路径如何配置,才可能保证二者 正常的配合运行 ?
发表于 2018-4-11 09:50:44 | 显示全部楼层
nLint可以單獨使用, 也可以跟Verdi搭配使用. License跟$PATH設置沒有特別的設定方式, 兩者互相不干擾
 楼主| 发表于 2018-4-11 11:33:41 | 显示全部楼层
回复 2# hyperpicc
    你好,能帮忙弄下吗,我现在 是按论坛里的资料为 verdi vcs只生成了一个license1,nlint生成了第二个license2,
让把license1拷贝到license2的前面,得到了license3, 现在等于是 nlint  verdi vcs三者都用license3,首先启动verdi,就有问题
[username_1@simu_host1 Desktop]$ verdi
logDir = /home/username_1/Desktop/verdiLog
Verdi Release Verdi3_I-2014.03 (RH Linux x86_64/64bit) 02/11/2014
(C) 1999 - 2014 by Synopsys, Inc.
All Rights Reserved.
www.synopsys.com
This program is proprietary and confidential information of Synopsys, Inc. and
may be used and disclosed only as authorized in a license agreement controlling
such use and disclosure.
Licensed Products communicate with Synopsys servers for the purpose of providing
software updates, detecting software piracy and verifying that customers are
using Licensed Products in conformity with the applicable License Key for such
Licensed Products. Synopsys will use information gathered in connection with
this process to deliver software updates and pursue software pirates and
infringers.
rcfile = /EDA/Verdi3/etc/novas.rc
guiConfFile = /home/username_1/novas.conf
Could not checkout Verdi license. Use Verdi -licdebug for more information.
 楼主| 发表于 2018-4-11 12:44:55 | 显示全部楼层
回复 2# hyperpicc
请教下,我看环境变量里的设置,nlint的license 是用的export LM_LICENSE_FILE=$SNS_HOME/nlint.dat;
而verdi  vcs用的也是 export LM_LICENSE_FILE=/usr/synopsys/license/synopsys.dat
环境变量都用  LM_LICENSE_FILE,   这样 这三软件 找license是不是会冲突啊 ?
 楼主| 发表于 2018-4-11 14:42:47 | 显示全部楼层
这句export SNPSLMD_LICENSE_FILE=27000@localhost 中,
前面的 SNPSLMD_LICENSE_FILE这是什么意思?
 楼主| 发表于 2018-4-11 23:21:17 | 显示全部楼层
环境变量里的 LM_LICENSE_FILE, SNPSLMD_LICENSE_FILE 都是固定 的  ?
发表于 2018-4-12 01:15:46 | 显示全部楼层
回复 3# american007
由於VCS, nLint, Verdi現在都是屬於$ynop$y$的軟件. $ynop$y$也提供了SCL作為License管理.
我採用的做法是將這些屬於$ynop$y$的軟件features都整合在一個license裡面. 如此只需要啟動一個license即可
发表于 2018-4-12 01:17:18 | 显示全部楼层
回复 4# american007
建議用LM_LICENSE_FILE=LM_LICENSE_FILE:<你的license>
用LM_LICENSE_FILE=<你的license>會覆蓋掉面的環境變量設定
发表于 2018-4-12 01:20:27 | 显示全部楼层
回复 5# american007
SNPSLMD_LICENSE_FILE基本相同於LM_LICENSE_FILE.
$ynop$y$的license管理工具去找license的時候, 會先找$SNPSLMD_LICENSE_FILE再找$LM_LICENSE_FILE.
(題外話, C@dence的license變量則有CDS_LIC_FILE)
发表于 2018-4-12 01:24:07 | 显示全部楼层
回复 6# american007
這是license管理者必須設定的.
1. 假如license server與軟件放在不同一台(基本上公司裡都是這種配置), 那麼就使用LM_LICENSE_FILE=<port>@<hostname>
2. 假如license server與軟件都是在同一台. 那麼可以使用LM_LICENSE_FILE=<路徑>的方式.
GMT+8, 2025-12-19 08:01 , Processed in 0.018608 second(s), 3 queries , Gzip On, Redis On.
